    5. {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    SOLVED {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    • Uli977
      Uli977 @dslraser last edited by
      @dslraser einen Rotel RSX-1057.
      Alter Ding aber super Klang!
      • dslraser
        dslraser Forum Testing Most Active @Uli977 last edited by dslraser
        @Uli977
        oder so...
         <variables>
           <variable type="" id="@!_^k9^zFWondd-=a;yB">erstes_wort</variable>
           <variable type="" id="OGOEqOh/EzI.f(,K^lb.">letztes_wort</variable>
         </variables>
         <block type="on_ext" id="MZX#q{Gs.k*hPSsJ9cKU" x="63" y="137">
           <value name="OID0">
             <shadow type="field_oid" id="Iv~|tQUnQir?Y:KkU?E4">
               <field name="oid">alexa2.0.History.summary</field>
             <block type="variables_set" id="7;U{Id?fayG4D/9zacn:">
               <field name="VAR" id="@!_^k9^zFWondd-=a;yB" variabletype="">erstes_wort</field>
                 <block type="text_indexOf" id="vu;@JqZ82JhLJ[stQiSM">
                   <field name="END">FIRST</field>
                     <block type="on_source" id="_J|$!h@a#CsIiO`({ebU">
                   <value name="FIND">
                     <shadow type="text" id="u]tclL!.B1zr1L+;EiRO">
                       <field name="TEXT">abc</field>
                     <block type="text" id="tH+g7qq:p]jw.fWaQfDz">
                       <field name="TEXT">spiele</field>
                 <block type="variables_set" id="!^uRN)9I3JiLr9d4~}SJ">
                   <field name="VAR" id="OGOEqOh/EzI.f(,K^lb." variabletype="">letztes_wort</field>
                     <block type="text_indexOf" id="JbIL2yFac?i*^Q2WTg|F">
                         <block type="on_source" id="Gvg2D-bOcwq5upLm76TR">
                       <value name="FIND">
                         <block type="text" id="1]2I2PG:.3LKq!TKaRwq">
                           <field name="TEXT">wohnzimmer</field>
                     <block type="controls_if" id="DLE4zW;!}2)dWCZraCs5">
                         <block type="logic_operation" id="Jv+_Dj1(/:vNV]F7Sp)~">
                           <field name="OP">AND</field>
                             <block type="variables_get" id=":8Sky#sE)OaVL^`ki?YC">
                             <block type="variables_get" id="p9:-dL%0+Dw!sElR15w+">
                         <block type="control" id="3X*:XR4h7~R|Ed|,n/tM">
                           <mutation delay_input="true"></mutation>
                           <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Bluetooth.00:05:CD:FE:7C:8D.connected</field>
                           <field name="DELAY_MS">3</field>
                             <block type="logic_boolean" id="P)c3)R|X@.HJ6|ot;~h^">
             <block type="on_ext" id="Np`X%6sixOMQ%rLG8}f?">
               <value name="OID0">
                 <shadow type="field_oid" id="P`oxf1xXZWdEzcp(9-`c">
                 <block type="controls_if" id="E^f1*Vai{bZA9HIGp:O]">
                     <block type="logic_operation" id="iU-Wq*:zwi)OFmha.0V=" inline="false">
                       <field name="OP">OR</field>
                         <block type="logic_compare" id="Ihx7uP01OIWXc`vDn]Qe">
                           <field name="OP">EQ</field>
                             <block type="get_value" id="Rt(YmF?$i-Fs@BdrAB{]">
                               <field name="OID">alexa2.0.History.summary</field>
                             <block type="text" id="S-8g!7ijnQNnn4vYw6zg">
                               <field name="TEXT">radio im wohnzimmer aus</field>
                         <block type="logic_compare" id="Vi!)G6^WE!mI2?xNUE^/">
                             <block type="get_value" id="+#rHESJ]RmF5nD9G(O27">
                             <block type="text" id="CrCbgaq,bZ6jhZ?/p{N]">
                               <field name="TEXT">mach die kiste aus</field>
                     <block type="control" id="G44K%t.cT$qWm]`g6$cu">
                       <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Player.controlPause</field>
                         <block type="logic_boolean" id="}C3ITXps53|IjKF4JG{y">
                         <block type="control" id="R=S~-``,W5]`$8y?!]5o">
                             <block type="logic_boolean" id="E=KTWyM*gPzKTjaFWC([">
                             <block type="control" id="n4J5Xbe.hFjRwd9-Y_g7">
                               <field name="OID">denon.0.zoneMain.powerZone</field>
                                 <block type="logic_boolean" id="{_lrr!ml1h(=)$e{^F]2">
        Alexa, spiele Radio NDR2 . läßt den ECHO selbst den Sender abspielen.
        Alexa, spiele Radio NDR2 im Wohnzimmer schaltet die Aktion.
        Sollte so gehen
        Uli977 1 Reply Last reply Reply Quote 0
        • dslraser
          @Uli977
          Okay, ich habe nur gefragt weil es für einige AVR auch Adapter gibt.
          Bei meinem Denon AVR funktioniert das ganze schon von Haus aus so wie Du Dir das wünscht. Alexa, spiele NDR2 auf Denon. (über HEOS)
          Dann bleiben Dir aber trotzdem die Möglichkeiten wie von @Jan1 geschrieben.
          • Uli977
            @dslraser ich probiere das heute Abend mal... bin selbst gespannt ob ich es hinbekomme
              sigi234 Forum Testing Most Active @Uli977 last edited by
              @Uli977 sagte in Alexa, spiele WDR2 im Wohnzimmer:
              Learning by Doing
              Uli977 1 Reply Last reply Reply Quote 1
              • Uli977
                Uli977 @sigi234 last edited by
                @sigi234
                Ich bekomme es nicht hin....
                Wenn Routine 02AlexaRadioRotel
                steuere/setze Wert activity:Lautsprecher auf 2
                Das will ich machen, aber ich stolpere gerade über die ganzen Bausteine.
                • dslraser
                  @Uli977
                  Mathe Baustein, dann 1 (nicht 2) rein
                  1 zum starten (das wird dann automatisch 2 im Adapter)
                  0 zum stoppen/ausschalten
                  das ist der Status
                  https://github.com/Pmant/ioBroker.harmony/blob/master/README.md
                  • Uli977
                    @dslraser Alles klar, das hat schon einmal geklappt..... die Harmony Activity wird gestartet!
                    • dslraser
                      @Uli977
                      ich habe meinen Beitrag oben ergänzt
                      • Uli977
                        @dslraser Danke!
                        Und jetzt setze
                        Music Provider auf WDR2
                        • Uli977
                          Ne, scheint der falsche Datenpunkt zu sein....
                          Brauche glaube ich den hier
                          • dslraser
                            @Uli977
                            ich mache es so
                            • Uli977
                              @dslraser Der bleibt bei mir aber immer leer...
                              • dslraser
                                @Uli977
                                • Uli977
                                  @dslraser warum nimmst du diesen Datenpunkt?
                                  • Uli977
                                    @dslraser Ahhh, geht!
                                    • Uli977
                                      @dslraser jetzt muss ich Alexa noch verklickern, dass sie sich mit Lautsprecher verbindet..... hast du eine Ahnung wie?
                                      • dslraser
                                        Kannst auch über die Sender ID machen. Es gibt mehrere Wege
                                        • Uli977
                                          hab was gefunde... connect
                                            Jan1 @Uli977 last edited by
                                            Wenn Du den Alexa Adapter hast kannst BT Geräte über einen DP verbinden und genau den steuerst an.
                                            Wenn Du ein Button aktivieren willst, einfach was reinschreiben, der reagiert auf so ziehmlich jeden Blödsinn ist ja nur ein Button.
                                              Genau den meine ich
                                              alexa harmony iobroker
                                              4077
