    4. Neue Installationsroutine (für Linux)
    • Oberjembker
      Oberjembker last edited by Oberjembker
      1. Anmerkung aus Zeile 203 (stable):
        # TODO: ^ Can we reduce code repetition in these 3 blocks? ^
        Folgender Vorschlag, der gesamte Block Zeilen 148 - 203 ersetzt durch:
      # 3 blocks code repetition reduced
      function add2sudoers() {
      	local xsudoers=$1
      	shift
      	xarry=("$@")
      	for cmd in "${xarry[@]}"; do
      		# Test each command if and where it is installed
      		cmd_bin=$(echo $cmd | cut -d ' ' -f1)
      		cmd_path=$(which $cmd_bin 2> /dev/null)
      		if [ $? -eq 0 ]; then
      			# Then add the command to SUDOERS_CONTENT
      			full_cmd=$(echo "$cmd" | sed -e "s|$cmd_bin|$cmd_path|")
      			SUDOERS_CONTENT+=$xsudoers"NOPASSWD: $full_cmd\n"
      		fi
      	done
      	SUDOERS_CONTENT="$username ALL=(ALL) ALL\n"
      	# Add the user to all groups we need and give him passwordless sudo privileges
      	# Define which commands iobroker may execute as sudo without password
      	declare -a iob_commands=(
      		"shutdown -h now" "halt" "poweroff" "reboot"
      		"systemctl start" "systemctl stop"
      		"mount" "umount" "systemd-run"
      		"apt-get" "apt" "dpkg" "make"
      		"ping" "fping" "arp-scan"
      		"setcap" "vcgencmd" "cat" "df"
      	add2sudoers "$username ALL=(ALL) " "${iob_commands[@]}"
      	# Additionally, define which iobroker-related commands may be executed by every user
      	declare -a all_user_commands=(
      			"systemctl start iobroker"
      			"systemctl stop iobroker"
      			"systemctl restart iobroker"
      	add2sudoers "ALL ALL=" "${all_user_commands[@]}"
      	# Furthermore, allow all users to execute node iobroker.js as iobroker
      	if [ "$IOB_USER" != "$USER" ]; then
      		add2sudoers "ALL ALL=($IOB_USER) " "node $CONTROLLER_DIR/iobroker.js"
      	fi
      Habe ich unter Raspberry/Buster getestet.
      • Oberjembker
        1. Stable und Buster sind prinzipiell gleich, leider ist das Datum bei beiden veraltet und gleich:
        INSTALLER_VERSION="2019-07-21"
        Wäre es nicht auch Zeit, die beiden zusammenzuführen?
        Lieben Gruß,
        Arne.
          apollon77 last edited by
          @Oberjembker Super Ideen, magst Du unter https://github.com/ioBroker/ioBroker mal einen PR erstellen für installer und fixer? Wenn du es bei dir schon so getestet hast ist das vllt das besten das beim Transfer Deiner Vorschläge nichts verloren geht ...
          • nieIP
            nieIP last edited by
            Hallo
            ich habe ioBroker auf einem RasPi 3 noch nach der "alten" Methode installiert. heute habe ich so viel am System auf der Kommandozeile zerbastelt, dass ioBroker nach dem ReBoot nicht mehr allein startet und sich Adapter nur noch mit Fehlermeldungen kompilieren lassen.
            Ich würde gern auf einer frischen SD Karte das Betriebssystem und ioBroker neu installieren.
            Es gibt vom backitup Adpater ein minimales und ein total Backup.
            Wie gehe ich am besten vor. Nach Möglchkeit möchte ich nicht die Einstellungen aller Adapter neu machen müssen. Und die VIS Views sollen auch wiederhergestellt werden.
            Reicht dafür ein Minimal Backup?
            J Röstkartoffel 2 Replies Last reply Reply Quote 0
              Jan1 @nieIP last edited by
              @nieIP
              Neue SD Karte, Debian Buster nach Anleitung installieren, IOBroker nach Doku installieren, Backitup Adapter drauf und minimal Backup wieder herstellen, lange warten, fertig.
              nieIP 1 Reply Last reply Reply Quote 0
                Warum wird eigentlich immer eine Sd-Karte genommen?
                Ein Usb-Stick läuft doch stabiler/sicherer und verkraftet auch eher mal ein plötzlich Strom weg als eine Sd
                  Jan1 @crunchip last edited by
                  @crunchip
                  Weil ein USB Stick hier die schlechtere Wahl wäre. Einer SD ist ein Stromausfall auch egal, aber dem Filesystem darauf genau so wenig wie beim USB Stick.
                  • Röstkartoffel
                    Röstkartoffel @nieIP last edited by Röstkartoffel
                    @nieIP sagte in Neue Installationsroutine (für Linux):
                    wie @Jan1 schon schrieb, ist das die richtige Vorgehensweise.
                    Aber schau bitte ersteinmal, ob im minimal der Ordner /files/vis.0 enthalten und dort drin auch dein VIS-Projekt liegt.
                    War bei meiner alten Installation auf dem Rock64 und dem Backup davon leider nicht der Fall, so das ich nach dem Restore mittels Filezilla den extrahierten VIS.0 Ordner aus dem Total-Backup in das neue ioBroker vom NUC geschoben habe.
                    • nieIP
                      nieIP @Röstkartoffel last edited by
                      @Röstkartoffel sagte in Neue Installationsroutine (für Linux):
                      Ja, ist da. Das ist aber ausser leeren Ordnern und dem backup.json auch das einzige, was da drin ist , hmm
                      • nieIP
                        nieIP @Jan1 last edited by nieIP
                        @Jan1 sagte in Neue Installationsroutine (für Linux):
                        ok, danke, werde ist versuchen.
                        Warum Debian und nicht Raspbian ?
                        Das habe ich mir selbst beantworten können, weil Raspbian auf Debian aufbaut.
                        Reicht die "Lite" Version für ein ioBroker?
                          Jan1 @nieIP last edited by Jan1
                          @nieIP
                          Ok, beim Pi eben Raspian 😎
                          Lite ist ausreichend.
                            marco-mh last edited by
                            Hallo Leute, ich versuche schon seit Donnerstag den Iobroker auf einer QNAP TS251+ in der Linux Station unter Ubuntu 18.04 zu installieren.
                            ich habe mich eigentlich an die Anleitung gehalten. node und nodejs sind 10.7, rpm ist 6.11.3
                            ich bekomme folgende Ausgabe.
                            User iobroker created
                            Created /etc/sudoers.d/iobroker
                            chown: invalid group: ‘admin:admin’
                            Directory /opt/iobroker created
                            touch: cannot touch '/opt/iobroker/INSTALLER_INFO.txt': Permission denied
                            chmod: cannot access '/opt/iobroker/INSTALLER_INFO.txt': No such file or directory
                            bash: line 724: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
                            bash: line 725: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
                            bash: line 726: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
                                Installing ioBroker (3/4)
                            bash: line 746: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
                            npm ERR! code EACCES
                            npm ERR! syscall access
                            npm ERR! path /opt/iobroker
                            npm ERR! errno -13
                            npm ERR! Error: EACCES: permission denied, access '/opt/iobroker'
                            npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker']
                            npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker\'',
                            npm ERR!   errno: -13,
                            npm ERR!   code: 'EACCES',
                            npm ERR!   syscall: 'access',
                            npm ERR!   path: '/opt/iobroker' }
                            npm ERR!
                            npm ERR! The operation was rejected by your operating system.
                            npm ERR! It is likely you do not have the permissions to access this file as the current user
                            npm ERR!
                            npm ERR! If you believe this might be a permissions issue, please double-check the
                            npm ERR! permissions of the file and its containing directories, or try running
                            npm ERR! the command again as root/Administrator.
                            npm ERR!     /home/admin/.npm/_logs/2019-11-29T11_42_35_030Z-debug.log
                                Finalizing installation (4/4)
                            bash: line 772: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
                            Enabling autostart...
                            Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
                            Autostart enabled!
                            bash: line 947: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
                            Fixing directory permissions...
                            This system does not support setting default permissions.
                            Do not use npm to manually install adapters unless you know what you are doing!
                            main: line 551: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
                            main: line 272: return: 192.168.178.10: numeric argument required
                                ioBroker was installed successfully
                                Open http://:8081 in a browser and start configuring!
                            You need to re-login before doing anything else on the console!
                            unter 16.04 in der Linux Station funktioniert es wunderbar.
                            danke für eure hilfe und Gruß Marco
                            apollon77 AlCalzone 2 Replies Last reply Reply Quote 0
                              apollon77 @marco-mh last edited by
                              @marco-mh Naja qnap ist halt leider kein echtes Linux sondern "custom" ... 😞 @AlCalzone
                                Hab ich also keine Chance?
                                schade, unter 16.04 gehts
                                aber danke
                                • AlCalzone
                                  AlCalzone Developer @marco-mh last edited by
                                  @marco-mh Ich bräuchte etwas mehr Infos über den User mit dem du angemeldet bist. Wie heißt dessen Gruppe? Normalerweise heißt die Gruppe wie der User.
                                  Als "echter" root sollte es gehen, aber dann bekommt admin keinen Zugriff aufs ioBroker-Verzeichnis.
                                    Ich hab es hinbekommen. Allerdings habe ich nicht die Linux Station genommen sondern hab eine Linux VM auf der QNAP installiert.
                                    Danke für die Hilfe
                                      mpa last edited by mpa
                                      ich versuche gerade iobroker auf einer VM mit Ubuntu LTS 18.04.3 zu installieren.
                                      Mittlerweile habe ich jetzt mehrmals die Anleitung https://www.iobroker.net/#de/documentation/install/linux.md durchgeackert aber bekomme es leider nicht hin.
                                      Beim Schritt "Installing ioBroker" bekomme ich immer folgende Fehlermeldungen:
                                      ../src/unix_dgram.cc: In function ‘void {anonymous}::OnRecv({anonymous}::SocketContext*)’:
                                      ../src/unix_dgram.cc:121:25: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                                           argv);
                                      In file included from ../src/unix_dgram.cc:5:0:
                                      ../../nan/nan.h:1024:46: note: declared here
                                         NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                                      ../src/unix_dgram.cc: In function ‘void {anonymous}::OnWritable({anonymous}::SocketContext*)’:
                                      ../src/unix_dgram.cc:129:28: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                                           0, NULL);
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         domain      = info[0]->Int32Value();
                                      In file included from /root/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,
                                                       from /root/.cache/node-gyp/10.17.0/include/node/node.h:63,
                                                       from ../../nan/nan.h:54,
                                      /root/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here
                                         V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                      /root/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                         declarator __attribute__((deprecated(message)))
                                      ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         type        = info[1]->Int32Value();
                                      ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         protocol    = info[2]->Int32Value();
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         fd = info[0]->Int32Value();
                                      ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                         String::Utf8Value path(info[1]);
                                      /root/.cache/node-gyp/10.17.0/include/node/v8.h:2892:28: note: declared here
                                                         explicit Utf8Value(Local<v8::Value> obj));
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         buf = info[1]->ToObject();
                                      In file included from /root/.cache/node-gyp/10.17.0/include/node/node.h:63:0,
                                      /root/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here
                                       Local<Object> Value::ToObject() const {
                                      ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         offset = info[2]->Uint32Value();
                                      /root/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here
                                         V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                                      ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         length = info[3]->Uint32Value();
                                      ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                         String::Utf8Value path(info[4]);
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      Könnte mir hier bitte jemand weiterhelfen?
                                      Vielen Dank!
                                        Alles nur Warnungen, ignorieren. Wichtig ist was die letzten Zeilen der gesamten Ausgabe sind ... wenn da steht das alles ok ist dann ist alles ok
                                          mpa @apollon77 last edited by
                                          @apollon77 da kommt dann leider nichts mehr, da sich die VM aufhängt und Putty dadurch die Verbindung verliert.
                                            A Former User last edited by
                                            Ich versuche gerade, den ioBroker unter Lubuntu zum Laufen zu bringen.
                                            Hierzu habe ich mich an die folgende Anleitung gehalten:
                                            Es sei wohl auch alles erfolgreich installiert worden.
                                            Nur komme ich mit dem Browser nicht auf die Oberfläche.
                                            http://<iplocalhost>:8081
                                            Es kommt, Seite ist nicht erreichbar
                                            ioborker habe ich mit iobroker stop/start als auch restart probiert neu zu starten
                                            Ich habe dann mal probiert
                                            iobroker start admin
                                            Dann kommt:
                                            module.js:549
                                            throw err;
                                            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                            at Function.Module._resolveFilename (module.js:547:15)
                                            AlCalzone Homoran 2 Replies Last reply Reply Quote 0
                                            installation
                                            64
                                            415
                                            114481
