    4. Node.js: Cannot find module
      Communicate last edited by
      es kam spontan und danach habe ich dann per iobroker upgrade alles aktualisiert.
      So sieht das Log aus:
      raspberrypi 2015-09-28 20:47:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:47:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:47:04 info host.raspberrypi instance system.adapter.admin.1 started with pid 9292
      raspberrypi 2015-09-28 20:46:34 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:46:34 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:46:29 info host.raspberrypi instance system.adapter.admin.1 started with pid 9291
      raspberrypi 2015-09-28 20:45:59 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:45:59 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:45:55 info host.raspberrypi instance system.adapter.admin.1 started with pid 9290
      raspberrypi 2015-09-28 20:45:25 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:45:25 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:45:19 info host.raspberrypi instance system.adapter.admin.1 started with pid 9289
      raspberrypi 2015-09-28 20:44:49 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:44:49 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:44:39 info host.raspberrypi instance system.adapter.admin.1 started with pid 9288
      raspberrypi 2015-09-28 20:44:09 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:44:09 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:44:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:44:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:44:01 info host.raspberrypi instance system.adapter.admin.1 started with pid 9287
      raspberrypi 2015-09-28 20:43:31 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:43:31 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:43:26 info host.raspberrypi instance system.adapter.admin.1 started with pid 9286
      raspberrypi 2015-09-28 20:42:56 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:42:56 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:42:46 info host.raspberrypi instance system.adapter.admin.1 started with pid 9285
      raspberrypi 2015-09-28 20:42:16 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:42:16 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:42:06 info host.raspberrypi instance system.adapter.admin.1 started with pid 9284
      raspberrypi 2015-09-28 20:41:36 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:41:36 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:41:28 info host.raspberrypi instance system.adapter.admin.1 started with pid 9283
      raspberrypi 2015-09-28 20:40:58 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:40:58 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:40:52 info host.raspberrypi instance system.adapter.admin.1 started with pid 9282
      raspberrypi 2015-09-28 20:40:22 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:40:22 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:40:15 info host.raspberrypi instance system.adapter.admin.1 started with pid 9281
      raspberrypi 2015-09-28 20:40:14 info host.raspberrypi instance system.adapter.admin.1 started with pid 9281
      raspberrypi 2015-09-28 20:39:45 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:39:45 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:39:44 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:39:44 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:39:36 info host.raspberrypi instance system.adapter.admin.1 started with pid 9280
      raspberrypi 2015-09-28 20:39:06 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:39:06 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:38:58 info host.raspberrypi instance system.adapter.admin.1 started with pid 9279
      raspberrypi 2015-09-28 20:38:28 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:38:28 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:38:21 info host.raspberrypi instance system.adapter.admin.1 started with pid 9278
      raspberrypi 2015-09-28 20:38:20 info host.raspberrypi instance system.adapter.admin.1 started with pid 9278
      raspberrypi 2015-09-28 20:37:50 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:37:50 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:37:38 info host.raspberrypi instance system.adapter.admin.1 started with pid 9277
      raspberrypi 2015-09-28 20:37:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:37:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:37:02 info host.raspberrypi instance system.adapter.admin.1 started with pid 9276
      raspberrypi 2015-09-28 20:36:32 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:36:32 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:36:27 info host.raspberrypi instance system.adapter.admin.1 started with pid 9275
      raspberrypi 2015-09-28 20:35:58 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:35:58 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:35:57 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:35:57 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:35:50 info host.raspberrypi instance system.adapter.admin.1 started with pid 9274
      raspberrypi 2015-09-28 20:35:20 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:35:20 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:35:09 info host.raspberrypi instance system.adapter.admin.1 started with pid 9273
      raspberrypi 2015-09-28 20:34:39 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:34:39 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:34:33 info host.raspberrypi instance system.adapter.admin.1 started with pid 9272
      raspberrypi 2015-09-28 20:34:03 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:34:03 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:33:57 info host.raspberrypi instance system.adapter.admin.1 started with pid 9271
      raspberrypi 2015-09-28 20:33:27 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:33:27 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:33:15 info host.raspberrypi instance system.adapter.admin.1 started with pid 9270
      raspberrypi 2015-09-28 20:32:45 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:32:45 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:32:32 info host.raspberrypi instance system.adapter.admin.1 started with pid 9269
      raspberrypi 2015-09-28 20:32:02 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:32:02 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:31:55 info host.raspberrypi instance system.adapter.admin.1 started with pid 9268
      raspberrypi 2015-09-28 20:31:25 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:31:25 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:31:16 info host.raspberrypi instance system.adapter.admin.1 started with pid 9267
      raspberrypi 2015-09-28 20:30:46 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:30:46 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:30:32 info host.raspberrypi instance system.adapter.admin.1 started with pid 9266
      raspberrypi 2015-09-28 20:30:02 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:30:02 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:29:58 info host.raspberrypi instance system.adapter.admin.1 started with pid 9265
      raspberrypi 2015-09-28 20:29:28 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:29:28 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:29:14 info host.raspberrypi instance system.adapter.admin.1 started with pid 9264
      raspberrypi 2015-09-28 20:29:13 info host.raspberrypi instance system.adapter.admin.1 started with pid 9264
      raspberrypi 2015-09-28 20:28:43 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:28:43 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:28:36 info host.raspberrypi instance system.adapter.admin.1 started with pid 9263
      raspberrypi 2015-09-28 20:28:06 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:28:06 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:28:01 info host.raspberrypi instance system.adapter.admin.1 started with pid 9262
      raspberrypi 2015-09-28 20:27:31 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:27:31 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:27:27 info host.raspberrypi instance system.adapter.admin.1 started with pid 9261
      raspberrypi 2015-09-28 20:26:57 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:26:57 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:26:52 info host.raspberrypi instance system.adapter.admin.1 started with pid 9260
      raspberrypi 2015-09-28 20:26:22 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:26:22 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:26:09 info host.raspberrypi instance system.adapter.admin.1 started with pid 9259
      raspberrypi 2015-09-28 20:25:39 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:25:39 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      raspberrypi 2015-09-28 20:25:38 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
      raspberrypi 2015-09-28 20:25:38 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:25:26 info instance system.adapter.admin.1 started with pid 9258
      host-raspberrypi 2015-09-28 20:24:56 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:24:56 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:24:49 info instance system.adapter.admin.1 started with pid 9257
      host-raspberrypi 2015-09-28 20:24:19 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:24:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:24:07 info instance system.adapter.admin.1 started with pid 9256
      host-raspberrypi 2015-09-28 20:23:37 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:23:37 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:23:33 info instance system.adapter.admin.1 started with pid 9255
      host-raspberrypi 2015-09-28 20:23:03 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:23:03 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:22:59 info instance system.adapter.admin.1 started with pid 9254
      host-raspberrypi 2015-09-28 20:22:29 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:22:29 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:22:25 info instance system.adapter.admin.1 started with pid 9253
      host-raspberrypi 2015-09-28 20:21:55 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:21:55 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:21:49 info instance system.adapter.admin.1 started with pid 9252
      host-raspberrypi 2015-09-28 20:21:19 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:21:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:21:14 info instance system.adapter.admin.1 started with pid 9251
      host-raspberrypi 2015-09-28 20:20:44 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:20:44 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:20:38 info instance system.adapter.admin.1 started with pid 9250
      host-raspberrypi 2015-09-28 20:20:08 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:20:08 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:20:01 info instance system.adapter.admin.1 started with pid 9249
      host-raspberrypi 2015-09-28 20:19:31 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:19:31 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:19:27 info instance system.adapter.admin.1 started with pid 9248
      host-raspberrypi 2015-09-28 20:18:57 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:18:57 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:18:53 info instance system.adapter.admin.1 started with pid 9247
      host-raspberrypi 2015-09-28 20:18:23 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:18:23 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:18:19 info instance system.adapter.admin.1 started with pid 9246
      host-raspberrypi 2015-09-28 20:17:49 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:17:49 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:17:40 info instance system.adapter.admin.1 started with pid 9245
      host-raspberrypi 2015-09-28 20:17:10 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:17:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:17:06 info instance system.adapter.admin.1 started with pid 9244
      host-raspberrypi 2015-09-28 20:16:36 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:16:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:16:32 info instance system.adapter.admin.1 started with pid 9233
      host-raspberrypi 2015-09-28 20:16:02 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:16:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:15:57 info instance system.adapter.admin.1 started with pid 9232
      host-raspberrypi 2015-09-28 20:15:27 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:15:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:15:22 info instance system.adapter.admin.1 started with pid 9231
      host-raspberrypi 2015-09-28 20:14:52 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:14:52 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:14:48 info instance system.adapter.admin.1 started with pid 9230
      host-raspberrypi 2015-09-28 20:14:18 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:14:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:14:08 info instance system.adapter.admin.1 started with pid 9229
      host-raspberrypi 2015-09-28 20:13:38 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:13:38 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:13:33 info instance system.adapter.admin.1 started with pid 9228
      host-raspberrypi 2015-09-28 20:13:03 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:13:03 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:12:59 info instance system.adapter.admin.1 started with pid 9227
      host-raspberrypi 2015-09-28 20:12:28 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:12:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:12:25 info instance system.adapter.admin.1 started with pid 9226
      host-raspberrypi 2015-09-28 20:11:54 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:11:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:11:50 info instance system.adapter.admin.1 started with pid 9225
      host-raspberrypi 2015-09-28 20:11:20 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:11:20 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:11:10 info instance system.adapter.admin.1 started with pid 9224
      host-raspberrypi 2015-09-28 20:10:40 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:10:40 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:10:36 info instance system.adapter.admin.1 started with pid 9223
      host-raspberrypi 2015-09-28 20:10:06 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:10:06 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:10:01 info instance system.adapter.admin.1 started with pid 9222
      host-raspberrypi 2015-09-28 20:09:31 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:09:31 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:09:26 info instance system.adapter.admin.1 started with pid 9221
      host-raspberrypi 2015-09-28 20:08:56 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:08:56 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:08:51 info instance system.adapter.admin.1 started with pid 9220
      host-raspberrypi 2015-09-28 20:08:21 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:08:21 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:08:09 info instance system.adapter.admin.1 started with pid 9219
      host-raspberrypi 2015-09-28 20:07:39 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:07:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:07:34 info instance system.adapter.admin.1 started with pid 9218
      host-raspberrypi 2015-09-28 20:07:04 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:07:04 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:07:00 info instance system.adapter.admin.1 started with pid 9217
      host-raspberrypi 2015-09-28 20:06:30 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:06:30 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:06:25 info instance system.adapter.admin.1 started with pid 9216
      host-raspberrypi 2015-09-28 20:05:55 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:05:55 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:05:51 info instance system.adapter.admin.1 started with pid 9215
      host-raspberrypi 2015-09-28 20:05:20 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:05:20 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:05:11 info instance system.adapter.admin.1 started with pid 9214
      host-raspberrypi 2015-09-28 20:04:41 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:04:41 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:04:36 info instance system.adapter.admin.1 started with pid 9213
      host-raspberrypi 2015-09-28 20:04:06 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:04:06 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:04:02 info instance system.adapter.admin.1 started with pid 9212
      host-raspberrypi 2015-09-28 20:03:32 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:03:32 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:03:28 info instance system.adapter.admin.1 started with pid 9211
      host-raspberrypi 2015-09-28 20:02:58 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:02:58 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:02:51 info instance system.adapter.admin.1 started with pid 9209
      host-raspberrypi 2015-09-28 20:02:21 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:02:21 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:02:17 info instance system.adapter.admin.1 started with pid 9208
      host-raspberrypi 2015-09-28 20:01:46 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:01:46 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:01:38 info instance system.adapter.admin.1 started with pid 9207
      host-raspberrypi 2015-09-28 20:01:08 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:01:08 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:01:03 info instance system.adapter.admin.1 started with pid 9206
      host-raspberrypi 2015-09-28 20:00:33 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 20:00:33 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 20:00:29 info instance system.adapter.admin.1 started with pid 9205
      host-raspberrypi 2015-09-28 19:59:59 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:59:59 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:59:54 info instance system.adapter.admin.1 started with pid 9204
      host-raspberrypi 2015-09-28 19:59:23 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:59:23 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:59:18 info instance system.adapter.admin.1 started with pid 9203
      host-raspberrypi 2015-09-28 19:58:48 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:58:48 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:58:40 info instance system.adapter.admin.1 started with pid 9202
      host-raspberrypi 2015-09-28 19:58:10 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:58:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:58:05 info instance system.adapter.admin.1 started with pid 9201
      host-raspberrypi 2015-09-28 19:57:35 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:57:35 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:57:31 info instance system.adapter.admin.1 started with pid 9200
      host-raspberrypi 2015-09-28 19:57:01 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:57:01 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:56:57 info instance system.adapter.admin.1 started with pid 9199
      host-raspberrypi 2015-09-28 19:56:27 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:56:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:56:23 info instance system.adapter.admin.1 started with pid 9198
      host-raspberrypi 2015-09-28 19:55:53 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:55:53 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:55:48 info instance system.adapter.admin.1 started with pid 9197
      host-raspberrypi 2015-09-28 19:55:18 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:55:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:55:06 info instance system.adapter.admin.1 started with pid 9196
      host-raspberrypi 2015-09-28 19:54:36 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:54:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:54:32 info instance system.adapter.admin.1 started with pid 9195
      host-raspberrypi 2015-09-28 19:54:02 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:54:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:53:58 info instance system.adapter.admin.1 started with pid 9194
      host-raspberrypi 2015-09-28 19:53:28 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:53:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:53:24 info instance system.adapter.admin.1 started with pid 9193
      host-raspberrypi 2015-09-28 19:52:54 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:52:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:52:48 info instance system.adapter.admin.1 started with pid 9192
      host-raspberrypi 2015-09-28 19:52:18 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:52:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:52:09 info instance system.adapter.admin.1 started with pid 9191
      host-raspberrypi 2015-09-28 19:51:39 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:51:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:51:34 info instance system.adapter.admin.1 started with pid 9190
      host-raspberrypi 2015-09-28 19:51:04 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:51:04 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:50:58 info instance system.adapter.admin.1 started with pid 9189
      host-raspberrypi 2015-09-28 19:50:28 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:50:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:50:24 info instance system.adapter.admin.1 started with pid 9188
      host-raspberrypi 2015-09-28 19:49:54 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:49:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:49:49 info instance system.adapter.admin.1 started with pid 9187
      host-raspberrypi 2015-09-28 19:49:19 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:49:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:49:13 info instance system.adapter.admin.1 started with pid 9186
      host-raspberrypi 2015-09-28 19:48:43 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:48:43 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:48:37 info instance system.adapter.admin.1 started with pid 9185
      host-raspberrypi 2015-09-28 19:48:07 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:48:07 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:48:02 info instance system.adapter.admin.1 started with pid 9184
      host-raspberrypi 2015-09-28 19:47:32 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:47:32 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:47:27 info instance system.adapter.admin.1 started with pid 9183
      host-raspberrypi 2015-09-28 19:46:57 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:46:57 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:46:52 info instance system.adapter.admin.1 started with pid 9182
      host-raspberrypi 2015-09-28 19:46:22 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:46:22 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:46:17 info instance system.adapter.admin.1 started with pid 9181
      host-raspberrypi 2015-09-28 19:45:47 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:45:47 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:45:40 info instance system.adapter.admin.1 started with pid 9180
      host-raspberrypi 2015-09-28 19:45:10 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:45:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:45:05 info instance system.adapter.admin.1 started with pid 9179
      host-raspberrypi 2015-09-28 19:44:35 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:44:35 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:44:31 info instance system.adapter.admin.1 started with pid 9178
      host-raspberrypi 2015-09-28 19:44:01 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:44:01 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:43:57 info instance system.adapter.admin.1 started with pid 9177
      host-raspberrypi 2015-09-28 19:43:27 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:43:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:43:22 info instance system.adapter.admin.1 started with pid 9176
      host-raspberrypi 2015-09-28 19:42:52 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:42:52 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:42:47 info instance system.adapter.admin.1 started with pid 9175
      host-raspberrypi 2015-09-28 19:42:17 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:42:17 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:42:09 info instance system.adapter.admin.1 started with pid 9174
      host-raspberrypi 2015-09-28 19:41:39 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:41:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:41:32 info instance system.adapter.admin.1 started with pid 9173
      host-raspberrypi 2015-09-28 19:41:02 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:41:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:40:58 info instance system.adapter.admin.1 started with pid 9172
      host-raspberrypi 2015-09-28 19:40:28 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:40:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:40:24 info instance system.adapter.admin.1 started with pid 9171
      host-raspberrypi 2015-09-28 19:39:54 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:39:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:39:49 info instance system.adapter.admin.1 started with pid 9170
      host-raspberrypi 2015-09-28 19:39:19 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:39:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:39:09 info instance system.adapter.admin.1 started with pid 9169
      host-raspberrypi 2015-09-28 19:38:39 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:38:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:38:35 info instance system.adapter.admin.1 started with pid 9168
      host-raspberrypi 2015-09-28 19:38:05 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:38:05 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:38:00 info instance system.adapter.admin.1 started with pid 9167
      host-raspberrypi 2015-09-28 19:37:30 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:37:30 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:37:24 info instance system.adapter.admin.1 started with pid 9166
      host-raspberrypi 2015-09-28 19:36:54 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:36:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:36:43 info instance system.adapter.admin.1 started with pid 9165
      host-raspberrypi 2015-09-28 19:36:12 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:36:12 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:36:06 info instance system.adapter.admin.1 started with pid 9164
      host-raspberrypi 2015-09-28 19:35:36 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:35:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:35:32 info instance system.adapter.admin.1 started with pid 9163
      host-raspberrypi 2015-09-28 19:35:02 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:35:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:34:58 info instance system.adapter.admin.1 started with pid 9162
      host-raspberrypi 2015-09-28 19:34:28 info Restart adapter system.adapter.admin.1 because enabled
      host-raspberrypi 2015-09-28 19:34:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      host-raspberrypi 2015-09-28 19:34:23 info instance system.adapter.admin.1 started with pid 9161
      host-raspberrypi 2015-09-28 19:33:53 info Restart adapter system.adapter.admin.1 because enabled
        mach mal ein reboot
          so, log einträge sind weg. Ich hatte auf einmal eine zweite admin instanz.
          Was auch immer ich gemacht habe, dass die auf einmal da war…
            kommando zurück. jetzt kann ich gar nicht mehr auf iobroker zugreifen:
            Diese Webseite ist nicht verfügbar.
            ERR_CONNECTION_REFUSED
            auch ein reboot hat nichts gebracht 😞
              jetzt siehts so aus, als hätte ich gar keine admin instanz mehr.
              Und owohl die VIS instanz ja da ist, kann ich vis auch nicht mehr aufrufen 😞
              ps -A | grep io
              17 ? 00:00:00 bioset
              20 ? 00:00:00 rpciod
              23 ? 00:00:00 nfsiod
              35 ? 00:00:00 DWC Notificatio
              2043 ? 00:00:11 io.js-controlle
              2325 ? 00:00:09 io.web.0
              2375 ? 00:00:08 io.hm-rega.0
              2376 ? 00:00:07 io.hm-rpc.0
              2378 ? 00:00:06 io.vis.0
                reboot!
                und wenn danach immer noch kein admin da ist:
                cd /opt/iobroker
                iobroker stop
                npm install iobroker.admin
                iobroker start
                  reboot hatte ich schon durch.
                  admin neu isntallieren probiere ich gerade
                    das klappt leider auch nicht mehr:
                    dules/utf-8-validate
                    node-gyp rebuild
                    ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate/build'
                    CXX(target) Release/obj.target/validation/src/validation.o
                    SOLINK_MODULE(target) Release/obj.target/validation.node
                    SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
                    COPY Release/validation.node
                    make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate/build'
                    ! > bufferutil@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
                    node-gyp rebuild
                    ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil/build'
                    CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                    SOLINK_MODULE(target) Release/obj.target/bufferutil.node
                    SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
                    COPY Release/bufferutil.node
                    make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil/build'
                    ! > utf-8-validate@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
                    node-gyp rebuild
                    ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate/build'
                    make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate/build'
                    ! > bufferutil@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
                    node-gyp rebuild
                    ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil/build'
                    make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil/build'
                    npm ERR!
                    npm ERR! Additional logging details can be found in:
                    npm ERR! /opt/iobroker/npm-debug.log
                    npm ERR! not ok code 0
                    und hier die npm-debug.log:
                    root@raspberrypi:/opt/iobroker# tail /opt/iobroker/npm-debug.log
                    6592 error npm-@googlegroups.com6593 error System Linux 3.18.11+
                    6594 error command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin"
                    6595 error cwd /opt/iobroker
                    6596 error node -v v0.10.22
                    6597 error npm -v 1.3.14
                    6598 error path /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/tough-cookie/lib/permuteDomain.js
                    6599 error code ENOENT
                    6600 error errno 34
                    6601 verbose exit [ 34, true ]/npm-@googlegroups.com
                      Da fehlt ihm eine Datei.
                      Versuch es mal mit:
                      cd /opt/iobroker
                      npm cache clean
                      npm install iobroker.admin --production
                      Wenn das nicht klappt, hat mir bei einem solchen Problem mit einem anderen Adapter der Tip von versteckt geholfen, alles im Verzeichnis /tmp zu installieren und dann rüberzukopieren
                      Rainer
                      …oder plattmachen
                        scheint erstmal geklappt zu haben. aber merkwürdig ists trotzdem…
                        2499
