    4. Test js-controller v2.0.x (GitHub)
    • smartboart
      smartboart @apollon77 last edited by
      @apollon77 said in [Aufruf] js-controller 2.0 Beta Test:
      @smartboart mehr log bitte
      gerne
      2019-10-14 19:36:28.810 - info: host.ioBroker-Rock Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
      2019-10-14 19:37:21.257 - info: host.ioBroker-Rock iobroker upgrade statistics
      2019-10-14 19:37:23.968 - info: host.ioBroker-Rock iobroker Update statistics from @0.2.0 to @0.2.2
      2019-10-14 19:37:25.117 - info: host.ioBroker-Rock iobroker NPM version: 6.9.0npm install iobroker.statistics@0.2.2 --loglevel error --production --save --prefix "/opt/iobroker" (System call)
      2019-10-14 19:39:04.319 - info: host.ioBroker-Rock iobroker In file included from ../node_modules/nan/nan.h:82:0, from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle) [with T = v8::Integer; v8::Handle = v8::Local]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To(v8::Handle i) { return i->ToInteger(); } ^
      2019-10-14 19:39:04.321 - info: host.ioBroker-Rock iobroker In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:10052:16: note: declared here Local Value::ToInteger() const { ^In file included from ../node_modules/nan/nan.h:82:0, from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle) [with T = v8::Int32; v8::Handle = v8::Local]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To(v8::Handle i) { return i->ToInt32(); } ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal v8::Value::ToInt32(v8::Local) const V8_WARN_UNUSED_RESULT MaybeLocal ToInt32(Local context) const; ^/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2437:43: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26:0, from ../src/bufferutil.cc:7:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2450:30: note: candidate: v8::Local v8::Value::ToInt32(v8::Isolate*) const Local ToInt32(Isolate* isolate) const); ^/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’ declarator attribute((deprecated(message))) ^~~~~~~~
      2019-10-14 19:39:04.324 - info: host.ioBroker-Rock iobroker /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2450:30: note: candidate expects 1 argument, 0 provided Local ToInt32(Isolate* isolate) const); ^/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’ declarator attribute((deprecated(message))) ^~~~~~~~~~
      2019-10-14 19:39:04.327 - info: host.ioBroker-Rock iobroker In file included from ../node_modules/nan/nan.h:82:0, from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle) [with T = v8::Uint32; v8::Handle = v8::Local]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To(v8::Handle i) { return i->ToUint32(); } ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal v8::Value::ToUint32(v8::Local) const V8_WARN_UNUSED_RESULT MaybeLocal ToUint32( ^~/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2435:44: note: candidate expects 1 argument, 0 provided
      2019-10-14 19:39:04.349 - info: host.ioBroker-Rock iobroker In file included from ../node_modules/nan/nan_new.h:189:0, from ../node_modules/nan/nan.h:82, from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase::return_t NanIntern::Factory::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’ return v8::BooleanObject::New(value).As(); ^
      2019-10-14 19:39:04.352 - info: host.ioBroker-Rock iobroker In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:5035:23: note: candidate: static v8::Local v8::BooleanObject::New(v8::Isolate*, bool) static Local New(Isolate* isolate, bool value); ^
      /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:5035:23: note: candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0, from ../node_modules/nan/nan.h:82, from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token return v8::BooleanObject::New(value).As(); ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token return v8::BooleanObject::New(value).As(); ^
      2019-10-14 19:39:04.371 - info: host.ioBroker-Rock iobroker ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase::return_t NanIntern::Factory::New(v8::Handle, v8::RegExp::Flags)’:../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local v8::RegExp::New(v8::Local, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return v8::RegExp::New(pattern, flags); ^
      2019-10-14 19:39:04.373 - info: host.ioBroker-Rock iobroker In file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26:0, from ../src/bufferutil.cc:7:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:5110:38: note: declared here Local New(Local pattern, Flags flags)); ^/home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’ declarator attribute((deprecated(message))) ^
      2019-10-14 19:39:04.378 - info: host.ioBroker-Rock iobroker In file included from ../node_modules/nan/nan_new.h:189:0, from ../node_modules/nan/nan.h:82, from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase::return_t NanIntern::Factory::New(v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’ return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src); ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.node-gyp/10.16.3/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal v8::ScriptCompiler::Compile(v8::Local, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason) static V8_WARN_UNUSED_RESULT MaybeLocal
      • smartboart
        smartboart last edited by smartboart
        Mir ist noch was aufgefallen. Hab für den fullybrowser nen Chron Job im Admin angelegt.
        Alle 4 Stunden neustarten.... Der Log sieht dann so aus. Ist der einzige adapter mit nem Chron job bei mir..
        host.ioBroker-Rock 2019-10-15 12:56:00.433 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
        host.ioBroker-Rock 2019-10-15 12:55:01.467 info instance system.adapter.fullybrowser.0 started with pid 28554
        host.ioBroker-Rock 2019-10-15 12:55:00.449 info Restart adapter system.adapter.fullybrowser.0 because enabled
        host.ioBroker-Rock 2019-10-15 12:55:00.443 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
        host.ioBroker-Rock 2019-10-15 12:54:01.492 info instance system.adapter.fullybrowser.0 started with pid 27182
        host.ioBroker-Rock 2019-10-15 12:54:00.446 info Restart adapter system.adapter.fullybrowser.0 because enabled
        host.ioBroker-Rock 2019-10-15 12:54:00.446 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
        host.ioBroker-Rock 2019-10-15 12:53:01.526 info instance system.adapter.fullybrowser.0 started with pid 25634
        host.ioBroker-Rock 2019-10-15 12:53:00.508 info Restart adapter system.adapter.fullybrowser.0 because enabled
        host.ioBroker-Rock 2019-10-15 12:53:00.507 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
        host.ioBroker-Rock 2019-10-15 12:52:01.455 info instance system.adapter.fullybrowser.0 started with pid 24280
        host.ioBroker-Rock 2019-10-15 12:52:00.435 info Restart adapter system.adapter.fullybrowser.0 because enabled
        host.ioBroker-Rock 2019-10-15 12:52:00.434 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
        host.ioBroker-Rock 2019-10-15 12:51:01.458 info instance system.adapter.fullybrowser.0 started with pid 22758
        host.ioBroker-Rock 2019-10-15 12:51:00.441 info Restart adapter system.adapter.fullybrowser.0 because enabled
        host.ioBroker-Rock 2019-10-15 12:51:00.440 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
          apollon77 @smartboart last edited by
          @smartboart denke alles nur Warnungen.
          smartboart 1 Reply Last reply Reply Quote 0
            @smartboart sicher das es 4 stündlich ist? Das siehe eher nach minütlich aus.
              apollon77 @darkiop last edited by
              @darkiop hast du hier bitte das Slave log komplett von dem Zeitraum?
              • smartboart
                smartboart @apollon77 last edited by smartboart
                ja sehr sicher...
                Das ist jadas verwunderliche...noch dazu der Fehler.
                  Jan1 @smartboart last edited by
                  @smartboart
                  das ist alle 4 Stunden jede Minute
                  • smartboart
                    smartboart @Jan1 last edited by
                    @Jan1 oh ok..ich glaube ich sollte mich nochmal mit den Chron Zeiten auseinanderstzen..Danke!!!
                    • smartboart
                      ok danke..hab ich mir gedacht, macht auch keine Probleme. Wenn du oder sonst wer dennoch ne Idee hat wie man diese gyp und nan Warnungen abstellt, gerne her damit.....
                        darkiop Most Active @apollon77 last edited by
                        @apollon77
                        Das ist alles von heute aufm Slave ab dem Zeitpunkt des Redis-Tests:
                        log_slave.txt
                          Sooooooo @darkiop Super Feedback!!
                          Die 2.0.32 ist auf GitHub, könntest Du alle 4 cases nochmal checken bitte?
                          Bisher wurden Adapter beim verlieren der States Connection beendet, aber der Host hat nur bei Objects-DB-verlust was getan ... Damit gab es Edge cases. Ist jetzt geändert.
                            darkiop Most Active last edited by
                            Danke. Ich schau mal ob ich heut noch dazu komme 😄
                              @apollon77 Noch ne Frage, kann ich eigentlich auch über Github eine alte Version ziehen? Also wie müsste ich z.b. vorgehen wenn ich jetzt wieder die 2.0.25 möchte für die es aber keine NPM Version gibt?
                              • SBorg
                                Die Versionsnummer mit anhängen (geht bei allen NPM-Paketen), also npm install ioBroker/ioBroker.js-controller@2.0.25
                                  @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                                  Das war jetzt doch Aufwändiger als Gedacht, siehe TF3 😄
                                  tf_2-0-32.pdf
                                  Mein Log von Heute ging eben auch per Mail an dich raus.
                                  apollon77 2 Replies Last reply Reply Quote 0
                                    darkiop Most Active @SBorg last edited by
                                    @SBorg Jep, das kenne ich - hab mich glaub falsch ausgedrückt. Kann ich auch zu einem Zeitpunkt eines Commits springen zu dem es keine Version gibt?
                                      @darkiop geht nicht. Nur eine npm Version oder aktuellen GitHub Stand. Ansonsten ginge noch ein spezifischer GitHub Commit, was äquivalent zu einem alten Stand wäre.
                                      Wozu brauchst Du die 2.0.25?
                                        @apollon77 die 2.0.25 musste nur als Beispiel herhalten 😉 wie würde der spezifische commit ausschauen?
                                          @darkiop Ooooohhhkkkkk ... 🙂
                                          Bei testfall 3 sieht man das er "restart" aufruft aber scheinbar wieder kein Restart passiert ... 😞
                                            @darkiop puuuhh da muss ich mal schauen ...
                                            Per Kommandozeile wäre es denke ich Bei zB 2.0.26 als https://github.com/ioBroker/ioBroker.js-controller/commit/2b2bb746da26cd06862a78a4eb1a1cf209e85d3e
                                            dann
                                            npm install ioBroker/ioBroker.js-controller#2b2bb746da26cd06862a78a4eb1a1cf209e85d3e
                                            0 Apollon77 committed to ioBroker/ioBroker.js-controller
                                            2.0.26: fixId fix
                                            js-controller
                                            48
                                            1047
                                            312284
