    4. [gelöst] ioBroker Wiederherstellung mit Backitup
    • StM47
      StM47 @Jan1 last edited by StM47
      @Jan1
      ja, wenn er läuft.
      Habe die Wiederherstellung mal über Nacht laufen lassen.
      Bekomme folgende Fehlermeldung:
      Gestartet...
      [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"****"}
      [ERROR] [mount] - [undefined sudo: Hostname iobroker kann nicht aufgelöst werden
      sudo: Die Audit-Nachricht kann nicht gesendet werden: Unbekannter Fehler -1
      sudo: pam_open_session: Systemfehler
      sudo: Regelwerks-Plugin konnte Sitzung nicht initialisieren
      [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount 192.168.178.50:/sharename/backupDir /opt/iobroker/backups
      [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standartbackup","deleteBackupAfter":"5","mysqlEnabled":false,"redisEnabled":false,"zigbeeEnabled":false,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"","context":{"fileNames":[],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"sudo mount 192.168.178.50:/sharename/backupDir /opt/iobroker/backups"}},"done":[],"types":[]},"adapter":null},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"stopIoB":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal_2019_10_28-02_00_20_Standartbackup_backupiobroker.tar.gz
      [DEBUG] [minimal] - done
      [DEBUG] [cifs] start with {"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"","backupDir":"/opt/iobroker/backups","deleteBackupAfter":"5"}
      [DEBUG] [cifs] - done
      [DEBUG] [dropbox] start with {"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"
      ","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total","deleteBackupAfter":"5"}
      [DEBUG] [dropbox] - Copy minimal_2019_10_28-02_00_20_Standartbackup_backupiobroker.tar.gz...
      [DEBUG] [dropbox] - done
      [DEBUG] [clean] start with {"deleteBackupAfter":"5"}
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standartbackup","deleteBackupAfter":"5","mysqlEnabled":false,"redisEnabled":false,"zigbeeEnabled":false,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_10_28-02_00_20_Standartbackup_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"sudo mount 192.168.178.50:/sharename/backupDir /opt/iobroker/backups"}},"done":["minimal","dropbox"],"types":["minimal"]},"adapter":null},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":"de","time":"28. Oktober 2019 um 02:00 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"stopIoB":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [telegram] - done
      [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standartbackup","deleteBackupAfter":"5","mysqlEnabled":false,"redisEnabled":false,"zigbeeEnabled":false,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_10_28-02_00_20_Standartbackup_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"sudo mount 192.168.178.50:/sharename/backupDir /opt/iobroker/backups"}},"done":["minimal","dropbox"],"types":["minimal"]},"adapter":null},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Oktober 2019 um 02:00 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"stopIoB":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [history] - backitup.0.history.html
      [DEBUG] [umount] start with {"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"****","backupDir":"/opt/iobroker/backups"}
      Und im LOG steht die selbe Fehlermeldung, wie im ersten Post.
      simatec J 2 Replies Last reply Reply Quote 0
      • simatec
        simatec Developer Most Active @StM47 last edited by
        @StM47
        Der Log ist nicht vom restore sondern von einem backup und sagt aus, dass dein mount nicht korrekt konfiguriert ist.
        Ich glaube du bringst hier ein wenig was durcheinander ...
          Jan1 @StM47 last edited by
          @StM47
          Du versuchst auf ein Mount zu zugreifen was nicht geht, deshalb war der Rat das Backup in den Ordner /opt/iobroker/backups zu legen und mit dem Backitup Adapter dann lokal zu wählen und eben das Backup aus besagtem Ordner wieder herzustellen.
          Wenn das nicht geht, dann hast Dein System versaut.
          StM47 1 Reply Last reply Reply Quote 0
          • StM47
            @Jan1
            genau das ist mein Plan.
            ich möchte ein gesichertes backup in /opt/iobroker/backups legen und von dort aus wieder herstellen.
            Das geht aber nur über das Terminal per SSH mit root.
            Mir fehlen aber eine genaue Anleitung dazu.
            Ich komme soweit, mich mit root auf der DiskStation mit Putty anzumelden.
            Dann weiß ich nicht weiter.
              @StM47
              Warum willst was anderes machen, als man Dir rät?
              • StM47
                @Jan1
                jetzt vertehe ich gar nichts mehr.
                Du schreibst:
                "deshalb war der Rat das Backup in den Ordner /opt/iobroker/backups zu legen und mit dem Backitup Adapter dann lokal zu wählen und eben das Backup aus besagtem Ordner wieder herzustellen"
                Genau das habe ich vor.
                Geht das auch anderst als mit dem Terminal?
                J simatec 2 Replies Last reply Reply Quote 0
                  Jan1 @StM47 last edited by Jan1
                  @StM47
                  Steht da Backitup Adapter oder Terminal???
                  Der einzige der hier immer Terminal schreibt, bist Du.
                  StM47 2 Replies Last reply Reply Quote 0
                  • simatec
                    @StM47
                    Warum willst du ein frisch erstelltes Backup direkt wieder herstellen?
                    Ich denke du verwechselst hier was grundlegendes ...
                    • StM47
                      @Jan1
                      ich muss doch aber erst ein gesichertes Backup in den Ordner /opt/iobroker/backups
                      legen.
                      Wie soll ich das ohne Terminal machen?
                      • StM47
                        StM47 @simatec last edited by
                        @simatec
                        ich habe mich sicher falsch ausgedrückt.
                        Ich möchte ein altes Backup, welches ich in der Dropbox liegen habe, wiederherstellen.
                          @StM47
                          Mit Filezilla z.B. oder einem FTP Programm Deiner Wahl.
                          Wobei ich jetzt auch nicht verstehe, was DU überhaupt machen willst.
                          • simatec
                            @StM47
                            Du nimmst ein Standard Backup von deiner alten Installation und legst es per SFTP auf dein neues System.
                            Danach stellst du mit backitup lokal das Backup wieder her ...
                            • StM47
                              @Jan1
                              auf ein FTP Programm bin ich noch gar nicht gekommen.
                              Teste ich gleich mal an..
                              • StM47
                                StM47 last edited by StM47
                                Ich gebe bald auf,
                                Es ist ohnen größeren Aufwand nicht möglich, per SFTP (SSH) mit eienm FTP Programm auf das root Verzeichnis einer Synology DiskStation zu kommen.
                                Es ist wohl einfacher, die Backup-Datei mit 2 bis 3 Shell-Befehlen in das Verzeichnis /opt/iobroker/backups zu bekommen, wie mit SFTP.
                                Es müsste mir nur jemand zeigen, wie das geht.
                                • simatec
                                  @StM47
                                  Kommst du per ssh in das Verzeichnis /opt/iobroker/backups?
                                  • StM47
                                    ja, komme ich.
                                    • simatec
                                      @StM47
                                      Dann sollte es auch per sftp gehen
                                      • StM47
                                        es geht auch mit SFTP. Muss aber vorher per Shell den Key aus der DiskStation extrahieren und damit für SFTP eine Schlüsseldatei basteln.
                                        Also ist das wieder eine ganz andere, für mich größere Baustelle.
                                        Synology hat da echt fliese Sicherheitsmaßnahmen getroffen.
                                        • StM47
                                          Ist hier kein Linux Spezialist, der mir kurz die 3 Befehle zum kopieren meines alten Backups in das Verzeichnis /opt/iobroker/backups aufschreiben kan?
                                          • simatec
                                            @StM47
                                            Hast du es mal mit Filezilla getestet?
                                            backitup backup diskstation docker dropbox wiederherstellung
                                            6278
