    4. Test js-controller v2.0.x (GitHub)
      Jan1 @BBTown last edited by
      @BBTown
      Wird auch nicht übernommen.
      • BBTown
        BBTown @Jan1 last edited by
        @Jan1 und im RAW?
          @BBTown
          Sorry, geht auch nicht
            sigi234 Forum Testing Most Active @Jan1 last edited by sigi234
            @Jan1 sagte in [Aufruf] js-controller 2.0 Beta Test:
            @Yetiberg
            stimmt, wird nicht übernommen
            Ja, auch ein hinzufügen von Objekte geht nicht.
            history.0	2019-10-27 12:22:53.481	warn	(19312) Objects Received unexpected pmessage: cfg.o.0_userdata.0
            iogo.0	2019-10-27 12:22:53.467	warn	(18416) Objects Received unexpected pmessage: cfg.o.0_userdata.0
            javascript.0	2019-10-27 12:22:53.467	warn	(5720) Objects Received unexpected pmessage: cfg.o.0_userdata.0
            admin.0	2019-10-27 12:22:53.467	warn	(13292) Objects Received unexpected pmessage: cfg.o.0_userdata.0
            iogo.0	2019-10-27 12:21:38.595	warn	(18416) Objects Received unexpected pmessage: cfg.o.0_userdata.0
            history.0	2019-10-27 12:21:38.585	warn	(19312) Objects Received unexpected pmessage: cfg.o.0_userdata.0
            javascript.0	2019-10-27 12:21:38.594	warn	(5720) Objects Received unexpected pmessage: cfg.o.0_userdata.0
            admin.0	2019-10-27 12:21:38.595	warn	(13292) Objects Received unexpected pmessage: cfg.o.0_userdata.0
            iogo.0	2019-10-27 12:20:38.283	warn	(18416) Objects Received unexpected pmessage: cfg.o.0_userdata.0.example_state.Bilder
            history.0	2019-10-27 12:20:38.283	warn	(19312) Objects Received unexpected pmessage: cfg.o.0_userdata.0.example_state.Bilder
            javascript.0	2019-10-27 12:20:38.282	warn	(5720) Objects Received unexpected pmessage: cfg.o.0_userdata.0.example_state.Bilder
            admin.0	2019-10-27 12:20:38.283	warn	(13292) Objects Received unexpected pmessage: cfg.o.0_userdata.0.example_state.Bilder
            BBTown apollon77 2 Replies Last reply Reply Quote 0
            • BBTown
              BBTown @sigi234 last edited by BBTown
              @sigi234
              Du hast wahr ... weder neue Kanäle noch Datenpunkte können unterhalb von "0_userdata.0" hinzugefügt werden, man landet immer in den Einstellungen von "0_userdata.0" selbst.
              Nachtrag
              Bei mir handelt es sich um die Version die bereits "meta.user" hat
              • SBorg
                SBorg Forum Testing Most Active @apollon77 last edited by
                @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                @Jan1 Ob nodeRed im Tab öffnen ggf auch mit .37 wieder tut?
                Funktionierte bei mir nach Umstellung auf Reverse Proxy nicht mehr. Mit der .37 geht es jetzt wieder 😎
                  sigi234 Forum Testing Most Active @BBTown last edited by
                  @BBTown sagte in [Aufruf] js-controller 2.0 Beta Test:
                  @sigi234
                  Nachtrag
                  So wo und was jetzt gehört umgestellt?
                    Jan1 @sigi234 last edited by
                    @sigi234
                    Vergiss es, da kannst machen was willst, es wird nichts übernommen.
                    Wir warten auf @apollon77 bis da ne neue Version raus kommt. Egal was man da ändert oder löscht, es springt immer wieder zurück.
                      apollon77 @sigi234 last edited by
                      @sigi234 MIST! Wird gefixt
                        GitHub hat die .38 ... damit sollte alles wieder tun mit 0_userdata.0 ... my fault 😞
                        BBTown SBorg 2 Replies Last reply Reply Quote 0
                        • BBTown
                          BBTown @apollon77 last edited by
                          is ja nicht tragisch, hat j a nix kaputt gemacht, eine neue Idee kommt damit ja nur einen halben Tag später 🙂
                          • SBorg
                            Kann, oder sollte ich, dann auch Objekte mittels createstate anlegen können? .38 ist installiert, geht aber nicht...
                            apollon77 paul53 2 Replies Last reply Reply Quote 0
                              apollon77 @SBorg last edited by
                              @SBorg Welchen Fehler bekommst Du?
                                paul53 @SBorg last edited by paul53
                                @SBorg sagte:
                                createState() erzeugt Datenpunkte nur unter javascript.N (N = Instanz-Nr.).
                                SBorg 1 Reply Last reply Reply Quote 1
                                • SBorg
                                  SBorg Forum Testing Most Active @paul53 last edited by SBorg
                                  @paul53 Deswegen ja meine Frage 🙂
                                  Ich kenne die Internas zu wenig, um das abschätzen zu können, aber wenn es doch eigene "Userstates" gibt, sollte man diese nicht auch per JS anlegen können? Aber das sieht dann IMHO wohl eher nach einer Funktionalität des Skript-Adapters aus, als denn des Controllers?
                                  *EDIT*
                                  https://github.com/ioBroker/ioBroker.javascript/issues/429
                                  SBorg2014 created this issue in ioBroker/ioBroker.javascript
                                  closed createState in 0_userdata.0 ermöglichen #429
                                    @SBorg sagte in [Aufruf] js-controller 2.0 Beta Test:
                                    Korrekt.
                                      sigi234 Forum Testing Most Active @apollon77 last edited by
                                      @apollon77
                                      Hallo, soll das so aussehen?
                                      Wo und wie bringe ich dann die Bilder rein, bzw. wo ist der Ordner im Verzeichnis? Oder verstehe ich was nicht.
                                        @sigi234 du meinst wegen dem „0_userdata.0“ ist der Platz für Bilder und Dateien?
                                        Dann wird der Vis Datei manager in einer nächsten Version uploads da hin erlauben. Jetzt geht schon per cli
                                        iobroker file write <Datei> 0_userdata.0/<Pfad>
                                        Dateien werden im Admin nicht angezeigt.
                                          sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
                                          Jetzt verstehe ich es. 😀
                                          Ok, wie kann ich dann folgende Struktur erstellen mit:
                                          0_userdata.0
                                          Meine Daten
                                          -Bilder
                                          -Icons
                                          -Objekte
                                          Ein zufügen dieser mit + erstellt mir immer ein Tochterobjekt
                                          Erledigt.
                                          Mich wundert aber auch das der Admin.0 so benannt ist : user files and images for background image
                                            @sigi234 bei den normalen Objekten im Admin brauchst du nichts für files ... machida nur die States.
                                            Files existieren quasi parallel dazu. Nur das Basis Verzeichnis ist gleich.
                                            js-controller
                                            48
                                            1047
                                            268332
