    4. [gelöst] Cannot install iobroker.javascript@4.3.1
    SOLVED [gelöst] Cannot install iobroker.javascript@4.3.1
      skokarl last edited by skokarl
      das Update auf 4.3.0 lief problemlos .... jetzt das hier :
      host.iobroker Cannot install iobroker.javascript@4.3.1: 243
      host.iobroker 2019-10-18 15:35:10.978 info iobroker exit 25
      host.iobroker 2019-10-18 15:35:09.964 error iobroker host.iobroker Cannot install iobroker.javascript@4.3.1: 243
      host.iobroker 2019-10-18 15:35:09.941 info iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-10-18T13_35_09_852Z-debug.log
      host.iobroker 2019-10-18 15:35:09.940 info iobroker
      host.iobroker 2019-10-18 15:35:09.841 info iobroker ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believ
      host.iobroker 2019-10-18 15:35:09.840 info iobroker npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroke
      host.iobroker 2019-10-18 15:35:09.839 info iobroker path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/nodenpm ERR! code EACCESnpm ERR! errno -13npm ERR! syscall access
      host.iobroker 2019-10-18 15:35:09.837 info iobroker npm ERR!
      host.iobroker 2019-10-18 15:34:40.989 info iobroker npm install iobroker.javascript@4.3.1 --loglevel error --production --save --prefix "/opt/iobroker" (System call)
      host.iobroker 2019-10-18 15:34:40.987 info iobroker NPM version: 6.9.0
      host.iobroker 2019-10-18 15:34:40.528 info iobroker Update javascript from @4.3.0 to @4.3.1
      host.iobroker 2019-10-18 15:34:39.296 info iobroker upgrade javascript
      • BBTown
        BBTown last edited by BBTown
        Du solltest mal den fixer (erneut?) rüber laufen lassen ... das klingt nach einem Berechtigungsproblem
        PS:
        Bitte stelle Logs in "Code Tags"
          Fixer wäre aber sehr komisch, da 4.3.0 einwandfrei durchlief.
          • BBTown
            BBTown @skokarl last edited by
            @skokarl sagte in Cannot install iobroker.javascript@4.3.1: 243:
            Ich kann dir nicht sagen wann der Fixer Sinn macht oder gar notwendig ist, aber in deinem Log lese ich "permission denied", das ist für mich recht eindeutig
              skokarl @BBTown last edited by
              @BBTown
              ja, ich hab das auch gesehen, aber Sinn macht es für mich nicht nicht.
              Ich probier es mal mit dem Fixer
                so, jetzt gings .....ganz ganz komisch,
                naja, waren auch ne Menge System Updates in letzter Zeit, irgendwer hat da was durcheinander
                gewirbelt.
                • BBTown
                  @skokarl setzt Du noch ein [gelöst] in die Überschrift deines ersten Beitrages?!
                  update
