    4. Test Adapter enigma2 v1.2.x
    • Elektroniker86
      Elektroniker86 last edited by
      Das habe ich schon alles probiert.
      Eben nochmal:
      host.ioBroker-Tinker	2019-10-24 23:47:26.418	info	Restart adapter system.adapter.enigma2.0 because enabled
      host.ioBroker-Tinker	2019-10-24 23:47:26.418	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
      host.ioBroker-Tinker	2019-10-24 23:47:26.418	error	Caught by controller[0]: at SAXParser.write (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:1436:13)
      host.ioBroker-Tinker	2019-10-24 23:47:26.418	error	Caught by controller[0]: at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:871:9)
      host.ioBroker-Tinker	2019-10-24 23:47:26.418	error	Caught by controller[0]: at strictFail (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:677:7)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at error (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:653:5)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at emit (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:624:35)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at SAXParser.onerror (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/xml2js/lib/parser.js:125:26)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at Parser.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/xml2js/lib/parser.js:310:18)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:320:7
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:382:46)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: TypeError: Cannot read property 'e2simplexmlresult' of undefined
      enigma2.0	2019-10-24 23:47:26.364	error	uncaught exception: Cannot read property 'e2simplexmlresult' of undefined
      Matten Matten 1 Reply Last reply Reply Quote 0
      • Matten Matten
        Matten Matten @Elektroniker86 last edited by Matten Matten
        @Elektroniker86
        Du hast die http authentifizierung aktiviert, dann musst du auch Benutzer und Passwort eingeben!
        • Elektroniker86
          Ja, das weiss ich aber dort habe ich kein Ben. u. Passwort drin.
          Dafür hab ich den Fehler gefunden.
          Und zwar, sobald ich den Schalter "Token-basierte Sicherheit" setze, bricht die Verbindung zu ioBroker ab.
          • Matten Matten
            @Elektroniker86
            Ja das ist richtig das muss ausgeschaltet werden.
            Im nächsten Update kommen solche Infos mit in die config Maske, es kommt doch relativ oft vor das die Leute das aktiviert haben.
            Matten Matten
            • Elektroniker86
              Ja, das wäre definitiv sinnvoll.
              Trotzdem vielen lieben Dank für den Support.
              War ja zum Glück nur falscher Alarm 😉
                el_malto @Elektroniker86 last edited by
                @Elektroniker86
                Das Problem wirde um Beitrag #12 schon geschildert und die Lösing steht auch ein paar Beiträge weiter unten.
                Aber hast die Lösung ja nun auch schon gefunden.
                  plc last edited by
                  ich habe versucht über den Link Engma Adapter zu installieren, klappt leider nicht.
                  Ich habe aus dem Log rauskopiert. Vielen Dank.
                  Log.txt
                  • Matten Matten
                    Matten Matten @plc last edited by
                    @plc sagte in Test Adapter enigma2 v1.2.x:
                    Log.txt
                    Hat doch alles geklappt. Jetzt musst du nur eine Instanz hinzufügen
                      plc @Matten Matten last edited by
                      @Matten-Matten
                      nach der Installation sieht man kein Einigma 2 unter Instanzen. Wenn dies manuel hinzugefügt werden soll, wie mache ich das?
                      J Matten Matten 2 Replies Last reply Reply Quote 0
                        Jan1 @plc last edited by
                        @plc
                        auf das + beim Adapter klicken
                        • Matten Matten
                          @Matten-Matten
                          Dann
                            plc last edited by
                            Danke euch. Ich habe installiert und konfiguriert. Wenn die Box VU+ an ist, sehe unter Objekten Informationen zum laufenden Kanal, Name Lautstärke usw. Aber ich kann nichts steuern. Zum Beispiel unter enigma2.0->enigma2->Volume ist ein Wert 30%. Unter Einstellungen zu diesem Parameter habe ich die Rechte auf Lesen und Schreiben gesetzt.
                            Trotzdem wenn ich ein Wert Manuel ändere und bestätige, erscheint der neue Wert kurz als grün und geht dann wieder auf den uhrsprünglichen Wert zurück.
                            Dann unter welchen Parametern kann ich die Kanäle schalten?
                            • dslraser
                              dslraser Forum Testing Most Active @plc last edited by dslraser
                              enigma2.0->enigma2
                              das ist die Anzeige, gehe mal auf command
                                plc @dslraser last edited by
                                @dslraser
                                command kann ich nicht aufklappen, ist leer. Oder muss ich dort manuel Attribute anlegen?
                                dslraser Matten Matten 2 Replies Last reply Reply Quote 0
                                • dslraser
                                  @dslraser
                                  hast Du mal ganz oben den Objektbaum neu erstellen lassen oder das Browserfenster mal aktualisiert ?
                                  • Matten Matten
                                    @dslraser
                                    Geh Mal auf aktualisieren oben links oder lade die Seite erneut
                                    • dslraser
                                      dslraser Forum Testing Most Active @Matten Matten last edited by
                                      @Matten-Matten 😊 Zeitgleich😊
                                      • Matten Matten
                                        Matten Matten @dslraser last edited by
                                        @dslraser 👊 🤷‍♂️
                                          plc last edited by
                                          👍 😊 funktioniert! Fast wie bei Windows ab und zu Aktualisieren, evtl. Neustart!
                                          • Matten Matten
                                            Matten Matten @plc last edited by Matten Matten
                                            Die schreib und Lesezugriffe sind bei allen states so wie sie auftauchen beabsichtigt. Wenn ein state nur ein read besitzt wird auch nur was ausgegeben.
                                            Wenn du bspw die Lautstärke aktuell sehen möchtest und diesen selben auch ändern, dann solltest du in der config des Adapters die alexa/ yahka Funktion aktivieren. Dann taucht eine weitere Objekt Struktur auf. Dort hast du eine Lautstärke Ausgabe und kannst gleichzeitig den Wert ändern.
                                            Matten Matten
                                            adapter enigma2
                                            71
                                            640
                                            141027
