    4. IoBroker reagiert nicht mehr
      wortmann30 last edited by
      Ist das das Fehler Log? Hilft das was?
      Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
      host-raspberrypi	2015-09-29 20:11:05	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:11:05	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:11:04	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:11:04	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:11:02	info	instance system.adapter.web.0 started with pid 6862
      host-raspberrypi	2015-09-29 20:10:59	info	instance system.adapter.admin.0 started with pid 6860
      host-raspberrypi	2015-09-29 20:10:55	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:10:55	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:10:54	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:10:54	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:10:53	info	instance system.adapter.history.0 started with pid 6850
      host-raspberrypi	2015-09-29 20:10:52	info	instance system.adapter.hmm.0 started with pid 6848
      host-raspberrypi	2015-09-29 20:10:32	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:10:32	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:10:29	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:10:29	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:10:29	info	instance system.adapter.web.0 started with pid 6838
      host-raspberrypi	2015-09-29 20:10:25	info	instance system.adapter.admin.0 started with pid 6836
      host-raspberrypi	2015-09-29 20:10:23	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:10:23	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:10:22	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:10:22	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:10:21	info	instance system.adapter.history.0 started with pid 6826
      host-raspberrypi	2015-09-29 20:10:20	info	instance system.adapter.hmm.0 started with pid 6824
      host-raspberrypi	2015-09-29 20:09:59	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:09:59	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:09:57	info	instance system.adapter.web.0 started with pid 6818
      host-raspberrypi	2015-09-29 20:09:55	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:09:55	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:09:51	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:09:51	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:09:50	info	instance system.adapter.admin.0 started with pid 6808
      host-raspberrypi	2015-09-29 20:09:50	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:09:50	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:09:49	info	instance system.adapter.history.0 started with pid 6802
      host-raspberrypi	2015-09-29 20:09:48	info	instance system.adapter.hmm.0 started with pid 6800
      host-raspberrypi	2015-09-29 20:09:27	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:09:27	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:09:24	info	instance system.adapter.web.0 started with pid 6794
      host-raspberrypi	2015-09-29 20:09:20	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:09:20	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:09:19	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:09:19	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:09:18	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:09:18	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:09:17	info	instance system.adapter.history.0 started with pid 6780
      host-raspberrypi	2015-09-29 20:09:16	info	instance system.adapter.hmm.0 started with pid 6778
      host-raspberrypi	2015-09-29 20:09:15	info	instance system.adapter.admin.0 started with pid 6776
      host-raspberrypi	2015-09-29 20:08:54	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:08:54	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:08:52	info	instance system.adapter.web.0 started with pid 6770
      host-raspberrypi	2015-09-29 20:08:47	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:08:47	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:08:46	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:08:46	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:08:45	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:08:45	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:08:45	info	instance system.adapter.history.0 started with pid 6756
      host-raspberrypi	2015-09-29 20:08:44	info	instance system.adapter.hmm.0 started with pid 6754
      host-raspberrypi	2015-09-29 20:08:41	info	instance system.adapter.admin.0 started with pid 6752
      host-raspberrypi	2015-09-29 20:08:22	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:08:22	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:08:19	info	instance system.adapter.web.0 started with pid 6746
      host-raspberrypi	2015-09-29 20:08:15	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:08:15	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:08:14	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:08:14	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:08:13	info	instance system.adapter.history.0 started with pid 6736
      host-raspberrypi	2015-09-29 20:08:12	info	instance system.adapter.hmm.0 started with pid 6734
      host-raspberrypi	2015-09-29 20:08:11	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:08:11	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:08:06	info	instance system.adapter.admin.0 started with pid 6728
      host-raspberrypi	2015-09-29 20:07:49	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:07:49	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:07:47	info	instance system.adapter.web.0 started with pid 6722
      host-raspberrypi	2015-09-29 20:07:43	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:07:43	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:07:42	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:07:42	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:07:41	info	instance system.adapter.history.0 started with pid 6712
      host-raspberrypi	2015-09-29 20:07:40	info	instance system.adapter.hmm.0 started with pid 6710
      host-raspberrypi	2015-09-29 20:07:36	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:07:36	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:07:32	info	instance system.adapter.admin.0 started with pid 6704
      host-raspberrypi	2015-09-29 20:07:17	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:07:17	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:07:14	info	instance system.adapter.web.0 started with pid 6698
      host-raspberrypi	2015-09-29 20:07:11	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:07:11	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:07:10	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:07:10	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:07:09	info	instance system.adapter.history.0 started with pid 6688
      host-raspberrypi	2015-09-29 20:07:08	info	instance system.adapter.hmm.0 started with pid 6686
      host-raspberrypi	2015-09-29 20:07:02	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:07:02	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:06:57	info	instance system.adapter.admin.0 started with pid 6680
      host-raspberrypi	2015-09-29 20:06:44	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:06:44	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:06:41	info	instance system.adapter.web.0 started with pid 6674
      host-raspberrypi	2015-09-29 20:06:39	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:06:39	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:06:38	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:06:38	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:06:36	info	instance system.adapter.history.0 started with pid 6664
      host-raspberrypi	2015-09-29 20:06:35	info	instance system.adapter.hmm.0 started with pid 6662
      host-raspberrypi	2015-09-29 20:06:27	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:06:27	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:06:22	info	instance system.adapter.admin.0 started with pid 6656
      host-raspberrypi	2015-09-29 20:06:11	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:06:11	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:06:08	info	instance system.adapter.web.0 started with pid 6650
      host-raspberrypi	2015-09-29 20:06:06	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:06:06	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:06:05	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:06:05	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:06:04	info	instance system.adapter.history.0 started with pid 6640
      host-raspberrypi	2015-09-29 20:06:03	info	instance system.adapter.hmm.0 started with pid 6638
      host-raspberrypi	2015-09-29 20:05:52	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:05:52	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:05:47	info	instance system.adapter.admin.0 started with pid 6632
      host-raspberrypi	2015-09-29 20:05:38	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:05:38	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:05:35	info	instance system.adapter.web.0 started with pid 6626
      host-raspberrypi	2015-09-29 20:05:34	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:05:34	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:05:33	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:05:33	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:05:31	info	instance system.adapter.history.0 started with pid 6616
      host-raspberrypi	2015-09-29 20:05:30	info	instance system.adapter.hmm.0 started with pid 6614
      host-raspberrypi	2015-09-29 20:05:17	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:05:17	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:05:11	info	instance system.adapter.admin.0 started with pid 6608
      host-raspberrypi	2015-09-29 20:05:05	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:05:05	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:05:02	info	instance system.adapter.web.0 started with pid 6602
      host-raspberrypi	2015-09-29 20:05:01	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:05:01	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:05:00	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:05:00	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:04:58	info	instance system.adapter.history.0 started with pid 6592
      host-raspberrypi	2015-09-29 20:04:58	info	instance system.adapter.hmm.0 started with pid 6590
      host-raspberrypi	2015-09-29 20:04:41	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:04:41	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:04:36	info	instance system.adapter.admin.0 started with pid 6584
      host-raspberrypi	2015-09-29 20:04:32	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:04:32	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:04:29	info	instance system.adapter.web.0 started with pid 6578
      host-raspberrypi	2015-09-29 20:04:28	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:04:28	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:04:28	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:04:28	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:04:25	info	instance system.adapter.history.0 started with pid 6568
      host-raspberrypi	2015-09-29 20:04:25	info	instance system.adapter.hmm.0 started with pid 6566
      host-raspberrypi	2015-09-29 20:04:06	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:04:06	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:03:59	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:03:59	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:03:59	info	instance system.adapter.admin.0 started with pid 6560
      host-raspberrypi	2015-09-29 20:03:55	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:03:55	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:03:55	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:03:55	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:03:54	info	instance system.adapter.web.0 started with pid 6550
      host-raspberrypi	2015-09-29 20:03:51	info	instance system.adapter.hmm.0 started with pid 6544
      host-raspberrypi	2015-09-29 20:03:50	info	instance system.adapter.history.0 started with pid 6542
      host-raspberrypi	2015-09-29 20:03:28	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:03:28	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:03:24	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:03:24	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:03:21	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:03:21	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:03:21	info	instance system.adapter.admin.0 started with pid 6532
      host-raspberrypi	2015-09-29 20:03:20	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:03:20	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:03:17	info	instance system.adapter.web.0 started with pid 6522
      host-raspberrypi	2015-09-29 20:03:16	info	instance system.adapter.hmm.0 started with pid 6520
      host-raspberrypi	2015-09-29 20:03:15	info	instance system.adapter.history.0 started with pid 6518
      host-raspberrypi	2015-09-29 20:02:51	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-29 20:02:51	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:02:47	info	Restart adapter system.adapter.web.0 because enabled
      host-raspberrypi	2015-09-29 20:02:47	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:02:46	info	Restart adapter system.adapter.hmm.0 because enabled
      host-raspberrypi	2015-09-29 20:02:46	error	instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:02:45	info	Restart adapter system.adapter.history.0 because enabled
      host-raspberrypi	2015-09-29 20:02:45	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-raspberrypi	2015-09-29 20:02:38	info	instance system.adapter.history.0 started with pid 6499
      host-raspberrypi	2015-09-29 20:02:38	info	instance system.adapter.hmm.0 started with pid 6498
      host-raspberrypi	2015-09-29 20:02:38	info	instance system.adapter.web.0 started with pid 6496
      host-raspberrypi	2015-09-29 20:02:38	info	instance system.adapter.admin.0 started with pid 6494
      host-raspberrypi	2015-09-29 20:02:15	info	instance system.adapter.vis.0 terminated while should be started once
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.16.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.16.WORKING extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.16.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.16.STATE extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.16.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.16.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.16.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.15.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.15.WORKING extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.15.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.15.STATE extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.15.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.15.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.15.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.14.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.14.WORKING extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.14.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.14.STATE extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.14.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.14.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.14.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.13.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.13.WORKING extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.13.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.13.STATE extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.13.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.13.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.13.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.12.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.12.WORKING extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.12.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.12.STATE extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.12.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.12.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.12.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.11.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.11.WORKING extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.11.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.11.STATE extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.11.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.11.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.11.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.10.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.10.WORKING extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.10.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.10.STATE extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.10.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.10.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.10.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.9.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.9.WORKING extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.9.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.9.STATE extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.9.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.9.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.9.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.8.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.8.WORKING extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.8.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.8.STATE extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.8.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.8.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.8.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.7.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.7.WORKING extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.7.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.7.STATE extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.7.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.7.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.7.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:14	info	object hm-rpc.2.CUX2800001.6.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.6.WORKING extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.6.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.6.STATE extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.6.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.6.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.6.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.5.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.5.WORKING extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.5.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.5.STATE extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.5.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.5.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.5.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.4.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.4.WORKING extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.4.TIMER_GET extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.4.STATE extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.4.TIMER_EVENT extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.4.TIMER_STOP extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.4.TIMER_SET extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.3.CMD_RET extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.3.WORKING extended
      hm-rpc-2	2015-09-29 20:02:13	info	object hm-rpc.2.CUX2800001.3.TIMER_GET extended
        Dass er langsam ist ist klar, der beendet sich dauernd selber und startet wieder.
        Bei einem error code7 hilft nur ein kompletter reboot des raspi.
        Rainer
          Hi
          ok
          werde ich restarten. Dazu muss ich den Keller. 😄
          Noch ne Frage, wo und wie kann ich was mit einem Backup sichern? Vis, ioBroker,…?
            Hm es schein mir der Raspi hat eine Problem er startet nicht mehr.
            es kommt der bunte Bildschirm dann kommt der shift mode zur recovery, es laufen die Aktionen durch aber dann ist ende der Home Bildschirm baut sich nicht auf… Und es bleibt schwarz und auf dem raspi leuchtet die Rote und Grüne LED...
            Ich denke ich muss neu aufsetzen und Mit Festplatte arbeiten...
            Bzw. vielleicht schalte ich ihn mal aus und lass ihn ne weile in ruhe und versuche es nochmal und sichere die Daten um es nachher einfacher zu haben aber dazu muss ich wissen was macht Sinn zu sichern?
              @wortmann30:
              Dazu muss ich den Keller. `
              Warum?
              Bist du nicht mit putty drauf?
              und da "(sudo) reboot"
              Einfach Stecker raus kann die SD-Karte schrotten!
              Rainer
                @Homoran:
                nicht mit putty drauf? `
                Nein habe einen Reboot direkt gemacht mit dem raspi Bildschirm gemacht. Und dann kommt er nicht mehr hoch.
                @Homoran:
                Einfach Stecker raus kann die SD-Karte schrotten! `
                So nachdem er nicht mehr kommt kann ich nur den Stecker ziehen…
                  Mist!
                  Ja jetzt kannst du Stecker ziehen 😞
                  Aber ich versteh es nicht.
                  Ich habe seitdem es einen Pi2 gibt die iobroker Installation darauf am laufen - noch nie Ärger mit der Karte gehabt.
                  Eine schnelle und ausreichend große Karte damit genug Zellen zum Schreiben genutzt werden und bessere Qualität sind einfach wichtig.
                  Bei mir ist es eine 16GB intenso Class 10.
                  Mit Billigkarten wie Medion und Platinum habe ich auch Probleme gehabt - sogar im Handy.
                  Alternativ habe ich noch Samsung UHS-I 32GB im Gebrauch - erstmal testweise.
                  Viel Erfolg
                  Rainer
                  PS selbst wenn nach formatieren die Karte wieder läuft - lass es!
                    @Homoran:
                    Mist!
                    PS selbst wenn nach formatieren die Karte wieder läuft - lass es! `
                    Ich denke wenn ich die Nur zum Booten nutze und den Rest auf eine Festplatte mache sollte das doch gehen?
                    ich habe eine Samsung 16GB class 10 karte… ist doch auch kein billig schrott oder?
                    Auf jeden fall habe ich die Karte gerade gezogen und wieder gesteckt und eben etwas gewartet und nun ist er wieder da!
                    Was soll ich sichern?
                      @wortmann30:
                      ich habe eine Samsung 16GB class 10 karte… ist doch auch kein billig schrott oder? `
                      Ich hoffe nicht. Die habe ich im RasPi1 und jetzt habe ich von den neuen Samsung evo direkt mal 5 gekauft.
                      der einfachste weg ist den gesamten ordner /opt/iobroker.
                      Dann hast du alles und kannst es bei Bedarf da wieder rausziehen.
                      Rainer
                        @Homoran:
                        Dann hast du alles und kannst es bei Bedarf da wieder rausziehen. `
                        ok drei Fragen:
                        Wie
                        Wohin
                        und was wie rausziehen? Alles wieder bei der neu Installation rein kopieren?
                          ok, drei Fragen:
                          Was willst du?
                          Warum willst du das?
                          Wie willst du das machen?
                          :mrgreen:
                          Entscheidend ist doch, wofür du die Sicherung nutzen willst.
                          Wenn du jetzt komplett neu aufbauen willst, willst du doch sicher nicht korrupte Daten mit übernehmen.
                          Also kompletter Neuaufbau und dann nur ein paar Konfigurationsdaten übernehmen (ist üblicherweise aber nicht der Rede wert, die neu zu machen)
                          Also views aus .vis; flows aus node-red wieder einspielen.
                          Geht. - Hier vielleicht auch für die eigene Doku diese Views und flows als einzelne textfiles exportieren und ggf. nach einem Crash wieder einzeln importieren!
                          ältere Verlaufsdaten wieder einspielen. Also die history-Daten zu den neuen hinzuspielen.
                          Es gibt viele Szenarien.
                          Wohin?
                          per ftp auf den Rechner.
                          Da war das "wie" mit dabei 😉
                          Rainer
                            Kurze Antwort:
                            ich weiß es noch nicht genau. Hauptsache spielen und probieren. Und was sicher ist ein Tablett an die Wand nageln und Vergangenheit werte auslesen, z.B. wie hat sich der Füllstand der Zisterne entwickelt…
                            Habe jetzt den Ordner iobroker gesichert. Werde nun den PI die nächsten Tage neu aufsetzen. Mit dem Ordner sollte ich ja alles haben auch die VIS Ansichten oder?
                              @wortmann30:
                              Mit dem Ordner sollte ich ja alles haben auch die VIS Ansichten oder? `
                              Ja, aber ich empfehle dir trotzdem alle nochmal einzeln als Textfile zu exportieren.
                              Wenn dann ein View mal die gesamte view-json zerschiesst, nutzt es nichts die wieder einzulesen.
                              Rainer
                                Und wie geht das? Ich habe das nicht verstanden. Vor allem finde ich den Speicherort der Views nicht.
                                  Du gehst im vis editor auf den Reiter Views, wählst deinen View aus und klickst oben in der Werkzeugleiste auf View exportieren 😉
                                    Danke Kapiert! und Kopiert 😄
                                    3023
