    4. Test Adaper Discovergy v0.4.x
    • Palm_Maniac
      Palm_Maniac @Dutchman last edited by
      @Dutchman
      ja, mit der 0.4.8 wird jetzt wieder genullt. ABER, mit der füllt sich das Log mit folgendenen Meldungen:
      discovergy.0	2019-10-14 13:02:25.575	error	Timer for meter : 60569887 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":24355,"_repeat":null,"_destroyed":false}
      discovergy.0	2019-10-14 13:02:25.575	error	Timer for meter : 60327823 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":24353,"_repeat":null,"_destroyed":false}
      discovergy.0	2019-10-14 13:02:20.539	error	Timer for meter : 60327823 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":19320,"_repeat":null,"_destroyed":false}
      discovergy.0	2019-10-14 13:02:20.538	error	Timer for meter : 60569887 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":19313,"_repeat":null,"_destroyed":false}
      discovergy.0	2019-10-14 13:02:15.493	error	Timer for meter : 60327823 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":14270,"_repeat":null,"_destroyed":false}
      discovergy.0	2019-10-14 13:02:15.492	error	Timer for meter : 60569887 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":14265,"_repeat":null,"_destroyed":false}
      discovergy.0	2019-10-14 13:02:10.446	error	Timer for meter : 60327823 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":9227,"_repeat":null,"_destroyed":false}
      discovergy.0	2019-10-14 13:02:10.445	error	Timer for meter : 60569887 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":9218,"_repeat":null,"_destroyed":false}
      discovergy.0	2019-10-14 13:02:05.402	error	Timer for meter : 60327823 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":4177,"_repeat":null,"_destroyed":false}
      discovergy.0	2019-10-14 13:02:05.401	error	Timer for meter : 60569887 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":4173,"_repeat":null,"_destroyed":false}
      Und es wird sekündlich mehr.
      • CKMartens
        CKMartens last edited by
        ich bin gerade dabei mein System komplett neu aufzusetzten. Die Version 0.4.8 ist installiert. NodeJS und Node sind in 10.16.3, der js-Controller in 2.0.29.
        Nach der Installation habe ich im 5 Sekunden Takt (die Zeit des Polling Intervall) die Fehlermeldung:
        discovergy.0	2019-10-14 13:18:06.447	error	(11686) Timer for meter : 61234718 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":8358,"_repeat":null,"_destroyed":false}
        discovergy.0	2019-10-14 13:18:01.376	error	(11686) Timer for meter : 61234718 with data : {"_called":true,"_idleTimeout":5000,"_idlePrev":null,"_idleNext":null,"_idleStart":3286,"_repeat":null,"_destroyed":false}
        • Dutchman
          Dutchman Developer Most Active Administrators last edited by Dutchman
          hast du die version per GitHub installiert ?
          auf NPM lag 0.4.7 mit nem Fehler die hab ich heute morgen rausgenommen.
          Installiere mal bitte ueber git, was passiert dan ?
          Moment ich sehe schon mein Fehler, danke ich fixes es gerade
          Palm_Maniac lobomau 2 Replies Last reply Reply Quote 0
          • Dutchman
            Dutchman Developer Most Active Administrators @CKMartens last edited by
            @CKMartens
            probier mal bitte nochmal von GitHub, versions Nummer ist die selbe aber de Fehler sollte raus sein.
            CKMartens 1 Reply Last reply Reply Quote 0
            • CKMartens
              CKMartens @Dutchman last edited by
              @Dutchman
              Ich habe heute vormittag die Version von Github installiert. Dann zurück auf 0.4.5.
              Habe gerade nochmal vin Github installiert
              ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.discovergy.git"
              und bis jetzt keine Fehler in der Log. Danke.
              • Palm_Maniac
                Palm_Maniac @Dutchman last edited by Palm_Maniac
                @Dutchman
                Ja, die Fehler gibts erst seit der Version 0.4.8 von Github.
                PS: Hab gerade auch mal zurück auf die V0.4.5 und dann wieder per Github auf die 0.4.8 installiert und jetzt sind die Meldungen weg. V0.4.6 war noch zu weit, es ging erst mit 0.4.5.
                • Dutchman
                  Dutchman Developer Most Active Administrators @Palm_Maniac last edited by Dutchman
                  @Palm_Maniac sagte in [Aufruf] Neuer Adaper Discovergy:
                  danke, das liegt daran das 0.4.8 noch nicht fertig war und du jetzt den neuen code hast 😉
                  super das es klappt, ich werd dan 0.4.8 auch offiziell release
                  • Dutchman
                    so habe 0.4.8 published, schaut die nächsten tage nochmal drüber ich möchte schnell nach stable (nur wenn alles geht!) da viele gerade das log problem haben
                    • Dutchman
                      wichtig
                      fuer alle de 0.4.8 laufen haben bin schleunigst auf 0.4.9 update es ist da ein uebler Intervall bug in 0.4.8!!!
                        mrzee last edited by
                        Ich habe mit der 0.4.9 deutlich häufiger:
                        (30737) Error retrieving information for : 605XXXXX
                        Mit der 0.4.5 passiert das nicht.
                          leuchtturm last edited by
                          Hallo, bei mir funktioniert die Anbindung an das Discovergy Portal seit heute auch.
                          Schwups, den Adapter installiert v0.49. Und es funktioniert alles aktuell wunderbar.
                          Danke für die Arbeit.
                          Gruß Thomas
                          • Palm_Maniac
                            Hier läuft auch alles bestens. Bisher keine Probleme bis auf die selben Fehler im Log, die @mrzee gemeldet hat. Hält sich aber im Rahmen.
                              danielhainich last edited by
                              hallo,
                              ich habe bei mir den adapter auch aktualisiert, bekomme aber keine daten. log ist soweit auch ok. kannst du helfen?
                              2019-11-15 12:42:40.162 - info: discovergy.0 starting. Version 0.4.9 in /opt/iobroker/node_modules/iobroker.discovergy, node: v8.16.1
                              2019-11-15 12:42:40.173 - info: discovergy.0 Discovergy Adapter startet, trying to discover meters associated with your account
                              2019-11-15 12:42:40.180 - debug: discovergy.0 client_secret decrypt ready
                              2019-11-15 12:42:40.953 - debug: discovergy.0 [{"meterId":"0c69d1ecd24e4d26ad45209f35b5081b","manufacturerId":"EMH","serialNumber":"08579355","fullSerialNumber":"1EMH0008579355","location":{"street":"XXX","streetNumber":"X","zip":"XXX","city":"XXX","country":"DE"},"administrationNumber":"DE0010810923200000000000000227778","type":"RLM","measurementType":"ELECTRICITY","loadProfileType":"RLM","scalingFactor":2000,"currentScalingFactor":2000,"voltageScalingFactor":1,"internalMeters":1,"firstMeasurementTime":1555054142000,"lastMeasurementTime":1573818063000}]
                              2019-11-15 12:42:40.953 - debug: discovergy.0 {"meterId":"0c69d1ecd24e4d26ad45209f35b5081b","manufacturerId":"EMH","serialNumber":"08579355","fullSerialNumber":"1EMH0008579355","location":{"street":"XXX","streetNumber":"X","zip":"XXX","city":"XXX","country":"DE"},"administrationNumber":"DE0010810923200000000000000227778","type":"RLM","measurementType":"ELECTRICITY","loadProfileType":"RLM","scalingFactor":2000,"currentScalingFactor":2000,"voltageScalingFactor":1,"internalMeters":1,"firstMeasurementTime":1555054142000,"lastMeasurementTime":1573818063000}
                              2019-11-15 12:42:40.955 - debug: discovergy.0 All meters : []
                              • JB_Sullivan
                                JB_Sullivan last edited by JB_Sullivan
                                Ich habe mich auch bei Discovergy zum Wechsel des Zähler angemeldet - also aktuell habe ich den noch nicht.
                                Den Adapter und den DEMO Login habe ich in ioB aber schonmal installiert. Scheint soweit zu funktionieren, wenn man von den diversen Error Meldungen im Log mal absieht. Liegt bestimmt daran, das ein DEMO Zugang ist.
                                Hätte ggf. jemand von Euch ein paar Design Idee für das VIS wie man die gewonnenen Daten schick darstellen kann? Ein Widget Export wäre auch super 😄
                                Vielen Dank
                                • opossum
                                  opossum last edited by opossum
                                  ich bekomme mit dem Adapter 0.4.9 keine Verbrauchswerte mehr ? Kann das jemand bestätigen?
                                  Ich wollte heute den Cron anpassen, danach war die Zeitplanung weg. Auch nach einer Neuinstallation bleibt das weg.
                                  Ich sehe in den Ereignissen, dass die Objekte geändert werden, allerdings bleiben die im Admin constant, das heißt, die Änderungen werden nicht geschrieben oder es kommen von Discovergy keine Werte?
                                  • JB_Sullivan
                                    Ich habe auch den 0.4.9er Adapter. Habe aber noch keinen DISCOVERGY Zähler und verwende in der Übergangsphase den Test (DEMO) Account von Discovergy.
                                    Das mit der Zeitplanung kann ich bestätigen, allerdings für die Verbrauchswerte des DEMO Accounts nicht. Die kommen nach wie vor rein.
                                    Hast du vielleicht auch auf den js-controlller 2.1.x geupdatet? Da ist ja eine Version 0.5.0 in Vorbereitung die mit dem js-controller kompatibel sein wird.
                                    • JB_Sullivan
                                      Scheint aber doch irgendwie ein Discovergy Problem zu sein. Im dortigen Forum war folgendes zu lesen:
                                      ich habe heute morgen die von mir aktivierte Meldung, XXX “hat seit 24.11.2019, 04:30:20 keine Daten gesendet.” erhalten. Jetzt hab ich den Zähler per Kabel direkt am Router und der Router hat Internet und keine Aussetzer. Trotzdem hab ich den Zähler resetet. Meine Handy App scheint auch gestört zu sein, weil es mehrere Anläufe braucht bis lagsam Inhalte geladen werden, aber der Live Stromverbrauch ist immer noch nicht zu sehen.
                                      Frage: Wie bekomme ich raus, dass es nicht an mir sondern an Discovergy liegt? Gibt es irgendwo eine Status Seite auf der die Stati eurer Dienste einsehbar sind?
                                      Wenns an mir liegt, was kann ich noch machen und wie überprüfe ich das?
                                      P.S.: seit heute Nacht (24.22.2019) 4:32 Uhr sind keine Daten mehr im Portal einsehbar.
                                      P.P.S.: Beide Lampen leuchten.
                                        deta Most Active last edited by deta
                                        jep, hab die Info auch bekommen.
                                        Mein Zähler ist aber Online
                                        • CKMartens
                                          CKMartens @opossum last edited by CKMartens
                                          @opossum bei mir werden die Daten des Smartmeters einwandfrei angezeigt und gespeichert.
                                            Liegt nicht am Adapter. Auf dem Discovergy Kunden Portal passiert auch wenig bis gar nix.
                                            Hab dort im Forum schon mal ein Thread aufgemacht.
                                            cu Deta
                                            energie
                                            33
                                            294
                                            42436
