[gelöst] Adapterseite lädt nicht bzw. sehr langsam
Rufe bitte
iobroker updateaus.
Was wird da angezeigt?
Hi
es kommt dann:
login as: root root@dorotka.ddns.net's password: Linux raspberrypi 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon Oct 12 12:59:32 2015 from p578b27a0.dip0.t-ipconnect.de root@raspberrypi:~# iobroker update module.js:340 throw err; ^ Error: Cannot find module 'node-uuid' at Function.Module._resolveFilename (module.js:338:15) at Function.Module._load (module.js:280:25) at Module.require (module.js:364:17) at require (module.js:380:17) at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/request/lib/auth.js:4:12) at Module._compile (module.js:456:26) at Object.Module._extensions..js (module.js:474:10) at Module.load (module.js:356:32) at Function.Module._load (module.js:312:12) at Module.require (module.js:364:17) root@raspberrypi:~#</anonymous> -
Deine installation ist nicht vollständig:
bitte aufrufen:
cd /opt/iobroker sudo npm cache clean sudo iobroker stop sudo pgrep -f '^io.*' | sudo xargs kill -9 sudo npm install iobroker.js-controller cd node_modules/iobroker.js-controller sudo npm update cd ../.. sudo chmod 777 * -R sudo iobroker start -
So weit lief alles gut durch.
Erst als ich sudo iobroker start eingegeben habe kam diese Meldung.
root@raspberrypi:/opt/iobroker# sudo iobroker start
Starting ioBroker controller daemon...
! /opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136
throw new Error(msg.error);
Error: TypeError: object is not a function
at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling.js:23:13
at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling.js:25:3)
at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:6:15)
at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136:19)
at ChildProcess.EventEmitter.emit (events.js:98:17)
at handleMessage (child_process.js:318:10)
at Pipe.channel.onread (child_process.js:345:11)
root@raspberrypi:/opt/iobroker# root@raspberrypi:/opt/iobroker# sudo iobroker start
at Pipe.channel.onread (child_process.js:-bash: root@raspberrypi:/opt/iobroker#: Datei oder Verzeichnis nicht gefunden
root@raspberrypi:/opt/iobroker# Starting ioBroker controller daemon...
-bash: Starting: Kommando nicht gefunden.
root@raspberrypi:/opt/iobroker# /opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136
-bash: /opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136: Datei oder Verzeichnis nicht gefunden
root@raspberrypi:/opt/iobroker# throw new Error(msg.error);
-bash: Syntaxfehler beim unerwarteten Wort(' root@raspberrypi:/opt/iobroker# ^ -bash: ^: Kommando nicht gefunden. root@raspberrypi:/opt/iobroker# Error: TypeError: object is not a function -bash: Error:: Kommando nicht gefunden. root@raspberrypi:/opt/iobroker# at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling.js:23:13 -bash: at: Kommando nicht gefunden. root@raspberrypi:/opt/iobroker# at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling.js:25:3) -bash: Syntaxfehler beim unerwarteten Wort('
root@raspberrypi:/opt/iobroker# at Module._compile (module.js:456:26)
-bash: Syntaxfehler beim unerwarteten Wort(' root@raspberrypi:/opt/iobroker# at Object.Module._extensions..js (module.js:474:10) -bash: Syntaxfehler beim unerwarteten Wort('
root@raspberrypi:/opt/iobroker# at Module.load (module.js:356:32)
-bash: Syntaxfehler beim unerwarteten Wort(' root@raspberrypi:/opt/iobroker# at Function.Module._load (module.js:312:12) -bash: Syntaxfehler beim unerwarteten Wort('
root@raspberrypi:/opt/iobroker# at Module.require (module.js:364:17)
-bash: Syntaxfehler beim unerwarteten Wort(' root@raspberrypi:/opt/iobroker# at require (module.js:380:17) -bash: Syntaxfehler beim unerwarteten Wort('
root@raspberrypi:/opt/iobroker# at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:6:15)
-bash: Syntaxfehler beim unerwarteten Wort(' root@raspberrypi:/opt/iobroker# at Module._compile (module.js:456:26) -bash: Syntaxfehler beim unerwarteten Wort('
root@raspberrypi:/opt/iobroker# at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136:19)
-bash: Syntaxfehler beim unerwarteten Wort(' root@raspberrypi:/opt/iobroker# at ChildProcess.EventEmitter.emit (events.js:98:17) -bash: Syntaxfehler beim unerwarteten Wort('
root@raspberrypi:/opt/iobroker# at handleMessage (child_process.js:318:10)
-bash: Syntaxfehler beim unerwarteten Wort(' root@raspberrypi:/opt/iobroker# at Pipe.channel.onread (child_process.js: -bash: Syntaxfehler beim unerwarteten Wort('
root@raspberrypi:/opt/iobroker#</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous> -
Dann empfehle ich dir das Verzeichnis
zu löschen und dann noch mal das aufrufen:
cd /opt/iobroker sudo npm cache clean sudo pgrep -f '^io.*' | sudo xargs kill -9 sudo npm install iobroker.js-controller sudo chmod 777 * -RDanach ausführen:
sudo node node_modules/iobroker.js-controller/controller.jsWas kommt?
Hi
ist hier ein Fehler drin?
Es kommt – ungültige Option
Jo bei mir Läd es auch nicht hab iobroker update eingegeben und das lief
root@raspberrypi:~# iobroker update update done Adapter "zwave" : 0.2.2 Adapter "yr" : 0.1.7 Adapter "wolf" : 0.0.4 Adapter "web" : 1.0.2 , installed 1.0.2 Adapter "vis-timeandweather": 0.0.2 , installed 0.0.2 Adapter "vis-rgraph" : 0.0.2 Adapter "vis-plumb" : 0.1.5 Adapter "vis-metro" : 0.1.9 , installed 0.1.9 Adapter "vis-lcars" : 0.1.6 Adapter "vis-jqui-mfd" : 0.0.1 Adapter "vis-hqwidgets" : 0.2.0 Adapter "vis-fancyswitch": 0.1.0 Adapter "vis-colorpicker": 0.1.1 Adapter "vis-bars" : 0.1.1 Adapter "vis" : 0.7.2 , installed 0.7.2 Adapter "terminal" : 0.1.2 Adapter "sonos" : 0.1.7 , installed 0.1.7 Adapter "rickshaw" : 0.2.2 Adapter "pushover" : 0.1.1 Adapter "pushbullet" : 0.0.11 Adapter "owfs" : 0.0.2 Adapter "onkyo" : 0.1.9 Adapter "socketio" : 1.0.0 Adapter "simple-api" : 1.0.0 Adapter "scenes" : 0.1.3 Adapter "sayit" : 0.3.12 Adapter "s7" : 0.2.3 Adapter "ping" : 0.1.4 Adapter "node-red" : 0.3.5 Adapter "mqtt" : 0.2.10 Adapter "modbus" : 0.2.2 Adapter "megad" : 1.0.1 Adapter "knx" : 0.2.10 Controller "js-controller" : 0.7.14 , installed 0.7.14 Adapter "javascript" : 1.0.2 Adapter "icons-ultimate-png": 0.1.0 , installed 0.1.0 Adapter "icons-open-icon-library-png": 0.1.1 Adapter "icons-mfd-svg" : 0.1.2 Adapter "icons-mfd-png" : 0.1.2 Adapter "icons-material-svg": 0.1.0 Adapter "icons-material-png": 0.1.0 Adapter "icons-addictive-flavour-png": 0.1.0 Adapter "ical" : 1.1.1 Adapter "hmm" : 1.0.0 Adapter "hue" : 0.4.4 Adapter "hm-rpc" : 0.5.2 , installed 0.5.2 Adapter "hm-rega" : 0.2.2 , installed 0.2.2 Adapter "history" : 0.1.3 Adapter "harmony" : 0.5.3 Adapter "example" : 0.1.1 , installed 0.1.1 Adapter "fritzbox" : 0.2.1 Adapter "flot" : 0.1.1 Adapter "email" : 0.1.2 Adapter "dwd" : 0.1.10 Adapter "cul" : 0.0.4 Adapter "b-control-em" : 0.1.1 Adapter "artnet" : 0.0.3 Adapter "admin" : 0.6.1 , installed 0.6.1 root@raspberrypi:~# sudo iobroker start ioBroker controller daemon already running. PID: 2219 root@raspberrypi:~# !Alles kann ich öffnen nur bei Adapter steht bearbeite
Es kommt diese Meldung:
root@raspberrypi:/opt/iobroker# sudo pgrep -f '^io.*' | sudo xargs kill -9 kill: Ungültige Option -- 9 Usage: kill [options] <pid>[...] Options: <pid>[...] send signal to every <pid>listed -<signal>, -s, --signal <signal>specify the <signal>to be sent -l, --list=[<signal>] list all signal names, or convert one to a name -L, --table list all signal names in a nice table -h, --help display this help and exit -V, --version output version information and exit For more details see kill(1).</signal></signal></signal></signal></pid></pid></pid> -
root@raspberrypi:/opt/iobroker# sudo pgrep -f '^io.*' | sudo xargs kill -9 kill: Ungültige Option -- 9 Usage: kill [options] <pid>[...] Options: <pid>[...] send signal to every <pid>listed -<signal>, -s, --signal <signal>specify the <signal>to be sent -l, --list=[<signal>] list all signal names, or convert one to a name -L, --table list all signal names in a nice table -h, --help display this help and exit -V, --version output version information and exit For more details see kill(1).</signal></signal></signal></signal></pid></pid></pid> ```` `Diese Meldung kannst du einfach ignorieren.
Hi
du bist der beste
Jetzt läuft es wieder. Vielen vielen Dank. -
So hab alles deinstalliert und neu installiert.
Raspberry einmal runter gefahren und wieder hoch und die Adapter Seite lädt nicht mehr
hab das auch alles durchlaufen und folgendes Problem:
root@ioBroker:/opt/iobroker# sudo chmod 777 * -R
root@ioBroker:/opt/iobroker# sudo node node_modules/iobroker.js-controller/contr oller.js
! module.js:340
throw err;
Error: Cannot find module 'engine.io'
at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/nod e_modules/socket.io/lib/index.js:9:14)
root@ioBroker:/opt/iobroker# iobroker start
Error: Error: Cannot find module 'engine.io'
at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/index.js:9:14)
at Pipe.channel.onread (child_process.js:345:11)</anonymous></anonymous></anonymous>>! ```` root@ioBroker:/opt/iobroker# iobroker list instances >! module.js:340 throw err; ^ Error: Cannot find module 'parseuri' at Function.Module._resolveFilename (module.js:338:15) at Function.Module._load (module.js:280:25) at Module.require (module.js:364:17) at require (module.js:380:17) at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/url.js:6:16) at Module._compile (module.js:456:26) at Object.Module._extensions..js (module.js:474:10) at Module.load (module.js:356:32) at Function.Module._load (module.js:312:12) at Module.require (module.js:364:17)</anonymous>Hilfe?! Ursprung war der Versuch die Updates einzuspielen.
Es gibt keine individuelle Lösung.
Hast du schon das probiert: http://forum.iobroker.com/viewtopic.php … 562#p13163
Dabei die Fehlermeldung von "sudo pgrep -f '^io.*' | sudo xargs kill -9" kannst du ignorieren.
Ja, genau das war mein Weg. Würde ja wenigstens gerne die Views irgendwie sichern. Hab ich mal schön versäumt und viel geändert.
Hi ich hab doch noch ein Problem, denn VIS startet nicht. Die AdminSeite geht aber wunderbar.
login as: root root@dorotka.ddns.net's password: Linux raspberrypi 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Fri Oct 16 17:48:54 2015 from i59f5ca06.versanet.de root@raspberrypi:~# cd /opt/iobroker root@raspberrypi:/opt/iobroker# ./iobroker restart Stopping ioBroker controller daemon... ioBroker controller daemon stopped. Starting ioBroker controller daemon... ioBroker controller daemon started. PID: 2895 root@raspberrypi:/opt/iobroker#Die Seite 192.168.0.20:8082/vis/index.html#Doro lädt lange und dann kommt "No conection to Server".
Das steht im Log
Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen. hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.23497.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1442308494} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.23497.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.23235.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1442254850} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.23235.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.22529.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1441909447} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.22529.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.22440.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1441909088} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.22440.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.21323.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1441202120} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.21323.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.21311.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1441202120} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.21311.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.21283.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1441202120} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.21283.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.20264.Active {'val':false,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1441210996} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.20264.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.19394.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1440521102} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.19394.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.17910.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1440178888} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.17910.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.17610.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1440096696} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.17610.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.17444.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1440057602} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.17444.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.17422.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1440057273} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.17422.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.17113.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1439830911} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.17113.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.16440.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.16440.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.15531.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1442422030} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.15531.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.15520.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.15520.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.15509.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.15509.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.15025.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1440099848} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.15025.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.15000.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.15000.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.14882.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.14882.Active hm-rega.0 2015-10-16 18:16:01 debug hm-rega.0 stateChange hm-rega.0.14570.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:01 debug inMem message hm-rega.0.* hm-rega.0.14570.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.13636.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.13636.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.13556.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.13556.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.13509.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.13509.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.13319.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.13319.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.13279.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.13279.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.12721.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.12721.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.12218.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.12218.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.12091.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.12091.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.11630.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.11630.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.10341.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.10341.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.9864.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.9864.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.9684.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.9684.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.9418.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.9418.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.9099.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.9099.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.8883.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.8883.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.8242.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.8242.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.8228.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.8228.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.8018.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.8018.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.7628.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.7628.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.7027.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.7027.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.6876.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.6876.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.6166.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.6166.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.6075.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.6075.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.5503.Active {'val':true,'ack':true,'ts':1445012161,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.5503.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.5279.Active {'val':true,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.5279.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.2189.Active {'val':true,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.2189.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.1964.Active {'val':true,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.1964.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.1906.Active {'val':true,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.1906.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.1595.Active {'val':true,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.1595.Active hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 <-- {'17113':{'Name':'Balkont%FCr','TypeName':'PROGRAM','PrgInfo':'Balkont%FCrkontakt', 'Active':true,'Timestamp':'2015-10-16 17:33:09'}, '15531':{'Name':'Bewegung','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 18:00:48'}, '8228':{'Name':'Blumen%20gie%DFen','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '21311':{'Name':'Display%20Flur%20unten%20%2B%20Schlafzimmer%20Taste%20oben%20kurz','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 05:59:47'}, '21283':{'Name':'Display%20Flur%20unten%20%2B%20Schlafzimmer%20Taste%20unten%20kurz','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 05:59:50'}, '21323':{'Name':'Display%20Flur%20unten%20%2BSchlafzimmerTaste%20oben%20lang','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 05:59:52'}, '1595':{'Name':'Displaynachricht%20senden','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-15 21:00:00'}, '16440':{'Name':'Drucker%20Tintenstand','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 18:00:00'}, '8883':{'Name':'Email-Status%20Versand','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 13:00:00'}, '9418':{'Name':'E%DFzimmer','TypeName':'PROGRAM','PrgInfo':'Heizungssteuerungsscript_E%DFzimmer', 'Active':true,'Timestamp':'2015-10-16 00:00:00'}, '7027':{'Name':'FB%2019%20T%20Taste%201%20LED%209%20aus%20Waschmaschine','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '6876':{'Name':'FB%2019%20T%20Taste%202%20LED%2010%20aus%20Sp%FClmaschine','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:56:55'}, '9684':{'Name':'FB%20Kanal%2012%20G%E4ste%20da%20Heizungsscript_Test','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '15000':{'Name':'Feiertag','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:56:55'}, '17444':{'Name':'Fenster_Ankleidezimmer','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:56:55'}, '6166':{'Name':'Fenster_Bad','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 18:06:55'}, '17422':{'Name':'Fenster_B%FCro','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 17:44:12'}, '22529':{'Name':'Fenster_G%E4stezimmer','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 17:33:37'}, '22440':{'Name':'Fenster_K%FCche','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 17:18:37'}, '6075':{'Name':'Fenster_Schlafzimmer','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 17:56:46'}, '2189':{'Name':'Garagentor','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 16:48:33'}, '7628':{'Name':'Loogia%20Tuer%20auf','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 17:32:02'}, '9864':{'Name':'Rollade_Loggia_FB%203%2B4','TypeName':'PROGRAM','PrgInfo':'100%25%20Auf%2FZU', 'Active':true,'Timestamp':'2015-10-11 11:57:02'}, '10341':{'Name':'Rollade_Loggia_FB%205%2B6','TypeName':'PROGRAM','PrgInfo':'42%25%20Rocky%20', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '13556':{'Name':'Rollade_Str_rechts_FB%209%2B10','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '12721':{'Name':'Rollade_Strasse_FB%207%2B8','TypeName':'PROGRAM','PrgInfo':'100%25%20Auf%2FZU', 'Active':true,'Timestamp':'2015-10-11 11:57:02'}, '14570':{'Name':'Rolladen%20S%FCd%2035%25%20ab%2023%20Grad','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 18:15:39'}, '13509':{'Name':'Rolladen_WZ_Sued_35prozenz','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '12218':{'Name':'Rolladensteuerung_Zeit_Loggia','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 00:00:00'}, '15509':{'Name':'Schalter%20oben%20laden','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 07:04:46'}, '15520':{'Name':'Schalter%20unten%20laden%20aus','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 07:04:49'}, '19394':{'Name':'Servicemelungen_LowBatterie','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-14 19:26:41'}, '1964':{'Name':'Systemvariabele%20Waschmaschine%20Gong%20%2B%20Anzeige','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:59:02'}, '8018':{'Name':'Systemvariabele%20Waschmaschine%20Gong%20%2B%20Anzeige','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:59:02'}, '5279':{'Name':'Systemvariable%20Sp%FClmasche%20setzen','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-14 20:19:04'}, '5503':{'Name':'Systemvariable%20Sp%FClmaschine%20Gong%20%2B%20Anzeige','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-14 20:21:04'}, '1906':{'Name':'Systemvariable%20Waschmaschine%20setzen','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:57:02'}, '14882':{'Name':'Tageszeitprogramm','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 18:15:00'}, '8242':{'Name':'Taste%2013%20Blumen%20gie%DFen%20l%F6schen','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '12091':{'Name':'Taster%20WZ%20Loggia%20Rolladen%2034Prozent','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:57:02'}, '17910':{'Name':'Taster-Wanddisplay_Test','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '11630':{'Name':'Taster_WZ_Rollade_Loggia','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '17610':{'Name':'Temperatur_19%20TastenFB%20lang','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '15025':{'Name':'Temperatur_19%20TastenFB_kurz','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '9099':{'Name':'T%FCrklingel','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '20264':{'Name':'Wanddisplay-DIS-WM55%20Taste%20unten%20Kanal%201','TypeName':'PROGRAM','PrgInfo':'', 'Active':false,'Timestamp':'1970-01-01 01:00:00'}, '23235':{'Name':'Wecker%206%20Uhr%20Mo-Fr','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-15 06:00:00'}, '23497':{'Name':'Wecker%209%20Uhr%20Mo-Fr','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '13636':{'Name':'WZ_Rollade_Sued_alle%20hoch','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, '13319':{'Name':'WZ_Rolladen_Sued%20Astro','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 08:03:00'}, '13279':{'Name':'WZ_Wandtaster%205%2B6%20Rollade%20Sued','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}} hm-rega.0 2015-10-16 18:16:00 debug hm-rega.0 stateChange hm-rega.0.1906.Active {'val':true,'ack':true,'ts':1445012100,'from':'system.adapter.hm-rega.0','lc':1435779720} hm-rega.0 2015-10-16 18:16:00 debug inMem message hm-rega.0.* hm-rega.0.1906.Active hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.21282 {'val':false,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444557388} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.21282 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.21281 {'val':false,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444967992} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.21281 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.21280 {'val':false,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444885898} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.21280 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.21279 {'val':0,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444968012} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.21279 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.19446 {'val':'???','ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444557388} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.19446 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.16439 {'val':90,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1445011200} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.16439 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.16438 {'val':20,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1445011200} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.16438 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 --> !# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Strin hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.16437 {'val':20,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1445011200} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.16437 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.16436 {'val':20,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1445011200} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.16436 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.14999 {'val':0,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444557388} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.14999 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.14881 {'val':5,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1445012100} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.14881 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.9396 {'val':false,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444557388} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.9396 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.9395 {'val':-1,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444557388} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.9395 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.9394 {'val':'???','ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444557388} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.9394 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.9392 {'val':false,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444711040} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.9392 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.9110 {'val':false,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444557388} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.9110 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.6149 {'val':false,'ack':true,'ts':1445012160,'from':'system.adapter.hm-rega.0','lc':1444557388} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.6149 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.5254 {'val':false,'ack':true,'ts':1445012159,'from':'system.adapter.hm-rega.0','lc':1444846864} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.5254 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.2172 {'val':false,'ack':true,'ts':1445012159,'from':'system.adapter.hm-rega.0','lc':1444557388} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.2172 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.1905 {'val':false,'ack':true,'ts':1445012159,'from':'system.adapter.hm-rega.0','lc':1444557542} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.1905 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.1233 {'val':false,'ack':true,'ts':1445012159,'from':'system.adapter.hm-rega.0','lc':0} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.1233 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.950 {'val':true,'ack':true,'ts':1445012159,'from':'system.adapter.hm-rega.0','lc':1444939905} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.950 hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.maintenance {'val':2,'ack':true,'ts':1445012159,'from':'system.adapter.hm-rega.0','lc':1445012148} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.maintenance hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 stateChange hm-rega.0.alarms {'val':0,'ack':true,'ts':1445012159,'from':'system.adapter.hm-rega.0','lc':1444557401} hm-rega.0 2015-10-16 18:15:59 debug inMem message hm-rega.0.* hm-rega.0.alarms hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 <-- {'1233':[false,'1970-01-01 01:00:00'], '950':[true,'2015-10-15 22:11:45'], '16439':[90.000000,'2015-10-16 18:00:00'], '16438':[20.000000,'2015-10-16 18:00:00'], '16437':[20.000000,'2015-10-16 18:00:00'], '16436':[20.000000,'2015-10-16 18:00:00'], '14999':[0,'2015-10-11 11:56:28'], '9392':[false,'2015-10-13 06:37:20'], '2172':[false,'2015-10-11 11:56:28'], '6149':[false,'2015-10-11 11:56:28'], '9394':['%3F%3F%3F','2015-10-11 11:56:28'], '9395':[-1.000000,'2015-10-11 11:56:28'], '21280':[false,'2015-10-15 07:11:38'], '21279':[0,'2015-10-16 06:00:12'], '5254':[false,'2015-10-14 20:21:04'], '9110':[false,'2015-10-11 11:56:28'], '14881':[5,'2015-10-16 18:15:00'], '9396':[false,'2015-10-11 11:56:28'], '19446':['%3F%3F%3F','2015-10-11 11:56:28'], '1905':[false,'2015-10-11 11:59:02'], '21281':[false,'2015-10-16 05:59:52'], '21282':[false,'2015-10-11 11:56:28'], '40':[0,'2015-10-11 11:56:41'], '41':[2,'2015-10-16 18:15:48']} hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 --> !# polling.fn 1.2 !# !# Dieses Script gibt die Werte aller Systemvariablen als J hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 --> programs.fn hm-rega.0 2015-10-16 18:15:59 debug hm-rega.0 --> polling.fn raspberrypi 2015-10-16 18:15:53 warn host.raspberrypi warning: Following packages cannot be read: example admin.0 2015-10-16 18:15:53 info admin.0 Repository received successfully. admin.0 2015-10-16 18:15:53 info admin.0 Repository received successfully. raspberrypi 2015-10-16 18:15:53 warn host.raspberrypi warning: Following packages cannot be read: example host-raspberrypi 2015-10-16 18:15:45 info Update repository 'online' under 'https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json' inMem 2015-10-16 18:15:45 debug message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1445012145, from=system.adapter.admin.0, lc=1445012145 admin-0 2015-10-16 18:15:45 info received all objects admin-0 2015-10-16 18:15:44 info received all states admin-0 2015-10-16 18:15:41 info Use link 'http://localhost:8081' to configure. admin-0 2015-10-16 18:15:41 info http server listening on port 8081 admin-0 2015-10-16 18:15:41 info Request actual repository... admin-0 2015-10-16 18:15:41 info requesting all objects admin-0 2015-10-16 18:15:41 info requesting all states admin-0 2015-10-16 18:15:41 info starting. Version 0.6.1 in /opt/iobroker/node_modules/iobroker.admin hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.21282 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557388} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.21282 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557388 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.21281 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444967992} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.21281 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444967992 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.21280 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444885898} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.21280 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444885898 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.21279 {'val':0,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444968012} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.21279 val=0, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444968012 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.19446 {'val':'???','ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557388} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.19446 val=???, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557388 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.16439 {'val':90,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1445011200} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.16439 val=90, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1445011200 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.16438 {'val':20,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1445011200} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.16438 val=20, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1445011200 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.16437 {'val':20,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1445011200} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.16437 val=20, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1445011200 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.16436 {'val':20,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1445011200} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.16436 val=20, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1445011200 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.14999 {'val':0,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557388} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.14999 val=0, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557388 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.14881 {'val':5,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1445012100} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.14881 val=5, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1445012100 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.9396 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557388} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.9396 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557388 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.9395 {'val':-1,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557388} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.9395 val=-1, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557388 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.9394 {'val':'???','ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557388} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.9394 val=???, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557388 hm-rega-0 2015-10-16 18:15:36 debug stateChange hm-rega.0.9392 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444711040} inMem 2015-10-16 18:15:36 debug message hm-rega.0.* hm-rega.0.9392 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444711040 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.9110 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557388} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.9110 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557388 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.6149 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557388} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.6149 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557388 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.5254 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444846864} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.5254 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444846864 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.2172 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557388} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.2172 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557388 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.1905 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557542} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.1905 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557542 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.1233 {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':0} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.1233 val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=0 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.950 {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444939905} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.950 val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444939905 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.maintenance {'val':2,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1445012012} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.maintenance val=2, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1445012012 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.alarms {'val':0,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1444557401} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.alarms val=0, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1444557401 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.23497.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1442308494} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.23497.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1442308494 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.23235.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1442254850} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.23235.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1442254850 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.22529.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1441909447} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.22529.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1441909447 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.22440.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1441909088} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.22440.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1441909088 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.21323.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1441202120} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.21323.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1441202120 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.21311.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1441202120} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.21311.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1441202120 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.21283.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1441202120} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.21283.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1441202120 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.20264.Active {'val':false,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1441210996} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.20264.Active val=false, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1441210996 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.19394.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1440521102} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.19394.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1440521102 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.17910.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1440178888} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.17910.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1440178888 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.17610.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1440096696} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.17610.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1440096696 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.17444.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1440057602} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.17444.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1440057602 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.17422.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1440057273} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.17422.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1440057273 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.17113.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1439830911} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.17113.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1439830911 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.16440.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.16440.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.15531.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1442422030} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.15531.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1442422030 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.15520.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.15520.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.15509.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.15509.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.15025.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1440099848} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.15025.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1440099848 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.15000.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.15000.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.14882.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.14882.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.14570.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.14570.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.13636.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.13636.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.13556.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.13556.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.13509.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.13509.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.13319.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.13319.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.13279.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.13279.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.12721.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.12721.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.12218.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.12218.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.12091.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.12091.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.11630.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.11630.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.10341.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.10341.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.9864.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.9864.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.9684.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.9684.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.9418.Active {'val':true,'ack':true,'ts':1445012136,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.9418.Active val=true, ack=true, ts=1445012136, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.9099.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.9099.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.8883.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.8883.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.8242.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.8242.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.8228.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.8228.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.8018.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.8018.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.7628.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.7628.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug '41':[2,'2015-10-16 18:13:32']} hm-rega-0 2015-10-16 18:15:35 debug '40':[0,'2015-10-11 11:56:41'], hm-rega-0 2015-10-16 18:15:35 debug '21282':[false,'2015-10-11 11:56:28'], hm-rega-0 2015-10-16 18:15:35 debug '21281':[false,'2015-10-16 05:59:52'], hm-rega-0 2015-10-16 18:15:35 debug '1905':[false,'2015-10-11 11:59:02'], hm-rega-0 2015-10-16 18:15:35 debug '19446':['%3F%3F%3F','2015-10-11 11:56:28'], hm-rega-0 2015-10-16 18:15:35 debug '9396':[false,'2015-10-11 11:56:28'], hm-rega-0 2015-10-16 18:15:35 debug '14881':[5,'2015-10-16 18:15:00'], hm-rega-0 2015-10-16 18:15:35 debug '9110':[false,'2015-10-11 11:56:28'], hm-rega-0 2015-10-16 18:15:35 debug '5254':[false,'2015-10-14 20:21:04'], hm-rega-0 2015-10-16 18:15:35 debug '21279':[0,'2015-10-16 06:00:12'], hm-rega-0 2015-10-16 18:15:35 debug '21280':[false,'2015-10-15 07:11:38'], hm-rega-0 2015-10-16 18:15:35 debug '9395':[-1.000000,'2015-10-11 11:56:28'], hm-rega-0 2015-10-16 18:15:35 debug '9394':['%3F%3F%3F','2015-10-11 11:56:28'], hm-rega-0 2015-10-16 18:15:35 debug '6149':[false,'2015-10-11 11:56:28'], hm-rega-0 2015-10-16 18:15:35 debug '2172':[false,'2015-10-11 11:56:28'], hm-rega-0 2015-10-16 18:15:35 debug '9392':[false,'2015-10-13 06:37:20'], hm-rega-0 2015-10-16 18:15:35 debug '14999':[0,'2015-10-11 11:56:28'], hm-rega-0 2015-10-16 18:15:35 debug '16436':[20.000000,'2015-10-16 18:00:00'], hm-rega-0 2015-10-16 18:15:35 debug '16437':[20.000000,'2015-10-16 18:00:00'], hm-rega-0 2015-10-16 18:15:35 debug '16438':[20.000000,'2015-10-16 18:00:00'], hm-rega-0 2015-10-16 18:15:35 debug '16439':[90.000000,'2015-10-16 18:00:00'], hm-rega-0 2015-10-16 18:15:35 debug '950':[true,'2015-10-15 22:11:45'], hm-rega-0 2015-10-16 18:15:35 debug <-- {'1233':[false,'1970-01-01 01:00:00'], hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.7027.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.7027.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.6876.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.6876.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.6166.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.6166.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug --> !# polling.fn 1.2 !# !# Dieses Script gibt die Werte aller Systemvariablen als J hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.6075.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.6075.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.5503.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.5503.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.5279.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.5279.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.2189.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.2189.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.1964.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.1964.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.1906.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.1906.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 hm-rega-0 2015-10-16 18:15:35 debug stateChange hm-rega.0.1595.Active {'val':true,'ack':true,'ts':1445012135,'from':'system.adapter.hm-rega.0','lc':1435779720} inMem 2015-10-16 18:15:35 debug message hm-rega.0.* hm-rega.0.1595.Active val=true, ack=true, ts=1445012135, from=system.adapter.hm-rega.0, lc=1435779720 debug '13279':{'Name':'WZ_Wandtaster%205%2B6%20Rollade%20Sued','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}} debug '13319':{'Name':'WZ_Rolladen_Sued%20Astro','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 08:03:00'}, debug '13636':{'Name':'WZ_Rollade_Sued_alle%20hoch','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, debug '23497':{'Name':'Wecker%209%20Uhr%20Mo-Fr','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, debug '23235':{'Name':'Wecker%206%20Uhr%20Mo-Fr','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-15 06:00:00'}, debug '20264':{'Name':'Wanddisplay-DIS-WM55%20Taste%20unten%20Kanal%201','TypeName':'PROGRAM','PrgInfo':'', 'Active':false,'Timestamp':'1970-01-01 01:00:00'}, debug '9099':{'Name':'T%FCrklingel','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, debug '15025':{'Name':'Temperatur_19%20TastenFB_kurz','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, debug '17610':{'Name':'Temperatur_19%20TastenFB%20lang','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, debug '11630':{'Name':'Taster_WZ_Rollade_Loggia','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, debug '17910':{'Name':'Taster-Wanddisplay_Test','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, debug '12091':{'Name':'Taster%20WZ%20Loggia%20Rolladen%2034Prozent','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:57:02'}, debug '8242':{'Name':'Taste%2013%20Blumen%20gie%DFen%20l%F6schen','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, debug '14882':{'Name':'Tageszeitprogramm','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 18:15:00'}, debug '1906':{'Name':'Systemvariable%20Waschmaschine%20setzen','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:57:02'}, debug '5503':{'Name':'Systemvariable%20Sp%FClmaschine%20Gong%20%2B%20Anzeige','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-14 20:21:04'}, debug '5279':{'Name':'Systemvariable%20Sp%FClmasche%20setzen','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-14 20:19:04'}, debug '8018':{'Name':'Systemvariabele%20Waschmaschine%20Gong%20%2B%20Anzeige','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:59:02'}, debug '1964':{'Name':'Systemvariabele%20Waschmaschine%20Gong%20%2B%20Anzeige','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-11 11:59:02'}, debug '19394':{'Name':'Servicemelungen_LowBatterie','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-14 19:26:41'}, debug '15520':{'Name':'Schalter%20unten%20laden%20aus','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 07:04:49'}, debug '15509':{'Name':'Schalter%20oben%20laden','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 07:04:46'}, debug '12218':{'Name':'Rolladensteuerung_Zeit_Loggia','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'2015-10-16 00:00:00'}, debug '13509':{'Name':'Rolladen_WZ_Sued_35prozenz','TypeName':'PROGRAM','PrgInfo':'', 'Active':true,'Timestamp':'1970-01-01 01:00:00'}, !–----------------------------
update
Jetzt geht alles!
Hab noch mal dieses gemacht.
cd /opt/iobroker npm install iobroker.js-controller --production -
Morjens,
so nach ewigem rumprobieren, geht die Admin Seite wieder. Auf Vis komme ich nicht und habe folgenden Fehler im Log:
ioBroker 2015-10-17 00:10:43 error host.ioBroker instance system.adapter.javascript.0 terminated with code 8 (node.js: Cannot find module) host-ioBroker 2015-10-17 00:12:33 error instance system.adapter.javascript.0 terminated with code 8 (node.js: Cannot find module)Hat jemand eine Ahnung? Auf jeden Fall beschäftige ich mich vor dem nächsten Update mit dem Thema Backup auf´s NAS…
Dann empfehle ich dir das Verzeichnis
zu löschen und dann noch mal das aufrufen:
cd /opt/iobroker sudo npm cache clean sudo pgrep -f '^io.*' | sudo xargs kill -9 sudo npm install iobroker.js-controller sudo chmod 777 * -RDanach ausführen:
sudo node node_modules/iobroker.js-controller/controller.jsWas kommt? `
habe das o. g. ausgeführt…jetzt komme ich per ssh nicht mehr drauf..
meldung: Handshake failed
Und jetzt?
Gruss
/opt/iobroker/node_modules/iobroker.js-controller
Und jetzt?
Gruss `
Verstehst du was die beschriebene Befehle machen?Die haben mit ssh nichts zu tun. Schon Gerätrestart probiert?
nein das weiss ich nicht und hätte ich das bloss nicht gemacht!! scheisse wenn man nicht weiss was man einhackt in der konsole..
ich habe nach dem gegoogelt also weil meine adapterseite lange geladen hat und dann bin ich auf deinen Thread gestossen hier….
Geräteneustart bzw. raspi neustart habe ich gemacht...kein erfolg...bringt dann auch nix wenn ich per hdmi einen monitor anschliese und eine usb tastatur oder?
gebe mir doch einfach bitte Anweisung was ich noch machen kann um das system zu retten oder wieder auf den Raspi zu kommen.....danke
es kommt wenn ich mich pr putty verbinde Folgende Meldung: fatal Error - network error Software caused Connection abort
auch wenn das keine Hilfe ist: Der Raspi frisst ab und an SD-Karten, da diese nicht für den Dauereinsatz gedacht sind.
Das Problem hatte ich auch - dann kamen wilde Fehler, die keinen Sinn machten.
Leider gab es dafür keine vernünftige Lösung außer einer Neuinstallation.
Bis dann
Christof
