    4. JavaScript
    5. Script - Info über Datenpunkte sammeln
      liv-in-sky @paul53 last edited by
      es gibt aber nur: type number, da müssen im "states" zahlen drin sein
      und type boolean - da müssen in "states"logic werte drin sein
              if (helpType=="number" || helpType=="boolean") {
                         var alarmString=false;var alarmString2=false;
                         for (var i=0;  i  < helpStates.length ;i++){
                            //  console.log( helpStates[i]);
                              mylog(isNaN(helpStates[i]).toString())  ;
                              if (isNaN(helpStates[i]) && helpType=="number") alarmString=true; //type number - stehen da nummern drin
                              var helpTypeBool= helpStates[i].toString()  + helpType;
                              if  (helpType=="boolean") {if (helpTypeBool !="falseboolean" && helpTypeBool != "trueboolean")  alarmString2=true;} //type boolean - stehen da booleans
                         if (alarmString){  htmlDP.push(id);
                                            htmlMSG.push("ACHTUNG Multstate must be number")}
                         if (alarmString2){ htmlDP.push(id);
                                            htmlMSG.push("ACHTUNG Multstate must be boolean")}
                         } else {htmlDP.push(id);
                                 htmlMSG.push("ACHTUNG Multstate wrong Def.")}
        paul53 @liv-in-sky last edited by
        @liv-in-sky:
        Richtig.
          sigi234 Forum Testing Most Active @liv-in-sky last edited by sigi234
          @liv-in-sky sagte in Script - Info über Datenpunkte sammeln:
          version 1.2: ProofingDatapoints21-10-19.txt ab "AB HIER NICHTS ÄNDERN" ersetzen - multistates check hinzugefügt
          <p style="color:red;font-family:Helvetica;"><i>!!! ohne Javascript Instanzen !!! kann enabled werden</i></p>undefined<p style="color:red;font-family:Helvetica;"><i>Script hat Fehler - bitte Log checken !!!</i></p>
          javascript.0	2019-10-22 21:12:27.223	error	(15748) at tryOnImmediate (timers.js:676:5)
          javascript.0	2019-10-22 21:12:27.223	error	(15748) at runCallback (timers.js:705:18)
          javascript.0	2019-10-22 21:12:27.223	error	(15748) at Immediate.setImmediate (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:214:41)
          javascript.0	2019-10-22 21:12:27.223	error	(15748) at change (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:4546:37)
          javascript.0	2019-10-22 21:12:27.223	error	(15748) at Object.stateChange (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:396:25)
          javascript.0	2019-10-22 21:12:27.223	error	(15748) at Object.callback (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1055:38)
          javascript.0	2019-10-22 21:12:27.223	error	(15748) at Object.<anonymous> (script.js.System.Objekte:285:5)
          javascript.0	2019-10-22 21:12:27.223	error	(15748) at checkWerte (script.js.System.Objekte:167:15)
          javascript.0	2019-10-22 21:12:27.223	error	(15748) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:808:29)
          javascript.0	2019-10-22 21:12:27.223	error	(15748) at script.js.System.Objekte:182:26
          javascript.0	2019-10-22 21:12:27.222	error	(15748) Error in callback: TypeError: Cannot read property 'common' of null
            liv-in-sky @sigi234 last edited by
            @sigi234
            leider habe ich heute keine zeit mehr - morgen als erstes - poste bitte mal deine settings
              @sigi234
              // @Liv-in-sky Okt.  2019
                                                        // WICHTIG
                                                        // hier muss die instanz der eigenen datenpunkte angegeben werden oder zusätzlich, die man prüfen möchte    , "alexa2.0"
                                                        //oder auch nur einzelne ornder in der datenstruktur z.b. "javascript.2.WLANUnifi"
              const instanzArr=[ "Eigene_Datenpunkte.0", "alexa2.0", "hm-rega.0", "hm-rpc.0"];
                                                        // beispiel const instanzArr=[ "eigeneDatenpunkte.0", "ping.0",];
              var color_in_table="black"         // Farbe text in webseite
              let schriftart="Helvetica";        // möglich: Helvetica,Serif
              var color_gradient1="#819FF7";     // Hintergrund webseite
              var colorHeadlines="darkblue";     // Farbe Überschriften in der VIS Anzeige
              var colorHeadlinesDP="#36d5ec ";   // Farbe Überschriften in der WebSeite Anzeige
              var warnFarbe = "#36d5ec";         //Farbe für Warnungen in vis und Webseite
                @sigi234
                hab doch noch mal nachgesehen - irgendwie ergeben die fehlermeldungen keinen sinn bzw. ich kann sie nicht richtig deuten - bitte stoppe script, lösche alle datenpunkte des scripts, kopiere die ganze neue version, setze nur deine "eigenen_datenpunkte.0" und starte das script nochmal
                  @liv-in-sky
                  Geht, Copy/Paste Fehler oder wenn ich eine const instanzArr hinzufüge.
                  HTML wurde nicht erstellt.
                    @sigi234 hi sigi
                    könntest du nochmal testen
                    ein fehler ist mir aufgefallen - das hing an einem datenpunkt im alexa2 adapter, den du ja standardmäßig prüfst
                      @nis
                      habe mal die prüfung für multistate eingeführt - wahrscheinlich hast du gerade keine solchen datenpunkte -, wenn doch, bitte testen, wenn du zeit hast
                        @sigi234 hi sigi
                        So, gerade getestet nur mit eigenen DP
                        Funktioniert, Html erstellt.
                          liv-in-sky @sigi234 last edited by liv-in-sky
                          @sigi234 und gleich fehler gefunden
                          javascript.0.Ansage.Terminvorschau - magst du mal den raw wert des objects posten ?
                              "user": "system.user.admin",
                              "ts": 1569269166953,
                              "common": {
                                "name": "Termine heute, morgen oder bis einschließlich übermorgen",
                                "type": "boolean",
                                "min": 1,
                                "max": 3,
                                "states": "1:heute;2:morgen;3:übermorgen",
                                "role": "state"
                              "native": {},
                              "acl": {
                                "object": 1636,
                                "owner": "system.user.admin",
                                "state": 1636
                              "_id": "javascript.0.Ansage.Terminvorschau",
                              "type": "state"
                              @sigi234 beim common.type boolean darf unten in den common.states nicht 1 oder 2 stehen sondern true oder false - also nur 2 werte
                              der common.type müßte hier number sein
                                Ok, DP wurde von einen Skript automatisch erstellt.
                                liv-in-sky paul53 2 Replies Last reply Reply Quote 0
                                  @sigi234 ist halt nicht standard - paul hat mir das so erklärt - wahrscheinlich funktioniert es - aber u.U. kann ein anderer adapter (evtl. iqontrol) dann probleme haben
                                    @liv-in-sky
                                    So habe weitere instanzArr hinzufügefügt.
                                    Kommt sofort die Fehlermeldung.
                                    javascript.0	2019-10-23 18:46:59.473	error	(2400) at tryOnImmediate (timers.js:676:5)
                                    javascript.0	2019-10-23 18:46:59.473	error	(2400) at runCallback (timers.js:705:18)
                                    javascript.0	2019-10-23 18:46:59.473	error	(2400) at Immediate.setImmediate (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:214:41)
                                    javascript.0	2019-10-23 18:46:59.473	error	(2400) at change (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:4546:37)
                                    javascript.0	2019-10-23 18:46:59.472	error	(2400) at Object.stateChange (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:396:25)
                                    javascript.0	2019-10-23 18:46:59.472	error	(2400) at Object.callback (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1055:38)
                                    javascript.0	2019-10-23 18:46:59.472	error	(2400) at Object.<anonymous> (script.js.System.Objekte:288:5)
                                    javascript.0	2019-10-23 18:46:59.472	error	(2400) at checkWerte (script.js.System.Objekte:170:15)
                                    javascript.0	2019-10-23 18:46:59.472	error	(2400) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:808:29)
                                    javascript.0	2019-10-23 18:46:59.472	error	(2400) at script.js.System.Objekte:185:26
                                    javascript.0	2019-10-23 18:46:59.472	error	(2400) Error in callback: TypeError: Cannot read property 'common' of null
        // WICHTIG
                                    const instanzArr=[ "alexa2.0", "Eigene_Datenpunkte", "ping.0",];
                                      paul53 @sigi234 last edited by paul53
                                      @sigi234 sagte:
                                      Was nicht bedeutet, dass es richtig sein muss. Es sind 3 Zustände (Multistate), also muss common.type "number" sein.
                                        @sigi234
                                        im datenpunkt ordnerCheck kannst du einzelne ordner durchsuchen
                                        probier darin mal "alexa2.0" und anschliessend "ping.0" - sobald der wert drin ist, läuft das script los und durchsucht nur diesen ordner
                                        eins davon sollte durchlaufen
                                        es scheint du hast einen state, der keinen datenpunkt hat (vermute ich mal) zumindest lt zeile, wo der fehler auftritt
                                        paul53 sigi234 2 Replies Last reply Reply Quote 0
                                          @liv-in-sky sagte:
                                          Ja, es sieht danach aus.
                                            ping.0
                                            Geht aber keine HTML:
                                            alexa2.0 geht nicht
                                            javascript template
                                            11
                                            291
                                            31937
