    2. English
    3. Scripting / Logic
    5. ASTRO function. Does not work again
      Ok, in the settings from the javascript-Adapter you must set your location, or check to use the ioBroker location.
      Enrico
        ap2017 @RappiRN last edited by
        @RappiRN I am aware of this and it was done. Don't forget, in my case ASTRO work right once after fresh power up, it turns up the light in expected time.
          The right once working, is it also at the right time?
          Which location settings you are using, from the adapter or from ioBroker? Sometimes it was a problem to use the ioBroker settings instead the adapter settings.
          Sorry i have not really an idea what the matter with your astro-function.
          Enrico
            ap2017 @RappiRN last edited by ap2017
            @RappiRN Yes, when I say it works right once, it means the timing is right. I tried both location settings, from the adapter as well as from system with same result.
              ap2017 last edited by
              Have brand new ioBroker installation on different platform (x64) with same script as show above, the Astro function still does not work. What am I doing wrong?
              • iomountain
                iomountain last edited by iomountain
                @ap2017 for debuging use debug, not telegram.
                substitute telegram whith debug to see what's going on.
                Look at the LOG.
                mine works:
                c8d8d908-8721-440c-b8e0-f1d21907f888-image.png ,
                Do you wanna Post an export of your Blockly?
                  ap2017 @iomountain last edited by
                  @iomountain Thank you for your response. I changed my script as you suggested, where do I find debugging log?
                  • iomountain
                    Try Log at main screen Admin
                    There you will find your "debug output" Messages
                      @iomountain I think that after long time of straggling I am getting close to resolving the issue with ASTRO function that I am experiencing. It looks like ASTRO algorithm does not like GEO coordinates in North America since it started to work fine after I set ASTRO for Berlin, Germany. Maybe negative value of Longitude confuses the algorithm?
                      Could you do me a favor and try your script with GEO set to Hartford CT in USA? Thank you.
                      • iomountain
                        It works, United States Hartford 41.76 -72.68
                        If you wanna see all astro times try the Script
                        // Astrotime for today - V2.0
                        console.log("=====================");
                        console.log("Astro time for today");
                        var nightEnd = getAstroDate("nightEnd");
                        console.log(" (0) nightEnd (End of night)........................: " + nightEnd.toLocaleTimeString());
                        var nauticalDawn = getAstroDate("nauticalDawn");
                        console.log(" (1) nauticalDawn (naut. Dämmerung Morgens)...........: " + nauticalDawn.toLocaleTimeString());
                        var dawn = getAstroDate("dawn");
                        console.log(" (2) dawn (Dämmerung Morgens).........................: " + dawn.toLocaleTimeString());
                        var sunrise = getAstroDate("sunrise");
                        console.log(" (3) sunrise (Sonnenaufgang)..........................: " + sunrise.toLocaleTimeString());
                        var sunriseEnd = getAstroDate("sunriseEnd");
                        console.log(" (4) sunriseEnd (Ende des Sonnenaufgangs).............: " + sunriseEnd.toLocaleTimeString());
                        var goldenHourEnd = getAstroDate("goldenHourEnd");
                        console.log(" (5) goldenHourEnd (Ende der Golden Hour VM)..........: " + goldenHourEnd.toLocaleTimeString());
                        var solarNoon = getAstroDate("solarNoon");
                        console.log(" (6) solarNoon (Mittag)...............................: " + solarNoon.toLocaleTimeString());
                        var goldenHour = getAstroDate("goldenHour");
                        console.log(" (7) goldenHour (Start der Golden Hour NM)............: " + goldenHour.toLocaleTimeString());
                        var sunsetStart = getAstroDate("sunsetStart");
                        console.log(" (8) sunsetStart (Start des Sonnenuntergangs).........: " + sunsetStart.toLocaleTimeString());
                        var sunset = getAstroDate("sunset");
                        console.log(" (9) sunset (Sonnenuntergang).........................: " + sunset.toLocaleTimeString());
                        var dusk = getAstroDate("dusk");
                        console.log("(10) dusk (Dämmerung Abends)..........................: " + dusk.toLocaleTimeString());
                        var nauticalDusk = getAstroDate("nauticalDusk");
                        console.log("(11) nauticalDusk (naut. Dämmerung Abends)............: " + nauticalDusk.toLocaleTimeString());
                        var night = getAstroDate("night");
                        console.log("(12) night (Start of night)..........................: " + night.toLocaleTimeString());
                        var nadir = getAstroDate("nadir");
                        console.log("(13) nadir (midnight)..............................: " + nadir.toLocaleTimeString());
                        var today = new Date();
                        var tomorrow = today.setDate(today.getDate()+1);
                        var tomorrowNight = getAstroDate("night", tomorrow);
                        console.log("Night starts tomorrow at " + tomorrowNight.toLocaleTimeString());
                        console.log(obj.id);
                        @ap2017
                          @iomountain I will try to set ASTRO back to US, thanks
                          • iomountain
                            @ap2017 don't forget to restart iobroker. Like "iobroker stop" and "iobroker start"
                            A 2 Replies Last reply Reply Quote 0
                              @iomountain Day I switched to US the ASTRO stopped working (no ASTRO string in LOG file). I restarted computer after I made a change. I will try your ASTRO script
                              Here is my script:
                              // Living Room Light
                              schedule({astro: "goldenHour", shift: 0}, function () {
                              console.log('astro_on');
                              setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
                              schedule("0 18 * * *", function () {
                              console.log('schedule_on');
                              schedule("30 23 * * *", function () {
                              console.log('schedule_off');
                              setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
                                @iomountain Here is the log from running your script Astro Time for Today, if it helps. So, script runs but shows error code at the end of each run.
                                2019-10-19 18:48:42.414 - info: mysensors.0 (18452) STARTED
                                2019-10-19 18:48:42.415 - info: mysensors.0 (18452) STARTED
                                2019-10-19 18:48:55.725 - info: javascript.0 (18920) Stop script script.js.ASTRO
                                2019-10-19 18:48:55.770 - info: javascript.0 (18920) Start javascript script.js.ASTRO
                                2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: =====================
                                2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: Astro time for today
                                2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: (0) nightEnd (End of night)........................: 5:36:06 AM
                                2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (1) nauticalDawn (naut. Dämmerung Morgens)...........: 6:08:18 AM
                                2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (2) dawn (Dämmerung Morgens).........................: 6:40:39 AM
                                2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (3) sunrise (Sonnenaufgang)..........................: 7:08:50 AM
                                2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (4) sunriseEnd (Ende des Sonnenaufgangs).............: 7:11:46 AM
                                2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (5) goldenHourEnd (Ende der Golden Hour VM)..........: 7:46:57 AM
                                2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (6) solarNoon (Mittag)...............................: 12:37:25 PM
                                2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (7) goldenHour (Start der Golden Hour NM)............: 5:27:52 PM
                                2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (8) sunsetStart (Start des Sonnenuntergangs).........: 6:03:04 PM
                                2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (9) sunset (Sonnenuntergang).........................: 6:06:00 PM
                                2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (10) dusk (Dämmerung Abends)..........................: 6:34:11 PM
                                2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (11) nauticalDusk (naut. Dämmerung Abends)............: 7:06:31 PM
                                2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (12) night (Start of night)..........................: 7:38:44 PM
                                2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (13) nadir (midnight)..............................: 12:37:25 AM
                                2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: =====================
                                2019-10-19 18:48:55.777 - info: javascript.0 (18920) script.js.ASTRO: Night starts tomorrow at 7:37:17 PM
                                2019-10-19 18:48:55.777 - error: javascript.0 (18920) script.js.ASTRO: script.js.ASTRO:41
                                2019-10-19 18:48:55.777 - error: javascript.0 (18920) console.log(obj.id);
                                2019-10-19 18:48:55.778 - error: javascript.0 (18920) ^
                                2019-10-19 18:48:55.778 - error: javascript.0 (18920) ReferenceError: obj is not defined
                                2019-10-19 18:48:55.778 - error: javascript.0 (18920) at script.js.ASTRO:41:13
                                2019-10-19 18:48:55.778 - error: javascript.0 (18920) at Script.runInContext (vm.js:133:20)
                                iomountain 1 Reply Last reply Reply Quote 0
                                • iomountain
                                  iomountain @ap2017 last edited by
                                  @ap2017 sagte in ASTRO function:
                                  shows that the AstroFunktion works
                                  What about the log of your script?
                                    @iomountain Here is my complete log from yesterday. Notice that in 18:58 I added your script with ASTRO Time for Day. Thank you for your help!
                                    10-20-19 Log.txt
                                    • iomountain
                                      something going wrong with ASTRO, still testing.
                                      • iomountain
                                        Could you please test this for 24 hours:
                                         <block type="comment" id="dZ/@oL!i0(@/:!$Ikw{J" x="13" y="13">
                                           <field name="COMMENT">Test Astro</field>
                                             <block type="astro" id="sxZ*u!O2O8lf$a?qgNf%">
                                               <field name="TYPE">sunrise</field>
                                               <field name="OFFSET">0</field>
                                                 <block type="debug" id="f0h|hnMOj,t0a9F4R/*u">
                                                   <field name="Severity">error</field>
                                                   <value name="TEXT">
                                                     <shadow type="text" id="t~{SzkO:N+m/c:_aXvF_">
                                                       <field name="TEXT">Sonnenaufgang</field>
                                                     <block type="debug" id=";Kc+}!GR24eQ4F1zvsqz">
                                                       <value name="TEXT">
                                                         <shadow type="text" id="d7@Q.7Mu+wBczv=iaKT?">
                                                         <block type="time_get" id="0}ve}|zeLByf%Wn1)Z~N">
                                                           <mutation format="true" language="false"></mutation>
                                                           <field name="OPTION">custom</field>
                                                           <field name="FORMAT">JJJJ-MM-TT SS:mm:ss.sss</field>
                                                 <block type="astro" id="e%0Te`wUBXm0Z(Tm~(uK">
                                                   <field name="TYPE">sunriseEnd</field>
                                                     <block type="debug" id="~yMY;Z`RDhY|PgL8aLYT">
                                                       <value name="TEXT">
                                                         <shadow type="text" id="{(iRk-Wgsniu)/OWNuec">
                                                           <field name="TEXT">Sonnenaufgang ende</field>
                                                         <block type="debug" id="q|N1he7_#J*z!t:Lxbq4">
                                                           <value name="TEXT">
                                                             <block type="time_get" id="tJ*UF;cM+aI^pYR^Qa;1">
                                                     <block type="astro" id="7-p8CPh^EAGz7TZ[HE=f">
                                                       <field name="TYPE">goldenHourEnd</field>
                                                         <block type="debug" id="#jT`iz!Nlmm:r|h0-a;{">
                                                           <value name="TEXT">
                                                             <shadow type="text" id="sF]?KilHL=/lQ@|f$!#B">
                                                               <field name="TEXT">Golden hour Ende</field>
                                                             <block type="debug" id="?jcK[-lRY6m67kH94cJ8">
                                                               <value name="TEXT">
        <block type="time_get" id=":6c/3{e5w_Qr@--(F2,$">
                                                         <block type="astro" id="tK}:wS(k,Xmf4I2Ms^,]">
                                                           <field name="TYPE">solarNoon</field>
                                                             <block type="debug" id="sYbNw@$;Db5D:)VF)*b}">
                                                               <value name="TEXT">
        <shadow type="text" id="h9Pt!n;uDsK%[C8H0T:-">
        <field name="TEXT">Sonnenmittag</field>
        <block type="debug" id="0z@Vv^UhX8S(2Uk.L}AX">
        <value name="TEXT">
        <block type="time_get" id="63mXGB7G3:L?++1KLilu">
                                                             <block type="astro" id="2X-czA2y[$Ug?5[Q_aUV">
                                                               <field name="TYPE">goldenHour</field>
        <block type="debug" id="VvR2BxdbZn.+TuU)7yLe">
        <value name="TEXT">
        <shadow type="text" id="#r/L5Io)*?Qz!Co)U:Jc">
        <field name="TEXT">Golden hour</field>
        <block type="debug" id="vO^xDs|z,PXJo=OKQ=bY">
        <value name="TEXT">
        <block type="time_get" id="8b(z1|U:aT{s/-zQOG-O">
        <block type="astro" id="dLczmmMSoFlkvb*/H*SF">
        <field name="TYPE">sunsetStart</field>
        <block type="debug" id="S%o3:;|MkGT:WNoq-5I/">
        <value name="TEXT">
        <shadow type="text" id="oZW7=ox`@zO:d)Qo`jM#">
        <field name="TEXT">Sonnenuntergang Anfang</field>
        <block type="debug" id="88*2`mY-$F4-h46R$bsh">
        <value name="TEXT">
        <block type="time_get" id="=yV74{gTTEshyETA[YT+">
        <block type="astro" id="`E^X3.`tEYD#t?w3p[Y6">
        <field name="TYPE">sunset</field>
        <block type="debug" id="3y?c.oF8m3]qo`y^Sk2Y">
        <value name="TEXT">
        <shadow type="text" id="_^a1$PSDO%=0T$ouPs,z">
        <field name="TEXT">Sonnenuntergang</field>
        <block type="debug" id="B{Xk(=sas9lxfcPeH~8l">
        <value name="TEXT">
        <block type="time_get" id="?;boy8-PvsRtK^R`i(d!">
        <block type="astro" id="yk2LFSH:M4]t,=g+r0Zr">
        <field name="TYPE">dusk</field>
        <block type="debug" id="JVc5|ie7ToL`o0+q*H6)">
        <value name="TEXT">
        <shadow type="text" id=":3i#l]vFr9mFH`8A9d40">
        <field name="TEXT">Abenddämmerung</field>
        <block type="debug" id="}#5$Eg5HxUq%N?JiZUB|">
        <value name="TEXT">
        <block type="time_get" id="C8-_%?]~kLQbzj4$5M:w">
        <block type="astro" id="o1Y86d?aD}-85W@_Bc{X">
        <field name="TYPE">nauticalDusk</field>
        <block type="debug" id="[y[=-3!xjqWbFILYTKrT">
        <value name="TEXT">
        <shadow type="text" id="(Ka/nD(#:R%T5M;oQVo+">
        <field name="TEXT">Nautische Abenddämmerung</field>
        <block type="debug" id="hQnK;WRQD=[=PuGnpeC^">
        <value name="TEXT">
        <block type="time_get" id="1*6{GuA}Ptl}@=:RYN8E">
        <block type="astro" id="j8y_r:dEbMD7iY2.W7L,">
        <field name="TYPE">night</field>
        <block type="debug" id="76(?!SO)O1xP:}liKAC%">
        <value name="TEXT">
        <shadow type="text" id="hkdb,q:hVvOIp?ukBqRa">
        <field name="TEXT">Nacht</field>
        <block type="debug" id="K`Fpc2JYxRBNQEc[yo9_">
        <value name="TEXT">
        <block type="time_get" id="f.=BzucV$CL,2#_}W7wU">
        <block type="astro" id=",EU+9{ySUaqT/?CfG5ap">
        <field name="TYPE">nightEnd</field>
        <block type="debug" id="nk=,IYJu$$)~c%9EMNZL">
        <value name="TEXT">
        <shadow type="text" id="?@=$%L4#!G}2|rgS]c=?">
        <field name="TEXT">Nachtende</field>
        <block type="debug" id="U_1^p,G9]J.];Zq9X~LM">
        <value name="TEXT">
        <block type="time_get" id="Wq.(8ZwGLimw6:lfSa!V">
        <block type="astro" id="Sz%RA[al07GBMdE@p1Gz">
        <field name="TYPE">nauticalDawn</field>
        <block type="debug" id="`y(OGo$-nPG8Ej5m[BHG">
        <value name="TEXT">
        <shadow type="text" id="EOoN^Uh$_,d+JSl]lGUh">
        <field name="TEXT">Nautische Morgendämmerung</field>
        <block type="debug" id="0S99AV1F|DJLUd,(d?qc">
        <value name="TEXT">
        <block type="time_get" id="YOyQlgY?b(gtz4v^}j+H">
        <block type="astro" id="Vw^5UMBH6vtWJyaq53.]">
        <field name="TYPE">dawn</field>
        <block type="debug" id="19?SR^q{j;E8z!!;D7[)">
        <value name="TEXT">
        <shadow type="text" id="Ar4KDdxuaHRys!_~m2WV">
        <field name="TEXT">Morgendämmerung</field>
        <block type="debug" id="=m0|q1#NNjFK3(dAk!Ad">
        <value name="TEXT">
        <block type="time_get" id="78Wc.sXU9AC;tMV..MwN">
        <block type="astro" id="i`FUoNopylwQy:QgoJ}v">
        <field name="TYPE">nadir</field>
        <block type="debug" id="r(e93[h_`7D!QfmFL~Mf">
        <value name="TEXT">
        <shadow type="text" id="|P[TC/:yl.5FkD_HO*./">
        <field name="TEXT">Nadir</field>
        <block type="debug" id="Dhca#mXRR2KV}e}.Opj$">
        <value name="TEXT">
        <block type="time_get" id="f[j$/@]5]_7kP7mnP#ds">
                                        • iomountain
                                          Mine works:
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenmittag
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenuntergang Anfang
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Abenddämmerung
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Abenddämmerung
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nacht
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nadir
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nachtende
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Morgendämmerung
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Morgendämmerung
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang ende
                                          javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour Ende
                                          if you dont have all these "errors" in your log, we try next ideas, or compare Versions.
                                            @iomountain sorry, I am traveling now, will be able to try next week
                                            blockly
                                            7589
