    2. English
    3. Scripting / Logic
    5. ASTRO function. Does not work again
    • iomountain
      iomountain @ap2017 last edited by
      @ap2017 sagte in ASTRO function:
      @iomountain Here is the log from running your script Astro Time for Today, if it helps.
      shows that the AstroFunktion works
      What about the log of your script?
        ap2017 @iomountain last edited by
        @iomountain Here is my complete log from yesterday. Notice that in 18:58 I added your script with ASTRO Time for Day. Thank you for your help!
        10-20-19 Log.txt
        • iomountain
          something going wrong with ASTRO, still testing.
          • iomountain
            Could you please test this for 24 hours:
             <block type="comment" id="dZ/@oL!i0(@/:!$Ikw{J" x="13" y="13">
               <field name="COMMENT">Test Astro</field>
                 <block type="astro" id="sxZ*u!O2O8lf$a?qgNf%">
                   <field name="TYPE">sunrise</field>
                   <field name="OFFSET">0</field>
                     <block type="debug" id="f0h|hnMOj,t0a9F4R/*u">
                       <field name="Severity">error</field>
                       <value name="TEXT">
                         <shadow type="text" id="t~{SzkO:N+m/c:_aXvF_">
                           <field name="TEXT">Sonnenaufgang</field>
                         <block type="debug" id=";Kc+}!GR24eQ4F1zvsqz">
                           <value name="TEXT">
                             <shadow type="text" id="d7@Q.7Mu+wBczv=iaKT?">
                             <block type="time_get" id="0}ve}|zeLByf%Wn1)Z~N">
                               <mutation format="true" language="false"></mutation>
                               <field name="OPTION">custom</field>
                               <field name="FORMAT">JJJJ-MM-TT SS:mm:ss.sss</field>
                     <block type="astro" id="e%0Te`wUBXm0Z(Tm~(uK">
                       <field name="TYPE">sunriseEnd</field>
                         <block type="debug" id="~yMY;Z`RDhY|PgL8aLYT">
                           <value name="TEXT">
                             <shadow type="text" id="{(iRk-Wgsniu)/OWNuec">
                               <field name="TEXT">Sonnenaufgang ende</field>
                             <block type="debug" id="q|N1he7_#J*z!t:Lxbq4">
                               <value name="TEXT">
                                 <block type="time_get" id="tJ*UF;cM+aI^pYR^Qa;1">
                         <block type="astro" id="7-p8CPh^EAGz7TZ[HE=f">
                           <field name="TYPE">goldenHourEnd</field>
                             <block type="debug" id="#jT`iz!Nlmm:r|h0-a;{">
                               <value name="TEXT">
                                 <shadow type="text" id="sF]?KilHL=/lQ@|f$!#B">
                                   <field name="TEXT">Golden hour Ende</field>
                                 <block type="debug" id="?jcK[-lRY6m67kH94cJ8">
                                   <value name="TEXT">
                                     <block type="time_get" id=":6c/3{e5w_Qr@--(F2,$">
                             <block type="astro" id="tK}:wS(k,Xmf4I2Ms^,]">
                               <field name="TYPE">solarNoon</field>
                                 <block type="debug" id="sYbNw@$;Db5D:)VF)*b}">
                                   <value name="TEXT">
                                     <shadow type="text" id="h9Pt!n;uDsK%[C8H0T:-">
                                       <field name="TEXT">Sonnenmittag</field>
                                     <block type="debug" id="0z@Vv^UhX8S(2Uk.L}AX">
                                       <value name="TEXT">
                                         <block type="time_get" id="63mXGB7G3:L?++1KLilu">
                                 <block type="astro" id="2X-czA2y[$Ug?5[Q_aUV">
                                   <field name="TYPE">goldenHour</field>
                                     <block type="debug" id="VvR2BxdbZn.+TuU)7yLe">
                                       <value name="TEXT">
                                         <shadow type="text" id="#r/L5Io)*?Qz!Co)U:Jc">
                                           <field name="TEXT">Golden hour</field>
                                         <block type="debug" id="vO^xDs|z,PXJo=OKQ=bY">
                                           <value name="TEXT">
                                             <block type="time_get" id="8b(z1|U:aT{s/-zQOG-O">
                                     <block type="astro" id="dLczmmMSoFlkvb*/H*SF">
                                       <field name="TYPE">sunsetStart</field>
                                         <block type="debug" id="S%o3:;|MkGT:WNoq-5I/">
                                           <value name="TEXT">
                                             <shadow type="text" id="oZW7=ox`@zO:d)Qo`jM#">
                                               <field name="TEXT">Sonnenuntergang Anfang</field>
                                             <block type="debug" id="88*2`mY-$F4-h46R$bsh">
                                               <value name="TEXT">
                                                 <block type="time_get" id="=yV74{gTTEshyETA[YT+">
                                         <block type="astro" id="`E^X3.`tEYD#t?w3p[Y6">
                                           <field name="TYPE">sunset</field>
                                             <block type="debug" id="3y?c.oF8m3]qo`y^Sk2Y">
                                               <value name="TEXT">
                                                 <shadow type="text" id="_^a1$PSDO%=0T$ouPs,z">
                                                   <field name="TEXT">Sonnenuntergang</field>
                                                 <block type="debug" id="B{Xk(=sas9lxfcPeH~8l">
                                                   <value name="TEXT">
                                                     <block type="time_get" id="?;boy8-PvsRtK^R`i(d!">
                                             <block type="astro" id="yk2LFSH:M4]t,=g+r0Zr">
                                               <field name="TYPE">dusk</field>
                                                 <block type="debug" id="JVc5|ie7ToL`o0+q*H6)">
                                                   <value name="TEXT">
                                                     <shadow type="text" id=":3i#l]vFr9mFH`8A9d40">
                                                       <field name="TEXT">Abenddämmerung</field>
                                                     <block type="debug" id="}#5$Eg5HxUq%N?JiZUB|">
                                                       <value name="TEXT">
                                                         <block type="time_get" id="C8-_%?]~kLQbzj4$5M:w">
                                                 <block type="astro" id="o1Y86d?aD}-85W@_Bc{X">
                                                   <field name="TYPE">nauticalDusk</field>
                                                     <block type="debug" id="[y[=-3!xjqWbFILYTKrT">
                                                       <value name="TEXT">
                                                         <shadow type="text" id="(Ka/nD(#:R%T5M;oQVo+">
                                                           <field name="TEXT">Nautische Abenddämmerung</field>
                                                         <block type="debug" id="hQnK;WRQD=[=PuGnpeC^">
                                                           <value name="TEXT">
                                                             <block type="time_get" id="1*6{GuA}Ptl}@=:RYN8E">
                                                     <block type="astro" id="j8y_r:dEbMD7iY2.W7L,">
                                                       <field name="TYPE">night</field>
                                                         <block type="debug" id="76(?!SO)O1xP:}liKAC%">
                                                           <value name="TEXT">
                                                             <shadow type="text" id="hkdb,q:hVvOIp?ukBqRa">
                                                               <field name="TEXT">Nacht</field>
                                                             <block type="debug" id="K`Fpc2JYxRBNQEc[yo9_">
                                                               <value name="TEXT">
        <block type="time_get" id="f.=BzucV$CL,2#_}W7wU">
                                                         <block type="astro" id=",EU+9{ySUaqT/?CfG5ap">
                                                           <field name="TYPE">nightEnd</field>
                                                             <block type="debug" id="nk=,IYJu$$)~c%9EMNZL">
                                                               <value name="TEXT">
        <shadow type="text" id="?@=$%L4#!G}2|rgS]c=?">
        <field name="TEXT">Nachtende</field>
        <block type="debug" id="U_1^p,G9]J.];Zq9X~LM">
        <value name="TEXT">
        <block type="time_get" id="Wq.(8ZwGLimw6:lfSa!V">
                                                             <block type="astro" id="Sz%RA[al07GBMdE@p1Gz">
                                                               <field name="TYPE">nauticalDawn</field>
        <block type="debug" id="`y(OGo$-nPG8Ej5m[BHG">
        <value name="TEXT">
        <shadow type="text" id="EOoN^Uh$_,d+JSl]lGUh">
        <field name="TEXT">Nautische Morgendämmerung</field>
        <block type="debug" id="0S99AV1F|DJLUd,(d?qc">
        <value name="TEXT">
        <block type="time_get" id="YOyQlgY?b(gtz4v^}j+H">
        <block type="astro" id="Vw^5UMBH6vtWJyaq53.]">
        <field name="TYPE">dawn</field>
        <block type="debug" id="19?SR^q{j;E8z!!;D7[)">
        <value name="TEXT">
        <shadow type="text" id="Ar4KDdxuaHRys!_~m2WV">
        <field name="TEXT">Morgendämmerung</field>
        <block type="debug" id="=m0|q1#NNjFK3(dAk!Ad">
        <value name="TEXT">
        <block type="time_get" id="78Wc.sXU9AC;tMV..MwN">
        <block type="astro" id="i`FUoNopylwQy:QgoJ}v">
        <field name="TYPE">nadir</field>
        <block type="debug" id="r(e93[h_`7D!QfmFL~Mf">
        <value name="TEXT">
        <shadow type="text" id="|P[TC/:yl.5FkD_HO*./">
        <field name="TEXT">Nadir</field>
        <block type="debug" id="Dhca#mXRR2KV}e}.Opj$">
        <value name="TEXT">
        <block type="time_get" id="f[j$/@]5]_7kP7mnP#ds">
            A 2 Replies Last reply Reply Quote 0
            • iomountain
              Mine works:
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenmittag
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenuntergang Anfang
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Abenddämmerung
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Abenddämmerung
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nacht
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nadir
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nachtende
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Morgendämmerung
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Morgendämmerung
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang ende
              javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour Ende
              if you dont have all these "errors" in your log, we try next ideas, or compare Versions.
                @iomountain sorry, I am traveling now, will be able to try next week
                • iomountain
                  mine works:
                  my Versions of Software:
                  Node.js v10.16.3
                  NPM 6.9.0
                    @iomountain I am getting this error while saving your script:
                    10/27/2019, 10:30:21 PM.531 [error]: javascript.0 (18920) script.js.ASTRO compile failed:
                    at script.js.ASTRO:1
                      @iomountain Actually, here is log after starting your script:
                      2019-10-27 22:35:16.197 - info: javascript.0 (18920) Stop script script.js.ASTRO
                      2019-10-27 22:35:20.358 - info: javascript.0 (18920) Start javascript script.js.ASTRO
                      2019-10-27 22:35:20.358 - error: javascript.0 (18920) script.js.ASTRO compile failed:
                      2019-10-27 22:35:20.359 - error: javascript.0 (18920) ^
                      2019-10-27 22:35:20.359 - error: javascript.0 (18920) SyntaxError: Unexpected token <
                      2019-10-27 22:35:20.359 - error: javascript.0 (18920) at new Script (vm.js:83:7)
                      2019-10-27 22:35:20.359 - error: javascript.0 (18920) at Object.createScript (vm.js:277:10)
                      2019-10-27 22:35:20.359 - error: javascript.0 (18920) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:961:28)
                      2019-10-27 22:35:20.359 - error: javascript.0 (18920) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1184:37)
                      2019-10-27 22:35:20.359 - error: javascript.0 (18920) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1237:17)
                      2019-10-27 22:35:20.359 - error: javascript.0 (18920) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:828:17)
                      2019-10-27 22:35:20.360 - error: javascript.0 (18920) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:433:21)
                      2019-10-27 22:35:20.360 - error: javascript.0 (18920) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                      2019-10-27 22:35:20.360 - error: javascript.0 (18920) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                      2019-10-27 22:35:20.360 - error: javascript.0 (18920) at process._tickCallback (internal/process/next_tick.js:68:7)
                        @iomountain My system:
                        Script Engine 4.3.1
                        Node.js 10.16.3
                        NPM 6.9.0
                        • iomountain
                          My script is a Blockly:
                            @iomountain Thank you, will enter and start it tonight
                              ap2017 @ap2017 last edited by ap2017
                              @ap2017 Please see log attached, ASTRO does not work. Server was restarted after scrip creation yesterday evening. Currently my script adapter configured for System ASTRO Settings, shows my street on the screen. I am wondering if possible to debug how system sees my location.
                              Tonight I will change Script Adapter ASTRO location to Germany and run same script over night.
                              10-29-19.txt
                              My script:
                              • iomountain
                                you can check the times at https://www.suncalc.org if you can get them.
                                  ap2017 @iomountain last edited by ap2017
                                  @iomountain I mean is there a way to check how ioBroker see my location? Maybe ASTRO gets screwed up because location is screwed up.
                                  • iomountain
                                    iomountain last edited by iomountain
                                    I am not sure, but i think what astro uses is only this:
                                    Is the Date and Time of your Operating System set right?
                                      @iomountain Here is the log with location in adapter ASTRO set to Germany. ASTRO seems to be working fine. As you can see, script reports ALL ASTRO events, while when my location was set to US it reported only few and then died.
                                      10-30-19 log.txt
                                        @iomountain In all my tests location in Overview Settings set to my address, see picture. Not sure what you mean by Date and Time
                                        iomountain 1 Reply Last reply Reply Quote 0
                                        • iomountain
                                          i use timedatectl on the command line of iobroker host to see all is set correct.
                                          • iomountain
                                            If you config:
                                            you also will find Astro Settings for your location.
                                            blockly
                                            7584
