    4. JavaScript
    5. Script - Info über Datenpunkte sammeln
      liv-in-sky @sigi234 last edited by
      @sigi234
      teste mal das - nur der teil ab "AB HIER NCHTS ÄNDERN" im script ersetzen
      //------------------------------------------AB HIER NICHTS ÄNDERN--------------------------------------------------------
      const versionNr = "15102019-1.0"
      var endehtml=   "<p style=\"color:"+color_in_table+"; font-family:"+schriftart+";\">Letztes File Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"</p>";
      var endehtmlDP=   "<p style=\"color:red; font-family:"+schriftart+";\">Letztes Table Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"</p>";
      const format = "<!DOCTYPE html><html lang=\"de\"><head><title>Putzer</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\"></head><body>";
      const htmlTable="<table style=\"color:"+color_in_table+";text-align:left; font-family:"+schriftart+";background-image: linear-gradient(67deg,transparent,"+color_gradient1+");\">";
      const htmlReset="<p style=\"color:red;font-family:"+schriftart+";\"><i>!!! ohne Javascript Instanzen !!! kann enabled werden</i></p>"
      //  var htmlOhneAnzahl="<p style=\"color:red;font-family:"+schriftart+";\"><i>!!! ohne DatenpunktZählung !!! kann enabled werden</i></p>"
      const htmlError="<p style=\"color:red;font-family:"+schriftart+";\"><i>Script hat Fehler - bitte Log checken !!!</i></p>"
      var allInstArr=[];
      const dpPrefix = "javascript."+ instance +".";
      var mylogs=false;
      var htmlDP=[];
      var htmlMSG=[];
      var counterAll=0;
      var htmlHelper="";
      createState(dpPrefix + "ProofingDatapoints.HTMLTable", { name: 'HTMLTable',  type: 'string', read:  true,  write: true,});
      createState(dpPrefix + "ProofingDatapoints.ScriptVersion", versionNr,{ name: 'ScriptVersion',  type: 'string', read:  true,  write: true,});
      createState(dpPrefix + "ProofingDatapoints.RunScript", { name: 'RunScript',  type: 'boolean', role:"switch", read:  true,  write: true,});
      createState(dpPrefix + "ProofingDatapoints.JavaInstanzCheck", true,{ name: 'JavaInstanzCheck',  type: 'boolean', role:"switch", read:  true,  write: true,});
      createState(dpPrefix + "ProofingDatapoints.ObjectAnzahlCheck", true,{ name: 'ObjectAnzahlCheck',  type: 'boolean', role:"switch", read:  true,  write: true,});
      createState(dpPrefix + "ProofingDatapoints.MonsterSearch", false,{ name: 'MonsterSearch',  type: 'boolean', role:"switch", read:  true,  write: true,});
      //------------------------------------------Zähle Objecte der  INSTANZEN--------------------------------------------------------
      function countDP(idb){
         var counter4=0;
         $(idb).each(function(id, i) {
         counter4++; })
      mylog(idb+counter4);
      htmlDP.unshift(idb);
      htmlMSG.unshift(counter4.toString());
      counterAll=counterAll+counter4;
      //------------------------------------------CHECK INSTANZEN--------------------------------------------------------
      function instanzCount(){
         var counter=0; var counter2=0;var counter3=0;
      $('system.adapter.*.alive').each(function(id, i) {
          var ida = id.split('.');
           allInstArr.push(ida[2]+"."+ida[3]+".*");
         if(!id.includes("vis")){
         counter++;
         if (getState(id).val==null) {;counter2++; mylog(ida[2]+ida[3]+"--------------------der hier wurde nie gestartet");
            htmlDP.push(ida[2]+"."+ida[3]);
            htmlMSG.push("Instanzen ohne Werte");} //else{instanzArr.push(ida[2]+"."+ida[3])}
         if (getState(id).val==false) {counter3++;mylog(ida[2]+ida[3]+"-----------------------der hier ist ausgeschalten");
            htmlMSG.push("nicht aktiviert");} /*else{instanzArr.push(ida[2]+"."+ida[3])}*/
      mylog("______________________________________________Anzahl Instanzen: " + counter.toString());
      htmlDP.push("");
      htmlMSG.push("");
      htmlDP.push("Anzahl Instanzen");
      htmlMSG.push(counter.toString());
      mylog("______________________________________________Anzahl gestoppter Instanzen ohne Werte: " + counter2.toString())
      htmlDP.push("Instanzen ohne Werte");
      htmlMSG.push(counter2.toString());
      htmlDP.push("Instanzen nicht aktiviert");
      htmlMSG.push(counter3.toString());
      //------------------------------------------CHECK ZUORDNUNG--------------------------------------------------------
      function checkTypes(select) {
         var counter=0;
         htmlMSG.push("");
         htmlDP.push("");
         mylog(select)
         $(select).each(function (id, i) {
             counter++
         if (!id.includes('scriptEnabled') && !id.includes('scriptProblem') /*&& !id.includes('Log-Script')  && !id.includes('Ereignisliste') && !id.includes('GETPROCESS')*/ ){
             if (!JSON.stringify(getObject(id)).includes("type")) {
                   console.log("no"+id);
                   htmlDP.push(id+": "+valType);
                   htmlMSG.push("<b>missing TYPE !!</b>" );}
              else{ var dpType = getObject(id).common.type;
                    var valType = typeof getState(id).val;
                    if(dpType != "mixed" ) {
                    if(dpType !== valType && !(dpType == 'array' && valType == 'object')) {
                       mylog(id + ': Datenpunkttyp: ' + dpType + ', Wert: ' + valType);
                       htmlMSG.push(dpType );}
             if(dpType != valType && !(dpType == 'array' && valType == 'object')) {
                 htmlDP.push(dpType);
                 htmlMSG.push(valType);
         htmlDP.push("ID+IST WERT");
         htmlMSG.push("SOLL WERT");
         htmlDP.push("<b><i>geprüfte Instanz</i></b>");
         htmlMSG.push("<b>"+select+"</b>");
         mylog("fertg" + counter.toString())
      //------------------------------------------CHECK  WERTE--------------------------------------------------------
      function checkWerte(select) {
         mylog("bin in check Werte");
         var counter=0;
         mylog(select);
             counter++
         if (!id.includes('scriptEnabled') && !id.includes('scriptProblem') && !id.includes('alexa') /* && !id.includes('Ereignisliste') && !id.includes('GETPROCESS')*/ ){
           //  var dpType = getObject(id).common.type;
             var valType =  getState(id).val;
             //if(dpType != "mixed" ) {}
                 if(valType === null) {mylog(id + ': Datenpunkttyp: ' /*+ dpType */+ ", Wert: "+valType);
                     htmlDP.push(id);
                     var ddd = new Date().getTime()-getObject(id).ts;
                     htmlMSG.push("missing seit " + Math.floor((ddd)/1000/60/60/24)+"d "+Math.floor((ddd)/1000/60/60 %24)+"h "+Math.floor((ddd)/1000/60 %60)+"m ");
          mylog("bin raus aus check Werte");
      function mylog(message) {
        if(mylogs)
            console.log(message);
      //-----------------------------------------------SCHALTER MAIN------------------------------------------------
      on({id:dpPrefix + "ProofingDatapoints.RunScript",  val: true}, function (obj) {
         let java= getState(dpPrefix + "ProofingDatapoints.JavaInstanzCheck").val;
         let instanzAnzahl= getState(dpPrefix + "ProofingDatapoints.ObjectAnzahlCheck").val;
         let monster= getState(dpPrefix + "ProofingDatapoints.MonsterSearch").val;
         setState(dpPrefix + "ProofingDatapoints.ScriptVersion",versionNr);
         htmlHelper="";
         setState(dpPrefix + "ProofingDatapoints.HTMLTable",htmlReset+endehtml+htmlError);
         writeFile(null, "/ProofingDatapoints/htmlputz.html" ,htmlReset+endehtml+htmlError+"</body>", function (error) {mylog('file written'); });
         htmlHelper="";
      setStateDelayed(dpPrefix + "ProofingDatapoints.RunScript",false,2500);
      htmlDP=[];
      htmlMSG=[];
      instanzCount();
      htmlDP.push("<b><i>INSTANZ INFO</i></b>"); htmlMSG.push(""); htmlDP.push(""); htmlMSG.push("");
      mylog(instanzArr.length+"==================="+instanzArr.toString());
      if (monster) instanzArr=allInstArr;  //ACHTUNG MONSTERSEARCH
      for(let name in instanzArr){
         checkWerte(instanzArr[name]+".*")
         mylog("!!!!!!!!!!!!!!!!!!!!:  "+instanzArr[name])};
          if (instanzAnzahl){
                htmlDP.unshift(""); htmlMSG.unshift("");htmlDP.unshift("<b><i>Objekte in Instanz</i></b>"); htmlMSG.unshift("Anzahl");
                for(let name in allInstArr){
                countDP(allInstArr[name]);}
                htmlDP.unshift("<b><i>Gesamt Objekte in Instanzen</i></b>"); htmlMSG.unshift("<b>"+counterAll.toString()+"</b>"); }
                //console.log("=============: "+counterAll);}
      if (java) checkWerte('javascript.*');
       htmlDP.push("<b><i>ID ohne WERT</i></b>");
       htmlMSG.push("");
         checkTypes(instanzArr[name]+".*")
           htmlDP.push("<b><i>ID falscher TYPE</i></b>");
       htmlMSG.push("");
       if (java) checkTypes('javascript.*');
      for(var i= htmlDP.length-1; i>-1; i--) {
        htmlHelper= htmlHelper+"<tr><td>"+htmlDP[i]+"&ensp;&ensp;</td><td>"+htmlMSG[i]+"&ensp;&ensp;</td></tr>"
         if (monster){endehtml="<p style=\"color:red; font-family:"+schriftart+";\"><i>!!! Monster Suche wird automatisch  deaktiviert !!!</i></p>"+endehtml;
                   endehtmlDP="<p style=\"color:red; font-family:"+schriftart+";\"><i>!!!  Monster Suche wird automatisch  deaktiviert !!! Bericht nur über WebSeite</i></p>"+endehtmlDP;}
         if (!instanzAnzahl){endehtml="<p style=\"color:red; font-family:"+schriftart+";\"><i>!!! ohne DatenpunktZählung !!! kann enabled werden</i></p>"+endehtml;
                   endehtmlDP="<p style=\"color:red; font-family:"+schriftart+";\"><i>!!! ohne DatenpunktZählung !!! kann enabled werden</i></p>"+endehtmlDP;}
        if (!java){ endehtml="<p style=\"color:red; font-family:"+schriftart+";\"><i>!!! ohne Javascript Instanzen !!! kann enabled werden</i></p>"+endehtml;
                   endehtmlDP="<p style=\"color:red; font-family:"+schriftart+";\"><i>!!! ohne Javascript Instanzen !!! kann enabled werden</i></p>"+endehtmlDP;}
         if(!monster) { setStateDelayed(dpPrefix + "ProofingDatapoints.HTMLTable",endehtmlDP+"<table>"+htmlHelper,900);} else{setStateDelayed(dpPrefix + "ProofingDatapoints.HTMLTable",endehtmlDP,900);}
          if(true)  writeFile(null, "/ProofingDatapoints/htmlputz.html" ,format+endehtml+htmlTable+htmlHelper+"</table></body>", function (error) { mylog('file written'); });
         endehtml="";
         setState(dpPrefix + "ProofingDatapoints.MonsterSearch",false);  //setzt monstersearch zurück
        sigi234 Forum Testing Most Active @liv-in-sky last edited by sigi234
        @liv-in-sky sagte in Script - Info über Datenpunkte sammeln:
        @sigi234
        var allInstArr=[];
        var mylogs=false;
        var htmlDP=[];
        var htmlMSG=[];
        var counterAll=0;
        var htmlHelper="";
           var counter4=0;
           counter4++; })
           counter++;
        htmlDP.push("");
        htmlMSG.push("");
           var counter=0;
           htmlMSG.push("");
           htmlDP.push("");
           mylog(select)
               counter++
           var counter=0;
           mylog(select);
               counter++
                       htmlDP.push(id);
          if(mylogs)
           htmlHelper="";
           htmlHelper="";
        htmlDP=[];
        htmlMSG=[];
        instanzCount();
            if (instanzAnzahl){
         htmlMSG.push("");
         htmlMSG.push("");
           endehtml="";
        Getestet, wann macht er ein File update?
        Aha, musste auf runskript gehen und auf true setzen, dachte es geht bei skript neustart.
          @sigi234 jedes mal, wenn der datenpunkt RunScript auf true gesetzt wird
          das war eine sicherheitsangabe - damit ich weiß, dass er durch das script durchgelaufen ist und nicht vor dem schreibvorgang einen scriptfehler hatte
            @sigi234 sind die missing angaben so ok ?
              Sehe es mir gerade an, die Html im Web wird nicht aktualisiert?
              In Vis schon. Bei einigen DP bin ich mir nicht sicher ob die Tage stimmen, muss ich nachsehen. 500 Tage sind schon lange.
              javascript.0.Wertstofftonne  	missing seit 509d 1h 20m
              Gesamt Objekte in Instanzen  	53330  ?
              Habe nur 21000
                @sigi234
                wie sehen die einzelnen zähler aus - also bei mir kommt es ungefähr hin mit 10000
                53300 ist sehr viel - fällt die in der übersicht bei dir was auf ?
                  @liv-in-sky
                  So jetzt sind es 17000 kommt so ungefähr hin.
                  Hatte kurz mal einen Nachricht: Skript hat Fehler
                  Web geht noch nicht.
                  Letztes File Update: 20:28:35 (gestern)
                  • Dutchman
                    Dutchman Developer Most Active Administrators @liv-in-sky last edited by
                    beim aufsuchen der datenpunkte kann es zu vielen warnungen im log kommen - ist nicht verhinderbar
                    koenntest dus eventuell mit nem
                    try {
                       hier der code
                    abfangen
                      @sigi234
                      ich hab noch einen fehler bei der berechnung der anzahl der objekte entdeckt - werd ich checken - "hängt mit monstersearch zusammen"
                      normal läuft es so - bei script start (runscript=true) wird eine datei geschrieben in der steht, dass es einen fehler gibt - läuft das script erfolgreich durch wird das file wieder überschrieben mit den ausgewerteten angaben. das bedeutet: für den durchlauf des scripts (millisekunden) gibt es eine webseite, die einen fehler anzeigt - wird aber am ende überschrieben - das ganze gilt auch für den datenpunkt für die vis
                      folgendes kann vorkommen:
                      • script startet - webseite mit fehler wird erstellt
                      • script bricht wegen fehler ab - in webseite steht auf fehler meldung
                      • script läuft durch - webseite mit fehlermeldung wird überschrieben - daten stehen in webseite
                      wenn, wie bei dir, die webseite nicht geschrieben wird , die daten für die vis schon, dann müßte der writeFile-befehl nicht mehr funktionieren, den zumindest müßte einmal ein webseite (wenn auch mit fehlermeldung) erzeugt werden
                      wenn ich ehrlich bin - mir fällt dazu nichts wirklich gutes ein - außer das ganze script nochmal zu ersetzen
                      nutze mal das ganze script hier: aber ersetze die var instanzArr mit deinen werten (ganz am anfang)
                      // @Liv-in-sky Okt.  2019
        // WICHTIG
                      const instanzArr=[ "controll-own.0", "alexa2.0"];      // hier muss die instanz der eigenen datenpunkte angegeben werden oder zusätzlich, die man prüfen möchte    , "alexa2.0"
        // beispiel const instanzArr=[ "eigeneDatenpunkte.0", "ping.0",];
                      var color_in_table="black"    //Farbe text in webseite
                      let schriftart="Helvetica";  //möglich: Helvetica,Serif
                      var color_gradient1="#819FF7"  // Hintergrund webseite
                      var allInstArr=[];
                      var  instanzArrHelp=[];
                      var mylogs=false;
                      var htmlDP=[];
                      var htmlMSG=[];
                      var counterAll=0;
                      var htmlHelper="";
                           allInstArr.push(ida[2]+"."+ida[3]);
                         counter++;
                      htmlDP.push("");
                      htmlMSG.push("");
                         var counter=0;
                         htmlMSG.push("");
                         htmlDP.push("");
                      console.log(typeof getState( "javascript.2.WLANUnifi.APInfo.AP-Light").val)
                         mylog(select)
                             counter++
                         if (!id.includes('scriptEnabled') && !id.includes('scriptProblem')  && getState(id).val !== null /*&& !id.includes('Log-Script')  && !id.includes('Ereignisliste') && !id.includes('GETPROCESS')*/ ){
                                   mylog("no"+id);
                                    if(dpType !== valType && !(dpType == 'array' && valType == 'object') /*&& !(dpType =='text' && valType=='string') && !(dpType =='string' && valType=='text')*/ ) {
                         var counter=0;
                         mylog(select);
                             counter++
                         if (!id.includes('scriptEnabled') && !id.includes('scriptProblem') /* )  && !id.includes('Ereignisliste') && !id.includes('GETPROCESS')*/ ){
                                     htmlDP.push(id);
                        if(mylogs)
                         mylog("bin richtig in count");
                         var counter4=0;
                         $(idb+".*").each(function(id, i) {
                         counter4++; })
                      console.log(idb+counter4);
                      mylog("bin raus aus count");
                         htmlHelper="";
                         htmlHelper="";
                         counterAll=0;
                         instanzArrHelp=[];
                         allInstArr=[];
                      htmlDP=[];
                      htmlMSG=[];
                      instanzCount();  //überprüft instanzen und stellt allInstArr her
                      if (monster) {instanzArrHelp=allInstArr;} else {instanzArrHelp=instanzArr}  //ACHTUNG MONSTERSEARCH
                      for(let name in instanzArrHelp){
                         checkWerte(instanzArrHelp[name]+".*")                   //checkt alle werte in intanzArr
                        mylog("!!!!!!!!!!!!!!!!!!!!:  "+instanzArrHelp[name]);}
                          if (instanzAnzahl){
                                  countDP(instanzArrHelp[name]);mylog("bin in zhlen");}
                                htmlDP.unshift("<b><i>Gesamt geprüfte Objekte in Instanzen</i></b>"); htmlMSG.unshift("<b>"+counterAll.toString()+"</b>"); }
                                mylog("=============: "+counterAll);
                      if (java && !monster) checkWerte('javascript.*');                //checkt alle javainstanzen
                       htmlMSG.push("");
                         checkTypes(instanzArrHelp[name]+".*")
                         mylog("!!!!!!!!!!!!!!!!!!!!:  "+instanzArrHelp[name])};
                           htmlMSG.push("");
                       if (java && !monster) checkTypes('javascript.*');
                         endehtml="";
                        @liv-in-sky
                        Super arbeit, funktioniert. Jetzt werden nur die Objekte gezählt die angegeben sind.
                        Objekte in Instanz  	Anzahl  
                        Eigene_datenpunkte.0  	0  
                        alexa2.0  	2040  
                        Gesamt geprüfte Objekte in Instanzen  	2040  
                        Vergleich mit ioBroker Ansicht : 2455
                        Info 2:
                        ical.3  	nicht aktiviert  
                        ical.2  	nicht aktiviert  
                        ical.1  	nicht aktiviert  
                        ical.0  	nicht aktiviert  
                        Diese Instanzen sind zwar aktiviert ( Grün) , gehe davon aus weil sie erst bei einen Cron starten sind sie bei dir als nicht aktiviert gekennzeichnet.Sind nur Beispiele , da gibt es mehrere.
                          @sigi234 die webseite funktioniert auch wieder ?
                          wegen der ical beispiele
                          ich verstehe das script folgendermaßen:
                          es läuft nicht immer, sondern nur bei bedarf, um mal zu sehen, wie es um die datenpunkte steht - besonders für die eigenen datenpunkte und die unter javascript.
                          • z.b habe ich einige leere dp gefunden, welche ich auch löschen kann, weil sie nicht mehr in benutzung sind - das gilt nicht für adapter (da kann ich ja die datenpunkte nicht definieren)
                          • oder nachdem ich mal alle datenpunkte einer instanz gelöscht habe (daswetter.com) bin ich von 1400 auf 900 datenpunkte gekommen - alle diese punkte müssen ja irgendwo/wie verwaltet werden und benötigin resourcen dafür - es kann also nicht schaden, die datenpunkte zu minimieren
                          • entwickler können checken, ob alle datenpunkte richtig deklariert worden sind und nur den gewünschen adapter zu überwachen
                          • entwickler können einzelne ordner in der struktut überwachen - also nicht eine ganze instanz, sondern nur die ordner (siehe bild) , die ich gerade bearbeite durch ein script (ist noch in entwicklung)
                            JA👍
                              liv-in-sky @Dutchman last edited by
                              @Dutchman sagte in Script - Info über Datenpunkte sammeln:
                              try {
                                 hier der code
                              abfangen
                              moin - hast du da mehr kenntnisse?
                              viele warnungen kommen bei der abfrage ob ein wert vorhanden ist
                              wenn ich nun das versuche, ändert sich nichts - die warnungen kommen - es wird kein error ausgegeben
                               try {
                                      } catch (e) {console.log("------------ERROR: "+e)}
                              ich glaube, dass man das nicht verhindern kann
                                liv-in-sky last edited by liv-in-sky
                                es gibt ein update - u.a gibt es jetzt eine directSearch ! mehrim ersten post
                                wünsche - anregungen werden gerne angenommen
                                bitte alles unter const instanzArr=... ersetzen
                                  @liv-in-sky
                                  <p style="color:red;font-family:Helvetica;"><i>!!! ohne Javascript Instanzen !!! kann enabled werden</i></p>undefined<p style="color:red;font-family:Helvetica;"><i>Script hat Fehler - bitte Log checken !!!</i></p>
                                  Skript:
        // WICHTIG
        //oder auch nur einzelne ornder in der datenstruktur z.b. "javascript.2.WLANUnifi"
                                  const instanzArr=[ "Eigene_Datenpunkte.0", "ping.0"];
        // beispiel const instanzArr=[ "eigeneDatenpunkte.0", "ping.0", "javascript.2.WLANUnifi"];
                                  var color_in_table="black"         // Farbe text in webseite
                                  let schriftart="Helvetica";        // möglich: Helvetica,Serif
                                  var color_gradient1="#819FF7";     // Hintergrund webseite
                                  var colorHeadlines="darkblue";     // Farbe Überschriften in der VIS Anzeige
                                  var colorHeadlinesDP="#36d5ec ";   // Farbe Überschriften in der WebSeite Anzeige
                                  var warnFarbe = "#36d5ec";         //Farbe für Warnungen in vis und Webseite
                                  javascript.0	2019-10-18 15:29:46.244	info	(12524) script.js.System.Objekte: ================================schreibe file
                                  javascript.0	2019-10-18 15:29:46.242	info	(12524) script.js.System.Objekte: ----------select: ping.0.*
                                  javascript.0	2019-10-18 15:29:46.242	info	(12524) script.js.System.Objekte: ---------: *
                                  javascript.0	2019-10-18 15:29:46.241	info	(12524) script.js.System.Objekte: ----------select: Eigene_Datenpunkte.0.*
                                  javascript.0	2019-10-18 15:29:46.241	info	(12524) script.js.System.Objekte: ---------: *
                                  javascript.0	2019-10-18 15:29:26.841	info	(12524) script.js.System.Objekte: registered 2 subscriptions and 0 schedules
                                  javascript.0	2019-10-18 15:29:26.838	info	(12524) Start javascript script.js.System.Objekte
                                  javascript.0	2019-10-18 15:29:26.835	info	(12524) Stop script script.js.System.Objekte
                                  javascript.0	2019-10-18 15:29:02.734	info	(12524) script.js.System.Objekte: registered 2 subscriptions and 0 schedules
                                  javascript.0	2019-10-18 15:29:02.728	info	(12524) Start javascript script.js.System.Objekte
                                  Schaut jetzt besser aus:
                                  Im DP OrdnerCheck war ein true drinnen
                                    Ja, aber wenn ich die instanzArr ändere wir keine Webseite geschrieben? Sollte doch sein.
                                    Ich habe die Webadresse zu den Favoriten hinzugefügt und rufe diese dann auf. Vielleicht setzt er da einen Cookie und aktualisiert nicht?
                                      @sigi234
                                      hast du das ganze script ersetzt - hatte ich vergessen zu erwähnen - es gibt auch eine änderung über ab hier nichts mehr ändern
                                      nur const instanzArr kannst du später wieder reinkopieren
                                        Ja
                                          liv-in-sky @sigi234 last edited by liv-in-sky
                                          @sigi234
                                          hier nochmal eine ganze version - bitte ganz ersetzen und anschliessend dein settings für const instanzArr wieder hernehmen
        // WICHTIG
                                          const instanzArr=[ "javascript.2.WLANUnifi", "javascript.0.ProofingDatapoints", "controll-own.0"];
                                          const versionNr = "15102019-1.1"
                                          const warnColor = warnFarbe ;
                                          const htmlHeaders = "style=\"color:"+colorHeadlines+";\"";
                                          const htmlHeadersDP = "style=\"color:"+colorHeadlinesDP+";\"";
                                          var allInstArr=[];
                                          var mylogs=false;
                                          var htmlDP=[];
                                          var htmlMSG=[];
                                          var counterAll=0;
                                          var directSearch=false;
                                          var htmlHelper="";
                                          var htmlHelperFile="";
                                          createState(dpPrefix + "ProofingDatapoints.ohneInstanzAnzeige", false,{ name: 'ohneInstanzAnzeige',  type: 'boolean', role:"switch", read:  true,  write: true,});
                                          createState(dpPrefix + "ProofingDatapoints.OrdnerCheck", { name: 'OrdnerCheck',  type: 'string', read:  true,  write: true,});
                                            var ohneInstanz = getState(dpPrefix + "ProofingDatapoints.ohneInstanzAnzeige").val;
                                            if (!ohneInstanz && !directSearch) {
                                             counter++;
                                           if (!ohneInstanz) {
                                          htmlDP.push("");
                                          htmlMSG.push("");
                                              mylog("bin in check types");
                                             var counter=0;
                                             htmlMSG.push("");
                                             htmlDP.push("");
                                             var sub= select.substring(select.length-1, select.length); log("---------: "+sub);log("----------select: "+select);
                                             mylog(select)
                                                 counter++
                                                           /* später testing)
                                                           console.log("======1=============no type: "+id +"object: "+JSON.stringify(getObject(id)));
                                                           if(!getObject(id).common.hasOwnProperty("type")) console.log("--------------kein TYPE: "+id) ;
                                                           console.log("======2=============no type: "+id +"object: "+JSON.stringify(getObject(id).common));
                                             htmlDP.push("<i>ID + IST-WERT</i>");
                                             htmlMSG.push("<i>SOLL-WERT</i>");
                                             htmlDP.push("-col-<b>geprüfte Instanz</b>");
                                             htmlMSG.push("-col-<i><b>"+select+"</b></i>");
                                             var counter=0;
                                             mylog(select);
                                                 counter++
                                                //var dpType = getObject(id).common.type;
                                                 try {
                                                // if(dpType != "mixed" ) {}
                                                         htmlDP.push(id);
                                            if(mylogs)
                                             var counter4=0;
                                             counter4++; })
                                          //----------------------------------------------Direct Suchen
                                          on({id:dpPrefix + "ProofingDatapoints.OrdnerCheck", change: "any"}, function (obj) {
                                              directSearch=true;
                                               instanzArrHelp=[];
                                              setState(dpPrefix + "ProofingDatapoints.RunScript",true);
                                             var endehtmlConst=   "<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\">Letztes File Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"</p>";
                                             var endehtmlDPConst=   "<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\">Letztes Table Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"</p>";
                                             htmlHelper="";
                                             htmlHelperFile="";
                                             counterAll=0;
                                             instanzArrHelp=[];
                                             allInstArr=[];
                                          htmlDP=[];
                                          htmlMSG=[];
                                          htmlDP.push("-col-<b>INSTANZ INFO</b>"); htmlMSG.push(""); htmlDP.push(""); htmlMSG.push("");
                                          if (directSearch) {instanzArrHelp=[]; instanzArrHelp.push(getState(dpPrefix + "ProofingDatapoints.OrdnerCheck").val);}
                                              if (instanzAnzahl){
                                                    htmlDP.unshift(""); htmlMSG.unshift("");htmlDP.unshift("<b>OBJECTE IN INSTANZ</b>"); htmlMSG.unshift("Anzahl");
                                                      if (java && !monster) countDP("javascript")
                                                    htmlDP.unshift("-col-<b>GESAMT GEPRÜFTE OBJECTE IN INSTANZEN</b>"); htmlMSG.unshift("-col-<b>"+counterAll.toString()+"</b>");
                                          if (java && !monster && !ohneInstanz && !directSearch) checkWerte('javascript.*');                //checkt alle javainstanzen
                                           htmlDP.push("-col-<b>ID's OHNE WERT:</b>");
                                           htmlMSG.push("");
                                               htmlDP.push("");
                                               htmlMSG.push("");
                                               htmlDP.push("-col-<b>IDs MIT FALSCHEN TYPE:</b>");
                                               htmlMSG.push("");
                                           if (java && !monster && !ohneInstanz && !directSearch ) checkTypes('javascript.*');
                                              let htmlDPVis; let htmlDPFile;let htmlMSGVis;let htmlMSGFile;
                                                if(htmlDP[i].includes("-col-")) {htmlDPVis=htmlDP[i].replace("-col-", (htmlHeadersDP+">"));  htmlDPVis=" "+htmlDPVis } else {htmlDPVis=">"+htmlDP[i]}
                                                if(htmlMSG[i].includes("-col-")) {htmlMSGVis=htmlMSG[i].replace("-col-", (htmlHeadersDP+">"));htmlMSGVis=" "+htmlMSGVis } else {htmlMSGVis=">"+htmlMSG[i]}
                                                htmlHelper= htmlHelper+"<tr><td"+htmlDPVis+"&ensp;&ensp;</td><td"+htmlMSGVis+"&ensp;&ensp;</td></tr>"
                                              //  if(htmlDP[i].includes("-col-")) {htmlDP[i]=htmlDP[i].replace("-col-", (htmlHeaders+">")); htmlDPFile=htmlDP[i]; htmlDPFile= " "+htmlDPFile ; } else {htmlDPFile=">"+htmlDP[i]}
                                                      if(htmlDP[i].includes("-col-")) {htmlDPFile=htmlDP[i].replace("-col-", (htmlHeaders+">"));  htmlDPFile= " "+htmlDPFile ; } else {htmlDPFile=">"+htmlDP[i]}
                                                if(htmlMSG[i].includes("-col-")) {htmlMSGFile=htmlMSG[i].replace("-col-", (htmlHeaders+">")); htmlMSGFile=" "+htmlMSGFile; } else {htmlMSGFile=">"+htmlMSG[i]}
                                                htmlHelperFile= htmlHelperFile+"<tr><td"+htmlDPFile+"&ensp;&ensp;</td><td"+htmlMSGFile+"&ensp;&ensp;</td></tr>"
                                             var   endehtml=endehtmlConst;
                                             var   endehtmlDP=endehtmlDPConst;
                                             if (monster){endehtml="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! Monster Suche wird automatisch  deaktiviert !!!</i></p>"+endehtml;
                                                       endehtmlDP="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! ACHTUNG: SYSTEM WIRD BELASTET !!! </br></br>!!! Monster Suche wird automatisch  deaktiviert !!! </br></br> BERICHT/AUSWERTUNG NUR ÜBER WEBSEITE</i></p>"+endehtmlDP;}
                                             if (!instanzAnzahl){endehtml="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! Auswertung ohne DatenpunktZählung !!! kann enabled werden</i></p>"+endehtml;
                                                       endehtmlDP="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! Auswertung ohne DatenpunktZählung !!! kann enabled werden</i></p>"+endehtmlDP;}
                                             if (!java){ endehtml="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! Auswertung ohne Javascript Instanzen !!! kann enabled werden</i></p>"+endehtml;
                                                       endehtmlDP="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! Auswertung ohne Javascript Instanzen !!! kann enabled werden</i></p>"+endehtmlDP;}
                                             console.log("================================schreibe file")  ;
                                             if(true)  writeFile(null, "/ProofingDatapoints/htmlputz.html" ,format+endehtml+htmlTable+htmlHelperFile+"</table></body>", function (error) { mylog('file written'); });
                                            // endehtml=endehtmlConst;
                                            // endehtmlDP=endehtmlDPConst;
                                            directSearch=false;
                                            @sigi234
                                            warte mal kurz - checke noch was !
                                            javascript template
                                            11
                                            291
                                            31731
