    4. Test Adapter hue v2.2.x
    • foxriver76
      foxriver76 Developer @BBTown last edited by
      @BBTown und log sagt configured Parameter not available oder sowas?
      • BBTown
        BBTown @foxriver76 last edited by BBTown
        @foxriver76 sagte in [Aufruf] Hue Adapter 2.0.0:
        wenn es nur das wäre 😉
        hue.0	2019-10-17 22:33:46.846	error	id: 12:666c08556f48208d654e981ead5b37e9 max retry reached: Error: parameter, battery, is not modifiable
        hue.0	2019-10-17 22:33:46.846	error	(803) lightQueue: job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.811	warn	id: 12:666c08556f48208d654e981ead5b37e9
        hue.0	2019-10-17 22:33:46.811	warn	(803) lightQueue: retry [10/10] job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.811	warn	id: 12:666c08556f48208d654e981ead5b37e9 failed: Error: parameter, battery, is not modifiable
        hue.0	2019-10-17 22:33:46.811	warn	(803) lightQueue: job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.776	warn	id: 12:666c08556f48208d654e981ead5b37e9
        hue.0	2019-10-17 22:33:46.776	warn	(803) lightQueue: retry [9/10] job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.776	warn	id: 12:666c08556f48208d654e981ead5b37e9 failed: Error: parameter, battery, is not modifiable
        hue.0	2019-10-17 22:33:46.776	warn	(803) lightQueue: job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.741	warn	id: 12:666c08556f48208d654e981ead5b37e9
        hue.0	2019-10-17 22:33:46.741	warn	(803) lightQueue: retry [8/10] job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.741	warn	id: 12:666c08556f48208d654e981ead5b37e9 failed: Error: parameter, battery, is not modifiable
        hue.0	2019-10-17 22:33:46.741	warn	(803) lightQueue: job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.707	warn	id: 12:666c08556f48208d654e981ead5b37e9
        hue.0	2019-10-17 22:33:46.707	warn	(803) lightQueue: retry [7/10] job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.706	warn	id: 12:666c08556f48208d654e981ead5b37e9 failed: Error: parameter, battery, is not modifiable
        hue.0	2019-10-17 22:33:46.706	warn	(803) lightQueue: job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.671	warn	id: 12:666c08556f48208d654e981ead5b37e9
        hue.0	2019-10-17 22:33:46.671	warn	(803) lightQueue: retry [6/10] job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.671	warn	id: 12:666c08556f48208d654e981ead5b37e9 failed: Error: parameter, battery, is not modifiable
        hue.0	2019-10-17 22:33:46.671	warn	(803) lightQueue: job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.636	warn	id: 12:666c08556f48208d654e981ead5b37e9
        hue.0	2019-10-17 22:33:46.636	warn	(803) lightQueue: retry [5/10] job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.636	warn	id: 12:666c08556f48208d654e981ead5b37e9 failed: Error: parameter, battery, is not modifiable
        hue.0	2019-10-17 22:33:46.636	warn	(803) lightQueue: job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.601	warn	id: 12:666c08556f48208d654e981ead5b37e9
        hue.0	2019-10-17 22:33:46.601	warn	(803) lightQueue: retry [4/10] job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.601	warn	id: 12:666c08556f48208d654e981ead5b37e9 failed: Error: parameter, battery, is not modifiable
        hue.0	2019-10-17 22:33:46.601	warn	(803) lightQueue: job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.564	warn	id: 12:666c08556f48208d654e981ead5b37e9
        hue.0	2019-10-17 22:33:46.564	warn	(803) lightQueue: retry [3/10] job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.564	warn	id: 12:666c08556f48208d654e981ead5b37e9 failed: Error: parameter, battery, is not modifiable
        hue.0	2019-10-17 22:33:46.564	warn	(803) lightQueue: job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.530	warn	id: 12:666c08556f48208d654e981ead5b37e9
        hue.0	2019-10-17 22:33:46.530	warn	(803) lightQueue: retry [2/10] job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.529	warn	id: 12:666c08556f48208d654e981ead5b37e9 failed: Error: parameter, battery, is not modifiable
        hue.0	2019-10-17 22:33:46.529	warn	(803) lightQueue: job sensors.updateSensorConfig:ZLLPresense
        hue.0	2019-10-17 22:33:46.495	warn	id: 12:666c08556f48208d654e981ead5b37e9
        hue.0	2019-10-17 22:33:46.495	warn	(803) lightQueue: retry [1/10] job sensors.updateSensorConfig:ZLLPresense
        debug	id: 12:666c08556f48208d654e981ead5b37e9 failed: Error: parameter, battery, is not modifiable
        Ich scheine die Batterie schalten zu wollen 😬
        • foxriver76
          Man kann nun übrigens auch das Einschaltverhalten der der Hue App annehmen. Sprich beim Einschalten wird dann nicht mehr automatisch auf 100 % hochgedimmt. Hierzu in den Adaptereinstellungen ‘natives ein und ausschaltverhalten’ auswaehlen.
          BBTown 1 Reply Last reply Reply Quote 3
          • BBTown
            Mal schauen ob mir ein Unterschied auffällt, da ich manches sowieso mit Helligkeitsvorgabe einschalte
            • foxriver76
              @BBTown ich probiere morgen mal noch was. Das ist sehr undurchsichtig in der genutzten API und der Entwickler kann es mir leider auch nicht korrekt erklären (hat auch keinen Sensor 😆 )
              • BBTown
                @foxriver76 ich benötige die Funktion nicht, teste aber sehr gern, wenn es hilft 🙂
                  WulfR last edited by
                  @foxriver76 Feedback zu Version 2.2.1: Ein/aus bei den neuen Hue SmartPlug Steckdosen geht, bei den alten LivingWhites noch nicht.
                  Danke für die viele Arbeit! Gruß, Wulf.
                  • foxriver76
                    foxriver76 Developer @WulfR last edited by foxriver76
                    @WulfR dann mal bitte Adapter auf debug und nach poll all. Loggt er ein riesiges JSON, da muss dann auch der Living Whites dabei sein, denke der Entwickler braucht auch wieder die Daten.
                    Oder erst mal nur die Fehlermeldung, hat ja die gleichen Funktionen wie ein Osram oder?
                    Also die Zeile: max retry reached: Error: Unknown type, On/Off plug-in unit nur müsste da ein anderer Typ stehen.
                      brain last edited by brain
                      @foxriver76 Feedback zu 2.2.1: Schalten von Osram Smart Plug funktioniert.
                        WulfR @foxriver76 last edited by WulfR
                        @foxriver76 - sorry, ich war nicht zu Hause und konnte Dir keine schnelle Antwort schicken.
                        Ob sich der LivingWhites Plug wie Osram verhält, kann ich nicht sagen, es ist jedenfalls ein altes Produkt von Philips aus der vor-Hue-Zeit. An der Unterseite ist ein Schalter mit "on/off" und "dim", bei steht er auf "on/off". Wahrscheinlich muss ich die Dinger eh bald entsorgen, denn Philips fährt den Support im Hue-Umfeld immer mehr runter.
                        Hier ist der Log-Auszug:
                        hue.0	2019-10-19 09:30:11.291	error	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 max retry reached: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.265	warn	(18719) lightQueue: retry [10/10] job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7
                        hue.0	2019-10-19 09:30:11.265	warn	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 failed: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.239	warn	(18719) lightQueue: retry [9/10] job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7
                        hue.0	2019-10-19 09:30:11.238	warn	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 failed: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.209	warn	(18719) lightQueue: retry [8/10] job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7
                        hue.0	2019-10-19 09:30:11.208	warn	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 failed: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.182	warn	(18719) lightQueue: retry [7/10] job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7
                        hue.0	2019-10-19 09:30:11.181	warn	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 failed: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.156	warn	(18719) lightQueue: retry [6/10] job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7
                        hue.0	2019-10-19 09:30:11.155	warn	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 failed: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.129	warn	(18719) lightQueue: retry [5/10] job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7
                        hue.0	2019-10-19 09:30:11.129	warn	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 failed: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.102	warn	(18719) lightQueue: retry [4/10] job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7
                        hue.0	2019-10-19 09:30:11.102	warn	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 failed: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.076	warn	(18719) lightQueue: retry [3/10] job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7
                        hue.0	2019-10-19 09:30:11.076	warn	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 failed: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.049	warn	(18719) lightQueue: retry [2/10] job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7
                        hue.0	2019-10-19 09:30:11.048	warn	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 failed: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.020	warn	(18719) lightQueue: retry [1/10] job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7
                        hue.0	2019-10-19 09:30:11.018	warn	(18719) lightQueue: job lights.setLightState:32:c6bd161f85765dded90688b4e56469d7 failed: Error: Unknown type, Dimmable plug-in unit
                        hue.0	2019-10-19 09:30:11.000	debug	(18719) final lightState for Hue_Bridge_1.Weihnachten_Terrassenfenster:{"bri":0,"on":false,"level":0}
                        hue.0	2019-10-19 09:30:10.959	debug	(18719) stateChange hue.0.Hue_Bridge_1.Weihnachten_Terrassenfenster.bri {"val":0,"ack":false,"ts":1571470210956,"q":0,"from":"system.adapter.hue.0","user":"system.user.admin","lc":1571470210956}
                        hue.0	2019-10-19 09:30:10.953	debug	(18719) stateChange hue.0.Hue_Bridge_1.Weihnachten_Terrassenfenster.on {"val":false,"ack":false,"ts":1571470210949,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1571470210949}
                        sigi234 foxriver76 2 Replies Last reply Reply Quote 0
                          sigi234 Forum Testing Most Active @WulfR last edited by
                          @WulfR
                          Bitte benutzt die Code Tags Funktion -> </>
                            WulfR @sigi234 last edited by
                            @sigi234 ... sorry!
                            • foxriver76
                              @WulfR danke. Nur die Ruhe, wenn’s mal paar Tage dauert.. ist ja Freizeit 😉
                              Ich habe es mal weitergegeben, kann sein dass das JSON noch benötigt wird, falls dies der Fall ist, gebe ich dir bescheid.
                              • Jey Cee
                                @WulfR sigi234 hat dich ja schon darauf Hingewiesen bitte code und logs in Code tags zu Packen. Es ist super schlecht zu lesen und unübersichtlich vorallem auf Mobilen Geräten.
                                Bitte hol das nach, dafür gibt es die Bearbeiten funktion rechts unten am Beitrag im 3 Punkte Menü.
                                  @foxriver76 ... es hat in der Tat Zeit, wie man am Namen sieht geht es um Weihnachtsvorbereitungen 😉
                                  Das ist jedenfalls der Eintrag fürs Gerät auf der Hue-Bridge:
                                  {"state":{"on":true,"bri":254,"alert":"select","mode":"homeautomation","reachable":true},"swupdate":{"state":"notupdatable","lastinstall":null},"type":"Dimmable plug-in unit","name":"Weihnachten Terrassenfenster","modelid":"LWL001","manufacturername":"Philips","productname":"LivingWhites Plug","capabilities":{"certified":true,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional"},"uniqueid":"00:17:88:01:00:2f:80:b1-0c","swversion":"1.0.1.4591"}
                                    WulfR @Jey Cee last edited by
                                    @Jey-Cee ... done.
                                    • foxriver76
                                      @WulfR Probier mal bitte 2.2.2, sollte nun laufen.
                                        @foxriver76 - Sieht gut aus! Vielen Dank!!
                                        • foxriver76
                                          foxriver76 Developer @lobomau last edited by
                                          @lobomau Kannst du mal testen ob 2.2.3 wieder läuft mit der runden Bridge?
                                          lobomau 2 Replies Last reply Reply Quote 0
                                          • lobomau
                                            lobomau @foxriver76 last edited by
                                            @foxriver76 kann ich machen. Ansonsten ist eckige schon auf dem Postweg zu mir. Die Runde hatte auch mit der hue Handy App Probleme.
                                            79.9k
                                            hue hue adapter zigbee
                                            25
                                            208
                                            17760
