    5. {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    SOLVED {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    • Uli977
      Uli977 @dslraser last edited by
      @dslraser Danke!
      Und jetzt setze
      Music Provider auf WDR2
      • dslraser
        dslraser Forum Testing Most Active @Uli977 last edited by dslraser
        @Uli977
        oder so...
         <variables>
           <variable type="" id="@!_^k9^zFWondd-=a;yB">erstes_wort</variable>
           <variable type="" id="OGOEqOh/EzI.f(,K^lb.">letztes_wort</variable>
         </variables>
         <block type="on_ext" id="MZX#q{Gs.k*hPSsJ9cKU" x="63" y="137">
           <value name="OID0">
             <shadow type="field_oid" id="Iv~|tQUnQir?Y:KkU?E4">
               <field name="oid">alexa2.0.History.summary</field>
             <block type="variables_set" id="7;U{Id?fayG4D/9zacn:">
               <field name="VAR" id="@!_^k9^zFWondd-=a;yB" variabletype="">erstes_wort</field>
                 <block type="text_indexOf" id="vu;@JqZ82JhLJ[stQiSM">
                   <field name="END">FIRST</field>
                     <block type="on_source" id="_J|$!h@a#CsIiO`({ebU">
                   <value name="FIND">
                     <shadow type="text" id="u]tclL!.B1zr1L+;EiRO">
                       <field name="TEXT">abc</field>
                     <block type="text" id="tH+g7qq:p]jw.fWaQfDz">
                       <field name="TEXT">spiele</field>
                 <block type="variables_set" id="!^uRN)9I3JiLr9d4~}SJ">
                   <field name="VAR" id="OGOEqOh/EzI.f(,K^lb." variabletype="">letztes_wort</field>
                     <block type="text_indexOf" id="JbIL2yFac?i*^Q2WTg|F">
                         <block type="on_source" id="Gvg2D-bOcwq5upLm76TR">
                       <value name="FIND">
                         <block type="text" id="1]2I2PG:.3LKq!TKaRwq">
                           <field name="TEXT">wohnzimmer</field>
                     <block type="controls_if" id="DLE4zW;!}2)dWCZraCs5">
                         <block type="logic_operation" id="Jv+_Dj1(/:vNV]F7Sp)~">
                           <field name="OP">AND</field>
                             <block type="variables_get" id=":8Sky#sE)OaVL^`ki?YC">
                             <block type="variables_get" id="p9:-dL%0+Dw!sElR15w+">
                         <block type="control" id="3X*:XR4h7~R|Ed|,n/tM">
                           <mutation delay_input="true"></mutation>
                           <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Bluetooth.00:05:CD:FE:7C:8D.connected</field>
                           <field name="DELAY_MS">3</field>
                             <block type="logic_boolean" id="P)c3)R|X@.HJ6|ot;~h^">
             <block type="on_ext" id="Np`X%6sixOMQ%rLG8}f?">
               <value name="OID0">
                 <shadow type="field_oid" id="P`oxf1xXZWdEzcp(9-`c">
                 <block type="controls_if" id="E^f1*Vai{bZA9HIGp:O]">
                     <block type="logic_operation" id="iU-Wq*:zwi)OFmha.0V=" inline="false">
                       <field name="OP">OR</field>
                         <block type="logic_compare" id="Ihx7uP01OIWXc`vDn]Qe">
                           <field name="OP">EQ</field>
                             <block type="get_value" id="Rt(YmF?$i-Fs@BdrAB{]">
                               <field name="OID">alexa2.0.History.summary</field>
                             <block type="text" id="S-8g!7ijnQNnn4vYw6zg">
                               <field name="TEXT">radio im wohnzimmer aus</field>
                         <block type="logic_compare" id="Vi!)G6^WE!mI2?xNUE^/">
                             <block type="get_value" id="+#rHESJ]RmF5nD9G(O27">
                             <block type="text" id="CrCbgaq,bZ6jhZ?/p{N]">
                               <field name="TEXT">mach die kiste aus</field>
                     <block type="control" id="G44K%t.cT$qWm]`g6$cu">
                       <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Player.controlPause</field>
                         <block type="logic_boolean" id="}C3ITXps53|IjKF4JG{y">
                         <block type="control" id="R=S~-``,W5]`$8y?!]5o">
                             <block type="logic_boolean" id="E=KTWyM*gPzKTjaFWC([">
                             <block type="control" id="n4J5Xbe.hFjRwd9-Y_g7">
                               <field name="OID">denon.0.zoneMain.powerZone</field>
                                 <block type="logic_boolean" id="{_lrr!ml1h(=)$e{^F]2">
        Alexa, spiele Radio NDR2 . läßt den ECHO selbst den Sender abspielen.
        Alexa, spiele Radio NDR2 im Wohnzimmer schaltet die Aktion.
        Sollte so gehen
        Uli977 1 Reply Last reply Reply Quote 0
        • Uli977
          Ne, scheint der falsche Datenpunkt zu sein....
          Brauche glaube ich den hier
          • dslraser
            @Uli977
            ich mache es so
            • Uli977
              @dslraser Der bleibt bei mir aber immer leer...
              • dslraser
                @Uli977
                • Uli977
                  @dslraser warum nimmst du diesen Datenpunkt?
                  • Uli977
                    @dslraser Ahhh, geht!
                    • Uli977
                      @dslraser jetzt muss ich Alexa noch verklickern, dass sie sich mit Lautsprecher verbindet..... hast du eine Ahnung wie?
                      • dslraser
                        @Uli977 sagte in Alexa, spiele WDR2 im Wohnzimmer:
                        Kannst auch über die Sender ID machen. Es gibt mehrere Wege
                        • Uli977
                          hab was gefunde... connect
                            Jan1 @Uli977 last edited by
                            Wenn Du den Alexa Adapter hast kannst BT Geräte über einen DP verbinden und genau den steuerst an.
                            Wenn Du ein Button aktivieren willst, einfach was reinschreiben, der reagiert auf so ziehmlich jeden Blödsinn ist ja nur ein Button.
                              Genau den meine ich
                              • Uli977
                                @dslraser Ok, das funktioniert nun soweit.
                                Wenn ich jetzt das ganze wieder ausschalten will..... also
                                • trenne Lautsprecher
                                • schalte Harmony Activity Lautsprecher aus
                                • und Alexa stop - also kein Radio mehr abspielen.
                                Brauche ich da eine zweite Routine?
                                • dslraser
                                  @Uli977
                                  ja
                                  • Uli977
                                    @dslraser Auch ein neues Skrip, oder kann ich dies ins gleiche schreiben
                                    • dslraser
                                      @Uli977
                                      so wie es Dir gefällt
                                      • Uli977
                                        Ok, das funktioniert auch.....
                                        Die Frage ist nur, warum spielt sie den Radiosender so leise obwohl der Wert für Lautstärke auf 50 steht....
                                        haselchen J 2 Replies Last reply Reply Quote 0
                                        • haselchen
                                          haselchen Most Active @Uli977 last edited by haselchen
                                          @Uli977
                                          Kommt auf den Datenpunkt an , den Du genommen hast.
                                          Player -> Level.volume
                                            @Uli977
                                            Weil der AV leise steht?
                                            haselchen Uli977 2 Replies Last reply Reply Quote 0
                                            • Uli977
                                              Uli977 @haselchen last edited by
                                              @haselchen
                                              alexa harmony iobroker
                                              4071
