    5. {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    SOLVED {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    • Uli977
      Uli977 last edited by
      Das erkläre ich euch später wie perfekt das erklärt war 😉
      • dslraser
        dslraser Forum Testing Most Active @Uli977 last edited by dslraser
        @Uli977
        oder so...
         <variables>
           <variable type="" id="@!_^k9^zFWondd-=a;yB">erstes_wort</variable>
           <variable type="" id="OGOEqOh/EzI.f(,K^lb.">letztes_wort</variable>
         </variables>
         <block type="on_ext" id="MZX#q{Gs.k*hPSsJ9cKU" x="63" y="137">
           <value name="OID0">
             <shadow type="field_oid" id="Iv~|tQUnQir?Y:KkU?E4">
               <field name="oid">alexa2.0.History.summary</field>
             <block type="variables_set" id="7;U{Id?fayG4D/9zacn:">
               <field name="VAR" id="@!_^k9^zFWondd-=a;yB" variabletype="">erstes_wort</field>
                 <block type="text_indexOf" id="vu;@JqZ82JhLJ[stQiSM">
                   <field name="END">FIRST</field>
                     <block type="on_source" id="_J|$!h@a#CsIiO`({ebU">
                   <value name="FIND">
                     <shadow type="text" id="u]tclL!.B1zr1L+;EiRO">
                       <field name="TEXT">abc</field>
                     <block type="text" id="tH+g7qq:p]jw.fWaQfDz">
                       <field name="TEXT">spiele</field>
                 <block type="variables_set" id="!^uRN)9I3JiLr9d4~}SJ">
                   <field name="VAR" id="OGOEqOh/EzI.f(,K^lb." variabletype="">letztes_wort</field>
                     <block type="text_indexOf" id="JbIL2yFac?i*^Q2WTg|F">
                         <block type="on_source" id="Gvg2D-bOcwq5upLm76TR">
                       <value name="FIND">
                         <block type="text" id="1]2I2PG:.3LKq!TKaRwq">
                           <field name="TEXT">wohnzimmer</field>
                     <block type="controls_if" id="DLE4zW;!}2)dWCZraCs5">
                         <block type="logic_operation" id="Jv+_Dj1(/:vNV]F7Sp)~">
                           <field name="OP">AND</field>
                             <block type="variables_get" id=":8Sky#sE)OaVL^`ki?YC">
                             <block type="variables_get" id="p9:-dL%0+Dw!sElR15w+">
                         <block type="control" id="3X*:XR4h7~R|Ed|,n/tM">
                           <mutation delay_input="true"></mutation>
                           <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Bluetooth.00:05:CD:FE:7C:8D.connected</field>
                           <field name="DELAY_MS">3</field>
                             <block type="logic_boolean" id="P)c3)R|X@.HJ6|ot;~h^">
             <block type="on_ext" id="Np`X%6sixOMQ%rLG8}f?">
               <value name="OID0">
                 <shadow type="field_oid" id="P`oxf1xXZWdEzcp(9-`c">
                 <block type="controls_if" id="E^f1*Vai{bZA9HIGp:O]">
                     <block type="logic_operation" id="iU-Wq*:zwi)OFmha.0V=" inline="false">
                       <field name="OP">OR</field>
                         <block type="logic_compare" id="Ihx7uP01OIWXc`vDn]Qe">
                           <field name="OP">EQ</field>
                             <block type="get_value" id="Rt(YmF?$i-Fs@BdrAB{]">
                               <field name="OID">alexa2.0.History.summary</field>
                             <block type="text" id="S-8g!7ijnQNnn4vYw6zg">
                               <field name="TEXT">radio im wohnzimmer aus</field>
                         <block type="logic_compare" id="Vi!)G6^WE!mI2?xNUE^/">
                             <block type="get_value" id="+#rHESJ]RmF5nD9G(O27">
                             <block type="text" id="CrCbgaq,bZ6jhZ?/p{N]">
                               <field name="TEXT">mach die kiste aus</field>
                     <block type="control" id="G44K%t.cT$qWm]`g6$cu">
                       <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Player.controlPause</field>
                         <block type="logic_boolean" id="}C3ITXps53|IjKF4JG{y">
                         <block type="control" id="R=S~-``,W5]`$8y?!]5o">
                             <block type="logic_boolean" id="E=KTWyM*gPzKTjaFWC([">
                             <block type="control" id="n4J5Xbe.hFjRwd9-Y_g7">
                               <field name="OID">denon.0.zoneMain.powerZone</field>
                                 <block type="logic_boolean" id="{_lrr!ml1h(=)$e{^F]2">
        Alexa, spiele Radio NDR2 . läßt den ECHO selbst den Sender abspielen.
        Alexa, spiele Radio NDR2 im Wohnzimmer schaltet die Aktion.
        Sollte so gehen
        Uli977 1 Reply Last reply Reply Quote 0
          Jan1 @haselchen last edited by
          @haselchen
          Ich bin Elektroniker und da denkst eben in der Logik. Hab aber auch schon gemerkt, dass das für andere oft nicht logisch klingt 😁
          • haselchen
            haselchen Most Active @Jan1 last edited by
            @Jan1
            Ich bin auch kein Vollprofi beim Blockly .
            Mir macht das Puzzlen einfach Spass 🙂
            Und am Ende zu sehen, dass die Logik wohl stimmt, die man gepuzzled hat 😁
              @haselchen
              Da hast recht, nur blöd wirds wenn sich das Ding so gar nicht an die ausgedachte Logik hält. Sind eben auch ein paar Blöcke dabei, bei denen man ein paar Definitionen beachten muss. Aber genau so lernt man das eben am schnellsten.
              • dslraser
                @Uli977 sagte in Alexa, spiele WDR2 im Wohnzimmer:
                AV-Receiver
                Was hast Du für einen AVR ?
                • Uli977
                  Uli977 @dslraser last edited by
                  @dslraser einen Rotel RSX-1057.
                  Alter Ding aber super Klang!
                  • dslraser
                    @Uli977
                    Okay, ich habe nur gefragt weil es für einige AVR auch Adapter gibt.
                    Bei meinem Denon AVR funktioniert das ganze schon von Haus aus so wie Du Dir das wünscht. Alexa, spiele NDR2 auf Denon. (über HEOS)
                    Dann bleiben Dir aber trotzdem die Möglichkeiten wie von @Jan1 geschrieben.
                    • Uli977
                      @dslraser ich probiere das heute Abend mal... bin selbst gespannt ob ich es hinbekomme
                        sigi234 Forum Testing Most Active @Uli977 last edited by
                        Learning by Doing
                        Uli977 1 Reply Last reply Reply Quote 1
                        • Uli977
                          Uli977 @sigi234 last edited by
                          @sigi234
                          Ich bekomme es nicht hin....
                          Wenn Routine 02AlexaRadioRotel
                          steuere/setze Wert activity:Lautsprecher auf 2
                          Das will ich machen, aber ich stolpere gerade über die ganzen Bausteine.
                          • dslraser
                            @Uli977
                            Mathe Baustein, dann 1 (nicht 2) rein
                            1 zum starten (das wird dann automatisch 2 im Adapter)
                            0 zum stoppen/ausschalten
                            das ist der Status
                            https://github.com/Pmant/ioBroker.harmony/blob/master/README.md
                            • Uli977
                              @dslraser Alles klar, das hat schon einmal geklappt..... die Harmony Activity wird gestartet!
                              • dslraser
                                @Uli977
                                ich habe meinen Beitrag oben ergänzt
                                • Uli977
                                  @dslraser Danke!
                                  Und jetzt setze
                                  Music Provider auf WDR2
                                  • Uli977
                                    Ne, scheint der falsche Datenpunkt zu sein....
                                    Brauche glaube ich den hier
                                    • dslraser
                                      @Uli977
                                      ich mache es so
                                      • Uli977
                                        @dslraser Der bleibt bei mir aber immer leer...
                                        • dslraser
                                          @Uli977
                                          • Uli977
                                            @dslraser warum nimmst du diesen Datenpunkt?
                                            • Uli977
                                              @dslraser Ahhh, geht!
                                              alexa harmony iobroker
                                              4078
