    2. English
    3. Scripting / Logic
    5. ASTRO function. Does not work again
    • iomountain
      iomountain last edited by
      mine works:
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenmittag
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenuntergang Anfang
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Abenddämmerung
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Abenddämmerung
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nacht
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nadir
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nachtende
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Morgendämmerung
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Morgendämmerung
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang ende
      javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour Ende
      my Versions of Software:
      Node.js v10.16.3
      NPM 6.9.0
        ap2017 @iomountain last edited by
        @iomountain I am getting this error while saving your script:
        10/27/2019, 10:30:21 PM.531 [error]: javascript.0 (18920) script.js.ASTRO compile failed:
        at script.js.ASTRO:1
          @iomountain Actually, here is log after starting your script:
          2019-10-27 22:35:16.197 - info: javascript.0 (18920) Stop script script.js.ASTRO
          2019-10-27 22:35:20.358 - info: javascript.0 (18920) Start javascript script.js.ASTRO
          2019-10-27 22:35:20.358 - error: javascript.0 (18920) script.js.ASTRO compile failed:
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) ^
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) SyntaxError: Unexpected token <
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at new Script (vm.js:83:7)
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at Object.createScript (vm.js:277:10)
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:961:28)
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1184:37)
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1237:17)
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:828:17)
          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:433:21)
          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at process._tickCallback (internal/process/next_tick.js:68:7)
            @iomountain My system:
            Script Engine 4.3.1
            Node.js 10.16.3
            NPM 6.9.0
            • iomountain
              My script is a Blockly:
                @iomountain Thank you, will enter and start it tonight
                  ap2017 @ap2017 last edited by ap2017
                  @ap2017 Please see log attached, ASTRO does not work. Server was restarted after scrip creation yesterday evening. Currently my script adapter configured for System ASTRO Settings, shows my street on the screen. I am wondering if possible to debug how system sees my location.
                  Tonight I will change Script Adapter ASTRO location to Germany and run same script over night.
                  10-29-19.txt
                  My script:
                  • iomountain
                    you can check the times at https://www.suncalc.org if you can get them.
                      ap2017 @iomountain last edited by ap2017
                      @iomountain I mean is there a way to check how ioBroker see my location? Maybe ASTRO gets screwed up because location is screwed up.
                      • iomountain
                        iomountain last edited by iomountain
                        I am not sure, but i think what astro uses is only this:
                        Is the Date and Time of your Operating System set right?
                        A 2 Replies Last reply Reply Quote 0
                          @iomountain Here is the log with location in adapter ASTRO set to Germany. ASTRO seems to be working fine. As you can see, script reports ALL ASTRO events, while when my location was set to US it reported only few and then died.
                          10-30-19 log.txt
                            @iomountain In all my tests location in Overview Settings set to my address, see picture. Not sure what you mean by Date and Time
                            iomountain 1 Reply Last reply Reply Quote 0
                            • iomountain
                              iomountain @ap2017 last edited by
                              @ap2017 sagte in ASTRO function:
                              i use timedatectl on the command line of iobroker host to see all is set correct.
                              • iomountain
                                If you config:
                                you also will find Astro Settings for your location.
                                  @iomountain said in ASTRO function:
                                  timedatectl
                                  Here is my time and date, all good:
                                    @iomountain In adapter config I set location to Germany to make ASTRO work. So, why does it works for Germany but does not work for my location in US?
                                    • iomountain
                                      I set my location to:
                                      restartet the Host.
                                      Run this Blockly:
                                       <block type="create" id="v72H-N1#%w_zseA#CMc" x="-212" y="-38">
                                         <field name="NAME">01-Nachtende</field>
                                           <block type="create" id="@kYi)AXak/ydmJCF!oo]">
                                             <field name="NAME">02-Morgendämmerung</field>
                                               <block type="create" id=";T8PP:ZCKeM4+U5?yi">
                                                 <field name="NAME">03-Sonnenaufgang</field>
                                                   <block type="create" id="gIfB:POQ4@(+!BTUapf">
                                                     <field name="NAME">04-Sonneneaufgang_Ende</field>
                                                       <block type="create" id="MFJk^e%f2^,QG[vUK4ee">
                                                         <field name="NAME">05-Golden_Houer_Ende</field>
                                                           <block type="create" id="hO7B(a7I~WK~vu8.7gDH">
                                                             <field name="NAME">06-Mittag</field>
                                                               <block type="create" id="eYe;t8x=FwBT4B,.|k.">
        <field name="NAME">07-Golden_Houer</field>
        <block type="create" id="tVROR/kUT3MINh%SOcdY">
        <field name="NAME">08-Sonnenuntergang_Anfang</field>
        <block type="create" id="kCb|+j}(0FzG/abd,q1">
        <field name="NAME">09-Sonnenuntergang</field>
        <block type="create" id="4UBzNj{JG:saTpO/G">
        <field name="NAME">10-Abenddämmerung</field>
        <block type="create" id="%kf8::E|Nt2icPYM.aB">
        <field name="NAME">11-Nacht</field>
                                           <block type="on_ext" id="CJC}fNA0]pCZXm3|IQhw">
                                             <value name="OID0">
                                               <shadow type="field_oid" id="~WnQKdX*p;3`gh]~Gv|}">
                                               <block type="field_oid" id="sLj^7q(fyKCJ@uKYgne@">
                                                 <field name="oid">javascript.0.Datenpunkte_own.Alarm.Alarm_AUS</field>
                                               <block type="debug" id="^Q)xU7M#5MVip9{Y2$hP">
                                                 <value name="TEXT">
                                                   <shadow type="text" id="%kcngJ7d=5*$asYlS~T|">
                                                     <field name="TEXT">03_Astro test start</field>
                                                   <block type="update" id="QIMsUa0@3?Vo;jj}r-U">
                                                     <field name="OID">javascript.0.01-Nachtende</field>
                                                       <block type="convert_from_date" id="^E3;~IY|ubg5}Cw9eYrO">
                                                         <mutation format="false" language="false"></mutation>
                                                         <field name="OPTION">hh:mm:ss</field>
                                                           <block type="time_astro" id="J0d,%PB7t8lb@8mXXXZ(">
                                                             <field name="TYPE">nightEnd</field>
                                                             <field name="OFFSET">0</field>
                                                       <block type="update" id="HB^8MQ(4ds+W5/u^OW4m">
                                                         <field name="OID">javascript.0.02-Morgendämmerung</field>
                                                           <block type="convert_from_date" id="oN=Uv}fYcHBCDPHtpXiw">
                                                               <block type="time_astro" id=":/y;e5awTDC:Cev;TUCS">
        <field name="TYPE">dawn</field>
                                                           <block type="update" id="+A7|YpLw]g_!(9]PC@UH">
                                                             <field name="OID">javascript.0.03-Sonnenaufgang</field>
                                                               <block type="convert_from_date" id="AMyc:3Tp9XP+4kq(nv-">
        <block type="time_astro" id=",4bKmH_J8szFEb.4u{OB">
        <field name="TYPE">sunrise</field>
                                                               <block type="update" id="DwtR_scz+f42pEJ/sKn?">
        <field name="OID">javascript.0.04-Sonneneaufgang_Ende</field>
        <block type="convert_from_date" id="a~M9OAt|LRQe5:d]~}H?">
        <block type="time_astro" id="7/scA1O-iX|.x-iB_~X3">
        <field name="TYPE">sunriseEnd</field>
        <block type="update" id="F.Y:ABQw?pppVIMuzXC4">
        <field name="OID">javascript.0.05-Golden_Houer_Ende</field>
        <block type="convert_from_date" id="jgDe(t)05^f2gQyGIaI6">
        <block type="time_astro" id="]qS[Z+Pab*WUXun969T">
        <field name="TYPE">goldenHourEnd</field>
        <block type="update" id="FjU7x+vB-{|nz?Ntgi]B">
        <field name="OID">javascript.0.06-Mittag</field>
        <block type="convert_from_date" id="Ewd,fX4o;ftqhEAKr)^">
        <block type="time_astro" id="}2iN_uE[d~xeJMc]9~%p">
        <field name="TYPE">solarNoon</field>
        <block type="update" id="(slH?vH:Tx73fJ(J2HY]">
        <field name="OID">javascript.0.07-Golden_Houer</field>
        <block type="convert_from_date" id="kh1//%:x4My;~kFU,E^">
        <block type="time_astro" id="~MgPI%%B44O6EzrHu._C">
        <field name="TYPE">goldenHour</field>
        <block type="update" id="g|Q7g?g_fO6AjzFr(le">
        <field name="OID">javascript.0.08-Sonnenuntergang_Anfang</field>
        <block type="convert_from_date" id="r6N{VKoWDb6,=S=QyNF">
        <block type="time_astro" id="!nNaC0sNkzDc_CZkch6">
        <field name="TYPE">sunsetStart</field>
        <block type="update" id="5k::E!c_Nzjkf_4MU}_U">
        <field name="OID">javascript.0.09-Sonnenuntergang</field>
        <block type="convert_from_date" id=",z]tcWXKDj7^syvxRkU[">
        <block type="time_astro" id="e.#C/a~nk+lc9h!VRKIG">
        <field name="TYPE">sunset</field>
        <block type="update" id="okk0X1l~(0(nUW+Re46b">
        <field name="OID">javascript.0.10-Abenddämmerung</field>
        <block type="convert_from_date" id="jT6:rKIF[@`bgdN2Ei+R">
        <block type="time_astro" id="CeiV[rNfs^|Wwo/^8]}L">
        <field name="TYPE">dusk</field>
        <block type="update" id="y3QMbYJ8biR5l7@~Vd92">
        <field name="OID">javascript.0.11-Nacht</field>
        <block type="convert_from_date" id="5z?E1xsLp;YRIJ6YIaB!">
        <block type="time_astro" id="Y[SLp]Z~a7!a0aht:]j?">
        <field name="TYPE">night</field>
                                      and got this
                                      seems OK for your location.
                                      What else could I check?
                                        @iomountain Please run with both system ASTRO and adapter ASTRO set to my location. Thank you.
                                        • iomountain
                                          I set the location to:
                                          ssh on HOST sudo reboot -h now
                                          Run this Blockly:
        <block type="create" id="m8=S(!$%YPfP56~qYN-V">
        <field name="NAME">12-Nadir</field>
                                                 <value name="OID0">
                                                     <value name="TEXT">
        <block type="update" id="r4Pp!x8AYRH2ByxfJ-uj">
        <field name="OID">javascript.0.12-Nadir</field>
        <block type="convert_from_date" id="70t2I`G4:U{os`6!_.!i">
        <block type="time_astro" id="s:0TbVo8LNISj)?5m=fr">
        <field name="TYPE">nadir</field>
                                          got this:
                                          javascript was set to:
                                          A 3 Replies Last reply Reply Quote 1
                                            @iomountain Thanks! I will try again on new X64 computer with freshly loaded software.
                                            blockly
                                            7592
