    4. Test Adapter hue v2.2.x
    • integer63
      integer63 @foxriver76 last edited by
      @foxriver76 ... ich bekomme jetzt auch immer diese Log Einträge, wenn ich über command etwas einstelle (2.1.0):
      hue.0	2019-10-17 07:45:50.674	warn	groupQueue: retry [10/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
      hue.0	2019-10-17 07:45:50.674	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
      hue.0	2019-10-17 07:45:50.636	warn	groupQueue: retry [9/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
      hue.0	2019-10-17 07:45:50.636	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
      hue.0	2019-10-17 07:45:50.596	warn	groupQueue: retry [8/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
      hue.0	2019-10-17 07:45:50.596	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
      hue.0	2019-10-17 07:45:50.559	warn	groupQueue: retry [7/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
      hue.0	2019-10-17 07:45:50.558	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
      hue.0	2019-10-17 07:45:50.520	warn	groupQueue: retry [6/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
      hue.0	2019-10-17 07:45:50.519	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
      hue.0	2019-10-17 07:45:50.480	warn	groupQueue: retry [5/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
      hue.0	2019-10-17 07:45:50.480	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
      hue.0	2019-10-17 07:45:50.402	warn	groupQueue: retry [4/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
      hue.0	2019-10-17 07:45:50.402	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
      hue.0	2019-10-17 07:45:50.364	warn	groupQueue: retry [3/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
      hue.0	2019-10-17 07:45:50.364	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
      hue.0	2019-10-17 07:45:50.301	warn	groupQueue: retry [2/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
      hue.0	2019-10-17 07:45:50.301	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
      hue.0	2019-10-17 07:45:50.260	warn	groupQueue: retry [1/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
      hue.0	2019-10-17 07:45:50.260	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
      B foxriver76 2 Replies Last reply Reply Quote 0
        brain @integer63 last edited by
        @integer63 Meine Lösung war (vorerst): zurück zu 2.0.0.
        integer63 1 Reply Last reply Reply Quote 0
        • foxriver76
          foxriver76 Developer @integer63 last edited by foxriver76
          @integer63 Kannst du mir den exakten Befehl geben, den du in command setzt und in dem Error endet? Ah scheint allgemein ein Problem mit dem xy zu sein und nicht mit dem Command.
          • integer63
            @foxriver76 Aber gerne: {"on":true,"bri":150,"sat":255,"xy":"0.6062,0.3723"} - hat bisher immer funktioniert
              Apropo last edited by
              @foxriver76 Da es mit der 2.2 ja anscheinend noch Probleme gibt bleibe ich dann wohl erst mal auf 2.0 und warte auf eine 2.3 oder sowas. Oder soll ich trotzdem mal die 2.2 installieren um für dich was zu testen?
              • foxriver76
                foxriver76 Developer last edited by foxriver76
                Jop am besten erst mal auf stable bleiben. Also Fehler die ich bei 2.2.0 auf dem Schirm habe: xy fixen und Sensor DPs steuerbar machen. Falls noch was aufgefallen ist, bitte mitteilen.
                  WulfR @foxriver76 last edited by
                  @foxriver76: Hue SmartPlug Steckdosen (die neuen und auch die alten LivingWhites) lassen sich nicht mehr an/ausschalten, der Fehler wurde vorher schon beschrieben (10 retries, dann error "(13400) lightQueue: job lights.setLightState:54:ddf37ce8845696dc1ab9cc71330de8e9 max retry reached: Error: Unknown type, On/Off plug-in unit".
                  Ich nutze die Adapter Version 2.2.0 (über iobroker update, nicht über Github).
                  Meine Installation: HueBridge1 mit 44 Lampen/Steckdosen + 18 Schalter/Dimmer/Sensoren, HueBridge2 mit 12 Lampen/Steckdosen + 7 Schalter/Dimmer/Sensoren, beide Bridges mit Firmware version 1934129020, API 1.34.0
                  Gruß, Wulf.
                  • integer63
                    integer63 @brain last edited by
                    @brain Danke für den Hinweis. Ich bin auch zurück auf 2.0 und kann bestätigen, dass der Fehler da nicht auftritt.
                    • foxriver76
                      Das mit xy ist gefixt. Laut dem Entwickler der node-hue-api unterstützt sein Modul die Funktionalität für das ein/ausschalten von Sensoren derzeit nicht. Er wäre allerdings bereit es zu implementieren, hierfür benötigt er jedoch die Daten des Sensors.
                      Wenn mal jemand mit Presence Sensor auf den GitHub Stand updaten könnte + Upload, dann den on State ändert, sollte u. a. Send this info to developer geloggt werden. Bitte das JSON hier posten. Danke.
                      @WulfR Das mit den Plugs schaue ich mir heute Abend mal an.
                      sigi234 A 2 Replies Last reply Reply Quote 0
                        sigi234 Forum Testing Most Active @foxriver76 last edited by
                        @foxriver76 sagte in [Aufruf] Hue Adapter 2.0.0:
                        Nein, und wie das Json runterladen?
                        • foxriver76
                          foxriver76 Developer @sigi234 last edited by
                          @sigi234 ist nur ein Logeintrag
                            Ok, Adapter auf debug stellen?
                            • foxriver76
                              @sigi234 Ne wird auf warn geloggt, bsp von dem Daylight Sensor:
                              2019-10-17 15:40:59.059 - warn: hue.0 Send this info to developer: {"_rawData":{"state":{"daylight":null,"lastupdated":"none"},"config":{"on":true,"configured":false,"sunriseoffset":30,"sunsetoffset":-30},"name":"Daylight","type":"Daylight","modelid":"PHDL00","manufacturername":"Philips","swversion":"1.0"},"_id":1,"_type":"Daylight","_configAttributes":{"on":true,"configured":false,"sunriseoffset":30,"sunsetoffset":-30},"_stateAttributes":{"daylight":null,"lastupdated":"none"}}
                              2019-10-17 15:40:59.252 - warn: hue.0 lightQueue: job sensors.updateSensorState:Daylight
                              id: 1:a4673562807eb95955656f4ceefafe18 failed: Error: invalid value, null}, for parameter, daylight
                              2019-10-17 15:40:59.254 - warn: hue.0 lightQueue: retry [1/10] job sensors.updateSensorState:Daylight
                              2019-10-17 15:40:59.299 - warn: hue.0 lightQueue: job sensors.updateSensorState:Daylight
                              2019-10-17 15:40:59.300 - warn: hue.0 lightQueue: retry [2/10] job sensors.updateSensorState:Daylight
                              2019-10-17 15:40:59.344 - warn: hue.0 lightQueue: job sensors.updateSensorState:Daylight
                              2019-10-17 15:40:59.345 - warn: hue.0 lightQueue: retry [3/10] job sensors.updateSensorState:Daylight
                                Apropo @foxriver76 last edited by
                                • Upload
                                Was meinst du mit + Upload?
                                Wenn ich auf den Github Stand update und den on State ändere kommt bei mir nur
                                hue.0	2019-10-17 16:41:47.872	error	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd max retry reached: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                hue.0	2019-10-17 16:41:47.841	warn	lightQueue: retry [10/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                                hue.0	2019-10-17 16:41:47.841	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                hue.0	2019-10-17 16:41:47.814	warn	lightQueue: retry [9/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                                hue.0	2019-10-17 16:41:47.813	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                hue.0	2019-10-17 16:41:47.787	warn	lightQueue: retry [8/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                                hue.0	2019-10-17 16:41:47.786	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                hue.0	2019-10-17 16:41:47.759	warn	lightQueue: retry [7/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                                hue.0	2019-10-17 16:41:47.758	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                hue.0	2019-10-17 16:41:47.732	warn	lightQueue: retry [6/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                                hue.0	2019-10-17 16:41:47.731	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                hue.0	2019-10-17 16:41:47.705	warn	lightQueue: retry [5/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                                hue.0	2019-10-17 16:41:47.704	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                hue.0	2019-10-17 16:41:47.678	warn	lightQueue: retry [4/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                                hue.0	2019-10-17 16:41:47.677	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                hue.0	2019-10-17 16:41:47.650	warn	lightQueue: retry [3/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                                hue.0	2019-10-17 16:41:47.650	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                hue.0	2019-10-17 16:41:47.623	warn	lightQueue: retry [2/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                                hue.0	2019-10-17 16:41:47.623	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                hue.0	2019-10-17 16:41:47.596	warn	lightQueue: retry [1/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                                hue.0	2019-10-17 16:41:47.595	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                                Nix mit Send this info ....
                                  @foxriver76
                                  undefined2019-10-17 16:50:49.478 - warn: hue.0 (15000) Send this info to developer: {"_rawData":{"state":{"presence":false,"lastupdated":"2019-10-17T14:47:09"},"swupdate":{"state":"noupdates","lastinstall":"2019-03-11T13:39:24"},"config":{"on":true,"battery":100,"reachable":true,"alert":"none","ledindication":false,"usertest":false,"sensitivity":2,"sensitivitymax":2,"pending":[]},"name":"Küche Sensor","type":"ZLLPresence","modelid":"SML001","manufacturername":"Philips","productname":"Hue motion sensor","swversion":"6.1.1.27575","uniqueid":"00:17:88:01:03:29:d9:8a-02-0406","capabilities":{"certified":true,"primary":true}},"_id":13,"_type":"ZLLPresense","_configAttributes":{"on":true,"battery":100,"reachable":true,"alert":"none","ledindication":false,"usertest":false,"sensitivity":2,"sensitivitymax":2,"pending":[]},"_stateAttributes":{"presence":false,"lastupdated":"2019-10-17T14:47:09"}}
                                  2019-10-17 16:50:49.495 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  id: 13:130374a202d0bea0d2203edb099f01a3 failed: Error: parameter, presence, is not modifiable
                                  2019-10-17 16:50:49.495 - warn: hue.0 (15000) lightQueue: retry [1/10] job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.531 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.531 - warn: hue.0 (15000) lightQueue: retry [2/10] job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.567 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.567 - warn: hue.0 (15000) lightQueue: retry [3/10] job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.603 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.603 - warn: hue.0 (15000) lightQueue: retry [4/10] job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.639 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.639 - warn: hue.0 (15000) lightQueue: retry [5/10] job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.673 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.673 - warn: hue.0 (15000) lightQueue: retry [6/10] job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.800 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.800 - warn: hue.0 (15000) lightQueue: retry [7/10] job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.836 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.836 - warn: hue.0 (15000) lightQueue: retry [8/10] job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.871 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.871 - warn: hue.0 (15000) lightQueue: retry [9/10] job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.906 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.906 - warn: hue.0 (15000) lightQueue: retry [10/10] job sensors.updateSensorState:ZLLPresense
                                  2019-10-17 16:50:49.941 - error: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                  id: 13:130374a202d0bea0d2203edb099f01a3 max retry reached: Error: parameter, presence, is not modifiable
                                  • BBTown
                                    BBTown @Apropo last edited by
                                    @Apropo sagte in [Aufruf] Hue Adapter 2.0.0:
                                    • lobomau
                                      lobomau last edited by lobomau
                                      Edit: Version 2.1.0 will auch nicht mehr. Hier funktioniert die Funktion neuen User suchen nicht mehr.
                                      Edit2: Version 2.0.0 funktioniert wieder.
                                      Hab geupdatet von 2.0.0. auf 2.2.0.
                                      Wird die alte Bridge (rund) noch unterstützt?
                                      Bekomme sie nicht ans laufen. Upload habe ich durchgeführt, aber es geht auch nicht mehr neuen User anlegen. Oder braucht man keinen User mehr?
                                      Hier paar Schaltversuche:
                                      hue.0	2019-10-17 20:44:04.555	error	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b max retry reached: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:44:04.529	warn	(10799) lightQueue: retry [10/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                      hue.0	2019-10-17 20:44:04.528	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:44:04.501	warn	(10799) lightQueue: retry [9/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                      hue.0	2019-10-17 20:44:04.500	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:44:04.474	warn	(10799) lightQueue: retry [8/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                      hue.0	2019-10-17 20:44:04.474	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:44:04.447	warn	(10799) lightQueue: retry [7/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                      hue.0	2019-10-17 20:44:04.447	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:44:04.420	warn	(10799) lightQueue: retry [6/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                      hue.0	2019-10-17 20:44:04.420	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:44:04.392	warn	(10799) lightQueue: retry [5/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                      hue.0	2019-10-17 20:44:04.392	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:44:04.365	warn	(10799) lightQueue: retry [4/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                      hue.0	2019-10-17 20:44:04.365	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:44:04.338	warn	(10799) lightQueue: retry [3/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                      hue.0	2019-10-17 20:44:04.337	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:44:04.310	warn	(10799) lightQueue: retry [2/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                      hue.0	2019-10-17 20:44:04.309	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:44:04.282	warn	(10799) lightQueue: retry [1/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                      hue.0	2019-10-17 20:44:04.281	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:25.776	error	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 max retry reached: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:25.745	warn	(10799) groupQueue: retry [10/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                      hue.0	2019-10-17 20:43:25.744	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:25.718	warn	(10799) groupQueue: retry [9/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                      hue.0	2019-10-17 20:43:25.717	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:25.690	warn	(10799) groupQueue: retry [8/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                      hue.0	2019-10-17 20:43:25.689	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:25.663	warn	(10799) groupQueue: retry [7/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                      hue.0	2019-10-17 20:43:25.661	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:25.635	warn	(10799) groupQueue: retry [6/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                      hue.0	2019-10-17 20:43:25.634	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:25.608	warn	(10799) groupQueue: retry [5/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                      hue.0	2019-10-17 20:43:25.607	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:25.581	warn	(10799) groupQueue: retry [4/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                      hue.0	2019-10-17 20:43:25.580	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:25.548	warn	(10799) groupQueue: retry [3/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                      hue.0	2019-10-17 20:43:25.547	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:25.521	warn	(10799) groupQueue: retry [2/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                      hue.0	2019-10-17 20:43:25.520	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:25.493	warn	(10799) groupQueue: retry [1/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                      hue.0	2019-10-17 20:43:25.492	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                      hue.0	2019-10-17 20:43:02.660	error	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 max retry reached: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:02.634	warn	(10799) lightQueue: retry [10/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                      hue.0	2019-10-17 20:43:02.633	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:02.607	warn	(10799) lightQueue: retry [9/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                      hue.0	2019-10-17 20:43:02.606	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:02.580	warn	(10799) lightQueue: retry [8/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                      hue.0	2019-10-17 20:43:02.579	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:02.552	warn	(10799) lightQueue: retry [7/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                      hue.0	2019-10-17 20:43:02.551	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:02.525	warn	(10799) lightQueue: retry [6/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                      hue.0	2019-10-17 20:43:02.524	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:02.497	warn	(10799) lightQueue: retry [5/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                      hue.0	2019-10-17 20:43:02.496	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:02.470	warn	(10799) lightQueue: retry [4/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                      hue.0	2019-10-17 20:43:02.469	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:02.443	warn	(10799) lightQueue: retry [3/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                      hue.0	2019-10-17 20:43:02.442	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:02.416	warn	(10799) lightQueue: retry [2/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                      hue.0	2019-10-17 20:43:02.415	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                      hue.0	2019-10-17 20:43:02.388	warn	(10799) lightQueue: retry [1/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                      hue.0	2019-10-17 20:43:02.388	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                        Apropo @BBTown last edited by
                                        @BBTown Ahhh, super danke dir!
                                        • foxriver76
                                          foxriver76 Developer @Apropo last edited by
                                          @Apropo 2.2.1 auf npm:
                                          • Osram Plug sollte nun wieder laufen (musste vom node-hue-api Entwickler in v3 noch integriert werden)
                                          • Bei der Nutzererstellung wurde statt dem Nutzernamen ein Objekt zurückgegeben -> ist gefixt
                                          • Sensor schalten geht vermutlich noch nicht
                                          • foxriver76
                                            foxriver76 Developer @lobomau last edited by foxriver76
                                            @lobomau Puh, weiß tatsächlich nicht ob der Support für die runde (v1) Bridge im npm Modul entfernt wurde. Im Changelog wird nichts erwähnt.
                                            79.9k
                                            hue hue adapter zigbee
                                            25
                                            208
                                            17747
