    4. [Aufruf] Hue Adapter 2.0.0
    • dslraser
      dslraser Forum Testing Most Active @foxriver76 last edited by
      @foxriver76
      okay, also macht es wohl doch keinen Sinn die alte Struktur zu behalten.
        brain last edited by
        @foxriver76
        Hi, ich habe gestern den Adapter auf Version 2.0.1geupdatet (parallel zum Update des js-controllers auf 2.0). Auf die neue Objektstruktur bin ich umgestiegen.
        Nun läuft mein Log mit Meldungen des hue-Adapters voll:
        2019-10-13 20:20:50.637 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
        2019-10-13 20:20:50.638 - warn: hue.0 (16313) lightQueue: retry [1/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
        2019-10-13 20:20:50.666 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
        2019-10-13 20:20:50.666 - warn: hue.0 (16313) lightQueue: retry [2/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
        2019-10-13 20:20:50.693 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
        2019-10-13 20:20:50.694 - warn: hue.0 (16313) lightQueue: retry [3/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
        2019-10-13 20:20:50.720 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
        2019-10-13 20:20:50.721 - warn: hue.0 (16313) lightQueue: retry [4/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
        2019-10-13 20:20:50.747 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
        2019-10-13 20:20:50.748 - warn: hue.0 (16313) lightQueue: retry [5/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
        2019-10-13 20:20:50.774 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
        2019-10-13 20:20:50.775 - warn: hue.0 (16313) lightQueue: retry [6/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
        2019-10-13 20:20:50.802 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
        2019-10-13 20:20:50.803 - warn: hue.0 (16313) lightQueue: retry [7/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
        2019-10-13 20:20:50.830 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
        2019-10-13 20:20:50.831 - warn: hue.0 (16313) lightQueue: retry [8/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
        2019-10-13 20:20:50.857 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
        2019-10-13 20:20:50.858 - warn: hue.0 (16313) lightQueue: retry [9/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
        2019-10-13 20:20:50.886 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
        2019-10-13 20:20:50.887 - warn: hue.0 (16313) lightQueue: retry [10/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
        2019-10-13 20:20:50.913 - error: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec max retry reached: Error: Unknown type, On/Off plug-in unit,
        Ich denke, das sind Probleme mit einem OSRAM Smart+ Plug, den ich davor einwandfrei schalten konnte. Die Steckdose ist zwar unter den Objekten angelegt, jedoch zeigt sie keine Reaktion, wenn ich den "ON"-Datenpunkt auf true setze.
        Gibt es einen Lösungsansatz?
        • foxriver76
          foxriver76 Developer @brain last edited by
          @brain Hast du von GitHub installiert? Probier bitte Nochmal von GitHub. Gab einige Inkompatibelitäten mit der node-hue-api v3. Ansonsten bitte die offizielle 2.0.0 nutzen die sollte auf jeden Fall gehen.
          • dslraser
            @foxriver76 sagte in [Aufruf] Hue Adapter 2.0.0:
            Wird wohl das Problem sein, werden wohl nur bei Neuanlage automatisch vom Adapter korrigiert.
            Alle Objekte gelöscht, neu angelegt mit neuer Struktur, alles für iot bearbeit (und x Scripte), aber läuft wie wie gewünscht.
              sveni_lee @arteck last edited by
              @arteck
              Ja, das klappt bei mir auch... aber wenn beide Lampen Tisch(1) und Tisch(2) abgeschaltet werden und zwar einzeln und nicht über die Gruppe, bleibt die Gruppe auf ON = true obwohl alles Lampen in der Gruppe auf false stehen.
                Stormbringer @dslraser last edited by
                @dslraser sagte in [Aufruf] Hue Adapter 2.0.0:
                Darf man fragen wie viele Lampen du hast? 🙈 Hab 65, glaub kann mir da 2 wochen urlaub nehmen falls ich mal updaten muss 😂😂
                foxriver76 dslraser 2 Replies Last reply Reply Quote 0
                • foxriver76
                  foxriver76 Developer @Stormbringer last edited by
                  Naja eigentlich müssten nur die min/Max Werte der Objekte angepasst werden. Würde auch mit einem kleinen Skript gehen. Und ansonsten kann man die Struktur ja auch halten durch die Option in den Adaptereinstellungen nur in den Cloud Adapter müsste man die Geräte dann neu aufnehmen.
                  • dslraser
                    dslraser Forum Testing Most Active @Stormbringer last edited by
                    @Stormbringer sagte in [Aufruf] Hue Adapter 2.0.0:
                    37
                      brain @foxriver76 last edited by
                      @foxriver76
                      Ich habe nun direkt auf 2.1.0 geupdatet (über GitHub). Die Fehler im Log tauchen immer noch auf. Allerdings kann ich die Steckdose nun wieder schalten - wenn auch nur über den Raum und nicht direkt über den Datenpunkt.
                      Meinst du ein Downgrade auf 2.0.0 könnte sinnvoll sein?
                      • foxriver76
                        foxriver76 Developer @brain last edited by foxriver76
                        @brain ja 2.0.0 und 2.0.1 nutzen noch die alte node-hue-api. Dann schaue ich mal was da nicht tut in der neuen Version.
                        Allerdings ist das nicht die 2.0.1 die du von GitHub installiert hast die auf npm ist.
                          @foxriver76
                          Danke. Mit Version 2.0.0 funktioniert es.
                            Apropo last edited by
                            Ich kann leider nicht bestätigen, dass der Adapter beim Motion Sensor die Werte aus der App übernimmt. Und an/aus schalten des Sensors über den Adapter geht natürlich auch nicht. Installiert ist die 2.1.0 von Github. Firmware der Bridge ist auf dem neusten Stand.
                            Der Zustand vom DP "on" bleibt bei mir immer auf true stehen, wenn ich in der App aus schalte. Das einzige das sich ändert ist der DP "lastupdatet" wo mir dann Invalid Date angezeigt wird. Im Screenshot sieht man es ganz gut. Der obere Sensor ist per App eingeschaltet, der untere ausgeschaltet.
                            Wenn ich versuche per Datenpunkt "on" den Sensor auf false/true zu setzen kommt folgendes im Log falls dir das hilft:
                            hue.0	2019-10-16 11:37:41.684	error	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb max retry reached: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            hue.0	2019-10-16 11:37:41.666	warn	lightQueue: retry [10/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                            hue.0	2019-10-16 11:37:41.666	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            hue.0	2019-10-16 11:37:41.636	warn	lightQueue: retry [9/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                            hue.0	2019-10-16 11:37:41.631	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            hue.0	2019-10-16 11:37:41.601	warn	lightQueue: retry [8/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                            hue.0	2019-10-16 11:37:41.601	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            hue.0	2019-10-16 11:37:41.575	warn	lightQueue: retry [7/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                            hue.0	2019-10-16 11:37:41.575	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            hue.0	2019-10-16 11:37:41.551	warn	lightQueue: retry [6/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                            hue.0	2019-10-16 11:37:41.547	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            hue.0	2019-10-16 11:37:41.516	warn	lightQueue: retry [5/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                            hue.0	2019-10-16 11:37:41.511	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            hue.0	2019-10-16 11:37:41.488	warn	lightQueue: retry [4/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                            hue.0	2019-10-16 11:37:41.484	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            hue.0	2019-10-16 11:37:41.461	warn	lightQueue: retry [3/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                            hue.0	2019-10-16 11:37:41.457	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            hue.0	2019-10-16 11:37:41.433	warn	lightQueue: retry [2/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                            hue.0	2019-10-16 11:37:41.429	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            hue.0	2019-10-16 11:37:41.409	warn	lightQueue: retry [1/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                            hue.0	2019-10-16 11:37:41.402	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                            Wenn ich sonst irgendwie helfen kann einfach schreien ....
                            • foxriver76
                              foxriver76 Developer @Apropo last edited by foxriver76
                              @Apropo schalten geht noch nicht.
                              Ist allerdings nur noch eine Kleinigkeit. Wann hast du von GitHub installiert. Wenn lauffähige Versionen gewünscht sind bitte maximal latest eher stable nutzen.
                              Siehe auch https://github.com/iobroker-community-adapters/ioBroker.hue/issues/76
                              foxriver76 created this issue in iobroker-community-adapters/ioBroker.hue
                              closed [2.1.0] Osram Smart Plug #76
                                Apropo @foxriver76 last edited by Apropo
                                @foxriver76 die 2.1 von Github habe ich vor ner guten Stunde installiert. Vorher hatte ich es mit der 2.0 aus dem latest probiert die ich gestern Mittag installiert hatte. Beides mit dem selben Ergebnis.
                                • foxriver76
                                  @Apropo also mit der offiziellen 2.1 sollten alle Sensor States regelmäßig aktualisiert werden. Das was aktuell auf GitHub liegt ist mit Vorsicht zu genießen.
                                    @foxriver76 ok, bin jetzt zurück auf 2.0 und warte brav auf ein Update
                                    31.7k
                                    79.8k
                                    hue hue adapter tester
                                    19
                                    86
                                    7456
