Problem mit upnp Adapter
! host.Iobroker 2018-09-13 23:45:56.296 error instance system.adapter.upnp.0 terminated with code 0 (OK)
! Caught 2018-09-13 23:45:56.295 error by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
! Caught 2018-09-13 23:45:56.295 error by controller[0]: at WebSocket.emit (events.js:214:7)
! Caught 2018-09-13 23:45:56.295 error by controller[0]: at emitTwo (events.js:126:13)
! Caught 2018-09-13 23:45:56.295 error by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
! Caught 2018-09-13 23:45:56.295 error by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
! Caught 2018-09-13 23:45:56.295 error by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
! Caught 2018-09-13 23:45:56.295 error by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
! Caught 2018-09-13 23:45:56.294 error by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
! Caught 2018-09-13 23:45:56.294 error by controller[0]: at WS. <anonymous>(/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
! Caught 2018-09-13 23:45:56.294 error by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
! Caught 2018-09-13 23:45:56.294 error by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
! Caught 2018-09-13 23:45:56.294 error by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
! Caught 2018-09-13 23:45:56.294 error by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
! Caught 2018-09-13 23:45:56.294 error by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
! Caught 2018-09-13 23:45:56.293 error by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
! Caught 2018-09-13 23:45:56.293 error by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
! Caught 2018-09-13 23:45:56.293 error by controller[0]: RangeError: Maximum call stack size exceeded
! upnp.0 2018-09-13 23:45:56.111 debug response
! upnp.0 2018-09-13 23:45:56.109 debug response
! upnp.0 2018-09-13 23:45:56.106 debug response
! upnp.0 2018-09-13 23:45:56.103 debug response
! upnp.0 2018-09-13 23:45:56.099 debug response
! upnp.0 2018-09-13 23:45:56.078 info cleaned everything up…
! upnp.0 2018-09-13 23:45:56.077 info Alive and sid states cleared
! upnp.0 2018-09-13 23:45:56.072 error at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
! upnp.0 2018-09-13 23:45:56.072 error at WebSocket.emit (events.js:214:7)
! upnp.0 2018-09-13 23:45:56.072 error at emitTwo (events.js:126:13)
! upnp.0 2018-09-13 23:45:56.072 error at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
! upnp.0 2018-09-13 23:45:56.072 error at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
! upnp.0 2018-09-13 23:45:56.072 error at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
! upnp.0 2018-09-13 23:45:56.072 error at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
! upnp.0 2018-09-13 23:45:56.072 error at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
! upnp.0 2018-09-13 23:45:56.072 error at WS. <anonymous>(/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
! upnp.0 2018-09-13 23:45:56.072 error at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
! upnp.0 2018-09-13 23:45:56.072 error at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
! upnp.0 2018-09-13 23:45:56.072 error at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
! upnp.0 2018-09-13 23:45:56.072 error at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
! upnp.0 2018-09-13 23:45:56.072 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
! upnp.0 2018-09-13 23:45:56.072 error at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
! upnp.0 2018-09-13 23:45:56.072 error at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
! upnp.0 2018-09-13 23:45:56.072 error RangeError: Maximum call stack size exceeded
! upnp.0 2018-09-13 23:45:56.072 error uncaught exception: Maximum call stack size exceeded</anonymous></anonymous></anonymous></anonymous> -
Der Fehler "maximum call stack size" ist die Folge von vielen Antworten und dagegen kann ich nicht viel machen.
Was manchmal funktioniert ist Adapter stoppen und wieder Starten.
Um das zu beheben muss ein erheblicher Teil des Adapters umgeschrieben werden.
Gesendet von meinem m8 mit Tapatalk
Das an und aus schalten hilft leider auch nicht wirklich
Deaktiviere mal in den Einstellungen "Verwende einfache Media Player-Objekte" und "Automatische Erkennung neuer Geräte".
Hab ich auch schon…alle Varianten durch.
Neue Geräte hab ich dann sowieso ausgeschalten. Da ständig Meldung von skyQ Receiver kam.
@crunchip Wie hast du das Problem denn gelöst? Bei mir läuft er nämlich auch nicht.
@Uli977 V1.015 läuft bei mir
@crunchip Wovon V1.015? Für UPNP gibt es doch nur V1.0.11
@Uli977 im latest
@crunchip Wo stelle ich das denn gerade nochmal ein?
@Uli977 is jetzt nicht dein ernst?
Oben auf deinen Schraubenschlüssel -
@crunchip ich habs mittlerweile gefunden. Nutzt du immer latest?
By the way... hab auch latest umgestellt und es gab nur V1.0.14
@crunchip und V1.0.14 macht auch das
@Uli977 dann hast du den Falschen, gibt mittlerweile einen community Adapter
@Uli977 ja in der Regel, bei dem ein oder anderen Adapter warte ich hin und wieder ab, bis ich ein update anstoße, dazu muss man halt fleißig im Forum mitlesen, gibt ja mehrere Gründe, warum und weshalb man ein Update manchmal ausserhalb der Reihe macht.
@crunchip Danke! Wie bekomme ich den installiert?
@crunchip Bedankt!
@crunchip läuft aber auch nicht.... aber ist jetzt egal....
@Uli977 du musst alle Geräte mal löschen, dann alle drei haken anklicken, ne weile warten bis alle Geräte gefunden wurden. Danach Haken, bei Automatische Erkennung wegmachen. Sollten Geräte, die nicht gebraucht/nicht funktionieren im Objektverzeichnis stehen, kannst du diese löschen, so das nur die, welche du benötigst gelistet werden.
