    4. Test Adapter zoneminder v0.3.x
    • coyote
      coyote Most Active @Meistertr last edited by
      @Meistertr hier das Log.
      Aber was soll ich sagen, Adapter ist jetzt grün und Objekte wurden angelegt.👍
      zoneminder.0	2019-10-25 22:50:43.430	debug	(14437) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["z
      zoneminder.0	2019-10-25 22:50:43.428	debug	(14437) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["z
      zoneminder.0	2019-10-25 22:50:43.412	debug	(14437) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam
      zoneminder.0	2019-10-25 22:50:43.409	debug	(14437) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],
      zoneminder.0	2019-10-25 22:50:43.403	debug	(14437) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],
      zoneminder.0	2019-10-25 22:50:43.390	debug	(14437) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-10-25 22:50:43.386	debug	(14437) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],
      zoneminder.0	2019-10-25 22:50:43.380	debug	(14437) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],
      zoneminder.0	2019-10-25 22:50:43.355	debug	(14437) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.
      zoneminder.0	2019-10-25 22:50:43.350	debug	(14437) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],
      zoneminder.0	2019-10-25 22:50:43.349	debug	(14437) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],
      zoneminder.0	2019-10-25 22:50:43.347	debug	(14437) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.
      zoneminder.0	2019-10-25 22:50:43.299	debug	(14437) REQUEST: Video_Options {"method":"GET","uri":"http://192.168.66.184/zm/index.php?mode=mp4&eid=594&view=view_video&null","headers":{"user-agent":"@nodeminder-api"}}
      zoneminder.0	2019-10-25 22:50:43.292	debug	(14437) REQUEST: Get data[object Object]
      zoneminder.0	2019-10-25 22:50:42.824	debug	(14437) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
      zoneminder.0	2019-10-25 22:50:42.823	debug	(14437) REQUEST: Post before object
      zoneminder.0	2019-10-25 22:50:42.823	debug	(14437) SetStates
      zoneminder.0	2019-10-25 22:50:41.155	debug	(14437) CAM_ids: ["zoneminder.0.cam_1","zoneminder.0.cam_2","zoneminder.0.cam_3","zoneminder.0.cam_4"]
      zoneminder.0	2019-10-25 22:50:41.148	debug	(14437) found states:_[["zoneminder.0.cam_4.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_4.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_4.zmEvent","Name","text","INIT"],["z
      zoneminder.0	2019-10-25 22:50:41.134	debug	(14437) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam
      zoneminder.0	2019-10-25 22:50:41.115	debug	(14437) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["z
      zoneminder.0	2019-10-25 22:50:41.114	debug	(14437) Monitor_3 o.Monitor_Status = [object Object]
      zoneminder.0	2019-10-25 22:50:41.114	debug	(14437) Monitor_3 o.Monitor = [object Object]
      zoneminder.0	2019-10-25 22:50:41.112	debug	(14437) found states:_[["zoneminder.0.cam_3.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_3.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_3.zmEvent","Name","text","INIT"],["z
      zoneminder.0	2019-10-25 22:50:41.109	debug	(14437) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-10-25 22:50:41.108	debug	(14437) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],
      zoneminder.0	2019-10-25 22:50:41.107	debug	(14437) Monitor_2 o.Monitor_Status = [object Object]
      zoneminder.0	2019-10-25 22:50:41.107	debug	(14437) Monitor_2 o.Monitor = [object Object]
      zoneminder.0	2019-10-25 22:50:41.098	debug	(14437) found states:_[["zoneminder.0.cam_2.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_2.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_2.zmEvent","Name","text","INIT"],["z
      zoneminder.0	2019-10-25 22:50:41.077	debug	(14437) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.
      zoneminder.0	2019-10-25 22:50:41.071	debug	(14437) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],
      zoneminder.0	2019-10-25 22:50:41.068	debug	(14437) Monitor_1 o.Monitor_Status = [object Object]
      zoneminder.0	2019-10-25 22:50:41.068	debug	(14437) Monitor_1 o.Monitor = [object Object]
      zoneminder.0	2019-10-25 22:50:41.059	debug	(14437) found states:_[["zoneminder.0.cam_1.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_1.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_1.zmEvent","Name","text","INIT"],["z
      zoneminder.0	2019-10-25 22:50:41.044	debug	(14437) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.
      zoneminder.0	2019-10-25 22:50:41.021	debug	(14437) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],
      zoneminder.0	2019-10-25 22:50:41.019	debug	(14437) Monitor_0 o.Monitor_Status = [object Object]
      zoneminder.0	2019-10-25 22:50:41.018	debug	(14437) Monitor_0 o.Monitor = [object Object]
      zoneminder.0	2019-10-25 22:50:40.552	debug	(14437) REQUEST: Get data[object Object]
      zoneminder.0	2019-10-25 22:50:40.518	debug	(14437) found states:_[["zoneminder.0.history.LastzmEvent","MonitorId","default_num","0"],["zoneminder.0.history.LastzmEvent","EventId","default_num","000"],["zoneminder.0.history.LastzmEvent","Name",
      zoneminder.0	2019-10-25 22:50:40.504	debug	(14437) [{"Monitor":{"Id":"1","Name":"Garage","ServerId":null,"StorageId":"1","Type":"Ffmpeg","Function":"Modect","Enabled":"1","LinkedMonitors":null,"Triggers":"","Device":"/dev/video0","Channel":"0"
      zoneminder.0	2019-10-25 22:50:40.502	debug	(14437) REQUEST: Get data[object Object]
      zoneminder.0	2019-10-25 22:50:39.738	debug	(14437) zmEventServer disabled
      zoneminder.0	2019-10-25 22:50:39.736	debug	(14437) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
      zoneminder.0	2019-10-25 22:50:39.736	debug	(14437) REQUEST: Post before object
      zoneminder.0	2019-10-25 22:50:39.735	debug	(14437) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
      zoneminder.0	2019-10-25 22:50:39.734	debug	(14437) REQUEST: Post before object
      zoneminder.0	2019-10-25 22:50:39.733	debug	(14437) Connected to Api
      zoneminder.0	2019-10-25 22:50:39.732	debug	(14437) AUTH: get cookies null
      zoneminder.0	2019-10-25 22:50:39.723	debug	(14437) REQUEST: Get data[object Object]
      zoneminder.0	2019-10-25 22:50:38.666	info	(14437) check user admin pw ioboker: true
      zoneminder.0	2019-10-25 22:50:38.023	info	(14437) undefined__testVariable___[object Object]
      zoneminder.0	2019-10-25 22:50:37.988	info	(14437) check group user admin group admin: false
      zoneminder.0	2019-10-25 22:50:37.804	debug	(14437) REQUEST: Options {"method":"POST","uri":"http://192.168.66.184/zm/api/host/login.json","body":"user=admin&pass=admin","headers":{"content-type":"application/x-www-form-urlencoded","content-len
      zoneminder.0	2019-10-25 22:50:37.802	debug	(14437) REQUEST: Post before object
      zoneminder.0	2019-10-25 22:50:37.801	debug	(14437) data: {"user":"admin","password":"admin","host":"http://192.168.66.184/zm","zmEvent":false}
      zoneminder.0	2019-10-25 22:50:37.692	info	(14437) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.zoneminder, node: v10.16.3
      Gibts irgendwo eine Anleitung von ZMEvent? Oder hast du es nach der ZMEvent Wiki Seite installiert?
        mikiline @Meistertr last edited by
        @Meistertr
        super das du dies versuchst zu integrieren daumenhoch
        ist beides bei mir angehakt und es nutzt den token, also die 3. möglichkeit wie von dir beschrieben
        mal sehen ob es klappt wenn es integriert ist. danke dir 😉
        Meistertr 1 Reply Last reply Reply Quote 0
        • Meistertr
          Meistertr Developer @mikiline last edited by
          @mikiline so ich hab jetzt alle 3 varianten drin aber scheinbar gibt es von der 1.30 bis 1.33 Probleme mit der API. ein endgültigen stand wird es erst mit der 1.34 geben die in naher Zukunft kommt.
          Probier mal ob es nun klappt. un schick mal einen log
            mikiline @Meistertr last edited by mikiline
            @Meistertr
            Guten Morgen, soeben versucht. Adapter wird zwar grün, jedoch kommen folgende Meldungen
            zoneminder.0	2019-10-27 08:02:06.521	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
            zoneminder.0	2019-10-27 08:02:06.510	debug	(12561) REQUEST: Options {"method":"GET","uri":"http://192.168.77.125/zm/api/monitors.json&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMTU5NzA2LCJleHAiOjE1NzIxNj
            zoneminder.0	2019-10-27 08:02:06.510	debug	(12561) REQUEST: Post before string
            zoneminder.0	2019-10-27 08:02:06.509	debug	(12561) SetStates
            zoneminder.0	2019-10-27 08:02:01.526	warn	(12561) No monitors found, please configure monitors in your zoneminder!
            zoneminder.0	2019-10-27 08:02:01.526	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
            zoneminder.0	2019-10-27 08:02:01.508	debug	(12561) REQUEST: Options {"method":"GET","uri":"http://192.168.77.125/zm/api/monitors.json&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMTU5NzA2LCJleHAiOjE1NzIxNj
            zoneminder.0	2019-10-27 08:02:01.508	debug	(12561) REQUEST: Post before string
            zoneminder.0	2019-10-27 08:02:01.508	debug	(12561) SetStates
            zoneminder.0	2019-10-27 08:01:56.521	warn	(12561) No monitors found, please configure monitors in your zoneminder!
            zoneminder.0	2019-10-27 08:01:56.521	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
            zoneminder.0	2019-10-27 08:01:56.509	debug	(12561) REQUEST: Options {"method":"GET","uri":"http://192.168.77.125/zm/api/monitors.json&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMTU5NzA2LCJleHAiOjE1NzIxNj
            zoneminder.0	2019-10-27 08:01:56.508	debug	(12561) REQUEST: Post before string
            zoneminder.0	2019-10-27 08:01:56.508	debug	(12561) SetStates
            zoneminder.0	2019-10-27 08:01:51.522	warn	(12561) No monitors found, please configure monitors in your zoneminder!
            zoneminder.0	2019-10-27 08:01:51.522	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
            zoneminder.0	2019-10-27 08:01:51.508	debug	(12561) REQUEST: Options {"method":"GET","uri":"http://192.168.77.125/zm/api/monitors.json&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMTU5NzA2LCJleHAiOjE1NzIxNj
            zoneminder.0	2019-10-27 08:01:51.508	debug	(12561) REQUEST: Post before string
            zoneminder.0	2019-10-27 08:01:51.508	debug	(12561) SetStates
            zoneminder.0	2019-10-27 08:01:46.753	debug	(12561) WEBSOCKET: {"status":"Success","reason":"","version":"4.4","type":"","event":"auth"}'
            zoneminder.0	2019-10-27 08:01:46.671	debug	(12561) WEBSOCKET Client Connected
            zoneminder.0	2019-10-27 08:01:46.666	warn	(12561) No monitors found, please configure monitors in your zoneminder!
            zoneminder.0	2019-10-27 08:01:46.665	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
            zoneminder.0	2019-10-27 08:01:46.662	warn	(12561) No monitors found, please configure monitors in your zoneminder!
            zoneminder.0	2019-10-27 08:01:46.662	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
            zoneminder.0	2019-10-27 08:01:46.647	debug	(12561) system.adapter.admin.0: logging true
            zoneminder.0	2019-10-27 08:01:45.860	debug	(12561) States connected to redis: 127.0.0.1:9000
            zoneminder.0	2019-10-27 08:01:45.810	debug	(12561) statesDB connected
            zoneminder.0	2019-10-27 08:01:45.802	debug	(12561) Redis States: Use Redis connection: 127.0.0.1:9000
            zoneminder.0	2019-10-27 08:01:45.801	debug	(12561) objectDB connected
            zoneminder.0	2019-10-27 08:01:45.796	debug	(12561) Objects connected to redis: 127.0.0.1:9001
            zoneminder.0	2019-10-27 08:01:45.744	debug	(12561) Redis Objects: Use Redis connection: 127.0.0.1:9001
            host.nuc-ubuntu	2019-10-27 08:01:45.078	info	instance system.adapter.zoneminder.0 started with pid 12561
            host.nuc-ubuntu	2019-10-27 08:01:42.700	info	instance system.adapter.zoneminder.0 terminated with code 156 (156)
            ich denke du solltest hier nicht deine Zeit "verschwenden" es scheint irgendwie nicht zu gehen und wir warten auf die 1.34
            Trotz allem herzlichen Dank für die Mühe. Falls etwas benötigt wird zum Testen, gerne melden
              Berchemer @Lenny.CB last edited by
              @Lenny-CB sagte in Test Adapter zoneminder v0.3.x:
              @Berchemer sagte in [Aufruf] Zoneminder 0.2.0 Testen:
              Habe nämlich alles Kameras mit je einem High- und einem Low-Monitor eingestellt. Low-Monitor ist nur zur Bewegungserkennung bei bestimmten Kameras und High-Monitor für die dazugehörige Aufnahme nach Bewegungserkennung.
              @Berchemer kannst Du das mal etwas näher ausführen? Besonders interessieren würde mich warum Du das so machst.
              Was ich bis dato an den Einstellungen verstanden habe, werden bei Bewegungserkennung Bilder aufgenommen. Bei mir ist es momentan so, dass sich auf den Bildern/Videos "Schlieren" bilden. Also es scheint als würde ein Schatten der Bewegung in die nächsten Frame´s gezogen. Kann man das mit deiner Methode umgehen?
              Deine Methode interpretiere ich so:
              Im LOW-Monitor ist ein CAM-Stream mit schmaler Bandbreite/Qualität, dieser erkennt die Bewegung.
              IM HIGH-Monitor ist ein CAM-Stream mit hoher Auflösung und unter "Linked Monitors" ist der LOW-Monitor eingetragen.
              Wenn der LOW-Monitor eine Bewegung erkennt, wird der HIGH-Monitor angetriggert und nimmt auf.
              Richtig?
              Ja Lenny-CB. So ist es gedacht und funktioniert auch soweit ganz gut, weil ich auch Videoaufnahmen mit Sound haben möchte, wenn ein Event stattfindet und die Kamera auch Audio unterstützt.
              Die LOW-Kamera nimmt den zweiten Stream der jeweiligen Kamera im Graustufenmodus und niedriger Auflösung zum Erkennen von Bewegung ind den definierten Zonen. Durch die Verknüpfung wird bei Bewegungserkennung der High-Monitor gestartet und nimmt die Szene im höheren ersten Stream der jeweiligen Kamera auf.
              Der Low-Monitor ist mit MOCORD konfiguriert und der High-Monitor mit NODECT.
              Somit brauche ich auch nur die Streams der HIGH-Monitore, die aufnehmen oder nur als MOTION eingestellt sind.
              Und jetzt muss ich mich mal mit dem zmeventmanager beschäftigen, weil ich ja auch in ioBroker erkennen möchte, ob gerade ein Monitor einen Alarm meldet oder nicht. Obwohl das, wie ich verstanden habe über die normale API mit (curl http://server/zm/api/monitors/alarm/id:1/command:status.json) und ausgelesen werden könnte, wie in der ZM-Doku unter https://zoneminder.readthedocs.io/en/stable/api.html#arm-disarm-monitors beschrieben.
              • Meistertr
                Meistertr Developer @Berchemer last edited by
                @Berchemer da hast du recht, das will ich auch noch einbauen , hier muss dann aber jede sekunde der wert aller monitore abgefragt werden. was etwas unwirtschaftlich ist. daher ist die lösung über zmevent besser.
                • Xsev
                  Xsev last edited by Xsev
                  Bei mir läuft der neue Adpter soweit sehr gut, abgesehen von den Events die werden bei mir nicht aktualisiert und bei gesetzdem Häkchen im Adpater bekomme ich folgende Fehlermeldung: ZM Version 1.32.2
                  oneminder.0	2019-10-27 21:09:45.251	error	(29387) WEBSOCKET: Error: Error: Client network socket disconnected before secure TLS connection was established
                  host.Homeserver	2019-10-27 21:09:45.250	error	States 192.168.13.100:46216 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                  zoneminder.0	2019-10-27 21:08:45.249	error	(29387) WEBSOCKET: Error: Error: Client network socket disconnected before secure TLS connection was established
                  host.Homeserver	2019-10-27 21:08:45.249	error	States 192.168.13.100:45482 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                  web.0	2019-10-27 21:08:27.723	info	(26815) <==Disconnect system.user.admin from ::ffff:192.168.13.165 vis.0
                  web.0	2019-10-27 21:08:27.722	info	(26815) <==Disconnect system.user.admin from ::ffff:192.168.13.165 flot
                  zoneminder.0	2019-10-27 21:07:45.246	error	(29387) WEBSOCKET: Error: Error: Client network socket disconnected before secure TLS connection was established
                  host.Homeserver	2019-10-27 21:07:45.246	error	States 192.168.13.100:44740 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                  zoneminder.0	2019-10-27 21:06:45.244	error	(29387) WEBSOCKET: Error: Error: Client network socket disconnected before secure TLS connection was established
                  host.Homeserver	2019-10-27 21:06:45.243	error	States 192.168.13.100:44004 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                  zoneminder.0	2019-10-27 21:05:45.242	error	(29387) WEBSOCKET: Error: Error: Client network socket disconnected before secure TLS connection was established
                  host.Homeserver	2019-10-27 21:05:45.239	error	States 192.168.13.100:43244 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                  Ansonsten Top Arbeit!!
                  P.s. Kann mir jemand sagen wie ich die Funktion (Motion, Modect etc.) zum Umschalten, einfach in Vis bekomme als Drop Down oder Button?
                    djsirius last edited by
                    @Meistertr
                    So, der Adapter ist auf 0.3.1 und der Login funktioniert!
                    Vielen Dank und super Arbeit! 👍
                      mikiline @djsirius last edited by
                      @djsirius
                      bei mir leider noch nicht....
                      zoneminder.0	2019-10-29 09:36:23.341	warn	(4286) No monitors found, please configure monitors in your zoneminder!
                      zoneminder.0	2019-10-29 09:36:23.341	debug	(4286) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fra
                      zoneminder.0	2019-10-29 09:36:23.330	debug	(4286) REQUEST: Options {"method":"GET","uri":"http://192.168.77.125/zm/api/monitors.json&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMzM4MTY4LCJleHAiOjE1NzIzNDE
                      zoneminder.0	2019-10-29 09:36:23.329	debug	(4286) REQUEST: Post before string
                      zoneminder.0	2019-10-29 09:36:23.329	debug	(4286) SetStates
                        djsirius last edited by djsirius
                        Mein Adapter geht zwar auf grün, aber das Log sagt mir auch "No monitors found, please configure monitors in your zoneminder!"
                        • Meistertr
                          @mikiline @djsirius aber die zmninja app geht ohne probleme?
                          coyote M 2 Replies Last reply Reply Quote 0
                          • coyote
                            @Meistertr habe heute endlich zmeventnotification installiert und im Adapter aktiviert.
                            Läuft scheinbar so wie es soll, Snap und Video URL werden angezeigt, History wird auch gefüllt.
                            Danke👍
                            Jetzt muss ich nur die Motion in Zoneminder mal noch anständig einstellen
                            Xsev 1 Reply Last reply Reply Quote 0
                              @Meistertr
                              ja, es läuft alles ohne Probleme. Nur die Anmeldung mit dem Adapter geht nicht.
                              Eventnotification mit ZMNinja und alles geht auch einwandfrei
                              • Xsev
                                Xsev @coyote last edited by
                                @coyote
                                Läuft bei dir die Event notification jetzt komplett? Was hast du installiert? Ich hab die nur im zoneminder laufen aber nix extra installiert? Mein Adapter ist grün, Cams sind auch am laufen aber Events bekomme ich nicht, nur oben erwähnte TLS Fehlermeldung im log. Hab ich was übersehen?
                                • coyote
                                  coyote Most Active @Xsev last edited by
                                  @Xsev ja, ich hab zmeventnotification gestern installiert nach Anleitung aber noch ohne hooks. Ohne dass du zmevent installiert hast kommt da auch nix an
                                  • Xsev
                                    Xsev @coyote last edited by Xsev
                                    @coyote Hättest du mal bitte einen Link zu der Anleitung. Also nicht das wir aneinander vorbei sprechen, in Zoneminder hab ich Zugriff auf die Events also die gespeicherten Videos. Ist das dann ein extra Modul im Broker oder im Zoneminder?
                                    Sorry für die blöde Frage aber steh grad a weng am Schlauch 🤗
                                      mikiline @Xsev last edited by mikiline
                                      @Xsev
                                      hier lang....
                                      Xsev 1 Reply Last reply Reply Quote 1
                                      • Xsev
                                        Xsev @mikiline last edited by
                                        @mikiline Ah alles klaro!! Danke! 👍
                                        • Meistertr
                                          Meistertr Developer last edited by Meistertr
                                          ok ich komme der sache näher... bitte nochmal von git testen alle versionen besonders die mit api 2.0
                                            djsirius @Meistertr last edited by djsirius
                                            31.7k
                                            79.8k
                                            camera motion zoneminder
                                            23
                                            206
                                            24400
