    2. English
    3. Scripting / Logic
    5. ASTRO function. Does not work again
      ap2017 @iomountain last edited by
      @iomountain Day I switched to US the ASTRO stopped working (no ASTRO string in LOG file). I restarted computer after I made a change. I will try your ASTRO script
      Here is my script:
      // Living Room Light
      schedule({astro: "goldenHour", shift: 0}, function () {
      console.log('astro_on');
      setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
      schedule("0 18 * * *", function () {
      console.log('schedule_on');
      schedule("30 23 * * *", function () {
      console.log('schedule_off');
      setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
        @iomountain Here is the log from running your script Astro Time for Today, if it helps. So, script runs but shows error code at the end of each run.
        2019-10-19 18:48:42.414 - info: mysensors.0 (18452) STARTED
        2019-10-19 18:48:42.415 - info: mysensors.0 (18452) STARTED
        2019-10-19 18:48:55.725 - info: javascript.0 (18920) Stop script script.js.ASTRO
        2019-10-19 18:48:55.770 - info: javascript.0 (18920) Start javascript script.js.ASTRO
        2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: =====================
        2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: Astro time for today
        2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: (0) nightEnd (End of night)........................: 5:36:06 AM
        2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (1) nauticalDawn (naut. Dämmerung Morgens)...........: 6:08:18 AM
        2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (2) dawn (Dämmerung Morgens).........................: 6:40:39 AM
        2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (3) sunrise (Sonnenaufgang)..........................: 7:08:50 AM
        2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (4) sunriseEnd (Ende des Sonnenaufgangs).............: 7:11:46 AM
        2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (5) goldenHourEnd (Ende der Golden Hour VM)..........: 7:46:57 AM
        2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (6) solarNoon (Mittag)...............................: 12:37:25 PM
        2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (7) goldenHour (Start der Golden Hour NM)............: 5:27:52 PM
        2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (8) sunsetStart (Start des Sonnenuntergangs).........: 6:03:04 PM
        2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (9) sunset (Sonnenuntergang).........................: 6:06:00 PM
        2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (10) dusk (Dämmerung Abends)..........................: 6:34:11 PM
        2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (11) nauticalDusk (naut. Dämmerung Abends)............: 7:06:31 PM
        2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (12) night (Start of night)..........................: 7:38:44 PM
        2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (13) nadir (midnight)..............................: 12:37:25 AM
        2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: =====================
        2019-10-19 18:48:55.777 - info: javascript.0 (18920) script.js.ASTRO: Night starts tomorrow at 7:37:17 PM
        2019-10-19 18:48:55.777 - error: javascript.0 (18920) script.js.ASTRO: script.js.ASTRO:41
        2019-10-19 18:48:55.777 - error: javascript.0 (18920) console.log(obj.id);
        2019-10-19 18:48:55.778 - error: javascript.0 (18920) ^
        2019-10-19 18:48:55.778 - error: javascript.0 (18920) ReferenceError: obj is not defined
        2019-10-19 18:48:55.778 - error: javascript.0 (18920) at script.js.ASTRO:41:13
        2019-10-19 18:48:55.778 - error: javascript.0 (18920) at Script.runInContext (vm.js:133:20)
        iomountain 1 Reply Last reply Reply Quote 0
        • iomountain
          iomountain @ap2017 last edited by
          @ap2017 sagte in ASTRO function:
          shows that the AstroFunktion works
          What about the log of your script?
            @iomountain Here is my complete log from yesterday. Notice that in 18:58 I added your script with ASTRO Time for Day. Thank you for your help!
            10-20-19 Log.txt
            • iomountain
              something going wrong with ASTRO, still testing.
              • iomountain
                Could you please test this for 24 hours:
                 <block type="comment" id="dZ/@oL!i0(@/:!$Ikw{J" x="13" y="13">
                   <field name="COMMENT">Test Astro</field>
                     <block type="astro" id="sxZ*u!O2O8lf$a?qgNf%">
                       <field name="TYPE">sunrise</field>
                       <field name="OFFSET">0</field>
                         <block type="debug" id="f0h|hnMOj,t0a9F4R/*u">
                           <field name="Severity">error</field>
                           <value name="TEXT">
                             <shadow type="text" id="t~{SzkO:N+m/c:_aXvF_">
                               <field name="TEXT">Sonnenaufgang</field>
                             <block type="debug" id=";Kc+}!GR24eQ4F1zvsqz">
                               <value name="TEXT">
                                 <shadow type="text" id="d7@Q.7Mu+wBczv=iaKT?">
                                 <block type="time_get" id="0}ve}|zeLByf%Wn1)Z~N">
                                   <mutation format="true" language="false"></mutation>
                                   <field name="OPTION">custom</field>
                                   <field name="FORMAT">JJJJ-MM-TT SS:mm:ss.sss</field>
                         <block type="astro" id="e%0Te`wUBXm0Z(Tm~(uK">
                           <field name="TYPE">sunriseEnd</field>
                             <block type="debug" id="~yMY;Z`RDhY|PgL8aLYT">
                               <value name="TEXT">
                                 <shadow type="text" id="{(iRk-Wgsniu)/OWNuec">
                                   <field name="TEXT">Sonnenaufgang ende</field>
                                 <block type="debug" id="q|N1he7_#J*z!t:Lxbq4">
                                   <value name="TEXT">
                                     <block type="time_get" id="tJ*UF;cM+aI^pYR^Qa;1">
                             <block type="astro" id="7-p8CPh^EAGz7TZ[HE=f">
                               <field name="TYPE">goldenHourEnd</field>
                                 <block type="debug" id="#jT`iz!Nlmm:r|h0-a;{">
                                   <value name="TEXT">
                                     <shadow type="text" id="sF]?KilHL=/lQ@|f$!#B">
                                       <field name="TEXT">Golden hour Ende</field>
                                     <block type="debug" id="?jcK[-lRY6m67kH94cJ8">
                                       <value name="TEXT">
                                         <block type="time_get" id=":6c/3{e5w_Qr@--(F2,$">
                                 <block type="astro" id="tK}:wS(k,Xmf4I2Ms^,]">
                                   <field name="TYPE">solarNoon</field>
                                     <block type="debug" id="sYbNw@$;Db5D:)VF)*b}">
                                       <value name="TEXT">
                                         <shadow type="text" id="h9Pt!n;uDsK%[C8H0T:-">
                                           <field name="TEXT">Sonnenmittag</field>
                                         <block type="debug" id="0z@Vv^UhX8S(2Uk.L}AX">
                                           <value name="TEXT">
                                             <block type="time_get" id="63mXGB7G3:L?++1KLilu">
                                     <block type="astro" id="2X-czA2y[$Ug?5[Q_aUV">
                                       <field name="TYPE">goldenHour</field>
                                         <block type="debug" id="VvR2BxdbZn.+TuU)7yLe">
                                           <value name="TEXT">
                                             <shadow type="text" id="#r/L5Io)*?Qz!Co)U:Jc">
                                               <field name="TEXT">Golden hour</field>
                                             <block type="debug" id="vO^xDs|z,PXJo=OKQ=bY">
                                               <value name="TEXT">
                                                 <block type="time_get" id="8b(z1|U:aT{s/-zQOG-O">
                                         <block type="astro" id="dLczmmMSoFlkvb*/H*SF">
                                           <field name="TYPE">sunsetStart</field>
                                             <block type="debug" id="S%o3:;|MkGT:WNoq-5I/">
                                               <value name="TEXT">
                                                 <shadow type="text" id="oZW7=ox`@zO:d)Qo`jM#">
                                                   <field name="TEXT">Sonnenuntergang Anfang</field>
                                                 <block type="debug" id="88*2`mY-$F4-h46R$bsh">
                                                   <value name="TEXT">
                                                     <block type="time_get" id="=yV74{gTTEshyETA[YT+">
                                             <block type="astro" id="`E^X3.`tEYD#t?w3p[Y6">
                                               <field name="TYPE">sunset</field>
                                                 <block type="debug" id="3y?c.oF8m3]qo`y^Sk2Y">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="_^a1$PSDO%=0T$ouPs,z">
                                                       <field name="TEXT">Sonnenuntergang</field>
                                                     <block type="debug" id="B{Xk(=sas9lxfcPeH~8l">
                                                       <value name="TEXT">
                                                         <block type="time_get" id="?;boy8-PvsRtK^R`i(d!">
                                                 <block type="astro" id="yk2LFSH:M4]t,=g+r0Zr">
                                                   <field name="TYPE">dusk</field>
                                                     <block type="debug" id="JVc5|ie7ToL`o0+q*H6)">
                                                       <value name="TEXT">
                                                         <shadow type="text" id=":3i#l]vFr9mFH`8A9d40">
                                                           <field name="TEXT">Abenddämmerung</field>
                                                         <block type="debug" id="}#5$Eg5HxUq%N?JiZUB|">
                                                           <value name="TEXT">
                                                             <block type="time_get" id="C8-_%?]~kLQbzj4$5M:w">
                                                     <block type="astro" id="o1Y86d?aD}-85W@_Bc{X">
                                                       <field name="TYPE">nauticalDusk</field>
                                                         <block type="debug" id="[y[=-3!xjqWbFILYTKrT">
                                                           <value name="TEXT">
                                                             <shadow type="text" id="(Ka/nD(#:R%T5M;oQVo+">
                                                               <field name="TEXT">Nautische Abenddämmerung</field>
                                                             <block type="debug" id="hQnK;WRQD=[=PuGnpeC^">
                                                               <value name="TEXT">
        <block type="time_get" id="1*6{GuA}Ptl}@=:RYN8E">
                                                         <block type="astro" id="j8y_r:dEbMD7iY2.W7L,">
                                                           <field name="TYPE">night</field>
                                                             <block type="debug" id="76(?!SO)O1xP:}liKAC%">
                                                               <value name="TEXT">
        <shadow type="text" id="hkdb,q:hVvOIp?ukBqRa">
        <field name="TEXT">Nacht</field>
        <block type="debug" id="K`Fpc2JYxRBNQEc[yo9_">
        <value name="TEXT">
        <block type="time_get" id="f.=BzucV$CL,2#_}W7wU">
                                                             <block type="astro" id=",EU+9{ySUaqT/?CfG5ap">
                                                               <field name="TYPE">nightEnd</field>
        <block type="debug" id="nk=,IYJu$$)~c%9EMNZL">
        <value name="TEXT">
        <shadow type="text" id="?@=$%L4#!G}2|rgS]c=?">
        <field name="TEXT">Nachtende</field>
        <block type="debug" id="U_1^p,G9]J.];Zq9X~LM">
        <value name="TEXT">
        <block type="time_get" id="Wq.(8ZwGLimw6:lfSa!V">
        <block type="astro" id="Sz%RA[al07GBMdE@p1Gz">
        <field name="TYPE">nauticalDawn</field>
        <block type="debug" id="`y(OGo$-nPG8Ej5m[BHG">
        <value name="TEXT">
        <shadow type="text" id="EOoN^Uh$_,d+JSl]lGUh">
        <field name="TEXT">Nautische Morgendämmerung</field>
        <block type="debug" id="0S99AV1F|DJLUd,(d?qc">
        <value name="TEXT">
        <block type="time_get" id="YOyQlgY?b(gtz4v^}j+H">
        <block type="astro" id="Vw^5UMBH6vtWJyaq53.]">
        <field name="TYPE">dawn</field>
        <block type="debug" id="19?SR^q{j;E8z!!;D7[)">
        <value name="TEXT">
        <shadow type="text" id="Ar4KDdxuaHRys!_~m2WV">
        <field name="TEXT">Morgendämmerung</field>
        <block type="debug" id="=m0|q1#NNjFK3(dAk!Ad">
        <value name="TEXT">
        <block type="time_get" id="78Wc.sXU9AC;tMV..MwN">
        <block type="astro" id="i`FUoNopylwQy:QgoJ}v">
        <field name="TYPE">nadir</field>
        <block type="debug" id="r(e93[h_`7D!QfmFL~Mf">
        <value name="TEXT">
        <shadow type="text" id="|P[TC/:yl.5FkD_HO*./">
        <field name="TEXT">Nadir</field>
        <block type="debug" id="Dhca#mXRR2KV}e}.Opj$">
        <value name="TEXT">
        <block type="time_get" id="f[j$/@]5]_7kP7mnP#ds">
                A 2 Replies Last reply Reply Quote 0
                • iomountain
                  Mine works:
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenmittag
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenuntergang Anfang
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Abenddämmerung
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Abenddämmerung
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nacht
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nadir
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nachtende
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Morgendämmerung
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Morgendämmerung
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang ende
                  javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour Ende
                  if you dont have all these "errors" in your log, we try next ideas, or compare Versions.
                    @iomountain sorry, I am traveling now, will be able to try next week
                    • iomountain
                      mine works:
                      my Versions of Software:
                      Node.js v10.16.3
                      NPM 6.9.0
                        @iomountain I am getting this error while saving your script:
                        10/27/2019, 10:30:21 PM.531 [error]: javascript.0 (18920) script.js.ASTRO compile failed:
                        at script.js.ASTRO:1
                          @iomountain Actually, here is log after starting your script:
                          2019-10-27 22:35:16.197 - info: javascript.0 (18920) Stop script script.js.ASTRO
                          2019-10-27 22:35:20.358 - info: javascript.0 (18920) Start javascript script.js.ASTRO
                          2019-10-27 22:35:20.358 - error: javascript.0 (18920) script.js.ASTRO compile failed:
                          2019-10-27 22:35:20.359 - error: javascript.0 (18920) ^
                          2019-10-27 22:35:20.359 - error: javascript.0 (18920) SyntaxError: Unexpected token <
                          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at new Script (vm.js:83:7)
                          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at Object.createScript (vm.js:277:10)
                          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:961:28)
                          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1184:37)
                          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1237:17)
                          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:828:17)
                          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:433:21)
                          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at process._tickCallback (internal/process/next_tick.js:68:7)
                            @iomountain My system:
                            Script Engine 4.3.1
                            Node.js 10.16.3
                            NPM 6.9.0
                            • iomountain
                              My script is a Blockly:
                                @iomountain Thank you, will enter and start it tonight
                                  ap2017 @ap2017 last edited by ap2017
                                  @ap2017 Please see log attached, ASTRO does not work. Server was restarted after scrip creation yesterday evening. Currently my script adapter configured for System ASTRO Settings, shows my street on the screen. I am wondering if possible to debug how system sees my location.
                                  Tonight I will change Script Adapter ASTRO location to Germany and run same script over night.
                                  10-29-19.txt
                                  My script:
                                  • iomountain
                                    you can check the times at https://www.suncalc.org if you can get them.
                                      ap2017 @iomountain last edited by ap2017
                                      @iomountain I mean is there a way to check how ioBroker see my location? Maybe ASTRO gets screwed up because location is screwed up.
                                      • iomountain
                                        iomountain last edited by iomountain
                                        I am not sure, but i think what astro uses is only this:
                                        Is the Date and Time of your Operating System set right?
                                          @iomountain Here is the log with location in adapter ASTRO set to Germany. ASTRO seems to be working fine. As you can see, script reports ALL ASTRO events, while when my location was set to US it reported only few and then died.
                                          10-30-19 log.txt
                                            @iomountain In all my tests location in Overview Settings set to my address, see picture. Not sure what you mean by Date and Time
                                            1.2k
                                            blockly
                                            7580
