    4. Test js-controller v2.0.x (GitHub)
    • N
      NightWatcher last edited by
      Stimmt, ich glaube gestern um die Uhrzeit habe ich versucht, den js-controller zu aktualisieren. Da stand dann aber in der console "is up to date"...
      Jetzt im Log sehe ich zu der Uhrzeit aber, dass er trotzdem versuchte, was zu laden?!
      Der interessante Teil:
      2019-10-21 19:22:07.061  - info: host.SERVER iobroker url "https://github.com/ioBroker/ioBroker.js-controller"
      2019-10-21 19:22:08.408  - info: host.SERVER iobroker install https://github.com/ioBroker/ioBroker.js-controller/tarball/e755ffbf2b811a235b952dad6012fd9cc769025d
      2019-10-21 19:22:09.276  - info: host.SERVER iobroker NPM version: 6.9.0
      2019-10-21 19:22:09.277  - info: host.SERVER iobroker npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/e755ffbf2b811a235b952dad6012fd9cc769025d --loglevel error --production --save --prefix "c:/ioBroker" (System call)
      2019-10-21 19:22:32.001  - info: host.SERVER iobroker npm
      2019-10-21 19:22:32.002  - info: host.SERVER iobroker  ERR! path c:\ioBroker\node_modules\iobroker.js-controllernpm ERR! code EBUSY
      2019-10-21 19:22:32.002  - info: host.SERVER iobroker npm
      2019-10-21 19:22:32.003  - info: host.SERVER iobroker
      2019-10-21 19:22:32.003  - info: host.SERVER iobroker ERR!
      2019-10-21 19:22:32.004  - info: host.SERVER iobroker
      2019-10-21 19:22:32.004  - info: host.SERVER iobroker errno
      2019-10-21 19:22:32.004  - info: host.SERVER iobroker  -4082
      2019-10-21 19:22:32.005  - info: host.SERVER iobroker npm
      2019-10-21 19:22:32.005  - info: host.SERVER iobroker ERR!
      2019-10-21 19:22:32.006  - info: host.SERVER iobroker
      2019-10-21 19:22:32.006  - info: host.SERVER iobroker syscall rename
      2019-10-21 19:22:32.009  - info: host.SERVER iobroker npm
      2019-10-21 19:22:32.010  - info: host.SERVER iobroker
      2019-10-21 19:22:32.010  - info: host.SERVER iobroker ERR! EBUSY: resource busy or locked, rename 'c:\ioBroker\node_modules\iobroker.js-controller' -> 'c:\ioBroker\node_modules\.iobroker.js-controller.DELETE'
      2019-10-21 19:22:32.027  - info: host.SERVER iobroker
      2019-10-21 19:22:32.027  - info: host.SERVER iobroker npm ERR! A complete log of this run can be found in:npm ERR!     C:\Users\Bjoern\AppData\Roaming\npm-cache\_logs\2019-10-21T17_22_32_016Z-debug.log
      2019-10-21 19:22:32.061  - error: host.SERVER iobroker host.SERVER Cannot install https://github.com/ioBroker/ioBroker.js-controller/tarball/e755ffbf2b811a235b952dad6012fd9cc769025d: 4294963214
      2019-10-21 19:22:33.074  - info: host.SERVER iobroker exit 25
      2019-10-21 19:25:00.008  - info: host.SERVER instance system.adapter.weatherunderground.0 started with pid 9380
      2019-10-21 19:25:00.715  - error: host.SERVER instance system.adapter.weatherunderground.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      Er lief dann aber erst mal noch weiter. Bis zu meinem manuellen restart heute morgen.
      Kann ich den js-controller einfach über npm install noch mal drüber installieren?
      • N
        • iobroker gestoppt
        • npm install https://github.com/ioBroker/ioBroker.js-controller
        ioBroker läuft wieder. Instanzen fahren auch gerade alle wieder hoch.
        arteck crunchip 2 Replies Last reply Reply Quote 0
          arteck Developer Most Active @NightWatcher last edited by
          @NightWatcher 👍
            crunchip Forum Testing Most Active @NightWatcher last edited by
            @NightWatcher das Problem hatte ich auch gestern beim Versuch auf Js-Controller .35
            auch ein
            hatte ich gemacht, jedoch musste ich dann feststellen, das ich keinen Adapter mehr updaten konnte, immer mit der Fehlermeldung npm error....
            in meinem Fall habe ich den Snapshot zurückgespielt
            • AlCalzone
              AlCalzone Developer @crunchip last edited by
              @crunchip sagte in [Aufruf] js-controller 2.0 Beta Test:
              Das relevante an dieser Fehlermeldung ist im "..." versteckt. npm error kann vieles sein.
                crunchip Forum Testing Most Active @AlCalzone last edited by
                @AlCalzone ist mir schon bewusst😊 , jedoch hab ich das leider nicht festgehalten für die Nachwelt und durchs zurückspielen per snapshot ist es ja nun nicht mehr vorhanden, sonst hätte ich es hinzugefügt.
                  apollon77 @NightWatcher last edited by
                  @NightWatcher Also automatisch macht hier nichts updates 🙂
                  Am besten installiere doch per npm direkt nochmal den controller drüber
                  Kommandos oben in der FAQ.
                  "No object found" bedeute das er die Object Library nicht findet ... also da fehlen Files oder sind kaputt
                    @NightWatcher sagte in [Aufruf] js-controller 2.0 Beta Test:
                    Wie hast Du denn versucht zu updaten??? Vllt via Admin mit "custom install" und "EIgene URL"? Nur so kann ich mir vorstellen das "iobroker url "https://github.com/ioBroker/ioBroker.js-controller" zustandekommt und das ist dann der komplett falsche Weg.
                    • s.bormann
                      Hallo, ich habe nun auch mal auf 2.0er Controller (aktuell 2.0.35) geupdated. Läuft, habe aber zwei Probleme:
                        1. Manchmal (unklar wann) sagt er beim Speichern von Einstellungen in einem Adapter:
                          "Bitte bestätigen Einige Daten sind nicht gespeichert. Verwerfen?"
                          so, als hätte man nicht gespeichert und würde versuchen, das Fenster zu schließen. Die Daten werden aber korrekt gespeichert:
                        1. Bei iQontrol (Frontend) dauert der Verbindungsaufbau viel länger, als vorher. Das Problem tritt beim Versuch auf, das erste Objekt über die socket-Verbindung zu laden. Danach läuft alles normal und schnell. Lediglich das erste Objekt, nach Initialisierung des Sockets braucht 1-2 Sekunden - was eine spürbare Verzögerung bedeuted.
                      Hat jemand ähnliche Beobachtungen?
                      Danke für die Entwicklung des neuen Controllers!!! VG!
                      liv-in-sky dslraser 2 Replies Last reply Reply Quote 0
                        liv-in-sky @s.bormann last edited by
                        @s-bormann ich kenne das nur, wenn der chrome browser einen neustart braucht - ich habe immer viele tabs offen und da kommt das bei mir vor
                        habe iqontrol getestet - ist so schnell wie vorher
                        • auch das mit dem verwerfen ist kein thema im moment -
                        benutze version 2.0.35
                        • s.bormann
                          s.bormann Most Active @liv-in-sky last edited by
                          @liv-in-sky
                          Das mit der Verzögerung tritt bei mir auch nur beim Neu-Laden von iQontrol auf. Dann läuft es bei mir auch so schnell, wie vorher. Lediglich der erste Verbindungsaufbau ist deutlich langsamer, als vorher.
                          Und das mit der Verwerfen-Meldung beim Speichern hat nichts mit iQontrol zu tun, das habe ich bei ganz vielen Adaptern.
                          LG
                          • dslraser
                            dslraser Forum Testing Most Active @s.bormann last edited by
                            @s-bormann sagte in [Aufruf] js-controller 2.0 Beta Test:
                            zu 1.
                            Das habe ich bei mir auch...
                            zu 2.
                            Kann ich bei mir nicht feststellen
                              liv-in-sky @s.bormann last edited by liv-in-sky
                              @s-bormann nehme alles zurück und behaupte gegenteil 🙂
                              jetzt habe ich punkt 1 auch gerade gehabt
                                apollon77 last edited by
                                Steht bei euch dann in der browser Konsole irgendwas? Fehler oder so?
                                  Jan1 last edited by
                                  ich hatte es ja schon mal angesprochen, ging aber irgendwie unter. Also noch mal kurz, wenn ich mir iQontrol und Nod-Red links in der Menü Leiste einblende, dann hatten beide ne Zeitlang einfach nur ne leere Seite innerhalb der IOBroker Seite geöffnet. Bei iQontroll funktioniert es mittlerweile wieder, Node-Red macht immer noch nichts.
                                  • dslraser
                                    dslraser Forum Testing Most Active @Jan1 last edited by
                                    @Jan1
                                    hatte ich weiter oben auch angesprochen, (zu iQontrol. )
                                    Geht bei mir übrigens auch mit .35 noch nicht.
                                      Jan1 @dslraser last edited by Jan1
                                      @dslraser
                                      OK, hatte ich dann wohl überlesen 😊
                                      iQontrol läuft allerdings bei mir wieder, seit wann weiß ich aber nicht, da ich die zwei Kandidaten ausgeblendet hatte und nur sporadisch ab und an versuche ob es funktioniert.
                                      Hatte vorhin aber ein System Update gemacht, dass mir Node auf 10.17.0 hoch gezogen hat.
                                      So, bin schon etwas schlauer.
                                      Hatte auch ein Firefox Update auf 70.0.
                                      Das Problem liegt wohl am Firefox, denn der Edgae macht das ohne Murren auf. Dafür weigert sich Edge den Admin unter HTTPS zu öffnen. Mit HTTPS kommt nur Zertifikatsfehler und das wars.
                                      • dslraser
                                        @Jan1
                                        Ich habe meinen Beitrag wieder gefunden, sieht dann bei mir so aus
                                        https://forum.iobroker.net/post/310991
                                          @dslraser
                                          und ich habe meinen fleißig editiert 😊
                                          Lies das mal und schau was da bei Dir passiert.
                                          • dslraser
                                            dslraser Forum Testing Most Active @Jan1 last edited by dslraser
                                            @Jan1 sagte in [Aufruf] js-controller 2.0 Beta Test:
                                            @dslraser
                                            Ich bin entweder mobil mit Chrome oder Firefox unterwegs, da geht es bei Beiden nicht.
                                            Auf dem Mac (habe nix anderes) geht es bei mir auch mit diesen Beiden + Safari nicht.
                                            Edit: das hatte @apollon77 dazu geschrieben (also zu meiner Meldung), aber das ist wohl dann kein iQontrol Thema, oder ?
                                            1.0k
                                            js-controller
                                            48
                                            1047
                                            312578
