    4. Test js-controller v2.0.x (GitHub)
      apollon77 @MathiasJ last edited by
      @MathiasJ Er ist dran. Das eine File manuell abzupassen tut vorher und nachher!
      • coyote
        coyote Most Active last edited by
        @apollon77 kannst du mir vllt da weiterhelfen? Habe diese "node-hue-api" gerade nochmal neu in die javascript instanz hinzugefügt, dann kommt folgendes:
        host.debian	2019-10-10 22:53:54.042	info	instance system.adapter.javascript.0 terminated with code 156 (156)
        host.debian	2019-10-10 22:53:54.042	error	Caught by controller[9]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
        host.debian	2019-10-10 22:53:54.042	error	Caught by controller[8]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
        host.debian	2019-10-10 22:53:54.042	error	Caught by controller[8]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
        host.debian	2019-10-10 22:53:54.042	error	Caught by controller[7]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[6]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[6]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[5]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[4]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[4]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[3]: (node:20588) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proc
        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[2]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[1]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: ********************************************************************************
        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: Please consult the documentation at https://github.com/peter-murray/node-hue-api for the documentation on the new API.
        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: require("node-hue-api").v3
        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: You need to migrate your code to use the new API available via import
        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: This will be removed in v4.x of node-hue-api.
        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: This shim provides a limited backporting of the features available in the updated API in v3.x.
        host.debian	2019-10-10 22:53:54.039	error	Caught by controller[0]: Backwards compatibility shim for node-hue-api.
        host.debian	2019-10-10 22:53:54.035	error	Caught by controller[0]: ********************************************************************************
        javascript.0	2019-10-10 22:53:52.981	info	(20588) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        javascript.0	2019-10-10 22:53:52.432	info	(20588) Got terminate signal TERMINATE_YOURSELF
        Vorher hatte das ohne Probleme funktioniert
          apollon77 @coyote last edited by
          @coyote sagte in [Aufruf] js-controller 2.0 Beta Test:
          192.168.66.31:443
          Also einmal 192.168.66.31:443 ECONREFUSED heist Connection Refused. DU kannst dich da nicht hin verbinden oder sowas. Da sist aber jetzt 100% Offtopic hier
          • coyote
            coyote Most Active @apollon77 last edited by coyote
            @apollon77 ja das ist mir eigentlich schon klar, die HueBridge ist aber erreichbar, also eigentlich kann es da nicht dran liegen und der Fehler kam ja erst als ich den node-hue-api in der Javascript Instanz nochmal hinzugefügt hab, deshalb dachte ich es könnte was mit dem js-controller zu tun haben, da es vorher ohne Probleme lief.
            Es geht mir eher um die unteren Zeilen
              @coyote Docker? Netzwerk? Firewall? SOwas vllt? Kannst Du von dem ioBroker Host die seite mit curl oder so erreichen? Owas ... aber anderer Thread Bitte!
              • coyote
                @apollon77 weder noch und ja ich kann auch über die iobroker objekte von hue, direkt meine lampen schalten, also ist die Bridge ja erreichbar. Hat damit nichts zu tun. Mir geht es nur um diese node-hue-api, das funktioniert nicht mehr. Gestern mit der 2.0.24 ging das ja noch ohne Probleme, sonst noch ne Idee?
                  @coyote keine ohne jetzt tief rein zu schauen. Die Änderungen 24->25 sind diesbezüglich auch an sich irrelevant.
                  • coyote
                    @apollon77 hm ok, naja könnte auch schon vorher ein Problem gewesen sein und ich hab es nicht gemerkt, erst als ich heute die Objekte neu synchronisieren wollte. Naja, dann weiß ich es momentan erst auch mal nicht, muss ich weiter suchen. Keine Ahnung was er jetzt für ein Problem mit dem node-hue-api hat, da bin ich nicht tief genug drin in der Materie.
                    • coyote
                      @apollon77 falls du irgendwann Zeit hast kannst du vllt mal kurz in die Log Datei schauen. Habe gerade die Javascript Instanz auf 4.3.0 upgedatet und Fehler im Log, weiß aber jetzt nicht, ob das mit dem js-controller zusammenhängt. Wenn nicht mach ich nen neuen Beitrag dazu.
                      Hier:Log.txt
                        @coyote der eine teil mir Write permissives ist mal wieder npm beim Paket Update wegen irgendwelchen rechten. Am besten install fiyer laufen lassen um sowas zu fixen.
                        Ansonsten
                        1. TypeError: Cannot read property 'Tail' of undefined
                        Ist ggf folgefehler weil die tail library nicht installiert wurde korrekt.
                        Also beides nicht Controller. Fixe die permission Fehler dann weiterschauen
                          apollon77 last edited by apollon77
                          So, ich mache hier heute Abend zu. Weiter geht es --> https://forum.iobroker.net/topic/25692/js-controller-2-0-ab-sofort-im-latest-repo
                          Ich bedanke mich bei Euch allen für die Super Zusammenarbeit. Zusammen haben wir glaube ich eine super getestete Version für "die Allgemeinheit" bekommen die jetzt, falls noch was drin ist, im Latest Repo final "reifen" kann 🙂
                          Ich melde mich um Weihnachten rum dann zur 2.1 wieder 😉
                            A Former User @Guest last edited by
                            @Nuggelbeb
                            Alles iO!!!
                            SUPER
                              Hallo nochmals,
                              Falls jemand noch Zeit und Lust hat. Auf Github ist die 2.0.26 mit den Kleinigkeiten die aufgefallen sind. Release im Latest geplant für heute abend/morgen.
                              Installation wie bisher hier üblich direkt per npm.
                              2.0.26 Release Bella
                              • (Apollon77) Make sure Logs are only streamed to admin for selected loglevel
                              • (Apollon77) Fix "iobroker file write"
                              • (Apollon77) Make sure invalid ids are handled correctly without throwing errors
                              • (bluefox) Add alias.0 as object to be added
                              • (bluefox) Allow Arrays as state values
                              • (bluefox) Translate object names
                                sigi234 Forum Testing Most Active @apollon77 last edited by
                                @apollon77
                                Screenshot (258).png 😀
                                  darkiop Most Active last edited by
                                  Habs eben installiert und check heut Abend wann wir wieder zuhause sind das Log 🙂
                                    liv-in-sky last edited by
                                    js-controller 2.0.25 startet - bisher keine fehler
                                    • BBTown
                                      BBTown last edited by
                                      @apollon77 hast Du gleich noch eine v2.0.27 nachgeschoben?
                                        Ja und gerade noch 2.0.28. sind jetzt bei den echten Edge cases angelangt 😉
                                        L E 2 Replies Last reply Reply Quote 0
                                        • BBTown
                                          @apollon77
                                          Respekt ... Privatleben wird auch total überschätzt 😎
                                            @apollon77 also dann hier nochmal wegen dem log
                                            da ja vorher diverse Adapter nicht mit der entsprechenden Logstufe funktionierten, habe ich nun mal bei sämtlichen Adaptern, die auf warn/error standen wieder auf Info gestellt.
                                            Betroffen waren der Web, Chromcast, virtualpowermeter, die das log "zugemüllt" hatten
                                            desweiteren, wurde z.b beim virtualpowermeter in der .25 Version trotz ändern der logstufe das log zugemüllt.
                                            in der .28 stehen nun bei mir alle Adapter auf Logstufe Info und log verhält sich sehr, sehr ruhig,
                                            fast nur noch Meldungen, wenn z.b. Adapter per cron aktualisieren
                                            js-controller
                                            48
                                            1047
                                            311782
