    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. MegaD 328
    MegaD 328
    • V
      vtec last edited by
      Нажатие кнопки поиска
      Error:	2015-09-29 00:31:30	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      Error:	2015-09-29 00:31:30	error	at Socket.StatesInMemClient.client.on.connectionTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      Error:	2015-09-29 00:31:30	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1891:34)
      Error:	2015-09-29 00:31:30	error	at Adapter.emit (events.js:95:17)
      Error:	2015-09-29 00:31:30	error	at Adapter.adapter.config.ports.(anonymous function).value (/opt/iobroker/node_modules/iobroker.megad/main.js:87:17)
      Error:	2015-09-29 00:31:30	error	at discoverMega (/opt/iobroker/node_modules/iobroker.megad/main.js:702:17)
      Error:	2015-09-29 00:31:30	error	at discoverMegaOnIP (/opt/iobroker/node_modules/iobroker.megad/main.js:671:24)
      Error:	2015-09-29 00:31:30	error	at Object.exports.createSocket (dgram.js:130:10)
      Error:	2015-09-29 00:31:30	error	at new Socket (dgram.js:113:16)
      Error:	2015-09-29 00:31:30	error	at newHandle (dgram.js:88:9)
      Error:	2015-09-29 00:31:30	error	Bad socket type specified. Valid types are: udp4, udp6
      message	2015-09-29 00:31:30	error	messagebox.system.adapter.megad.0 [object Object] Bad socket type specified. Valid types are: udp4, udp6
      Если используется модуль Datagram Sockets, то там написано: Creates a datagram Socket of the specified types. Valid types are udp4 and udp6.
      • Bluefox
        Bluefox last edited by
        @vtec:
        Если используется модуль Datagram Sockets, то там написано: Creates a datagram Socket of the specified types. Valid types are udp4 and udp6. `
        Версия node.js старая… Попробуй поменять строчку 671 в main.js на
        var client = dgram.createSocket('udp4');
        • V
          vtec last edited by
          Обновил до 0.10.40, тоже самое. Еще новее?
          • Bluefox
            @vtec:
            Обновил до 0.10.40, тоже самое. Еще новее? `
            забудь.Я поменял вызов. Обнови megad
              Bosya last edited by
              @Bluefox:
              Что это такое? По имени naf `
              http://ab-log.ru/smart-house/ethernet/megad-328
              Флажок (чекбокс) справа от поля Net указывает, что NetAction будет вызван ТОЛЬКО при недоступности сервера. По умолчанию вызывается всегда.
                @Bluefox:
                @Bosya:
                Вчера всплыла еще такая вещь - при снятии галочки "двойное нажатие" перестали работать скрипты на одиночное нажатие:
                on("megad.0.p9_P9", function (obj) {
                    if (obj.newState.val === true) {
                      request(Lamp4);
                В чем может быть подвох? Галочку вернул - она почти не мешает, но это лишняя нагрузка на систему и лишняя задержка для ожидания того, чего не нужно… `
                Просто там генерировались 0 и 1 вместо true и false.
                Можешь в последней версии 0.2.11 поменять строку 934 с
                    adapter.setState(config.id, config.value, true);
                на
                    adapter.setState(config.id, !!config.value, true);
                Я так понимаю это уже в 0.2.12 исправлено. А как по поводу моего предыдущего замечания?
                @Bosya:
                Драйвер обновил, но не помогло. Проверил браузером и теперь везде OK, но в Mozilla было замечено что шрифт OK отличается для 0 и остальных. Дальнейший анализ показал, что у ответов сервера разный тип.
                Для 0 это - text/html, а для остальных - text/plain. `
                • V
                  vtec last edited by
                  версия 0.2.12
                  1. поиск так и не заработал.
                  2. Считывание misc не заработало, так же по прежнему из поля mode считывает.
                  3. Пожелание: во вкладке настройка драйверов в столбце "заголовок" сделать переход на мегу при условии что ip прописан в настройках (типа как переходим на редактор vis).
                    MSapogov last edited by
                    @vtec:
                    версия 0.2.12
                    3. Пожелание: во вкладке настройка драйверов в столбце "заголовок" сделать переход на мегу при условии что ip прописан в настройках (типа как переходим на редактор vis). `
                    4. Убрать поле "Сценарий:", если тип датчика DHT11 или DHT22.
                    5. Выход PWM может быть установлен не на всех выходах (Ограничение Atmega 328p)
                    • Bluefox
                      @vtec:
                      версия 0.2.12
                      Ничего не понимаю.
                      А можешь прислать wireshark. Как iobroker ищет?
                      • Bluefox
                        @MSapogov:
                        @vtec:
                        версия 0.2.12
                        5. Выход PWM может быть установлен не на всех выходах (Ограничение Atmega 328p) `
                        На каких портах можно pwm?
                          Andrei34 last edited by
                          @Bluefox:
                          На каких портах можно pwm? `
                          На 10 , 12 и 13 портах .
                          • I
                            instalator last edited by
                            @Andrei34:
                            @Bluefox:
                            На каких портах можно pwm? На 10 , 12 и 13 портах .
                            Ну если быть точным то 3,5,6,9,10,11 - Если говорить про мегу 328
                            Неправильно написал.
                            5,11,12,15,16,17 вот так вроде по даташиту
                            • Bluefox
                              У вас данные расходятся. Так что мне делать?
                                @Bluefox:
                                У вас данные расходятся. Так что мне делать? `
                                У MegaD на 10 , 12 и 13 портах .
                                  @Andrei34:
                                  @Bluefox:
                                  У вас данные расходятся. Так что мне делать? У MegaD на 10 , 12 и 13 портах .
                                  Ага. 10, 12 и 13. На других PWM невозможен для Mega-D.
                                  • V
                                    vtec last edited by
                                    Возможно это если у вас 7I7O?
                                    По документации распиновки кабеля меги: P7, P10,P12,P13
                                    • V
                                      vtec last edited by
                                      @Bluefox:
                                      Ничего не понимаю.
                                      А можешь прислать wireshark. Как iobroker ищет? `
                                      Как это сделать если iobroker стоит на другом компьютере и он под линукс? Tcpdump?
                                        @vtec:
                                        По документации распиновки кабеля меги: P7, P10,P12,P13 `
                                        Нет, не 7I7O.
                                        Вы попробуйте переведите порт P7 в OUT… У вас не будет выбора SW или PWM, я проверил.
                                        • V
                                          vtec last edited by
                                          Подтверждаю P10,P12,P13
                                          • Bluefox
                                            @Bosya:
                                            @Bluefox:
                                            Флажок (чекбокс) справа от поля Net указывает, что NetAction будет вызван ТОЛЬКО при недоступности сервера. По умолчанию вызывается всегда. `
                                            Как это так. Какой смысл вызывать сетевой скрипт, если сервер недоступен?
                                            430
                                            127080
