    5. {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    SOLVED {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    • Uli977
      Uli977 last edited by
      Det klingt ja alles total einfach für eine Anfänger wie mich 🙂
      Werde ich mal rangehen....
      • dslraser
        dslraser Forum Testing Most Active @Uli977 last edited by dslraser
        @Uli977
        oder so...
         <variables>
           <variable type="" id="@!_^k9^zFWondd-=a;yB">erstes_wort</variable>
           <variable type="" id="OGOEqOh/EzI.f(,K^lb.">letztes_wort</variable>
         </variables>
         <block type="on_ext" id="MZX#q{Gs.k*hPSsJ9cKU" x="63" y="137">
           <value name="OID0">
             <shadow type="field_oid" id="Iv~|tQUnQir?Y:KkU?E4">
               <field name="oid">alexa2.0.History.summary</field>
             <block type="variables_set" id="7;U{Id?fayG4D/9zacn:">
               <field name="VAR" id="@!_^k9^zFWondd-=a;yB" variabletype="">erstes_wort</field>
                 <block type="text_indexOf" id="vu;@JqZ82JhLJ[stQiSM">
                   <field name="END">FIRST</field>
                     <block type="on_source" id="_J|$!h@a#CsIiO`({ebU">
                   <value name="FIND">
                     <shadow type="text" id="u]tclL!.B1zr1L+;EiRO">
                       <field name="TEXT">abc</field>
                     <block type="text" id="tH+g7qq:p]jw.fWaQfDz">
                       <field name="TEXT">spiele</field>
                 <block type="variables_set" id="!^uRN)9I3JiLr9d4~}SJ">
                   <field name="VAR" id="OGOEqOh/EzI.f(,K^lb." variabletype="">letztes_wort</field>
                     <block type="text_indexOf" id="JbIL2yFac?i*^Q2WTg|F">
                         <block type="on_source" id="Gvg2D-bOcwq5upLm76TR">
                       <value name="FIND">
                         <block type="text" id="1]2I2PG:.3LKq!TKaRwq">
                           <field name="TEXT">wohnzimmer</field>
                     <block type="controls_if" id="DLE4zW;!}2)dWCZraCs5">
                         <block type="logic_operation" id="Jv+_Dj1(/:vNV]F7Sp)~">
                           <field name="OP">AND</field>
                             <block type="variables_get" id=":8Sky#sE)OaVL^`ki?YC">
                             <block type="variables_get" id="p9:-dL%0+Dw!sElR15w+">
                         <block type="control" id="3X*:XR4h7~R|Ed|,n/tM">
                           <mutation delay_input="true"></mutation>
                           <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Bluetooth.00:05:CD:FE:7C:8D.connected</field>
                           <field name="DELAY_MS">3</field>
                             <block type="logic_boolean" id="P)c3)R|X@.HJ6|ot;~h^">
             <block type="on_ext" id="Np`X%6sixOMQ%rLG8}f?">
               <value name="OID0">
                 <shadow type="field_oid" id="P`oxf1xXZWdEzcp(9-`c">
                 <block type="controls_if" id="E^f1*Vai{bZA9HIGp:O]">
                     <block type="logic_operation" id="iU-Wq*:zwi)OFmha.0V=" inline="false">
                       <field name="OP">OR</field>
                         <block type="logic_compare" id="Ihx7uP01OIWXc`vDn]Qe">
                           <field name="OP">EQ</field>
                             <block type="get_value" id="Rt(YmF?$i-Fs@BdrAB{]">
                               <field name="OID">alexa2.0.History.summary</field>
                             <block type="text" id="S-8g!7ijnQNnn4vYw6zg">
                               <field name="TEXT">radio im wohnzimmer aus</field>
                         <block type="logic_compare" id="Vi!)G6^WE!mI2?xNUE^/">
                             <block type="get_value" id="+#rHESJ]RmF5nD9G(O27">
                             <block type="text" id="CrCbgaq,bZ6jhZ?/p{N]">
                               <field name="TEXT">mach die kiste aus</field>
                     <block type="control" id="G44K%t.cT$qWm]`g6$cu">
                       <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Player.controlPause</field>
                         <block type="logic_boolean" id="}C3ITXps53|IjKF4JG{y">
                         <block type="control" id="R=S~-``,W5]`$8y?!]5o">
                             <block type="logic_boolean" id="E=KTWyM*gPzKTjaFWC([">
                             <block type="control" id="n4J5Xbe.hFjRwd9-Y_g7">
                               <field name="OID">denon.0.zoneMain.powerZone</field>
                                 <block type="logic_boolean" id="{_lrr!ml1h(=)$e{^F]2">
        Alexa, spiele Radio NDR2 . läßt den ECHO selbst den Sender abspielen.
        Alexa, spiele Radio NDR2 im Wohnzimmer schaltet die Aktion.
        Sollte so gehen
        Uli977 1 Reply Last reply Reply Quote 0
          Jan1 @Uli977 last edited by
          @Uli977
          Ist es auch. Man muss eigentlich nur logisch an die Sache rangehen.
          Was will ich machen und welche DPs kann ich dafür missbrauchen. Dann einfach der gesprochenen Logik folgen und schon ist das Blockly fertig.
          Der Trick ist wirklich die gesprochene ne Logik bei dem Wunsch den man hat. Beispiel, ich will dass das Licht angeht, wenn es dunkel ist und jemand die Tür öffnet.
          Wenn Du jetzt das wenn durch falls ersetzt, hast schon exakt das gewünschte Blockly😎
          haselchen 1 Reply Last reply Reply Quote 1
          • haselchen
            haselchen Most Active @Jan1 last edited by
            @Jan1
            Perfekt erklärt . Dem ist nichts hinzuzufügen 😊
            • Uli977
              Das erkläre ich euch später wie perfekt das erklärt war 😉
                Jan1 @haselchen last edited by
                @haselchen
                Ich bin Elektroniker und da denkst eben in der Logik. Hab aber auch schon gemerkt, dass das für andere oft nicht logisch klingt 😁
                • haselchen
                  @Jan1
                  Ich bin auch kein Vollprofi beim Blockly .
                  Mir macht das Puzzlen einfach Spass 🙂
                  Und am Ende zu sehen, dass die Logik wohl stimmt, die man gepuzzled hat 😁
                    @haselchen
                    Da hast recht, nur blöd wirds wenn sich das Ding so gar nicht an die ausgedachte Logik hält. Sind eben auch ein paar Blöcke dabei, bei denen man ein paar Definitionen beachten muss. Aber genau so lernt man das eben am schnellsten.
                    • dslraser
                      @Uli977 sagte in Alexa, spiele WDR2 im Wohnzimmer:
                      AV-Receiver
                      Was hast Du für einen AVR ?
                      • Uli977
                        Uli977 @dslraser last edited by
                        @dslraser einen Rotel RSX-1057.
                        Alter Ding aber super Klang!
                        • dslraser
                          @Uli977
                          Okay, ich habe nur gefragt weil es für einige AVR auch Adapter gibt.
                          Bei meinem Denon AVR funktioniert das ganze schon von Haus aus so wie Du Dir das wünscht. Alexa, spiele NDR2 auf Denon. (über HEOS)
                          Dann bleiben Dir aber trotzdem die Möglichkeiten wie von @Jan1 geschrieben.
                          • Uli977
                            @dslraser ich probiere das heute Abend mal... bin selbst gespannt ob ich es hinbekomme
                              sigi234 Forum Testing Most Active @Uli977 last edited by
                              Learning by Doing
                              Uli977 1 Reply Last reply Reply Quote 1
                              • Uli977
                                Uli977 @sigi234 last edited by
                                @sigi234
                                Ich bekomme es nicht hin....
                                Wenn Routine 02AlexaRadioRotel
                                steuere/setze Wert activity:Lautsprecher auf 2
                                Das will ich machen, aber ich stolpere gerade über die ganzen Bausteine.
                                • dslraser
                                  @Uli977
                                  Mathe Baustein, dann 1 (nicht 2) rein
                                  1 zum starten (das wird dann automatisch 2 im Adapter)
                                  0 zum stoppen/ausschalten
                                  das ist der Status
                                  https://github.com/Pmant/ioBroker.harmony/blob/master/README.md
                                  • Uli977
                                    @dslraser Alles klar, das hat schon einmal geklappt..... die Harmony Activity wird gestartet!
                                    • dslraser
                                      @Uli977
                                      ich habe meinen Beitrag oben ergänzt
                                      • Uli977
                                        @dslraser Danke!
                                        Und jetzt setze
                                        Music Provider auf WDR2
                                        • Uli977
                                          Ne, scheint der falsche Datenpunkt zu sein....
                                          Brauche glaube ich den hier
                                          • dslraser
                                            @Uli977
                                            ich mache es so
                                            • Uli977
                                              @dslraser Der bleibt bei mir aber immer leer...
                                              alexa harmony iobroker
                                              4072
