    4. JavaScript
    5. Script - Info über Datenpunkte sammeln
      sigi234 Forum Testing Most Active @liv-in-sky last edited by sigi234
      @liv-in-sky sagte in Script - Info über Datenpunkte sammeln:
      version 1.2: ProofingDatapoints21-10-19.txt ab "AB HIER NICHTS ÄNDERN" ersetzen - multistates check hinzugefügt
      <p style="color:red;font-family:Helvetica;"><i>!!! ohne Javascript Instanzen !!! kann enabled werden</i></p>undefined<p style="color:red;font-family:Helvetica;"><i>Script hat Fehler - bitte Log checken !!!</i></p>
      javascript.0	2019-10-22 21:12:27.223	error	(15748) at tryOnImmediate (timers.js:676:5)
      javascript.0	2019-10-22 21:12:27.223	error	(15748) at runCallback (timers.js:705:18)
      javascript.0	2019-10-22 21:12:27.223	error	(15748) at Immediate.setImmediate (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:214:41)
      javascript.0	2019-10-22 21:12:27.223	error	(15748) at change (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:4546:37)
      javascript.0	2019-10-22 21:12:27.223	error	(15748) at Object.stateChange (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:396:25)
      javascript.0	2019-10-22 21:12:27.223	error	(15748) at Object.callback (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1055:38)
      javascript.0	2019-10-22 21:12:27.223	error	(15748) at Object.<anonymous> (script.js.System.Objekte:285:5)
      javascript.0	2019-10-22 21:12:27.223	error	(15748) at checkWerte (script.js.System.Objekte:167:15)
      javascript.0	2019-10-22 21:12:27.223	error	(15748) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:808:29)
      javascript.0	2019-10-22 21:12:27.223	error	(15748) at script.js.System.Objekte:182:26
      javascript.0	2019-10-22 21:12:27.222	error	(15748) Error in callback: TypeError: Cannot read property 'common' of null
        liv-in-sky @sigi234 last edited by
        @sigi234
        leider habe ich heute keine zeit mehr - morgen als erstes - poste bitte mal deine settings
          @sigi234
          // @Liv-in-sky Okt.  2019
                                                    // WICHTIG
                                                    // hier muss die instanz der eigenen datenpunkte angegeben werden oder zusätzlich, die man prüfen möchte    , "alexa2.0"
                                                    //oder auch nur einzelne ornder in der datenstruktur z.b. "javascript.2.WLANUnifi"
          const instanzArr=[ "Eigene_Datenpunkte.0", "alexa2.0", "hm-rega.0", "hm-rpc.0"];
                                                    // beispiel const instanzArr=[ "eigeneDatenpunkte.0", "ping.0",];
          var color_in_table="black"         // Farbe text in webseite
          let schriftart="Helvetica";        // möglich: Helvetica,Serif
          var color_gradient1="#819FF7";     // Hintergrund webseite
          var colorHeadlines="darkblue";     // Farbe Überschriften in der VIS Anzeige
          var colorHeadlinesDP="#36d5ec ";   // Farbe Überschriften in der WebSeite Anzeige
          var warnFarbe = "#36d5ec";         //Farbe für Warnungen in vis und Webseite
            @sigi234
            hab doch noch mal nachgesehen - irgendwie ergeben die fehlermeldungen keinen sinn bzw. ich kann sie nicht richtig deuten - bitte stoppe script, lösche alle datenpunkte des scripts, kopiere die ganze neue version, setze nur deine "eigenen_datenpunkte.0" und starte das script nochmal
              @liv-in-sky
              Geht, Copy/Paste Fehler oder wenn ich eine const instanzArr hinzufüge.
              HTML wurde nicht erstellt.
                @sigi234 hi sigi
                könntest du nochmal testen
                ein fehler ist mir aufgefallen - das hing an einem datenpunkt im alexa2 adapter, den du ja standardmäßig prüfst
                  @nis
                  habe mal die prüfung für multistate eingeführt - wahrscheinlich hast du gerade keine solchen datenpunkte -, wenn doch, bitte testen, wenn du zeit hast
                    @sigi234 hi sigi
                    So, gerade getestet nur mit eigenen DP
                    Funktioniert, Html erstellt.
                      liv-in-sky @sigi234 last edited by liv-in-sky
                      @sigi234 und gleich fehler gefunden
                      javascript.0.Ansage.Terminvorschau - magst du mal den raw wert des objects posten ?
                          "user": "system.user.admin",
                          "ts": 1569269166953,
                          "common": {
                            "name": "Termine heute, morgen oder bis einschließlich übermorgen",
                            "type": "boolean",
                            "min": 1,
                            "max": 3,
                            "states": "1:heute;2:morgen;3:übermorgen",
                            "role": "state"
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "owner": "system.user.admin",
                            "state": 1636
                          "_id": "javascript.0.Ansage.Terminvorschau",
                          "type": "state"
                          @sigi234 beim common.type boolean darf unten in den common.states nicht 1 oder 2 stehen sondern true oder false - also nur 2 werte
                          der common.type müßte hier number sein
                            Ok, DP wurde von einen Skript automatisch erstellt.
                            liv-in-sky paul53 2 Replies Last reply Reply Quote 0
                              @sigi234 ist halt nicht standard - paul hat mir das so erklärt - wahrscheinlich funktioniert es - aber u.U. kann ein anderer adapter (evtl. iqontrol) dann probleme haben
                                @liv-in-sky
                                So habe weitere instanzArr hinzufügefügt.
                                Kommt sofort die Fehlermeldung.
                                javascript.0	2019-10-23 18:46:59.473	error	(2400) at tryOnImmediate (timers.js:676:5)
                                javascript.0	2019-10-23 18:46:59.473	error	(2400) at runCallback (timers.js:705:18)
                                javascript.0	2019-10-23 18:46:59.473	error	(2400) at Immediate.setImmediate (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:214:41)
                                javascript.0	2019-10-23 18:46:59.473	error	(2400) at change (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:4546:37)
                                javascript.0	2019-10-23 18:46:59.472	error	(2400) at Object.stateChange (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:396:25)
                                javascript.0	2019-10-23 18:46:59.472	error	(2400) at Object.callback (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1055:38)
                                javascript.0	2019-10-23 18:46:59.472	error	(2400) at Object.<anonymous> (script.js.System.Objekte:288:5)
                                javascript.0	2019-10-23 18:46:59.472	error	(2400) at checkWerte (script.js.System.Objekte:170:15)
                                javascript.0	2019-10-23 18:46:59.472	error	(2400) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:808:29)
                                javascript.0	2019-10-23 18:46:59.472	error	(2400) at script.js.System.Objekte:185:26
                                javascript.0	2019-10-23 18:46:59.472	error	(2400) Error in callback: TypeError: Cannot read property 'common' of null
        // WICHTIG
                                const instanzArr=[ "alexa2.0", "Eigene_Datenpunkte", "ping.0",];
                                  paul53 @sigi234 last edited by paul53
                                  @sigi234 sagte:
                                  Was nicht bedeutet, dass es richtig sein muss. Es sind 3 Zustände (Multistate), also muss common.type "number" sein.
                                    @sigi234
                                    im datenpunkt ordnerCheck kannst du einzelne ordner durchsuchen
                                    probier darin mal "alexa2.0" und anschliessend "ping.0" - sobald der wert drin ist, läuft das script los und durchsucht nur diesen ordner
                                    eins davon sollte durchlaufen
                                    es scheint du hast einen state, der keinen datenpunkt hat (vermute ich mal) zumindest lt zeile, wo der fehler auftritt
                                    paul53 sigi234 2 Replies Last reply Reply Quote 0
                                      paul53 @liv-in-sky last edited by
                                      @liv-in-sky sagte:
                                      Ja, es sieht danach aus.
                                        ping.0
                                        Geht aber keine HTML:
                                        alexa2.0 geht nicht
                                          @sigi234
                                          ich versuch mal den fehler abzufangen und einen fehler mit mehr info im iobroker log auszugeben
                                          du kanns tauch gerne mal dieses script versuchen - ist nur der teil unterm setting
                                          //------------------------------------------AB HIER NICHTS ÄNDERN--------------------------------------------------------
                                          const versionNr = "15102019-1.2"
                                          const warnColor = warnFarbe ;
                                          const format = "<!DOCTYPE html><html lang=\"de\"><head><title>Putzer</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\"></head><body>";
                                          const htmlTable="<table style=\"color:"+color_in_table+";text-align:left; font-family:"+schriftart+";background-image: linear-gradient(67deg,transparent,"+color_gradient1+");\">";
                                          const htmlReset="<p style=\"color:red;font-family:"+schriftart+";\"><i>!!! ohne Javascript Instanzen !!! kann enabled werden</i></p>"
                                          const htmlHeaders = "style=\"color:"+colorHeadlines+";\"";
                                          const htmlHeadersDP = "style=\"color:"+colorHeadlinesDP+";\"";
                                          //  var htmlOhneAnzahl="<p style=\"color:red;font-family:"+schriftart+";\"><i>!!! ohne DatenpunktZählung !!! kann enabled werden</i></p>"
                                          const htmlError="<p style=\"color:red;font-family:"+schriftart+";\"><i>Script hat Fehler - bitte Log checken !!!</i></p>"
                                          var allInstArr=[];
                                          var  instanzArrHelp=[];
                                          const dpPrefix = "javascript."+ instance +".";
                                          var mylogs=false;
                                          var htmlDP=[];
                                          var htmlMSG=[];
                                          var counterAll=0;
                                          var directSearch=false;
                                          var switchOn=false;
                                          var helplogs=false;
                                          var htmlHelper="";
                                          var htmlHelperFile="";
                                          createState(dpPrefix + "ProofingDatapoints.HTMLTable", { name: 'HTMLTable',  type: 'string', read:  true,  write: true,});
                                          createState(dpPrefix + "ProofingDatapoints.ScriptVersion", versionNr,{ name: 'ScriptVersion',  type: 'string', read:  true,  write: true,});
                                          createState(dpPrefix + "ProofingDatapoints.RunScript",false, { name: 'RunScript',  type: 'boolean', role:"switch", read:  true,  write: true,});
                                          createState(dpPrefix + "ProofingDatapoints.JavaInstanzCheck", true,{ name: 'JavaInstanzCheck',  type: 'boolean', role:"switch", read:  true,  write: true,});
                                          createState(dpPrefix + "ProofingDatapoints.ObjectAnzahlCheck", true,{ name: 'ObjectAnzahlCheck',  type: 'boolean', role:"switch", read:  true,  write: true,});
                                          createState(dpPrefix + "ProofingDatapoints.MonsterSearch", false,{ name: 'MonsterSearch',  type: 'boolean', role:"switch", read:  true,  write: true,});
                                          createState(dpPrefix + "ProofingDatapoints.ohneInstanzAnzeige", false,{ name: 'ohneInstanzAnzeige',  type: 'boolean', role:"switch", read:  true,  write: true,});
                                          createState(dpPrefix + "ProofingDatapoints.OrdnerCheck", "", { name: 'OrdnerCheck',  type: 'string', read:  true,  write: true,});
                                          createState(dpPrefix + "ProofingDatapoints.RunSuccessful", false, { name: 'RunSuccessful',  type: 'boolean', role:"state", read:  true,  write: false,});
                                          //------------------------------------------CHECK INSTANZEN--------------------------------------------------------
                                          function instanzCount(){
                                            var ohneInstanz = getState(dpPrefix + "ProofingDatapoints.ohneInstanzAnzeige").val;
                                             var counter=0; var counter2=0;var counter3=0;
                                          $('system.adapter.*.alive').each(function(id, i) {
                                              var ida = id.split('.');
                                               allInstArr.push(ida[2]+"."+ida[3]);
                                            if (!ohneInstanz && !directSearch) {
                                             if(!id.includes("vis")){
                                             counter++;
                                             if (getState(id).val==null) {;counter2++; mylog(ida[2]+ida[3]+"--------------------der hier wurde nie gestartet");
                                                htmlDP.push(ida[2]+"."+ida[3]);
                                                htmlMSG.push("Instanzen ohne Werte");} //else{instanzArr.push(ida[2]+"."+ida[3])}
                                             if (getState(id).val==false) {counter3++;mylog(ida[2]+ida[3]+"-----------------------der hier ist ausgeschalten");
                                                htmlMSG.push("nicht aktiviert");} /*else{instanzArr.push(ida[2]+"."+ida[3])}*/
                                           if (!ohneInstanz) {
                                          mylog("______________________________________________Anzahl Instanzen: " + counter.toString());
                                          htmlDP.push("");
                                          htmlMSG.push("");
                                          htmlDP.push("Anzahl Instanzen");
                                          htmlMSG.push(counter.toString());
                                          mylog("______________________________________________Anzahl gestoppter Instanzen ohne Werte: " + counter2.toString())
                                          htmlDP.push("Instanzen ohne Werte");
                                          htmlMSG.push(counter2.toString());
                                          htmlDP.push("Instanzen nicht aktiviert");
                                          htmlMSG.push(counter3.toString());
                                          //------------------------------------------CHECK ZUORDNUNG--------------------------------------------------------
                                          function checkTypes(select) {
                                              helplog("bin in check types");
                                             var counter=0;
                                             htmlMSG.push("");
                                             htmlDP.push("");
                                             var sub= select.substring(select.length-1, select.length); log("---------: "+sub);//console.log("----------select: "+select);
                                             mylog(select)
                                             $(select).each(function (id, i) {
                                                 counter++
                                               //  console.log("===============id vor null - kein value zu:  "+id);
                                             if (!id.includes('scriptEnabled') && !id.includes('scriptProblem')  && getState(id).val !== null /*&& !id.includes('Log-Script')  && !id.includes('Ereignisliste') && !id.includes('GETPROCESS')*/ ){
                                                 //console.log("===============id vor null - kein value zu:  "+id);
                                                //console.log("status0-checkType");
                                                 if (getState(id).val==null) console.log("===============nullwert - kein value zu:  "+id);
                                                //console.log("status1-checkType");
                                                 if (!JSON.stringify(getObject(id)).includes("type") && !JSON.stringify(getObject(id)).includes("name") /*&& !JSON.stringify(getObject(id)).includes("meta")*/ ) {
                                                //console.log("===============id nach stringify - kein value zu:  "+id);
                                                      var valType = typeof getState(id).val;
                                                       htmlDP.push(id+": "+valType);
                                                       htmlMSG.push("<b>missing DP-OBEJCT !!</b>" );}
                                                  else{
                                                   //console.log("status2-checkType");
                                                      var dpType = getObject(id).common.type;
                                                        if(dpType != "mixed" ) {
                                                        if(dpType !== valType && !(dpType == 'array' && valType == 'object' &&  dpType == 'meta.user') /*&& !(dpType =='text' && valType=='string') && !(dpType =='string' && valType=='text')*/ ) {
                                                           mylog(id + ': Datenpunkttyp: ' + dpType + ', Wert: ' + valType);
                                                           htmlMSG.push(dpType );
                                                           /* später testing)
                                                           console.log("======1=============no type: "+id +"object: "+JSON.stringify(getObject(id)));
                                                           if(!getObject(id).common.hasOwnProperty("type")) console.log("--------------kein TYPE: "+id) ;
                                                           console.log("======2=============no type: "+id +"object: "+JSON.stringify(getObject(id).common));
                                                 if(dpType != valType && !(dpType == 'array' && valType == 'object')) {
                                                     htmlDP.push(dpType);
                                                     htmlMSG.push(valType);
                                             htmlDP.push("<i>ID + IST-WERT</i>");
                                             htmlMSG.push("<i>SOLL-WERT</i>");
                                           //  htmlDP.push("<b>geprüfte Instanz</b>");
                                            // htmlMSG.push("<i><b>"+select+"</b></i>");
                                              htmlDP.push("-col-<b>geprüfte Instanz</b>");
                                             htmlMSG.push("-col-<i><b>"+select+"</b></i>");
                                             helplog("fertg in checkType mit:" + counter.toString()+ " Durchläufen")
                                          //------------------------------------------CHECK  WERTE--------------------------------------------------------
                                          function checkWerte(select) {
                                             helplog("bin in check Werte");
                                             var counter=0;
                                             mylog(select);
                                                 counter++
                                             if (!id.includes('scriptEnabled') && !id.includes('scriptProblem') /* )  && !id.includes('Ereignisliste') && !id.includes('GETPROCESS')*/ ){
                                                //var dpType = getObject(id).common.type;
                                                      if (!JSON.stringify(getObject(id)).includes("type") && !JSON.stringify(getObject(id)).includes("name") ) { //CHECK MISSING OBJECT))
                                                       try{
                                                       } catch (e) {console.log("------------ERROR: "+e + "bei id: " + id); }
                                                       else {
                                                 var valType =  getState(id).val;
                                                // if(dpType != "mixed" ) {}
                                                //console.log("status1");
                                                     if(valType === null) {mylog(id + ': Datenpunkttyp: ' /*+ dpType */+ ", Wert: "+valType);
                                                         htmlDP.push(id);
                                                         var ddd = new Date().getTime()-getObject(id).ts;
                                                         htmlMSG.push("missing seit " + Math.floor((ddd)/1000/60/60/24)+"d "+Math.floor((ddd)/1000/60/60 %24)+"h "+Math.floor((ddd)/1000/60 %60)+"m ");
                                                        //console.log("status2");
                                                  if(getObject(id).common.hasOwnProperty("states") /*&& JSON.stringify(getObject(id).common.states)!=null && JSON.stringify(getObject(id).common.states)!=undefined */){
                                                     // console.log("======2=============no type: "+id +"object: "+JSON.stringify(getObject(id).common.states));
                                                     //console.log("der hier: " +id);
                                                     try{
                                                     var helpStates= Object.keys(getObject(id).common.states);
                                                     } catch (e) {console.log("------------ERROR: "+e + "bei id: " + id); extendObject(id, {common: {states:{"0":"script"}}})}
                                                     var helpType= getObject(id).common.type;
                                                   //  console.log(helpType);
                                                  //console.log(helpStates.toString());
                                                 // console.log(helpStates[0] + helpStates[1] );
                                                  if (helpType=="number" || helpType=="boolean") {
                                                             var alarmString=false;var alarmString2=false;
                                                             for (var i=0;  i  < helpStates.length ;i++){
        //  console.log( helpStates[i]);
        mylog(isNaN(helpStates[i]).toString())  ;
        if (isNaN(helpStates[i]) && helpType=="number") alarmString=true; //type number - stehen da nummern drin
        var helpTypeBool= helpStates[i].toString()  + helpType;
        if  (helpType=="boolean") {if (helpTypeBool !="falseboolean" && helpTypeBool != "trueboolean")  alarmString2=true;} //type boolean - stehen da booleans
                                                             if (alarmString){  htmlDP.push(id);
        htmlMSG.push("-col-<b>ACHTUNG Multstate must be number</b>")}
                                                             if (alarmString2){ htmlDP.push(id);
        htmlMSG.push("-col-<b>ACHTUNG Multstate must be boolean</b>")}
                                                             } else {htmlDP.push(id);
        htmlMSG.push("-col-<b>ACHTUNG Multstate wrong Def.</b>")}
                                                  } //ende states check
                                                 /* else {            htmlDP.push(id);
        htmlMSG.push("ACHTUNG Multstate wrong Def.")}*/
                                             } //ende check missing object
                                             } // ende script enabled check
                                             }); // ende selct.each
                                              helplog("bin raus aus check Werte");
                                          function mylog(message) {
                                            if(mylogs)
                                                console.log(message);
                                          }function helplog(message) {
                                            if(helplogs)
                                          //------------------------------------------Zähle Objecte der  INSTANZEN--------------------------------------------------------
                                          function countDP(idb){
                                             mylog("bin richtig in count");
                                             var counter4=0;
                                             $(idb+".*").each(function(id, i) {
                                             counter4++; })
                                          mylog(idb+counter4);
                                          htmlDP.unshift(idb);
                                          htmlMSG.unshift(counter4.toString());
                                          counterAll=counterAll+counter4;
                                          mylog("bin raus aus count");
                                          //----------------------------------------------Direct Suchen
                                          on({id:dpPrefix + "ProofingDatapoints.OrdnerCheck", ack: false, change: "any"}, function (obj) {
                                              directSearch=true;
                                               instanzArrHelp=[];
                                              setState(dpPrefix + "ProofingDatapoints.RunScript",true);
                                          //-----------------------------------------------SCHALTER MAIN------------------------------------------------
                                          on({id:dpPrefix + "ProofingDatapoints.RunScript", ack: false, val: true}, function (obj) {
                                             setState(dpPrefix + "ProofingDatapoints.RunSuccessful",false);
                                             let java= getState(dpPrefix + "ProofingDatapoints.JavaInstanzCheck").val;
                                             let instanzAnzahl= getState(dpPrefix + "ProofingDatapoints.ObjectAnzahlCheck").val;
                                             let monster= getState(dpPrefix + "ProofingDatapoints.MonsterSearch").val;
                                             var endehtmlConst=   "<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\">Letztes File Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"</p>";
                                             var endehtmlDPConst=   "<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\">Letztes Table Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"</p>";
                                             setState(dpPrefix + "ProofingDatapoints.ScriptVersion",versionNr);
                                             htmlHelper="";
                                             htmlHelperFile="";
                                             setState(dpPrefix + "ProofingDatapoints.HTMLTable",htmlReset+endehtml+htmlError);
                                             writeFile(null, "/ProofingDatapoints/htmlputz.html" ,htmlReset+endehtml+htmlError+"</body>", function (error) {mylog('file written'); });
                                             counterAll=0;
                                             instanzArrHelp=[];
                                             allInstArr=[];
                                          setStateDelayed(dpPrefix + "ProofingDatapoints.RunScript",false,2500);
                                          htmlDP=[];
                                          htmlMSG=[];
                                          instanzCount();  //überprüft instanzen und stellt allInstArr her
                                          htmlDP.push("-col-<b>INSTANZ INFO</b>"); htmlMSG.push(""); htmlDP.push(""); htmlMSG.push("");
                                          mylog(instanzArr.length+"==================="+instanzArr.toString());
                                          if (monster) {instanzArrHelp=allInstArr;} else {instanzArrHelp=instanzArr}  //ACHTUNG MONSTERSEARCH
                                          if (directSearch) {instanzArrHelp=[]; instanzArrHelp.push(getState(dpPrefix + "ProofingDatapoints.OrdnerCheck").val);}
                                          for(let name in instanzArrHelp){
                                             checkWerte(instanzArrHelp[name]+".*")                   //checkt alle werte in intanzArr
                                              mylog("!!!!!!!!!!!!!!!!!!!!:  "+instanzArrHelp[name]);}
                                              if (instanzAnzahl){
                                                    htmlDP.unshift(""); htmlMSG.unshift("");htmlDP.unshift("<b>OBJECTE IN INSTANZ</b>"); htmlMSG.unshift("Anzahl");
                                                      countDP(instanzArrHelp[name]);mylog("bin in zhlen");}
                                                      if (java && !monster) countDP("javascript")
                                                    htmlDP.unshift("-col-<b>GESAMT GEPRÜFTE OBJECTE IN INSTANZEN</b>"); htmlMSG.unshift("-col-<b>"+counterAll.toString()+"</b>");
                                                    mylog("=============: "+counterAll);
                                          if (java && !monster && !ohneInstanz && !directSearch) checkWerte('javascript.*');                //checkt alle javainstanzen
                                           htmlDP.push("-col-<b>ID's OHNE WERT:</b>");
                                           htmlMSG.push("");
                                             checkTypes(instanzArrHelp[name]+".*")
                                             mylog("!!!!!!!!!!!!!!!!!!!!:  "+instanzArrHelp[name])};
                                               htmlDP.push("");
                                               htmlMSG.push("");
                                               htmlDP.push("-col-<b>IDs MIT FALSCHEN TYPE:</b>");
                                               htmlMSG.push("");
                                           if (java && !monster && !ohneInstanz && !directSearch ) checkTypes('javascript.*');
                                           //console.log(htmlMSG.length+"--"+htmlDP.length)
                                          for(var i= htmlDP.length-1; i>-1; i--) {
                                             //console.log(htmlDP[i]+"anerer :"+htmlMSG[i]);
                                               //  if (htmlMSG[i].includes("-col-")) console.log(htmlMSG[i]);
                                                 let htmlDPVis; let htmlDPFile;let htmlMSGVis;let htmlMSGFile;
                                                 if(htmlDP[i].includes("-col-")) {htmlDPVis=htmlDP[i].replace("-col-", (htmlHeadersDP+">"));  htmlDPVis=" "+htmlDPVis } else {htmlDPVis=">"+htmlDP[i]}
                                                 if(htmlMSG[i].includes("-col-")) {htmlMSGVis=htmlMSG[i].replace("-col-", (htmlHeadersDP+">"));htmlMSGVis=" "+htmlMSGVis } else {htmlMSGVis=">"+htmlMSG[i]}
                                                 htmlHelper= htmlHelper+"<tr><td"+htmlDPVis+"&ensp;&ensp;</td><td"+htmlMSGVis+"&ensp;&ensp;</td></tr>"
                                              //  if(htmlDP[i].includes("-col-")) {htmlDP[i]=htmlDP[i].replace("-col-", (htmlHeaders+">")); htmlDPFile=htmlDP[i]; htmlDPFile= " "+htmlDPFile ; } else {htmlDPFile=">"+htmlDP[i]}
                                                 if(htmlDP[i].includes("-col-")) {htmlDPFile=htmlDP[i].replace("-col-", (htmlHeaders+">"));  htmlDPFile= " "+htmlDPFile ; } else {htmlDPFile=">"+htmlDP[i]}
                                                 if(htmlMSG[i].includes("-col-")) {htmlMSGFile=htmlMSG[i].replace("-col-", (htmlHeaders+">")); htmlMSGFile=" "+htmlMSGFile; } else {htmlMSGFile=">"+htmlMSG[i]}
                                                 htmlHelperFile= htmlHelperFile+"<tr><td"+htmlDPFile+"&ensp;&ensp;</td><td"+htmlMSGFile+"&ensp;&ensp;</td></tr>"
                                             var   endehtml=endehtmlConst;
                                             var   endehtmlDP=endehtmlDPConst;
                                             if (monster){endehtml="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! Monster Suche wird automatisch  deaktiviert !!!</i></p>"+endehtml;
                                                       endehtmlDP="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! ACHTUNG: SYSTEM WIRD BELASTET !!! </br></br>!!! Monster Suche wird automatisch  deaktiviert !!! </br></br> BERICHT/AUSWERTUNG NUR ÜBER WEBSEITE</i></p>"+endehtmlDP;}
                                             if (!instanzAnzahl){endehtml="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! Auswertung ohne DatenpunktZählung !!! kann enabled werden</i></p>"+endehtml;
                                                       endehtmlDP="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! Auswertung ohne DatenpunktZählung !!! kann enabled werden</i></p>"+endehtmlDP;}
                                             if (!java){ endehtml="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! Auswertung ohne Javascript Instanzen !!! kann enabled werden</i></p>"+endehtml;
                                                       endehtmlDP="<p style=\"color:"+warnColor+"; font-family:"+schriftart+";\"><i>!!! Auswertung ohne Javascript Instanzen !!! kann enabled werden</i></p>"+endehtmlDP;}
                                             if(!monster) { setStateDelayed(dpPrefix + "ProofingDatapoints.HTMLTable",endehtmlDP+"<table>"+htmlHelper,900);} else{setStateDelayed(dpPrefix + "ProofingDatapoints.HTMLTable",endehtmlDP,900);}
                                             mylog("================================schreibe file")  ;
                                             writeFile(null, "/ProofingDatapoints/htmlputz.html" ,format+endehtml+htmlTable+htmlHelperFile+"</table></body>", function (error) { mylog('file written'); });
                                            // endehtml=endehtmlConst;
                                            // endehtmlDP=endehtmlDPConst;
                                             setState(dpPrefix + "ProofingDatapoints.MonsterSearch",false);  //setzt monstersearch zurück
                                             directSearch=false;
                                              setState(dpPrefix + "ProofingDatapoints.RunSuccessful",true);
                                          mit etwas glück kommt damit eine fehlermeldung mit der id !
                                            @liv-in-sky
                                            Hmm, irgendetwas stimmt nicht.
                                            Skript Grün, aber angezeigt wird Instanz ist deaktiviert. Das dauert so 2-5 Minuten dann geht die Meldung weg.
                                            javascript template
                                            11
                                            291
                                            31937
