    4. Test Adapter Nuki-extended v2.0.x
      miwe @Zefau last edited by miwe
      @Zefau Hier das Log:
      @Zefau said in [Aufruf] Nuki-extended Adapter:
      @miwe sagte in [Aufruf] Nuki-extended Adapter:
      Neither Bridge API or Web API initialized! Steht im Log. Leider ohne Funktion.
      Kannst du die Instanz mal auf debug stellen und mir das Log vom Start des Adapters bis inkl. des triggerns eines Events schicken?
      Hier das Log:
      nuki-extended.0 2019-10-22 19:52:12.903 debug (30466) system.adapter.admin.0: logging true
      nuki-extended.0 2019-10-22 19:52:06.332 debug (30466) system.adapter.admin.0: logging false
      nuki-extended.0 2019-10-22 19:51:48.610 debug (30466) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1571766708605,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":157176
      nuki-extended.0 2019-10-22 19:51:48.606 debug (30466) Web API: {"token":"ce09d58a5c4a84ffb7bbe58523c1cb77a979f4aca534ff368d9ba","url":"https://api.nuki.io"}
      nuki-extended.0 2019-10-22 19:51:48.606 debug (30466) Bridge API:undefined
      nuki-extended.0 2019-10-22 19:51:48.606 debug (30466) DEVICE:{"id":449894709,"hex":"1ad0d935","smartlockId":449894709,"name":"Wohnungstür","type":"Smartlock","path":"smartlocks.wohnungstür","bridge":null}
      nuki-extended.0 2019-10-22 19:51:48.606 warn (30466) Neither Bridge API or Web API initialized!
      nuki-extended.0 2019-10-22 19:51:48.605 info (30466) Trigger action -LOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
      nuki-extended.0 2019-10-22 19:51:48.605 debug (30466) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":2,"ack":false,"ts":1571766708603,"q":0,"from":"system.adapter.scenes.0","user":"system.user.admin","lc":157176670860
      admin.0 2019-10-22 19:51:36.253 info (789) successful connection to socket.io from ::ffff:192.168.2.45
      admin.0 2019-10-22 19:51:32.490 info (789) successful connection to socket.io from ::ffff:192.168.2.45
      nuki-extended.0 2019-10-22 19:51:23.368 debug (30466) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1571766683324,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":157176
      nuki-extended.0 2019-10-22 19:51:23.324 debug (30466) Updating lock smartlocks.wohnungstür with payload: {"smartlockId":44994709,"accountId":21458587,"authId":31686,"name":"Wohnungstür","favorite":false,"config":{"name":"Wohnungstür","latit
      nuki-extended.0 2019-10-22 19:51:23.318 debug (3066) Updating lock openers.haustür with payload: {"smartlockId":90449586,"accountId":21456587,"authId":343167,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,"
      nuki-extended.0 2019-10-22 19:51:23.317 debug (30466) getWebApi(): [{"smartlockId":90449586,"accountId":214582587,"type":2,"authId":341647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.888,"longitude":12.06853,
      nuki-extended.0 2019-10-22 19:51:23.076 info (30466) Polling Nuki Web API deactivated.
      nuki-extended.0 2019-10-22 19:51:23.031 info (30466) starting. Version 2.0.0-rc.7 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v8.16.0
      Hilft das?
      Accountid / Smartlockid sind verfälscht. Diesen keine Beachtung schenken.
      • Zefau
        Zefau @miwe last edited by
        @miwe jo, vielen Dank. Hast du eine Bridge eingetragen und aktiviert?
        M cash 4 Replies Last reply Reply Quote 0
          @Zefau Ja. habe ich. Bei dem anderen Adapter hat es problemlos funktioniert.
          • cash
            cash Most Active @Zefau last edited by
            @Zefau habe versucht die neue Version zu installieren. Ich vermute es hat nicht geklappt.
            Ich habe über Web-Admi Quelle beliebig und URL https://github.com/Zefau/ioBroker.nuki-extended ausgewählt.
            Danach legt er auch den _Actions State wieder an. Allerdings sieht er so aus:
            "states": {
                  "0": "NO_ACTION",
                  "1": "ACTIVE RTO",
                  "2": "DEACTIVATE RTO",
                  "3": "ELECTRIC STRIKE ACTUATION",
                  "4": "ACTIVATE CM",
                  "5": "DEACTIVATE CM"
            Wenn ich Github mir so ansehe hätte ich dort noch 6 und 7 erwartet?
            Schalten kann ich auch nicht mehr. Aber diesmal kommt im Log:
            nuki-extended.1	2019-10-23 18:20:26.076	warn	Neither Bridge API or Web API initialized!
            Habe jetzt aber auch noch nicht den Callback manuell gelöscht.
            • cash
              cash Most Active @Zefau last edited by cash
              @Zefau Die Installation muss doch geklappt haben. Kann nun nur nicht mehr bei Bridge Polling auswählen?
              Habe die Callback Datenpunkte manuell gelöscht und die ID manuell auf der Bridge gelöscht. Mit dem Neustart vom Adapter wird der Callback aber auch derzeit nicht angelegt. Es geht also quasi nichts mehr.
              Update: Callback hat nach ein paar weiteren Versuchen wieder geklappt. Somit konnte ich den Opener auch wieder wie gewünscht bedienen. Habe aber nur Ring to Open getestet....
              • Zefau
                Zefau @cash last edited by
                @cash sagte in [Aufruf] Nuki-extended Adapter:
                Habe ich entfernt. Das pollen hält die Nuki Bridge einfach nicht aus. Ist leider kein gutes Stück Hardware.
                  @Zefau Hi - hast Du möglicherweise einen Lösungsansatz zwischenzeitlich parat?
                  • Zefau
                    Probiere bitte nochmal die Github version.
                      @Zefau der Adapter startet nun nicht mehr. Log:
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:189:7)
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at <anonymous>
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:488:13)
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5587:17)
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at adapter.getStates (/opt/iobroker/node_modules/iobroker.nuki-extended/nuki-extended.js:81:4)
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at initNukiAPIs (/opt/iobroker/node_modules/iobroker.nuki-extended/nuki-extended.js:284:41)
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at Array.map (<anonymous>)
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at adapter.config.bridges.map (/opt/iobroker/node_modules/iobroker.nuki-extended/nuki-extended.js:289:68)
                      host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: ReferenceError: bridge_ident is not defined
                      • Zefau
                        @miwe sorry, v2.0.1 sollte es fixen.
                          Hi, ich habe es hinbekommen - nun stellt sich jedoch folgende Frage:
                          Warum reagiert das Schloss erst beim 2ten mal? Beim ersten mal positive Rückmeldungen im Log, jedoch ohne Reaktion, beim 2ten mal ausösen funktioniert es. Verbindung zum Schloss ist gegeben und sehr gut.
                          P.S. - Ich teste mal ob sich dieses Problem mit der 2.01 erledigt hat.
                          • Zefau
                            Kannst du das vollständige Log posten (ab Adapter-Start), sofern das noch auftritt?
                              @Zefau nuki-extended.0 2019-10-26 17:48:23.540 info (9733) Successfully triggered action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                              nuki-extended.0 2019-10-26 17:48:22.954 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1572104902950,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":1572104
                              nuki-extended.0 2019-10-26 17:48:22.951 debug (9733) Action applied on Bridge API.
                              nuki-extended.0 2019-10-26 17:48:22.951 info (9733) Trigger action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                              nuki-extended.0 2019-10-26 17:48:22.950 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":1,"ack":false,"ts":1572104902949,"q":0,"from":"system.adapter.scenes.0","user":"system.user.admin","lc":1572104902949
                              admin.0 2019-10-26 17:48:16.872 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
                              admin.0 2019-10-26 17:48:11.865 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
                              nuki-extended.0 2019-10-26 17:47:51.836 info (9733) Listening for Nuki events on port 51989.
                              nuki-extended.0 2019-10-26 17:47:51.830 debug (9733) Callback (with URL http://192.168.2.53:51989/nuki-api-bridge) already attached to Nuki Bridge with name Nuki .
                              nuki-extended.0 2019-10-26 17:47:51.829 debug (9733) Retrieved current callbacks from Nuki Bridge with name Nuki .
                              nuki-extended.0 2019-10-26 17:47:51.464 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1572104871421,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":1572104
                              nuki-extended.0 2019-10-26 17:47:51.454 debug (9733) Updating device smartlocks.wohnungstür with payload: {"deviceType":0,"nukiId":449894709,"name":"Wohnungstür","bridge":"1092735473","state":{"mode":2,"state":1,"batteryCritical":false,"timestam
                              nuki-extended.0 2019-10-26 17:47:51.454 debug (9733) Updating device openers.haustür with payload: {"deviceType":2,"nukiId":455049994,"name":"Haustür","bridge":"1092735473","state":{"mode":3,"state":1,"batteryCritical":false,"timestamp":"2019-10
                              nuki-extended.0 2019-10-26 17:47:51.453 debug (9733) getBridgeApi(): [{"deviceType":2,"nukiId":455049994,"name":"Haustür","lastKnownState":{"mode":3,"state":1,"stateName":"online","batteryCritical":false,"timestamp":"2019-10-26T14:36:44+00:00"},
                              nuki-extended.0 2019-10-26 17:47:51.421 debug (9733) Updating device smartlocks.wohnungstür with payload: {"smartlockId":449894709,"accountId":2145826587,"authId":3431686,"name":"Wohnungstür","favorite":false,"config":{"name":"Wohnungstür","lati
                              nuki-extended.0 2019-10-26 17:47:51.417 debug (9733) Updating device openers.haustür with payload: {"smartlockId":9044984586,"accountId":2145826587,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,
                              nuki-extended.0 2019-10-26 17:47:51.416 debug (9733) getWebApi(): [{"smartlockId":9044984586,"accountId":2145826587,"type":2,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,"longitude":12.064853,"
                              nuki-extended.0 2019-10-26 17:47:51.158 info (9733) Polling Nuki Web API deactivated.
                              nuki-extended.0 2019-10-26 17:47:51.115 info (9733) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v10.17.0
                              nuki-extended.0 2019-10-26 17:47:50.688 debug (9733) States connected to redis: 127.0.0.1:9000
                              nuki-extended.0 2019-10-26 17:47:50.643 debug (9733) statesDB connected
                              nuki-extended.0 2019-10-26 17:47:50.640 debug (9733) Objects connected to redis: 127.0.0.1:9001
                              nuki-extended.0 2019-10-26 17:47:50.639 debug (9733) Redis States: Use Redis connection: 127.0.0.1:9000
                              nuki-extended.0 2019-10-26 17:47:50.638 debug (9733) objectDB connected
                              nuki-extended.0 2019-10-26 17:47:50.610 debug (9733) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              host.iobroker 2019-10-26 17:47:50.169 info instance system.adapter.nuki-extended.0 started with pid 9733
                              • Zefau
                                @miwe das Log sieht gut aus. Ist in dem Log der Fehler enthalten, dass das Schloss erst beim zweiten Mal reagiert? Es erscheint ja richtigerweise nur eine Erfolgsmeldung.
                                In dem Log wird _ACTION 1x mit Wert "1" getriggert (und 2x auf "0" resettet).
                                  @Zefau Was sagt mir das? Ich kann damit nichts anfangen. Ich möchte das Schloss über die Szenen des IOBROKERS steuern. Was muss ich hier machen?
                                    nuki-extended.0 2019-10-26 17:52:36.348 debug (9733) system.adapter.admin.0: logging false
                                    nuki-extended.0 2019-10-26 17:52:18.545 debug (9733) system.adapter.admin.0: logging true
                                    nuki-extended.0 2019-10-26 17:52:14.647 debug (9733) system.adapter.admin.0: logging false
                                    admin.0 2019-10-26 17:51:21.169 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
                                    nuki-extended.0 2019-10-26 17:49:48.716 debug (9733) Updating device smartlocks.wohnungstür with payload: {"smartlockId":449894709,"accountId":2145826587,"authId":3431686,"name":"Wohnungstür","favorite":false,"config":{"name":"Wohnungstür","lati
                                    nuki-extended.0 2019-10-26 17:49:48.710 debug (9733) Updating device openers.haustür with payload: {"smartlockId":9044984586,"accountId":2145826587,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,
                                    nuki-extended.0 2019-10-26 17:49:48.710 debug (9733) getWebApi(): [{"smartlockId":9044984586,"accountId":2145826587,"type":2,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,"longitude":12.064853,"
                                    nuki-extended.0 2019-10-26 17:49:48.344 debug (9733) Updating device smartlocks.wohnungstür with payload: {"nukiId":449894709,"state":{"deviceType":0,"mode":2,"state":3,"batteryCritical":false,"timestamp":"2019-10-26T15:49:48+00:00","locked":3},
                                    nuki-extended.0 2019-10-26 17:49:48.343 debug (9733) Received payload via callback: {"nukiId":449894709,"state":{"deviceType":0,"mode":2,"state":3,"stateName":"unlocked","batteryCritical":false,"timestamp":"2019-10-26T15:49:48+00:00"}}
                                    nuki-extended.0 2019-10-26 17:49:24.417 info (9733) Successfully triggered action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                                    nuki-extended.0 2019-10-26 17:49:17.412 debug (9733) Action applied on Bridge API.
                                    nuki-extended.0 2019-10-26 17:49:17.412 info (9733) Trigger action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                                    nuki-extended.0 2019-10-26 17:49:17.412 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":1,"ack":false,"ts":1572104957410,"q":0,"from":"system.adapter.scenes.0","user":"system.user.admin","lc":1572104953664
                                    nuki-extended.0 2019-10-26 17:49:14.079 info (9733) Successfully triggered action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                                    nuki-extended.0 2019-10-26 17:49:13.666 debug (9733) Action applied on Bridge API.
                                    nuki-extended.0 2019-10-26 17:49:13.666 info (9733) Trigger action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                                    nuki-extended.0 2019-10-26 17:49:13.665 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":1,"ack":false,"ts":1572104953664,"q":0,"from":"system.adapter.scenes.0","user":"system.user.admin","lc":1572104953664
                                    admin.0 2019-10-26 17:49:08.829 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
                                    admin.0 2019-10-26 17:49:05.115 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
                                    Hier das komplette Log mit insgesamt 3 Versuchen . Es hat erst beim 3ten mal diesmals funktioniert.
                                    • Zefau
                                      Kannst du mal versuchen in den Objekten beim State _ACTION manuell einen Wert (z.B. LOCK oder UNLOCK) zu wählen?
                                        @Zefau Wie geht das? Ich bin da leider nicht so bewandert wie Du und habe keine Lust mir den Broker durch mein gefummel zu zerschiessen 🙂
                                        • Zefau
                                          @miwe einfach in der Navigation Objekte wählen und dort zum State navigieren: nuki-extended.0.smartlocks.wohnungstür._ACTION. Dann rechts wo NO_ACTION(0) steht einen anderen Wert auswählen.
                                            @Zefau
                                            Das kommt dabei heraus - Schloss hat nicht reagiert,
                                            nuki-extended.0 2019-10-26 18:02:28.341 debug (25155) system.adapter.admin.0: logging true
                                            nuki-extended.0 2019-10-26 18:02:23.694 info (25155) Successfully triggered action -LOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                                            nuki-extended.0 2019-10-26 18:02:23.006 debug (25155) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1572105743002,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":157210
                                            nuki-extended.0 2019-10-26 18:02:23.003 debug (25155) Action applied on Bridge API.
                                            nuki-extended.0 2019-10-26 18:02:23.003 info (25155) Trigger action -LOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                                            nuki-extended.0 2019-10-26 18:02:23.002 debug (25155) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":2,"ack":false,"ts":1572105743000,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1572105743000
                                            nuki-extended.0 2019-10-26 18:01:08.527 info (25155) Listening for Nuki events on port 51989.
                                            nuki-extended.0 2019-10-26 18:01:08.521 debug (25155) Callback (with URL http://192.168.2.53:51989/nuki-api-bridge) already attached to Nuki Bridge with name Nuki .
                                            nuki-extended.0 2019-10-26 18:01:08.520 debug (25155) Retrieved current callbacks from Nuki Bridge with name Nuki .
                                            nuki-extended.0 2019-10-26 18:01:08.312 debug (25155) Updating device smartlocks.wohnungstür with payload: {"smartlockId":449894709,"accountId":2145826587,"authId":3431686,"name":"Wohnungstür","favorite":false,"config":{"name":"Wohnungstür","lat
                                            nuki-extended.0 2019-10-26 18:01:08.308 debug (25155) Updating device openers.haustür with payload: {"smartlockId":9044984586,"accountId":2145826587,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858
                                            nuki-extended.0 2019-10-26 18:01:08.307 debug (25155) getWebApi(): [{"smartlockId":9044984586,"accountId":2145826587,"type":2,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,"longitude":12.064853,
                                            nuki-extended.0 2019-10-26 18:01:08.141 debug (25155) Updating device smartlocks.wohnungstür with payload: {"deviceType":0,"nukiId":449894709,"name":"Wohnungstür","bridge":"1092735473","state":{"mode":2,"state":3,"batteryCritical":false,"timesta
                                            nuki-extended.0 2019-10-26 18:01:08.140 debug (25155) Updating device openers.haustür with payload: {"deviceType":2,"nukiId":455049994,"name":"Haustür","bridge":"1092735473","state":{"mode":3,"state":1,"batteryCritical":false,"timestamp":"2019-1
                                            nuki-extended.0 2019-10-26 18:01:08.139 debug (25155) getBridgeApi(): [{"deviceType":2,"nukiId":455049994,"name":"Haustür","lastKnownState":{"mode":3,"state":1,"stateName":"online","batteryCritical":false,"timestamp":"2019-10-26T14:36:44+00:00"}
                                            nuki-extended.0 2019-10-26 18:01:07.885 info (25155) Polling Nuki Web API deactivated.
                                            nuki-extended.0 2019-10-26 18:01:07.853 debug (25155) States connected to redis: 127.0.0.1:9000
                                            nuki-extended.0 2019-10-26 18:01:07.842 info (25155) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v10.17.0
                                            nuki-extended.0 2019-10-26 18:01:07.763 debug (25155) statesDB connected
                                            nuki-extended.0 2019-10-26 18:01:07.760 debug (25155) Objects connected to redis: 127.0.0.1:9001
                                            nuki-extended.0 2019-10-26 18:01:07.759 debug (25155) Redis States: Use Redis connection: 127.0.0.1:9000
                                            nuki-extended.0 2019-10-26 18:01:07.758 debug (25155) objectDB connected
                                            nuki-extended.0 2019-10-26 18:01:07.732 debug (25155) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                            host.iobroker 2019-10-26 18:01:07.312 info instance system.adapter.nuki-extended.0 started with pid 25155
                                            31.7k
                                            79.8k
                                            nuki nuki-extended adapter
                                            65
                                            599
                                            110941
