    4. Test js-controller v2.0.x (GitHub)
      darkiop Most Active last edited by
      Habe beide auf die 2.0.30 gezogen.
      Beim installieren gab es ungewöhnlich viele Warnungen, die hatte ich vorher nicht - siehe Log. Beide laufen aber ohne Auffälligkeiten.
      iobroker-switch.sh
      type '1.5' (latest) or '2.0' (from github)
      switch js-controller to: 2.0
      ioBroker is terminated ...
      Install js-controller 2.0.x ...
      > iobroker.js-controller@2.0.30 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.9.0
      > unix-dgram@2.0.2 install /opt/iobroker/node_modules/unix-dgram
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      ../src/unix_dgram.cc: In function ‘void {anonymous}::OnRecv({anonymous}::SocketContext*)’:
      ../src/unix_dgram.cc:121:25: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                           argv);
      In file included from ../src/unix_dgram.cc:5:0:
      ../../nan/nan.h:1024:46: note: declared here
         NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
      ../src/unix_dgram.cc: In function ‘void {anonymous}::OnWritable({anonymous}::SocketContext*)’:
      ../src/unix_dgram.cc:129:28: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                           0, NULL);
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         domain      = info[0]->Int32Value();
      In file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26:0,
                       from /home/iobroker/.node-gyp/10.16.3/include/node/node.h:63,
                       from ../../nan/nan.h:54,
      /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2478:46: note: declared here
         V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
      /home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         type        = info[1]->Int32Value();
      ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         protocol    = info[2]->Int32Value();
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         fd = info[0]->Int32Value();
      ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[1]);
      /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2892:28: note: declared here
                         explicit Utf8Value(Local<v8::Value> obj));
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         buf = info[1]->ToObject();
      In file included from /home/iobroker/.node-gyp/10.16.3/include/node/node.h:63:0,
      /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:10046:15: note: declared here
       Local<Object> Value::ToObject() const {
      ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         offset = info[2]->Uint32Value();
      /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2477:47: note: declared here
         V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
      ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         length = info[3]->Uint32Value();
      ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[4]);
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
        COPY Release/unix_dgram.node
      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
      > iobroker.js-controller@2.0.30 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      + iobroker.js-controller@2.0.30
      updated 4 packages and audited 35156 packages in 96.546s
      found 52 vulnerabilities (40 low, 12 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      ioBroker will be started ...
      Starting iobroker controller daemon...
      iobroker controller daemon started. PID: 20872
      ┬─[root@iobroker-master:/opt/iobroker]─[10:16:27]
        Zu deinen gewünschten Tests:
        Testfall 1:
        master + slave = alive
        master beenden
        nicht wieder starten
        Testfall 2:
        master beenden
        20s warten
        wieder starten
        Testfall 3:
        redis beenden
        Testfall 4:
        redis beenden
        paar Sekunden warten
        redis starten
        prüfen ob States die innerhalb der 40s erzeugt werden nach dem starten von redis verfügbar sind
          Testfall 1:
          iobroker-master um 10:26:02 beendet und nicht wieder gestartet, log auf slave. Nach ner gewissen Zeit beenden sich die Adapter und der controller lauert:
          2019-10-15 10:26:31.418  - error: host.iobroker-hwr connect ETIMEDOUT
          2019-10-15 10:26:31.415  - error: smartmeter.1 (641) connect ETIMEDOUT
          2019-10-15 10:26:31.416  - error: smartmeter.0 (626) connect ETIMEDOUT
          2019-10-15 10:26:43.421  - error: host.iobroker-hwr connect ETIMEDOUT
          2019-10-15 10:26:43.423  - error: smartmeter.1 (641) connect ETIMEDOUT
          2019-10-15 10:26:43.423  - error: smartmeter.0 (626) connect ETIMEDOUT
          2019-10-15 10:26:45.929  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:26:45.929  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:26:45.928  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:26:57.926  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:26:57.926  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:26:57.928  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:03.926  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:03.926  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:03.928  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:09.926  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:09.926  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:09.926  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:15.926  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:15.926  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:18.927  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:21.926  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:21.926  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:24.926  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:27.926  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:30.926  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:33.926  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:33.926  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:36.927  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:36.927  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:39.927  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:42.926  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:42.926  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:45.926  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:48.926  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:48.927  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:51.927  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:54.926  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:54.926  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:57.926  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:27:57.927  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:28:00.927  - error: smartmeter.1 (641) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:28:00.929  - error: smartmeter.0 (626) connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:28:03.430  - warn: host.iobroker-hwr Slave controller detected objects disconnection. Stop all instances.
          2019-10-15 10:28:03.435  - info: host.iobroker-hwr stopInstance system.adapter.smartmeter.0
          2019-10-15 10:28:03.436  - info: host.iobroker-hwr stopInstance forced system.adapter.smartmeter.0 killing pid 626
          2019-10-15 10:28:03.437  - info: host.iobroker-hwr stopInstance system.adapter.smartmeter.1
          2019-10-15 10:28:03.438  - info: host.iobroker-hwr stopInstance forced system.adapter.smartmeter.1 killing pid 641
          2019-10-15 10:28:03.926  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:28:06.927  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:28:09.927  - error: host.iobroker-hwr connect EHOSTUNREACH 192.168.1.82:9001
          2019-10-15 10:28:09.938  - error: host.iobroker-hwr Cannot find view "system" for search "instance" : Error: Connection is closed.
          2019-10-15 10:28:09.942  - info: host.iobroker-hwr instance system.adapter.smartmeter.1 terminated with code 156 (156)
          2019-10-15 10:28:09.943  - info: host.iobroker-hwr All instances are stopped.
          2019-10-15 10:28:09.944  - error: host.iobroker-hwr Cannot find view "system" for search "instance" : Error: Connection is closed.
          2019-10-15 10:28:09.945  - info: host.iobroker-hwr instance system.adapter.smartmeter.0 terminated with code 156 (156)
          2019-10-15 10:28:09.945  - info: host.iobroker-hwr All instances are stopped.
          2019-10-15 10:28:12.439  - warn: host.iobroker-hwr Slave controller detected objects disconnection. Stop all instances.
          2019-10-15 10:28:12.440  - info: host.iobroker-hwr stopInstance system.adapter.smartmeter.0
          2019-10-15 10:28:12.441  - info: host.iobroker-hwr stopInstance system.adapter.smartmeter.1
          2019-10-15 10:28:25.052  - info: host.iobroker-hwr iobroker _restart
          2019-10-15 10:28:25.602  - info: host.iobroker-hwr iobroker Starting node restart.js
          2019-10-15 10:28:27.058  - info: host.iobroker-hwr iobroker.js-controller version 2.0.30 js-controller starting
          2019-10-15 10:28:27.065  - info: host.iobroker-hwr Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
          2019-10-15 10:28:27.066  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.16.3
          2019-10-15 10:28:27.068  - info: host.iobroker-hwr ip addresses: 10.3.1.22 fe80::561e:8619:1900:f27
            Testfall 2:
            iobroker-master um 10:30:05 beendet und nach 20s wieder gestartet, log auf slave:
            --> Kein Log das die Verbindung wieder besteht. 10:32:37 wurde der iobroker-master wieder gestartet und war ein paar Sekunden später auch wieder Verbunden (--> ersichtlich im Admin).
            2019-10-15 10:30:01.626  - info: host.iobroker-hwr iobroker Starting node restart.js
            2019-10-15 10:30:03.055  - info: host.iobroker-hwr iobroker.js-controller version 2.0.30 js-controller starting
            2019-10-15 10:30:03.063  - info: host.iobroker-hwr Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
            2019-10-15 10:30:03.064  - info: host.iobroker-hwr hostname: iobroker-hwr, node: v10.16.3
            2019-10-15 10:30:03.065  - info: host.iobroker-hwr ip addresses: 10.3.1.22 fe80::561e:8619:1900:f27
            2019-10-15 10:30:20.413  - info: host.iobroker-hwr connected to Objects and States
            2019-10-15 10:30:20.684  - info: host.iobroker-hwr 87 instances found
            2019-10-15 10:30:20.709  - info: host.iobroker-hwr starting 2 instances
            2019-10-15 10:30:20.727  - info: host.iobroker-hwr instance system.adapter.smartmeter.0 started with pid 928
            2019-10-15 10:30:24.719  - info: host.iobroker-hwr instance system.adapter.smartmeter.1 started with pid 943
            2019-10-15 10:32:28.828  - error: host.iobroker-hwr connect ETIMEDOUT
            2019-10-15 10:32:28.833  - error: smartmeter.0 (928) connect ETIMEDOUT
            2019-10-15 10:32:28.838  - error: smartmeter.1 (943) connect ETIMEDOUT
            2019-10-15 10:32:40.833  - error: host.iobroker-hwr connect ETIMEDOUT
            2019-10-15 10:32:40.841  - error: smartmeter.0 (928) connect ETIMEDOUT
            2019-10-15 10:32:40.864  - error: smartmeter.1 (943) connect ETIMEDOUT
            2019-10-15 10:32:42.839  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:42.847  - error: smartmeter.0 (928) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:42.867  - error: smartmeter.1 (943) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:44.844  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:44.850  - error: smartmeter.0 (928) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:44.870  - error: smartmeter.1 (943) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:46.846  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:46.851  - error: smartmeter.0 (928) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:46.873  - error: smartmeter.1 (943) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:48.850  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:48.854  - error: smartmeter.0 (928) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:48.876  - error: smartmeter.1 (943) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:50.852  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:50.857  - error: smartmeter.0 (928) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:50.878  - error: smartmeter.1 (943) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:52.855  - error: host.iobroker-hwr connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:52.859  - error: smartmeter.0 (928) connect ECONNREFUSED 192.168.1.82:9001
            2019-10-15 10:32:52.881  - error: smartmeter.1 (943) connect ECONNREFUSED 192.168.1.82:9001
              Testfall 3
              iobroker-redis um 10:45:13 Uhr beendet. Log Master.
              Einige Minuten später iobroker-redis wieder gestartet - der iobroker-master schafft es nicht wieder auf die Beine. Nach einem restart des Containers für den Master ist wieder alles verbunden.
              log_tf3.txt
                darkiop Most Active last edited by darkiop
                Testfall 4
                ┬─[darkiop@odin:~]─[11:00:32]
                ╰─>$ docker stop iobroker-redis
                ┬─[darkiop@odin:~]─[11:02:15]
                ╰─>$ docker start iobroker-redis
                smartmeter.1 hat einen Wert von 2019-10-15 11:01:34.726 über sql.0 in die DB geschrieben!
                  apollon77 @darkiop last edited by
                  @darkiop Alles unix dgram complier warnungen 😞 Aber ja ist egal, tut alles
                    apollon77 last edited by
                    Danke für die Tests!!
                    • Testfall1 : So soll es sein
                    • Testfall 2: Auch hier soll es so sein. Wenn Du auf "debug" oder "silly" log hättest würdest du die reconnects als Log sehen.
                    • Testfall 3 Bitte mit der neuen 2.0.31 auf Github nochmal testen
                    • Testfall 4; Cooool 🙂
                      darkiop Most Active @apollon77 last edited by darkiop
                      @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                      Gern!
                      Da stimmt was nicht:
                      ┬─[darkiop@odin:~]─[13:35:02]
                      iobroker-redis
                      ┬─[darkiop@odin:~]─[13:41:53]
                      iobroker-redis
                      Log Master:
                      2019-10-15 13:41:48.364  - error: scenes.0 (1492) connect ETIMEDOUT
                      2019-10-15 13:41:48.366  - error: pi-hole.0 (1228) connect ETIMEDOUT
                      2019-10-15 13:41:48.368  - error: harmony.0 (388) connect ETIMEDOUT
                      2019-10-15 13:41:48.368  - error: simple-api.0 (1695) connect ETIMEDOUT
                      2019-10-15 13:41:48.372  - error: javascript.1 (1068) connect ETIMEDOUT
                      2019-10-15 13:41:48.372  - error: sql.0 (1819) connect ETIMEDOUT
                      2019-10-15 13:41:48.372  - error: telegram.0 (2364) connect ETIMEDOUT
                      2019-10-15 13:41:48.375  - error: host.iobroker-master connect ETIMEDOUT
                      2019-10-15 13:41:48.379  - error: hm-rega.0 (403) connect ETIMEDOUT
                      2019-10-15 13:41:48.379  - error: hs100.0 (480) connect ETIMEDOUT
                      2019-10-15 13:41:48.379  - error: tr-064-community.0 (2710) connect ETIMEDOUT
                      2019-10-15 13:41:48.385  - error: stiebel-isg.0 (2029) connect ETIMEDOUT
                      2019-10-15 13:41:48.385  - error: moma.0 (1162) connect ETIMEDOUT
                      2019-10-15 13:41:48.390  - error: ping.0 (1378) connect ETIMEDOUT
                      2019-10-15 13:41:48.391  - error: hm-rpc.1 (426) connect ETIMEDOUT
                      2019-10-15 13:41:48.392  - error: backitup.0 (457) connect ETIMEDOUT
                      2019-10-15 13:41:48.393  - error: hm-rpc.2 (450) connect ETIMEDOUT
                      2019-10-15 13:41:48.393  - error: javascript.0 (808) connect ETIMEDOUT
                      2019-10-15 13:41:48.399  - error: mercedesme.0 (1108) connect ETIMEDOUT
                      2019-10-15 13:41:48.407  - error: info.0 (789) connect ETIMEDOUT
                      2019-10-15 13:42:00.004  - warn: host.iobroker-master instance system.adapter.daswetter.0 already running with pid 11372
                      2019-10-15 13:42:03.215  - info: host.iobroker-master instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                      2019-10-15 13:42:04.501  - debug: harmony.0 (388) system.adapter.admin.0: logging true
                      2019-10-15 13:42:04.532  - debug: harmony.0 (388) States connected to redis: 192.168.1.86:6379
                      2019-10-15 13:42:20.048  - error: admin.0 (419) uncaught exception: Maximum call stack size exceeded
                      2019-10-15 13:42:20.052  - error: admin.0 (419) RangeError: Maximum call stack size exceeded
                          at Sender.frameAndSend (/opt/iobroker/node_modules/ws/lib/Sender.js:166:14)
                          at /opt/iobroker/node_modules/ws/lib/Sender.js:126:12
                          at Sender.applyExtensions (/opt/iobroker/node_modules/ws/lib/Sender.js:287:5)
                          at /opt/iobroker/node_modules/ws/lib/Sender.js:120:10
                          at Sender.flush (/opt/iobroker/node_modules/ws/lib/Sender.js:268:3)
                          at /opt/iobroker/node_modules/ws/lib/Sender.js:270:10
                          at /opt/iobroker/node_modules/ws/lib/Sender.js:127:7
                      2019-10-15 13:42:20.318  - error: host.iobroker-master Caught by controller[0]: RangeError: Maximum call stack size exceeded
                      2019-10-15 13:42:20.320  - error: host.iobroker-master Caught by controller[0]:     at Sender.frameAndSend (/opt/iobroker/node_modules/ws/lib/Sender.js:166:14)
                      2019-10-15 13:42:20.321  - error: host.iobroker-master Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Sender.js:126:12
                      2019-10-15 13:42:20.323  - error: host.iobroker-master Caught by controller[0]:     at Sender.applyExtensions (/opt/iobroker/node_modules/ws/lib/Sender.js:287:5)
                      2019-10-15 13:42:20.324  - error: host.iobroker-master Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Sender.js:120:10
                      2019-10-15 13:42:20.325  - error: host.iobroker-master Caught by controller[0]:     at Sender.flush (/opt/iobroker/node_modules/ws/lib/Sender.js:268:3)
                      2019-10-15 13:42:20.326  - error: host.iobroker-master Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Sender.js:270:10
                      2019-10-15 13:42:20.327  - error: host.iobroker-master Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Sender.js:127:7
                      2019-10-15 13:42:20.328  - error: host.iobroker-master Caught by controller[0]:     at Sender.applyExtensions (/opt/iobroker/node_modules/ws/lib/Sender.js:287:5)
                      2019-10-15 13:42:20.328  - error: host.iobroker-master Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Sender.js:120:10
                      2019-10-15 13:42:20.329  - error: host.iobroker-master Caught by controller[0]:     at Sender.flush (/opt/iobroker/node_modules/ws/lib/Sender.js:268:3)
                      2019-10-15 13:42:20.331  - info: host.iobroker-master instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                      2019-10-15 13:42:20.333  - info: host.iobroker-master Restart adapter system.adapter.admin.0 because enabled
                      2019-10-15 13:42:20.340  - debug: harmony.0 (388) system.adapter.admin.0: logging false
                      2019-10-15 13:42:49.810  - info: tankerkoenig.0 (2155) Reading data from tankerkoenig ...
                      2019-10-15 13:42:50.388  - info: host.iobroker-master instance system.adapter.admin.0 started with pid 27743
                      2019-10-15 13:43:00.021  - info: host.iobroker-master instance system.adapter.daswetter.0 started with pid 28216
                      2019-10-15 13:43:09.649  - info: host.iobroker-master instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                      Keine neue States da:
                      apollon77 2 Replies Last reply Reply Quote 0
                        @darkiop in dem Fall ist Admin gestorben weil sich irgendwie Dinge aufgestaut haben und Admin restartet. Ggf fehlen dadurch Daten? Lad im browser mal neu. Jetzt fehlende States da?
                        Ansonsten hat sich der iobroker aber wieder gefangen mit der Version oder?!
                          @darkiop Aahhh noch eine Frage: du hast nur States im redis, korrekt?
                            Ok, zweiter Test - jetzt ohne den admin.0 crash ....
                            der Master ist wieder auf den Beinen, der Slave hat es aber nicht geschaft. stop/start aufm Slave und er ist wieder verbunden.
                            Puffert der controller auch Logs? Die 3 hier sind eigentlich entstanden während redis weg war, geschrieben wurden sie nach dem redis wieder da war:
                            2019-10-15 14:00:00.786  - info: javascript.0 (618) script.js.PRODUKTIV.Beleuchtung.01_Bewegungsmelder_Flur: +++ Bewegung im Flur. Helligkeitsschwelle bei < 10 | Aktuelle Helligkeit: 31.8 | Licht wird nicht geschaltet. +++
                            2019-10-15 14:00:01.180  - info: javascript.0 (618) script.js.PRODUKTIV.Beleuchtung.01_Bewegungsmelder_Flur: +++ Bewegung im Flur. Helligkeitsschwelle bei < 10 | Aktuelle Helligkeit: 32.6 | Licht wird nicht geschaltet. +++
                            2019-10-15 14:00:01.523  - info: javascript.0 (618) script.js.PRODUKTIV.Beleuchtung.01_Bewegungsmelder_Flur: +++ Bewegung im Flur. Helligkeitsschwelle bei < 10 | Aktuelle Helligkeit: 32.6 | Licht wird nicht geschaltet. +++
                            Edit:
                            So lange war redis weg:
                              Ja.
                              • smartboart
                                smartboart @apollon77 last edited by
                                @apollon77 said in [Aufruf] js-controller 2.0 Beta Test:
                                @smartboart mehr log bitte
                                gerne
                                2019-10-14 19:36:28.810 - info: host.ioBroker-Rock Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                2019-10-14 19:37:21.257 - info: host.ioBroker-Rock iobroker upgrade statistics
                                2019-10-14 19:37:23.968 - info: host.ioBroker-Rock iobroker Update statistics from @0.2.0 to @0.2.2
                                2019-10-14 19:37:25.117 - info: host.ioBroker-Rock iobroker NPM version: 6.9.0npm install iobroker.statistics@0.2.2 --loglevel error --production --save --prefix "/opt/iobroker" (System call)
                                2019-10-14 19:39:04.319 - info: host.ioBroker-Rock iobroker In file included from ../node_modules/nan/nan.h:82:0, from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle) [with T = v8::Integer; v8::Handle = v8::Local]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To(v8::Handle i) { return i->ToInteger(); } ^
                                2019-10-14 19:39:04.321 - info: host.ioBroker-Rock iobroker In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:10052:16: note: declared here Local Value::ToInteger() const { ^In file included from ../node_modules/nan/nan.h:82:0, from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle) [with T = v8::Int32; v8::Handle = v8::Local]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To(v8::Handle i) { return i->ToInt32(); } ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal v8::Value::ToInt32(v8::Local) const V8_WARN_UNUSED_RESULT MaybeLocal ToInt32(Local context) const; ^/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2437:43: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26:0, from ../src/bufferutil.cc:7:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2450:30: note: candidate: v8::Local v8::Value::ToInt32(v8::Isolate*) const Local ToInt32(Isolate* isolate) const); ^/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’ declarator attribute((deprecated(message))) ^~~~~~~~
                                2019-10-14 19:39:04.324 - info: host.ioBroker-Rock iobroker /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2450:30: note: candidate expects 1 argument, 0 provided Local ToInt32(Isolate* isolate) const); ^/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’ declarator attribute((deprecated(message))) ^~~~~~~~~~
                                2019-10-14 19:39:04.327 - info: host.ioBroker-Rock iobroker In file included from ../node_modules/nan/nan.h:82:0, from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle) [with T = v8::Uint32; v8::Handle = v8::Local]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To(v8::Handle i) { return i->ToUint32(); } ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal v8::Value::ToUint32(v8::Local) const V8_WARN_UNUSED_RESULT MaybeLocal ToUint32( ^~/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2435:44: note: candidate expects 1 argument, 0 provided
                                2019-10-14 19:39:04.349 - info: host.ioBroker-Rock iobroker In file included from ../node_modules/nan/nan_new.h:189:0, from ../node_modules/nan/nan.h:82, from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase::return_t NanIntern::Factory::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’ return v8::BooleanObject::New(value).As(); ^
                                2019-10-14 19:39:04.352 - info: host.ioBroker-Rock iobroker In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:5035:23: note: candidate: static v8::Local v8::BooleanObject::New(v8::Isolate*, bool) static Local New(Isolate* isolate, bool value); ^
                                /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:5035:23: note: candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0, from ../node_modules/nan/nan.h:82, from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token return v8::BooleanObject::New(value).As(); ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token return v8::BooleanObject::New(value).As(); ^
                                2019-10-14 19:39:04.371 - info: host.ioBroker-Rock iobroker ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase::return_t NanIntern::Factory::New(v8::Handle, v8::RegExp::Flags)’:../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local v8::RegExp::New(v8::Local, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return v8::RegExp::New(pattern, flags); ^
                                2019-10-14 19:39:04.373 - info: host.ioBroker-Rock iobroker In file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26:0, from ../src/bufferutil.cc:7:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:5110:38: note: declared here Local New(Local pattern, Flags flags)); ^/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’ declarator attribute((deprecated(message))) ^
                                2019-10-14 19:39:04.378 - info: host.ioBroker-Rock iobroker In file included from ../node_modules/nan/nan_new.h:189:0, from ../node_modules/nan/nan.h:82, from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase::return_t NanIntern::Factory::New(v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’ return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src); ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal v8::ScriptCompiler::Compile(v8::Local, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason) static V8_WARN_UNUSED_RESULT MaybeLocal
                                • smartboart
                                  smartboart last edited by smartboart
                                  Mir ist noch was aufgefallen. Hab für den fullybrowser nen Chron Job im Admin angelegt.
                                  Alle 4 Stunden neustarten.... Der Log sieht dann so aus. Ist der einzige adapter mit nem Chron job bei mir..
                                  host.ioBroker-Rock 2019-10-15 12:56:00.433 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
                                  host.ioBroker-Rock 2019-10-15 12:55:01.467 info instance system.adapter.fullybrowser.0 started with pid 28554
                                  host.ioBroker-Rock 2019-10-15 12:55:00.449 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                  host.ioBroker-Rock 2019-10-15 12:55:00.443 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
                                  host.ioBroker-Rock 2019-10-15 12:54:01.492 info instance system.adapter.fullybrowser.0 started with pid 27182
                                  host.ioBroker-Rock 2019-10-15 12:54:00.446 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                  host.ioBroker-Rock 2019-10-15 12:54:00.446 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
                                  host.ioBroker-Rock 2019-10-15 12:53:01.526 info instance system.adapter.fullybrowser.0 started with pid 25634
                                  host.ioBroker-Rock 2019-10-15 12:53:00.508 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                  host.ioBroker-Rock 2019-10-15 12:53:00.507 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
                                  host.ioBroker-Rock 2019-10-15 12:52:01.455 info instance system.adapter.fullybrowser.0 started with pid 24280
                                  host.ioBroker-Rock 2019-10-15 12:52:00.435 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                  host.ioBroker-Rock 2019-10-15 12:52:00.434 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
                                  host.ioBroker-Rock 2019-10-15 12:51:01.458 info instance system.adapter.fullybrowser.0 started with pid 22758
                                  host.ioBroker-Rock 2019-10-15 12:51:00.441 info Restart adapter system.adapter.fullybrowser.0 because enabled
                                  host.ioBroker-Rock 2019-10-15 12:51:00.440 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
                                    apollon77 @smartboart last edited by
                                    @smartboart denke alles nur Warnungen.
                                    smartboart 1 Reply Last reply Reply Quote 0
                                      @smartboart sicher das es 4 stündlich ist? Das siehe eher nach minütlich aus.
                                        @darkiop hast du hier bitte das Slave log komplett von dem Zeitraum?
                                        • smartboart
                                          smartboart @apollon77 last edited by smartboart
                                          ja sehr sicher...
                                          Das ist jadas verwunderliche...noch dazu der Fehler.
                                            Jan1 @smartboart last edited by
                                            @smartboart
                                            das ist alle 4 Stunden jede Minute
                                            js-controller
                                            48
                                            1047
                                            311805
