    4. Test Adapter Nuki-extended v2.0.x
    • Zefau
      Zefau @miwe last edited by
      @miwe sagte in [Aufruf] Nuki-extended Adapter:
      hast Du möglicherweise einen Lösungsansatz zwischenzeitlich parat?
      Probiere bitte nochmal die Github version.
        miwe @Zefau last edited by
        @Zefau der Adapter startet nun nicht mehr. Log:
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:189:7)
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at <anonymous>
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:488:13)
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5587:17)
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at adapter.getStates (/opt/iobroker/node_modules/iobroker.nuki-extended/nuki-extended.js:81:4)
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at initNukiAPIs (/opt/iobroker/node_modules/iobroker.nuki-extended/nuki-extended.js:284:41)
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at Array.map (<anonymous>)
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: at adapter.config.bridges.map (/opt/iobroker/node_modules/iobroker.nuki-extended/nuki-extended.js:289:68)
        host.iobroker 2019-10-25 06:41:15.081 error Caught by controller[0]: ReferenceError: bridge_ident is not defined
        • Zefau
          @miwe sorry, v2.0.1 sollte es fixen.
            miwe @Zefau last edited by miwe
            @Zefau said in [Aufruf] Nuki-extended Adapter:
            Hi, ich habe es hinbekommen - nun stellt sich jedoch folgende Frage:
            Warum reagiert das Schloss erst beim 2ten mal? Beim ersten mal positive Rückmeldungen im Log, jedoch ohne Reaktion, beim 2ten mal ausösen funktioniert es. Verbindung zum Schloss ist gegeben und sehr gut.
            P.S. - Ich teste mal ob sich dieses Problem mit der 2.01 erledigt hat.
            • Zefau
              Kannst du das vollständige Log posten (ab Adapter-Start), sofern das noch auftritt?
                @Zefau nuki-extended.0 2019-10-26 17:48:23.540 info (9733) Successfully triggered action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                nuki-extended.0 2019-10-26 17:48:22.954 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1572104902950,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":1572104
                nuki-extended.0 2019-10-26 17:48:22.951 debug (9733) Action applied on Bridge API.
                nuki-extended.0 2019-10-26 17:48:22.951 info (9733) Trigger action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                nuki-extended.0 2019-10-26 17:48:22.950 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":1,"ack":false,"ts":1572104902949,"q":0,"from":"system.adapter.scenes.0","user":"system.user.admin","lc":1572104902949
                admin.0 2019-10-26 17:48:16.872 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
                admin.0 2019-10-26 17:48:11.865 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
                nuki-extended.0 2019-10-26 17:47:51.836 info (9733) Listening for Nuki events on port 51989.
                nuki-extended.0 2019-10-26 17:47:51.830 debug (9733) Callback (with URL http://192.168.2.53:51989/nuki-api-bridge) already attached to Nuki Bridge with name Nuki .
                nuki-extended.0 2019-10-26 17:47:51.829 debug (9733) Retrieved current callbacks from Nuki Bridge with name Nuki .
                nuki-extended.0 2019-10-26 17:47:51.464 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1572104871421,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":1572104
                nuki-extended.0 2019-10-26 17:47:51.454 debug (9733) Updating device smartlocks.wohnungstür with payload: {"deviceType":0,"nukiId":449894709,"name":"Wohnungstür","bridge":"1092735473","state":{"mode":2,"state":1,"batteryCritical":false,"timestam
                nuki-extended.0 2019-10-26 17:47:51.454 debug (9733) Updating device openers.haustür with payload: {"deviceType":2,"nukiId":455049994,"name":"Haustür","bridge":"1092735473","state":{"mode":3,"state":1,"batteryCritical":false,"timestamp":"2019-10
                nuki-extended.0 2019-10-26 17:47:51.453 debug (9733) getBridgeApi(): [{"deviceType":2,"nukiId":455049994,"name":"Haustür","lastKnownState":{"mode":3,"state":1,"stateName":"online","batteryCritical":false,"timestamp":"2019-10-26T14:36:44+00:00"},
                nuki-extended.0 2019-10-26 17:47:51.421 debug (9733) Updating device smartlocks.wohnungstür with payload: {"smartlockId":449894709,"accountId":2145826587,"authId":3431686,"name":"Wohnungstür","favorite":false,"config":{"name":"Wohnungstür","lati
                nuki-extended.0 2019-10-26 17:47:51.417 debug (9733) Updating device openers.haustür with payload: {"smartlockId":9044984586,"accountId":2145826587,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,
                nuki-extended.0 2019-10-26 17:47:51.416 debug (9733) getWebApi(): [{"smartlockId":9044984586,"accountId":2145826587,"type":2,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,"longitude":12.064853,"
                nuki-extended.0 2019-10-26 17:47:51.158 info (9733) Polling Nuki Web API deactivated.
                nuki-extended.0 2019-10-26 17:47:51.115 info (9733) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v10.17.0
                nuki-extended.0 2019-10-26 17:47:50.688 debug (9733) States connected to redis: 127.0.0.1:9000
                nuki-extended.0 2019-10-26 17:47:50.643 debug (9733) statesDB connected
                nuki-extended.0 2019-10-26 17:47:50.640 debug (9733) Objects connected to redis: 127.0.0.1:9001
                nuki-extended.0 2019-10-26 17:47:50.639 debug (9733) Redis States: Use Redis connection: 127.0.0.1:9000
                nuki-extended.0 2019-10-26 17:47:50.638 debug (9733) objectDB connected
                nuki-extended.0 2019-10-26 17:47:50.610 debug (9733) Redis Objects: Use Redis connection: 127.0.0.1:9001
                host.iobroker 2019-10-26 17:47:50.169 info instance system.adapter.nuki-extended.0 started with pid 9733
                • Zefau
                  @miwe das Log sieht gut aus. Ist in dem Log der Fehler enthalten, dass das Schloss erst beim zweiten Mal reagiert? Es erscheint ja richtigerweise nur eine Erfolgsmeldung.
                  In dem Log wird _ACTION 1x mit Wert "1" getriggert (und 2x auf "0" resettet).
                    @Zefau Was sagt mir das? Ich kann damit nichts anfangen. Ich möchte das Schloss über die Szenen des IOBROKERS steuern. Was muss ich hier machen?
                      nuki-extended.0 2019-10-26 17:52:36.348 debug (9733) system.adapter.admin.0: logging false
                      nuki-extended.0 2019-10-26 17:52:18.545 debug (9733) system.adapter.admin.0: logging true
                      nuki-extended.0 2019-10-26 17:52:14.647 debug (9733) system.adapter.admin.0: logging false
                      admin.0 2019-10-26 17:51:21.169 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
                      nuki-extended.0 2019-10-26 17:49:48.716 debug (9733) Updating device smartlocks.wohnungstür with payload: {"smartlockId":449894709,"accountId":2145826587,"authId":3431686,"name":"Wohnungstür","favorite":false,"config":{"name":"Wohnungstür","lati
                      nuki-extended.0 2019-10-26 17:49:48.710 debug (9733) Updating device openers.haustür with payload: {"smartlockId":9044984586,"accountId":2145826587,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,
                      nuki-extended.0 2019-10-26 17:49:48.710 debug (9733) getWebApi(): [{"smartlockId":9044984586,"accountId":2145826587,"type":2,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,"longitude":12.064853,"
                      nuki-extended.0 2019-10-26 17:49:48.344 debug (9733) Updating device smartlocks.wohnungstür with payload: {"nukiId":449894709,"state":{"deviceType":0,"mode":2,"state":3,"batteryCritical":false,"timestamp":"2019-10-26T15:49:48+00:00","locked":3},
                      nuki-extended.0 2019-10-26 17:49:48.343 debug (9733) Received payload via callback: {"nukiId":449894709,"state":{"deviceType":0,"mode":2,"state":3,"stateName":"unlocked","batteryCritical":false,"timestamp":"2019-10-26T15:49:48+00:00"}}
                      nuki-extended.0 2019-10-26 17:49:24.417 info (9733) Successfully triggered action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                      nuki-extended.0 2019-10-26 17:49:17.412 debug (9733) Action applied on Bridge API.
                      nuki-extended.0 2019-10-26 17:49:17.412 info (9733) Trigger action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                      nuki-extended.0 2019-10-26 17:49:17.412 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":1,"ack":false,"ts":1572104957410,"q":0,"from":"system.adapter.scenes.0","user":"system.user.admin","lc":1572104953664
                      nuki-extended.0 2019-10-26 17:49:14.079 info (9733) Successfully triggered action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                      nuki-extended.0 2019-10-26 17:49:13.666 debug (9733) Action applied on Bridge API.
                      nuki-extended.0 2019-10-26 17:49:13.666 info (9733) Trigger action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                      nuki-extended.0 2019-10-26 17:49:13.665 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":1,"ack":false,"ts":1572104953664,"q":0,"from":"system.adapter.scenes.0","user":"system.user.admin","lc":1572104953664
                      admin.0 2019-10-26 17:49:08.829 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
                      admin.0 2019-10-26 17:49:05.115 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
                      Hier das komplette Log mit insgesamt 3 Versuchen . Es hat erst beim 3ten mal diesmals funktioniert.
                      • Zefau
                        Kannst du mal versuchen in den Objekten beim State _ACTION manuell einen Wert (z.B. LOCK oder UNLOCK) zu wählen?
                          @Zefau Wie geht das? Ich bin da leider nicht so bewandert wie Du und habe keine Lust mir den Broker durch mein gefummel zu zerschiessen 🙂
                          • Zefau
                            @miwe einfach in der Navigation Objekte wählen und dort zum State navigieren: nuki-extended.0.smartlocks.wohnungstür._ACTION. Dann rechts wo NO_ACTION(0) steht einen anderen Wert auswählen.
                              @Zefau
                              Das kommt dabei heraus - Schloss hat nicht reagiert,
                              nuki-extended.0 2019-10-26 18:02:28.341 debug (25155) system.adapter.admin.0: logging true
                              nuki-extended.0 2019-10-26 18:02:23.694 info (25155) Successfully triggered action -LOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                              nuki-extended.0 2019-10-26 18:02:23.006 debug (25155) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1572105743002,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":157210
                              nuki-extended.0 2019-10-26 18:02:23.003 debug (25155) Action applied on Bridge API.
                              nuki-extended.0 2019-10-26 18:02:23.003 info (25155) Trigger action -LOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                              nuki-extended.0 2019-10-26 18:02:23.002 debug (25155) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":2,"ack":false,"ts":1572105743000,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1572105743000
                              nuki-extended.0 2019-10-26 18:01:08.527 info (25155) Listening for Nuki events on port 51989.
                              nuki-extended.0 2019-10-26 18:01:08.521 debug (25155) Callback (with URL http://192.168.2.53:51989/nuki-api-bridge) already attached to Nuki Bridge with name Nuki .
                              nuki-extended.0 2019-10-26 18:01:08.520 debug (25155) Retrieved current callbacks from Nuki Bridge with name Nuki .
                              nuki-extended.0 2019-10-26 18:01:08.312 debug (25155) Updating device smartlocks.wohnungstür with payload: {"smartlockId":449894709,"accountId":2145826587,"authId":3431686,"name":"Wohnungstür","favorite":false,"config":{"name":"Wohnungstür","lat
                              nuki-extended.0 2019-10-26 18:01:08.308 debug (25155) Updating device openers.haustür with payload: {"smartlockId":9044984586,"accountId":2145826587,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858
                              nuki-extended.0 2019-10-26 18:01:08.307 debug (25155) getWebApi(): [{"smartlockId":9044984586,"accountId":2145826587,"type":2,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,"longitude":12.064853,
                              nuki-extended.0 2019-10-26 18:01:08.141 debug (25155) Updating device smartlocks.wohnungstür with payload: {"deviceType":0,"nukiId":449894709,"name":"Wohnungstür","bridge":"1092735473","state":{"mode":2,"state":3,"batteryCritical":false,"timesta
                              nuki-extended.0 2019-10-26 18:01:08.140 debug (25155) Updating device openers.haustür with payload: {"deviceType":2,"nukiId":455049994,"name":"Haustür","bridge":"1092735473","state":{"mode":3,"state":1,"batteryCritical":false,"timestamp":"2019-1
                              nuki-extended.0 2019-10-26 18:01:08.139 debug (25155) getBridgeApi(): [{"deviceType":2,"nukiId":455049994,"name":"Haustür","lastKnownState":{"mode":3,"state":1,"stateName":"online","batteryCritical":false,"timestamp":"2019-10-26T14:36:44+00:00"}
                              nuki-extended.0 2019-10-26 18:01:07.885 info (25155) Polling Nuki Web API deactivated.
                              nuki-extended.0 2019-10-26 18:01:07.853 debug (25155) States connected to redis: 127.0.0.1:9000
                              nuki-extended.0 2019-10-26 18:01:07.842 info (25155) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v10.17.0
                              nuki-extended.0 2019-10-26 18:01:07.763 debug (25155) statesDB connected
                              nuki-extended.0 2019-10-26 18:01:07.760 debug (25155) Objects connected to redis: 127.0.0.1:9001
                              nuki-extended.0 2019-10-26 18:01:07.759 debug (25155) Redis States: Use Redis connection: 127.0.0.1:9000
                              nuki-extended.0 2019-10-26 18:01:07.758 debug (25155) objectDB connected
                              nuki-extended.0 2019-10-26 18:01:07.732 debug (25155) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              host.iobroker 2019-10-26 18:01:07.312 info instance system.adapter.nuki-extended.0 started with pid 25155
                              • Zefau
                                @miwe Und ging es beim ersten Mal?
                                  @Zefau nein. Ich habe aber auch nur einmal probiert.
                                    @Zefau Jetzt eben nochmal probiert - geht. Seltsam.
                                      miwe @miwe last edited by
                                      @miwe Bis jetzt funktioniert es plötzlich einwandfrei. Wunderheilung? Keine Ahnung. Ich beobachte mal weiter. Besten Dan für deine Mühen und gute Arbeit hier.
                                      • Zefau
                                        Zefau @cash last edited by
                                        @cash sagte in [Aufruf] Nuki-extended Adapter:
                                        Ich hoffe echt das Nuki Firmware der Bridge deutlich verbessern kann.
                                        Wie läuft das Update bisher bei dir?
                                        Haste schon gesehen, dass es eine neue Beta Firmware für die Bridge gibt (https://developer.nuki.io/t/early-access-bridge-beta-2-4-0/3331?u=zefau) ?
                                        cash Grizzelbee 3 Replies Last reply Reply Quote 0
                                        • cash
                                          cash Most Active @Zefau last edited by
                                          @Zefau Ich bin noch bei der 2.0.1 weil die eigentlich relativ sauber läuft. Nach dem Update läuft es ja meist erstmal nicht 😞 deshalb bin ich etwas zurückhaltend.
                                          Beta hatte ich mitbekommen und auch das erste Kommtentar von einem User der erstmal zufrieden war. Das würde ich aber bei mir nicht riskieren. Das wäre mir zu heiß.
                                          Insgesamt bin ich mit Nuki zwar zufrieden aber es würde halt soviel mehr gehen wenn die StatusUpdates zuverlässiger kämen.
                                          Ich habe bei mir das Problem, dass meine Garage direkt neben der Haustür ist und sobald ich aussteige, wird die Wohnungstür geöffnet, nur bleibt die halt nicht offen. Eh ich dann mittels Ring to Open im Haus bin ist es viel zu spät. An sich sehr unlogisch programmiert. Ich wollte das per Adapter lösen. Einfach 3 Sekunden nach dem der Status der Haustür wieder Online ist soll er die Tür aufmachen (natürlich mit vielen Zusatzbedingungen wie Geofencing usw.)
                                          Die Testpush kam auch eigentlich immer relativ passend nur das öffnen klappte bisher einmal. Und selbst dort stand im Log das es über die Bridge nicht gegangen ist und stattdessen die Webapi genommen wurde. Insgesamt für mich zu unzuverlässig als das ich das produktiv nutzen würden.
                                          Die Probeschaltungen funktionieren zwar aber ich glaube wenn ich zu Nah nach einer Statusänderungen schalte ist die Bridge überfordert. Vielleicht wird das ja mit der Beta besser. Anderseits wenn Nuki nur die Hälfte der Requests umsetzt wäre das Produkt ohne eigene Scripte schon nahe zu perfekt....
                                          • cash
                                            @Zefau Habe jetzt das Update gemacht. Wie befürchtet funktioniert jetzt garnichts mehr.
                                            Das Log ist komplett leer. Selbst beim Start stand in der Vorversion etwas von Polling Web-Api alle 60 Sekunden. Jetzt sehe ich nur das der Adapter gestartet ist. Er aktualisiert aber weder wenn ich versuche über den Adapter etwas zu machen noch wenn ich per App etwas ändere. Das heißt sowohl Bridge-Api als auch Web-Api liefern nichts? Sollte dann nicht warnings im log kommen?
                                            Ich deaktiviere den Adapter jetzt erstmal wieder und werde heute Abend mal wieder den callback manuell löschen und mal gucken ob es danach wieder geht.
                                            31.7k
                                            79.8k
                                            nuki nuki-extended adapter
                                            65
                                            599
                                            110887
