    4. Test Adaper Tado v0.1.x
      Stormbringer @Dutchman last edited by
      @Dutchman Modus Auto und Manuell 😉 Dachte das kommt noch? Die API mûsste es eigentlich hergeben, übern HAM Adapter gehts
        Hohenbostler last edited by
        Hallo
        ich habe auch eine dauerhafte Fehlermeldung.
        tado.0	2019-10-28 21:56:42.012	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:55:38.381	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:54:34.731	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:53:31.114	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:52:27.454	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:51:23.868	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:50:20.048	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:49:16.463	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:48:12.841	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:47:09.272	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:46:05.656	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:45:01.908	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:45:01.885	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:45:01.867	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        tado.0	2019-10-28 21:45:01.795	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
        • CKMartens
          CKMartens last edited by
          Nachdem ein Thermostat aus- und wieder eingeschaltet wurde, wird ja die vorher eingestellte Temperatur wieder übernommen. Ist dies auch mit dem Modus möglich?
          Beispiel:
          Meine Thermostate laufen im Auto-Modus um die Away-Funktion von tado zu verwenden.
          Wenn ein Fenster im Raum aufgemacht wird zum lüften, schalte ich per Skript das Thermostat aus:
          Dabei schaltet tado natürlich auf den Modus "Manual"
          Wenn das Fenster wieder zu gemacht wird, wird das Thermostat wieder eingeschaltet. Der Modus bleibt aber weiterhin auf "Manual", was auch dazu führt, das die Away-Temperatur übersteuert wird.
          Als Workaround setze ich, nachdem das Thermostat wieder eingeschaltet wurde, den State von clearZoneOverlay auf true.
          Könnte der Adapter automatisch wierder den Modus einstellen der vorher eingestellt war? Also Auto wieder auf Auto und Manual wieder aus Manual.
          Danke.
            Stormbringer @CKMartens last edited by
            @CKMartens Das er nach ausschalten, wieder auf die ursprünglich gesetzten Modus (und bei manuell Temperatur) stellt fände ich auch sehr praktisch.
            • Dutchman
              Dutchman Developer Most Active Administrators @Stormbringer last edited by
              @Stormbringer sagte in Test Adaper Tado v0.1.x:
              kommt, diese Woche bissl schwer mit zeit 😕
                Coffeelover last edited by
                Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 4469
                @CKMartens: Cool - danke für deinen Hinweis zum Workaround.
                  @Dutchman Danke Perfekt, kein Stress. Hauptsache es kommt irgendwann 😉 Bis dahin läuft der HAM ja 😉
                    Hohenbostler last edited by Hohenbostler
                    Guten Morgen,
                    passend zu Tado adapter habe ich mir alle für mich wichten Funktionen von der Tado V3+ nachgebaut.
                    Beim Tado ditrekt stört mich das die Fenster offen erkennung nicht wirklich klappt und ich für den Away Modus zahlen muss. Ich stelle es hier gerne zur Verfügung muss aber dazu sagen das ich kein Fachmann bin aber es tut was es soll. Alles geht über einzelne selbst angelegte Datenpunkte Datenpunkte.PNG
                    Heizungssteuerung.zip
                    Ich hoffe damit kann evtl jemand was anfangen.[Heizungssteuerung.zip]
                    Hier ein Update >>>> Heizungssteuerung.zip
                    C Dutchman 2 Replies Last reply Reply Quote 0
                      Coffeelover @Hohenbostler last edited by
                      @Hohenbostler super Sache. Wie steuert dein Adapter denn jetzt? Heizphasen und dazu aus wenn Fenster auf oder away? Woher triggerst du den away Status?
                        Hohenbostler @Coffeelover last edited by
                        @Coffeelover sagte in Test Adaper Tado v0.1.x:
                        Naja away -> Sobald meine Frau und ich aus dem Haus sind steuer ich den Datenpunkt away. Siehe script..
                        Fenster auf werden auch Datenpunkte geschrieben -> Getriggert von Xiaomi Fenster sensoren. Die reagieren ja wirklich wenn die Fenster auf sind.
                        Naja der rest ist in den scripten. 😉
                        • Dutchman
                          Dutchman Developer Most Active Administrators @Hohenbostler last edited by Dutchman
                          @Hohenbostler sagte in Test Adaper Tado v0.1.x:
                          hmm, das ist aber ein sehr interessanter Ansatz den diese Funktionen könnte man auch über den adapter definieren.
                          Ich hab nur n bissl angst das Tado irgendwann Sachen blockieren wird da die ja jetzt Geld fragen und wir es so steuern können.... hmm
                          ich denke mal sowas sollte in der community bleiben und per additionele scripts ermöglicht werden, nicht das die wegen sowas irgendwas die API fuer den adapter komplett sperren das währe mist.
                          S H 2 Replies Last reply Reply Quote 0
                            senger1985 @Dutchman last edited by
                            @Dutchman da bin ich deiner Meinung.
                              Hohenbostler @Dutchman last edited by
                              @Dutchman sagte in Test Adaper Tado v0.1.x:
                              Soll ich den Post wieder löschen?
                              • Dutchman
                                noe ... sensur soweit gehts noch 😛 wie gesagt selber machen kan ja jeder aber ich finde es zu gefaehrlich dedicated in den adapter ein zu bauen.
                                dEn damit bauen ich ihre bezahlte version nach und ich möchten niemanden verärgern.
                                  (2881) Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 4469
                                  S R 2 Replies Last reply Reply Quote 0
                                    senger1985 @Coffeelover last edited by
                                    @Coffeelover wir sind dran.
                                    Habe bitte noch etwas Geduld.
                                      Überhaupt keine Eile - ich dachte nur es würde euch helfen, wenn ich das hier poste...
                                      Wenn nicht, lasse ich das auch gerne bleiben.
                                        @Coffeelover gar kein Problem.
                                        Gut wäre es, wenn du auf der Github-Seite, zum Adapter ein Issue eröffnest.
                                          Coffeelover @senger1985 last edited by
                                          @senger1985 Würde ich auch - aber ich weiß nicht, was das Problem dahinter ist. Einfach: "Fehlermeldungen im Log"?
                                            @Coffeelover so in etwa.
                                            "Fehlermeldung, bei Installation"
                                            "Bei der Installation von Version xyz kommt folgende Fehlermeldung:
                                            (hier dann den Screenshot einfügen.)
                                            Nur so als Beispiel.
                                            31.7k
                                            79.9k
                                            adapter tado testing team
                                            62
                                            868
                                            198338
