    4. Test installer ioBroker Experimental-Edition
    • N
      NightWatcher @Stabilostick last edited by
      @Stabilostick schon probiert.
      Dann kommt z.b.
      $ ./iobroker add bring  --host SERVER(ioBrokerServer)
      ERROR: C:\ioBroker\ioBroke
      ERROR: rServer\node_modules\standard-as-callback\built\index.js:6
              throw e;
      Error: Cannot find module 'safe-buffer'
      Require stack:
      - C:\ioBroker\ioBrokerServer\node_modules\request\lib\helpers.js
      - C:\ioBroker\ioBrokerServer\node_modules\request\index.js
      - C:\ioBroker\ioBrokerServer\node_modules\iobroker.js-controller\lib\setup\setupInstall.js
      - C:\ioBroker\ioBrokerServer\node_modules\iobroker.js-controller\lib\setup.js
      - C:\ioBroker\ioBrokerServer\node_modules\iobroker.js-controller\iobroker.js
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:794:15)
      ERROR:     at F
      ERROR: unction.Module._load (internal/modules/cjs/loader.js:687:27)
          at Module.require (internal/modules/cjs/loader.js:849:19)
          at require (internal/modules/cjs/helpers.js:74:18)
          at Object.<anonymous> (C:\ioBroker\ioBrokerServer\node_modules\request\lib\helpers.js:5:14)
          at Module._compile (internal/modules/cjs/loader.js:956:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:973:10)
          at Module.load (internal/modules/cjs/loader.js:812:32)
          at Function.Module._load (internal/modules/cjs/loader.js:724:14)
          at Module.require (internal/modules/cjs/loader.js:849:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          'C:\\ioBroker\\ioBrokerServer\\node_modules\\request\\lib\\helpers.js',
          'C:\\ioBroker\\ioBrokerServer\\node_modules\\request\\index.js',
          'C:\\ioBroker\\ioBrokerServer\\node_modules\\iobroker.js-controller\\lib\\setup\\setupInstall.js',
      ERROR: rServer\\node_modules\\iobroker.js-controller\\lib\\setup.js',
          'C:\\ioBroker\\ioBrokerServer\\node_modules\\iobroker.js-controller\\iobroker.js'
      ERROR: process exited with code 1
      Stabilostick 1 Reply Last reply Reply Quote 0
      • Stabilostick
        Stabilostick @NightWatcher last edited by
        @NightWatcher sagte in ioBroker Experimental-Edition:
        safe-buffer
        Wenn Du die Kommandozeile der Instanz aufmachst und
        npm i safe-buffer
        ausführst und dann die Installation wiederholst, bringt das dich weiter?
        • N
          @Stabilostick sagte in ioBroker Experimental-Edition:
          npm i safe-buffer
          Leider nein.
          • N
            Läuft wieder alles.
            Bei mir lag es daran, dass eine andere node Instanz auf dem System lief.
            Die habe ich gelöscht, dann über das Startmenu die ioBroker Kommndozeile geöffnet und safe-buffer nachinstalliert. Dann musste ich komischer weise noch den js-controller per npm nachinstallieren.
            Beim Start von ioBroker danach haben sich alle Module sauber nachinstalliert.
            • N
              Doch nicht.... nachdem ich
              npm i safe-buffer
              ausführe, löscht er mir alle module. Deshalb musste ich auch den js-controller neu installieren. Es installierte sich aber leider nur die stable und ein upgrade auf die latest ist nicht möglich.
              Jetzt bin ich nach einigen Versuchen wieder am alten Stand, dass sich einige Adapter nicht installieren lassen, da safe-buffer nicht vorhanden ist.
                sigi234 Forum Testing Most Active @Stabilostick last edited by sigi234
                @Stabilostick
                Kann ich mir die Dienste irgendwie auf den Desktop legen und von dort bei Bedarf starten lassen?
                Habe jetzt 4 Installationen und 3 auf manuell gestellt.
                • Stabilostick
                  Stabilostick @sigi234 last edited by Stabilostick
                  @sigi234
                  Mach Dir zwei Links auf die iobroker.exe im daemon-Ordner der jeweiligen Instanz. Im Link dann den Befehlszeilenparameter start bzw. stop jeweils hinzufügen. Klappt es damit?
                    So?
                    "C:\Program Files\iobroker\Test\daemon\iobroker.exe" \stop
                    • Stabilostick
                      @sigi234
                      Ohne \
                        @sigi234
                        Ohne \
                        Ups, geht nicht.
                        • Stabilostick
                          @sigi234
                          Gibt es da in einem der Link-Property-Fenster so etwas wie „als Administrator“ ausführen“?
                            @sigi234
                            Ja, habe es als Admin ausgeführt, dann kommt einen Warnung , dann auf Ok und es funktioniert.
                            Wenn ich die Dienste öffne wird es erst bei einen erneuten Aufruf auch angezeigt.
                            Ich schalte mal UAC aus 😀
                            • Stabilostick
                              @sigi234
                              Geht ja nicht an, dass da jeder Wald- und Wiesenanwender ioBroker beendet. 😁
                              • Stabilostick
                                Dank @wolfpack57 konnten ich zwei Probleme mit dem 2.0.34.a Installer aufdecken.
                                1. Wenn mehr als 10MB Logs am Tag auf die Konsole geschrieben werden, beendet sich der Windows Service Wrapper. Der Dienst ist dann beendet aber ioBroker läuft trotzdem weiter. 👍
                                2. Bei einer Migration läuft die states-Datenbank auch wenn man den Port im Setup geändert hat immer auf dem Port, der im Quellsystem eingestellt war.
                                Ich werde das Setup für neue ioBroker Installationen entsprechend In Kürze anpassen.
                                  @Stabilostick
                                  Hallo, es gibt eine neue Node.js Version (v10.17.0), wie soll mann jetzt updaten? Sollte man überhaupt oder auf einen neue Installer Version von dir warten?
                                  • Stabilostick
                                    @sigi234
                                    Abwarten. Sobald js-controller 2.0.36+ im latest ist, baue ich einen neuen Installer für die Experimental-Edition. Dann ist auch wieder die 1.5.14 dran.
                                      Updateversuch mit schlechtem Ausgang
                                      Hatte Installer auf Englisch gestellt. Die Dialogboxen waren abwechselnd EN und DE. Aber das ist Kosmetik, kommt beim Bügeln.
                                      Das Log sieht erst mal nicht schlecht aus.
                                      2019-11-01 06:45:55.069 - info: host.DESKTOP-0UPK22M(ioBrMain3) iobroker.js-controller version 2.0.34 js-controller starting
                                      2019-11-01 06:45:55.073 - info: host.DESKTOP-0UPK22M(ioBrMain3) Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
                                      2019-11-01 06:45:55.074 - info: host.DESKTOP-0UPK22M(ioBrMain3) hostname: DESKTOP-0UPK22M(ioBrMain3), node: v12.12.0
                                      2019-11-01 06:45:55.083 - info: host.DESKTOP-0UPK22M(ioBrMain3) ip addresses: fe80::cfa:b599:f147:f33c 192.168.1.25
                                      2019-11-01 06:45:55.133 - info: host.DESKTOP-0UPK22M(ioBrMain3) connected to Objects and States
                                      2019-11-01 06:45:55.154 - info: host.DESKTOP-0UPK22M(ioBrMain3) 3 instances found
                                      Nach etwas hin und her beginnt die Adapterinstallation.
                                      Auch History wird erfolgreich installiert und subscribiert die Objects.
                                      In Zeile 5421 ist der damit fertig.
                                      Dann wird Terminal Adapter installiert. Nach etwas "gyp" Schluckauf meldet er in Zeile 5454 Vollzug
                                      Auch Tradfri wird installiert Aber dann beginnt das Chaos
                                      2019-11-01 06:57:05.379 - info: host.DESKTOP-0UPK22M(ioBrMain3) iobroker npm-install: Update "system.adapter.tradfri.0"
                                      2019-11-01 06:57:06.399 - info: host.DESKTOP-0UPK22M(ioBrMain3) iobroker npm-install: exit 0
                                      2019-11-01 06:57:06.417 - info: host.DESKTOP-0UPK22M(ioBrMain3) instance system.adapter.tradfri.0 started with pid 7832
                                      2019-11-01 06:57:06.898 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[0]: C:\Program Files\io
                                      2019-11-01 06:57:06.898 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[1]: broker\ioBrMain3\node_modules\iobroker.tradfri\build\main.js:710
                                      2019-11-01 06:57:06.898 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[1]: adapter.log.error("unhandled exception:" + getMessage(err));
                                      2019-11-01 06:57:06.898 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[1]: ^
                                      2019-11-01 06:57:06.898 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[1]: TypeError: Cannot read property 'log' of undefined
                                      2019-11-01 06:57:06.898 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[1]: at process.onUnhandledError (C:\Program Files\iobroker\ioBrMain3\node_modules\iobroker.tradfri\build\main.js:710:13)
                                      2019-11-01 06:57:06.898 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[1]: at process.emit (events.js:210:5)
                                      2019-11-01 06:57:06.899 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[1]: at process._fatalException (internal/process/execution.js:150:25)
                                      2019-11-01 06:57:06.899 - error: host.DESKTOP-0UPK22M(ioBrMain3) instance system.adapter.tradfri.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2019-11-01 06:57:06.899 - info: host.DESKTOP-0UPK22M(ioBrMain3) Restart adapter system.adapter.tradfri.0 because enabled
                                      2019-11-01 06:57:07.431 - warn: host.DESKTOP-0UPK22M(ioBrMain3) startInstance cannot find adapter "sonoff@2.0.2". Try to install it... 1 attempt
                                      2019-11-01 06:57:07.436 - info: host.DESKTOP-0UPK22M(ioBrMain3) iobroker install sonoff@2.0.2 using installedVersion
                                      2019-11-01 06:57:08.011 - error: host.DESKTOP-0UPK22M(ioBrMain3) iobroker npm-install: C:\Program Files\iobroker\ioBrM
                                      2019-11-01 06:57:08.012 - error: host.DESKTOP-0UPK22M(ioBrMain3) iobroker npm-install: ain3\node_modules\standard-as-callback\built\index.js:6
                                      throw e;
                                      Error: Cannot find module 'core-util-is'
                                      Require stack:
                                      - C:\Program Files\iobroker\ioBrMain3\node_modules\verror\lib\verror.js
                                      - C:\Program Files\iobroker\ioBrMain3\node_modules\jsprim\lib\jsprim.js
                                      - C:\Program Files\iobroker\ioBrMain3\node_modules\http-signature\lib\signer.js
                                      - C:\Program Files\iobroker\ioBrMain3\node_modules\http-signature\lib\index.js
                                      - C:\Program Files\iobroker\ioBrMain3\node_modules\request\req
                                      2019-11-01 06:57:08.012 - error: host.DESKTOP-0UPK22M(ioBrMain3) iobroker npm-install: uest.js
                                      - C:\Program Files\iobroker\ioBrMain3\node_modules\request\index.js
                                      - C:\Program Files\iobroker\ioBrMain3\node_modules\iobroker.js-controller\lib\setup\setupInstall.js
                                      - C:\Program Files\iobroker\ioBrMain3\node_modules\iobroker.js-controller\lib\setup.js
                                      - C:\Program Files\iobroker\ioBrMain3\node_modules\iobroker.js-controller\iobroker.js
                                      2019-11-01 06:57:08.013 - error: host.DESKTOP-0UPK22M(ioBrMain3) iobroker npm-install: ame (internal/modules/cjs/loader.js:794:15)
                                      at Function.Module._load (internal/modules/cjs/loader.js:687:27)
                                      at Object. (C:\Program Files\iobroker\ioBrMain3\node_modules\verror\lib\verror.js:9:19)
                                      2019-11-01 06:57:08.013 - error: host.DESKTOP-0UPK22M(ioBrMain3) iobroker npm-install: ules/cjs/loader.js:956:30)
                                      requireStack: [
                                      'C:\\Program Files\\iobrok
                                      2019-11-01 06:57:08.014 - error: host.DESKTOP-0UPK22M(ioBrMain3) iobroker npm-install: er\\ioBrMain3\\node_modules\\verror\\lib\\verror.js',
                                      'C:\\Program Files\\iobroker\\ioBrMain3\\node_modules\\jsprim\\lib\\jsprim.js',
                                      'C:\\Program Files\\iobroker\\ioBrMain3\\node_modules\\http-signature\\lib\\signer.js',
                                      'C:\\Program Files\\iobroker\\ioBrMain3\\node_modules\\http-signature\\lib\\index.js',
                                      2019-11-01 06:57:08.015 - error: host.DESKTOP-0UPK22M(ioBrMain3) iobroker npm-install: 'C:\\Program Files\\iobroker\\ioBrMain3\\node_modules\\request\\request.js',
                                      Das log endet ein paar Tausend Zeilen später
                                      2019-11-01 07:00:15.038 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[36]: de: 'MODULE_NOT_FOUND',
                                      2019-11-01 07:00:15.039 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[36]: requireStack: [
                                      2019-11-01 07:00:15.039 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[37]: 'C:\\Program Files\\iobroker\\ioBrMain3\\node_modules\\win
                                      2019-11-01 07:00:15.039 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[38]: ston\\node_modules\\readable-stream\\lib\\_stream_readable.
                                      2019-11-01 07:00:15.039 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[39]: js',
                                      2019-11-01 07:00:15.039 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[39]: 'C:\\Program Files\\iobroker\\ioBrMain3\\node_modul
                                      2019-11-01 07:00:15.039 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[40]: es\\winston\\node_modules\\readable-strea
                                      2019-11-01 07:00:15.039 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[41]: m\\readable.js',
                                      2019-11-01 07:00:15.039 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[41]: 'C:\\Program Files\\
                                      2019-11-01 07:00:15.039 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[42]: iobroker\\ioBrMain3\\node_modules\\winston\\lib\\winston\\logger.js',
                                      2019-11-01 07:00:15.040 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[42]: 'C:\\Pr
                                      2019-11-01 07:00:15.040 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[43]: ogram Files\\iobroker\\ioBrMain3\\node_modules\\winston\\lib\\winston\\create-logger.js',
                                      2019-11-01 07:00:15.040 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[43]: 'C:\\
                                      2019-11-01 07:00:15.040 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[44]: Program Files\\iobroker\\ioBrMain3\\node_modules\\winston\\lib\\winston.j
                                      2019-11-01 07:00:15.040 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[45]: s',
                                      2019-11-01 07:00:15.040 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[45]: 'C:\\Program Files\\iobroker\\ioBrMain3\\node_modules\\iobroker.js-controller\\lib\\log
                                      2019-11-01 07:00:15.040 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[46]: ger.js',
                                      2019-11-01 07:00:15.040 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[46]: 'C:\\Program Files\\iobroker\\ioBrMain3\\node_modules\\iobro
                                      2019-11-01 07:00:15.040 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[47]: ker.js-controller\\lib\\adapter.js',
                                      2019-11-01 07:00:15.040 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[47]: '
                                      2019-11-01 07:00:15.041 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[48]: C:\\Program Files\\iobroker\\ioBrMain3\\node_mo
                                      2019-11-01 07:00:15.041 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[49]: dules\\iobroker.nut\\lib\\utils.js',
                                      2019-11-01 07:00:15.041 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[49]: 'C:\\Program Files\\iobroker\\ioBrMain3\\
                                      2019-11-01 07:00:15.041 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[50]: node_modules\\iobroker.nut\\nut.js'
                                      2019-11-01 07:00:15.041 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[50]: ]
                                      2019-11-01 07:00:15.041 - error: host.DESKTOP-0UPK22M(ioBrMain3) Caught by controller[50]: }
                                      2019-11-01 07:00:15.041 - error: host.DESKTOP-0UPK22M(ioBrMain3) instance system.adapter.nut.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2019-11-01 07:00:15.041 - info: host.DESKTOP-0UPK22M(ioBrMain3) Restart adapter system.adapter.nut.1 because enabled
                                      Sieht für mich als Laien so aus, als käme da ein Parser ausser Tritt.
                                      Die Adapter gehen nicht in Betrieb, Indikatorpunkte bleiben rot.
                                      Nach einen Stop und Start aus der Konsole geht gar nichts mehr. Auch nicht nach einen Restart des Rechners.
                                      Bin vorerst wieder auf die alte Instanz gegangen. Ist ja mein Produktivsystem.
                                      • Stabilostick
                                        Stabilostick @klassisch last edited by Stabilostick
                                        @klassisch
                                        Die Adapter werde jeweils genau in der alten Version (sofern noch verfügbar) nachinstalliert. Gibt es für die Adapter ggf. eine neuere Version?
                                        Tradfri und nut-Adapter? Stoppe die. Was macht der Rest?
                                          klassisch Most Active @Stabilostick last edited by klassisch
                                          @Stabilostick Tradfri ist 2.2.0 , die neueste stable ist 2.4.3
                                          nut ist 1.1.3 und das ist auch die neueste stable.
                                          Stoppen kann ich nichts, weil diese neue ioBroker Version nicht mehr gestartet ist. Scheint sich aufgehängt zu haben. Kein Log im Browser angezeigt, kein Logfile angelegt und bei ioBroker stop gab es eine Fehlermeldung. Derzeit arbeite ich wieder mit der alten.
                                          Ich könnte höchstens den Tradfri Adapter modernisieren und dann den Installationsversuch wiederholen.
                                          • N
                                            NightWatcher @klassisch last edited by
                                            @klassisch genau wie bei mir. Bin auch auf die alte Version zurück und habe per npm aktualisiert. Mit der exe hier habe ich genau das Problem auch gehabt.
                                            K P 2 Replies Last reply Reply Quote 1
                                            js-controller nodejs windows windows installation
                                            3238
