    4. JavaScript
    5. IoBroker und VOIP / SIP Calls mit Asterisk + Fritzbox
      Kai103 last edited by Kai103
      @Stuebi said in IoBroker und VOIP / SIP Calls mit Asterisk + Fritzbox:
      asterisk -rvvvv
      hm... jetzt zwei mal einen Anruf gemacht, keine Fehler . im Asterisk -rvvvv erscheint
      Using SIP RTP CoS mark 5
         -- Called 24......../01765XXXXXXXX
            > 0x73f07880 -- Strict RTP learning after remote address set to: 192.168.0.1:7078
         -- SIP/24.......-00000001 is making progress
         -- SIP/24........-00000001 answered
         -- Executing [0176XXXXXXXXX@ael-ansage:1] Answer("SIP/24......-00000001", "") in new stack
         -- Executing [0176XXXXXXX@ael-ansage:2] Wait("SIP/24.........-00000001", "1") in new stack
         -- Executing [0176XXXXXXX@ael-ansage:3] Read("SIP/24........-00000001", "dtmf,/tmp/audio_1570985582279&beep,0,s,5,1") in new stack
         -- <SIP/24..........-00000001> Playing '/tmp/audio_1570985582279.gsm' (language 'en')
         -- <SIP/24...........-00000001> Playing 'beep.gsm' (language 'en')
         -- User entered nothing, 4 chances left
         -- <SIP/24...........-00000001> Playing '/tmp/audio_1570985582279.gsm' (language 'en')
         -- <SIP/24.............-00000001> Playing 'beep.gsm' (language 'en')
         -- User entered nothing, 3 chances left
         -- <SIP/24.........-00000001> Playing '/tmp/audio_1570985582279.gsm' (language 'en')
         -- User entered nothing, 2 chances left
         -- User entered nothing, 1 chance left
         -- <SIP/24.........-00000001> Playing 'beep.gsm' (language 'en')
         -- User entered nothing.
         -- Executing [0176xxxxxxxx@ael-ansage:4] GotoIf("SIP/24.......-00000001", "0?5:6") in new stack
         -- Goto (ael-ansage,0176xxxxxxx,6)
         -- Executing [0176xxxxxxx@ael-ansage:6] NoOp("SIP/24...........-00000001", "Finish if_ael-ansage_1") in new stack
         -- Executing [0176xxxxxxxxx@ael-ansage:7] Hangup("SIP/24..........-00000001", "") in new stack
       == Spawn extension (ael-ansage, 0176xxxxxxxx, 7) exited non-zero on 'SIP/24........-00000001'
         -- Executing [h@ael-ansage:1] GotoIf("SIP/24.........-00000001", "1?2:4") in new stack
         -- Goto (ael-ansage,h,2)
         -- Executing [h@ael-ansage:2] NoOp("SIP/2...........-00000001", "/bin/rm /tmp/audio_1570985582279.*") in new stack
         -- Executing [h@ael-ansage:3] System("SIP/24..........-00000001", "/bin/rm /tmp/audio_1570985582279.*") in new stack
         -- Executing [h@ael-ansage:4] NoOp("SIP/24...........-00000001", "Finish if_ael-ansage_2") in new stack
         -- Executing [h@ael-ansage:5] SayDigits("SIP/24........-00000001", "") in new stack
         -- Executing [h@ael-ansage:6] NoOp("SIP/24.......-00000001", "Finish if_ael-ansage_1") in new stack
         -- Executing [h@ael-ansage:7] Hangup("SIP/24........-00000001", "") in new stack
       == Spawn extension (ael-ansage, h, 7) exited non-zero on 'SIP/24.......-00000001'
      gefühlt sehe ich da keinen Fehler, aber auf was wartet das Programm ?
      Und im Iobroker Log auch keine Fehler mehr :
      2019-10-13 18:53:24.161 - info: asterisk.0 Dialing completed. Result: {"parameter":{"callerid":"04111111111","telnr":"0176XXXXXXXX","text":"Test Test","extension":"24........","audiofile":"/tmp/audio_1570985582279","delete":"delete"},"options":{"action":"originate","channel":"SIP/24....../0176XXXXXXX","context":"ael-ansage","exten":"0176XXXXXXX","priority":1,"timeout":60000,"variable":{"repeat":5,"file":"/tmp/audio_1570985582279","del":"delete"},"callerid":"0411111111111111"},"guid":"8d8e363b-67e2-3517-d116-f8f1aa366880","result":{"response":"Success","actionid":"8d8e363b-67e2-3517-d116-f8f1aa366880","message":"Originate successfully queued"}}
      Wobei es schon faszinierend ist, überall ist die zu verwendende abgehende Nummer eingetragen, das wird aber ignoriert und es wird immer die Hauptfestnetznummer angezeigt.
      Stuebi 1 Reply Last reply Reply Quote 0
      • Stuebi
        Stuebi @Kai103 last edited by
        @Kai103 , wenn ich dich richtig verstehe, funktioniert es jetzt.
        Das Problem mit der Hauptfestnetznummer kenne ich. Ich glaube die Fritzbox überschreibt den die Hauptfestnetznummer wieder. Du kannst ja nochmals versuchen diese mit Vorwahl und ohne Vorwahl einzutragen. Vielleicht hilft das.
          es lief... dann musste ich ich wieder auf einen anderen pi wechseln, und da gibt es nun wieder Ärger. Ich schicke dir mal ne Mail...
          Danke schon mal
          • I
            Inxession last edited by Inxession
            Leider bekomme ich folgende Fehlermeldung
            pi@raspberrypi:~ $ asterisk -rvvvvv
            Unable to open specified master config file '/etc/asterisk/asterisk.conf', using built-in defaults
            Unable to connect to remote asterisk (does /var/run/asterisk/asterisk.ctl exist? )
            Was mache ich falsch?
            Danke und Gruß
            Michael
            • Stuebi
              Stuebi @Inxession last edited by
              @Inxession , es sieht so aus als ob asterisk nicht gestartet wurde. Einmal asterisk starten und dann nochmals versuchen.
              Wie du asterisk startest, findest du in der README .
              • I
                Guten Morgen @Stuebi
                ...so nun habe ich nochmal alles neu aufgesetzt.
                Der Log von iobroker wird jetzt nicht mehr zugemüllt.
                Allerdings bringt mir der Befehl
                asterisk -rvvvvv
                folgende Ausgabe
                Unable to connect to remote asterisk (does /var/run/asterisk/asterisk.ctl exist?)
                Als Werte in der Callout Funktion trage ich die Rufnummer ein, einen Text und die abgehende Rufnummer.
                Wenn ich dann den Button betätige, meldet der Log von iobroker "Start dialing".
                Mehr passiert leider nicht.
                Danke und schönes Wochenende
                  Flo1989 last edited by
                  Hallo, ich habe da auch mal eine Frage. Ich möchte gerne einstellen das bei meiner Alarmanlage erst die eine Nummer und dann verzögert eine Andere Nummer Angerufen wird. Habe es schon versucht den Adapter zwei mal zu installieren aber es läuft immer nur über einen. Von dem ich halt die Daten kopiert habe per putty.
                  Hat da jemand eine einfache Lösung für mich?
                  • Stuebi
                    Stuebi @Flo1989 last edited by
                    @Flo1989 , standardmäßig laufen die Calls asynchron und daher parallel. schaue nachher ob man diese auch synchron starten kann.
                    Stuebi M 2 Replies Last reply Reply Quote 0
                    • Stuebi
                      Stuebi @Stuebi last edited by
                      @Stuebi , versuche es mit async = false.
                      var number   = "040 666-7766";
                      var callerid = '040 123 999'; // optional, if not set anonymous call
                      var msg      = "Hello, this textmessage will be converted to audio";
                      // call telephone nummber 040 666-7766 and play text message as audio
                      sendTo('asterisk.0', "dial", { telnr: number, callerid: callerid, text:  msg, async: false},  (res) => {
                            console.log('Result: ' + JSON.stringify(res));
                        Flo1989 @Stuebi last edited by
                        @Stuebi Sry für die doofe Frage aber wo und wie füge ich die zweite Nummer ein bzw. Wie schreibe ich das per putty? Bin da noch Neuling und mache die meisten Einstellungen über den IoBroker oder per Blocky. 🙈
                          flisse last edited by flisse
                          ich habe mir auch den Asterisk Adapter installiert und eingerichtet.
                          Bei mir funktioniert nur das einloggen in der Fritzbox nicht. Nutzername und Passwort sind natürlich kontrolliert und richtig. In den Ereignissen der Fritzbox kommen folgende Meldungen:
                          Anmeldung für IP-Telefoniegerät "12345678" von IP-Adresse 192.168.178.xx nicht erfolgreich
                          Wenn ich in Putty den Befehl asterisk -rvvvvvvv eingebe, kommt folgendes:
                          [Nov  6 09:22:22] NOTICE[649]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for '12345678@192.168.178.1' timed out, trying again (Attempt #379)
                          [Nov  6 09:22:42] NOTICE[649]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for '12345678@192.168.178.1' timed out, trying again (Attempt #380)
                          [Nov  6 09:23:02] NOTICE[649]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for '12345678@192.168.178.1' timed out, trying again (Attempt #381)
                          und das wiederholt sich dann immer wieder. Woran kann das liegen? Bin genau nach der Anleitung vorgegangen. Meine Fritzbox ist eine 7590 mit der Firmware 7.12.
                          Genutzt wird mein ioBroker und somit auch der Asterisk Adapter auf einem Raspberry Pi 4.
                          • Rupert
                            Rupert last edited by
                            Bei mir das gleiche Verhalten bzw. Fehler wie bei @flisse
                            Ebenbfalls Pi4 4GB mit Fritzbox 7590.
                            Gibt es dazu schon eine Lösung oder hat jemand einen Tipp.
                            Danke.
                            • Stuebi
                              Stuebi @Rupert last edited by Stuebi
                              @Rupert , kannst du einmal die Meldung aus asterisk -rvvvvvv hier veröffentlichen. Kannst du die Fritzbox von der asterisk Maschine aus mit Ping erreichen? Steht etwas im Fritzbox Logfile? Sind asterisk und die Fritzbox im gleichen Netz?
                              VG
                              Stübi
                              Rupert 2 Replies Last reply Reply Quote 0
                              • Rupert
                                Rupert @Stuebi last edited by
                                @Stuebi
                                Danke.
                                Sind im gleichen Netz. Das Andere erledige ich Anfang der Woche, da ich jetzt übers WE nicht zuhause bin.
                                • Rupert
                                  @Stuebi
                                  asterisk -rvvvvvv sagt:
                                  Connected to Asterisk 16.2.1~dfsg-1+deb10u1 currently running on raspberrypi (pid = 621)
                                  [Dec 16 14:35:17] NOTICE[821]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for '12345678@192.168.9.250' timed out, trying again (Attempt #6)
                                  [Dec 16 14:35:37] NOTICE[821]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for '12345678@192.168.9.250' timed out, trying again (Attempt #7)
                                  [Dec 16 14:35:57] NOTICE[821]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for '12345678@192.168.9.250' timed out, trying again (Attempt #8)
                                  Fritzbox-Log sagt:
                                  16.12.19
                                  14:25:13
                                  Anmeldung für IP-Telefoniegerät "12345678" von IP-Adresse 192.168.9.170 nicht erfolgreich. [2 Meldungen seit 16.12.19 14:06:53]
                                  Ping zur Fritzbox IP 192.168.9.250 sagt:
                                  PING 192.168.9.250 (192.168.9.250) 56(84) bytes of data.
                                  64 bytes from 192.168.9.250: icmp_seq=1 ttl=64 time=0.438 ms
                                  64 bytes from 192.168.9.250: icmp_seq=2 ttl=64 time=0.432 ms
                                  64 bytes from 192.168.9.250: icmp_seq=3 ttl=64 time=0.369 ms
                                  64 bytes from 192.168.9.250: icmp_seq=4 ttl=64 time=0.327 ms
                                  Fritzbox hat in meinem Netzt die 192.168.9.250
                                  Pi4 hat im selben Netz die 192.168.9.170
                                  Auf dem Pi4 laufen iobroker + pivccu3
                                  Realisieren möchte ich folgende Funktion:
                                  Wenn die Türschelle betätigt wird sollen alle Telefone im Haus für ca. 15 Sek. klingeln.
                                  Auf dem Display soll als Nachricht "Türklingel" erscheinen.
                                  Anruf soll sich danach automatisch beenden, eine Durchsage benötige ich nicht.
                                  Beste Grüße
                                  • Stuebi
                                    Es gibt anscheinend ein paar Leute mit dem Problem Asterisk in Verbindung mit der Fritzbox. Nutzt Du die PJSIP oder SIP Konfiguration?
                                    Hier ist z.B. ein Tipp https://www.ip-phone-forum.de/threads/fritzbox-und-asterisk-registration-timed-out.257765/ wie der Fehler behoben wurde. Mit den Parametern
                                    qualify=yes
                                    qualifyfreq=600
                                    in sip.conf sollt es gehen. In der pjsip.conf müsste es
                                    qualify_frequency=60
                                    qualify_timeout=5.0      ; Qualify timeout in fractional seconds (default: "3.0")
                                    sein. Die Konfigurationsdateien findest Du in dem Verzeichnis /etc/asterisk . Anschließend musst du asterisk neu starten oder die sip/pjsip neue einlesen. Das geht wie folgt: asterisk -rvvvvvv und anschließend sip reload oder pjsip reload ausführen.
                                    Ich bin gespannt, ob das hilft.
                                    VG
                                    Stübi
                                    Rupert 1 Reply Last reply Reply Quote 0
                                    • Rupert
                                      sip reload
                                      Danke für deine Hilfe!
                                      Ich benutze noch SIP.
                                      Die Parameter haben keinen Unterschied gemacht.
                                      Aber ich habe mir die Beiträge im von dir verlinkten Forum durchgelesen und bei einem User hat es geholfen die Fritzbox mal für 5 Minuten stromlos zu machen (einen normalen Neustart der FB hatte ich auch schon versucht).
                                      Habe ich auch mal gemacht und siehe da. Der Befehl sip show registry gibt nun Registered aus.
                                      raspberrypi*CLI> sip show registry
                                      Host                                    dnsmgr Username       Refresh State                Reg.Time
                                      192.168.9.250:5060                      N      123456789          285 Registered           Tue, 17 Dec 2019 18:46:44
                                      1 SIP registrations.
                                      Log der FB sagt nun ebenfalls, dass die Anmeldung erfolgreich war.
                                      Beste Grüße
                                      • sergey67
                                        sergey67 last edited by
                                        @Stuebi
                                        Hallo!
                                        Ist es möglich, dass Anrufe vom Ibroker an Asterisk-Nebenstellennummern im lokalen Netzwerk gehen, ohne die Fritzbox und den VOIP-Provider zu verwenden. Entschuldigung für mein deutsch Vielen Dank.
                                        • Stuebi
                                          Stuebi @sergey67 last edited by
                                          @sergey67 , das sollte eigentlich möglich sein. Aber das musst Du eine eigene extensions.ael und sip.conf bzw. pjsip.conf erstellen. Einfache einmal googlen.
                                          sergey67 1 Reply Last reply Reply Quote 0
                                          • sergey67
                                            sergey67 @Stuebi last edited by
                                            @Stuebi
                                            Vielen Dank! Ich werde versuchen, es herauszufinden.
                                            205
                                            40278
