    5. {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    SOLVED {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    • Uli977
      Uli977 @Jan1 last edited by
      @Jan1 hmmm.... könnte sein.... meine aber es war eigentlich lauter wenn ich es manuell eingeschaltet habe
      • dslraser
        dslraser Forum Testing Most Active @Uli977 last edited by dslraser
        @Uli977
        oder so...
         <variables>
           <variable type="" id="@!_^k9^zFWondd-=a;yB">erstes_wort</variable>
           <variable type="" id="OGOEqOh/EzI.f(,K^lb.">letztes_wort</variable>
         </variables>
         <block type="on_ext" id="MZX#q{Gs.k*hPSsJ9cKU" x="63" y="137">
           <value name="OID0">
             <shadow type="field_oid" id="Iv~|tQUnQir?Y:KkU?E4">
               <field name="oid">alexa2.0.History.summary</field>
             <block type="variables_set" id="7;U{Id?fayG4D/9zacn:">
               <field name="VAR" id="@!_^k9^zFWondd-=a;yB" variabletype="">erstes_wort</field>
                 <block type="text_indexOf" id="vu;@JqZ82JhLJ[stQiSM">
                   <field name="END">FIRST</field>
                     <block type="on_source" id="_J|$!h@a#CsIiO`({ebU">
                   <value name="FIND">
                     <shadow type="text" id="u]tclL!.B1zr1L+;EiRO">
                       <field name="TEXT">abc</field>
                     <block type="text" id="tH+g7qq:p]jw.fWaQfDz">
                       <field name="TEXT">spiele</field>
                 <block type="variables_set" id="!^uRN)9I3JiLr9d4~}SJ">
                   <field name="VAR" id="OGOEqOh/EzI.f(,K^lb." variabletype="">letztes_wort</field>
                     <block type="text_indexOf" id="JbIL2yFac?i*^Q2WTg|F">
                         <block type="on_source" id="Gvg2D-bOcwq5upLm76TR">
                       <value name="FIND">
                         <block type="text" id="1]2I2PG:.3LKq!TKaRwq">
                           <field name="TEXT">wohnzimmer</field>
                     <block type="controls_if" id="DLE4zW;!}2)dWCZraCs5">
                         <block type="logic_operation" id="Jv+_Dj1(/:vNV]F7Sp)~">
                           <field name="OP">AND</field>
                             <block type="variables_get" id=":8Sky#sE)OaVL^`ki?YC">
                             <block type="variables_get" id="p9:-dL%0+Dw!sElR15w+">
                         <block type="control" id="3X*:XR4h7~R|Ed|,n/tM">
                           <mutation delay_input="true"></mutation>
                           <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Bluetooth.00:05:CD:FE:7C:8D.connected</field>
                           <field name="DELAY_MS">3</field>
                             <block type="logic_boolean" id="P)c3)R|X@.HJ6|ot;~h^">
             <block type="on_ext" id="Np`X%6sixOMQ%rLG8}f?">
               <value name="OID0">
                 <shadow type="field_oid" id="P`oxf1xXZWdEzcp(9-`c">
                 <block type="controls_if" id="E^f1*Vai{bZA9HIGp:O]">
                     <block type="logic_operation" id="iU-Wq*:zwi)OFmha.0V=" inline="false">
                       <field name="OP">OR</field>
                         <block type="logic_compare" id="Ihx7uP01OIWXc`vDn]Qe">
                           <field name="OP">EQ</field>
                             <block type="get_value" id="Rt(YmF?$i-Fs@BdrAB{]">
                               <field name="OID">alexa2.0.History.summary</field>
                             <block type="text" id="S-8g!7ijnQNnn4vYw6zg">
                               <field name="TEXT">radio im wohnzimmer aus</field>
                         <block type="logic_compare" id="Vi!)G6^WE!mI2?xNUE^/">
                             <block type="get_value" id="+#rHESJ]RmF5nD9G(O27">
                             <block type="text" id="CrCbgaq,bZ6jhZ?/p{N]">
                               <field name="TEXT">mach die kiste aus</field>
                     <block type="control" id="G44K%t.cT$qWm]`g6$cu">
                       <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Player.controlPause</field>
                         <block type="logic_boolean" id="}C3ITXps53|IjKF4JG{y">
                         <block type="control" id="R=S~-``,W5]`$8y?!]5o">
                             <block type="logic_boolean" id="E=KTWyM*gPzKTjaFWC([">
                             <block type="control" id="n4J5Xbe.hFjRwd9-Y_g7">
                               <field name="OID">denon.0.zoneMain.powerZone</field>
                                 <block type="logic_boolean" id="{_lrr!ml1h(=)$e{^F]2">
        Alexa, spiele Radio NDR2 . läßt den ECHO selbst den Sender abspielen.
        Alexa, spiele Radio NDR2 im Wohnzimmer schaltet die Aktion.
        Sollte so gehen
        Uli977 1 Reply Last reply Reply Quote 0
          Jan1 @Uli977 last edited by
          @Uli977
          Einfach mal testen und den DP den @haselchen genannt hat mal probieren.
            Jan1 @haselchen last edited by
            @haselchen sagte in Alexa, spiele WDR2 im Wohnzimmer:
            @Jan1
            Manchmal ist es eben sehr banal 🤣
            • Uli977
              @Jan1 welchen hat er benannt?
              Aber ich könnte auch im Harmony Adapter vielleicht die Lautärke anpassen... oder?
                @Uli977
                Steht doch oben.
                Da gibts einige Möglichkeiten. Wobei Du auch über das Script die Lautstärke hoch und wieder runter stellen kannst wenn die BT Verbindung getrennt wird. Einfach bisschen damit spielen.
                • Uli977
                  Eine Sache noch... wenn ich das Ganze wieder ausschalte
                  Dann trennt sich die Bluetooth Verbindung - ok
                  Die Harmony Aktivität geht wieder aus - ok
                  aber Alexa spielt weiter den Radiosender - nicht ok
                  Welchen Datenpunkt muss ich ansprechen um das Radiospielen auszuschalten?
                  Danke und Gruß!
                  dslraser J 3 Replies Last reply Reply Quote 0
                  • dslraser
                    @Uli977 sagte in Alexa, spiele WDR2 im Wohnzimmer:
                    Danke und Gruß!
                    control Pause
                    • dslraser
                      @Uli977
                      für so einfache Verzögerungen kannst Du auch rechts im Baustein einen Haken setzen und da die Verzögerung einstellen
                        @Uli977
                        Sieht fast so aus als würde alles laufen. War nicht so schwer, oder?
                        • Uli977
                          @Jan1 @haselchen @dslraser
                          Ich danke euch! Es läuft.....
                          Die Kür wäre jetzt, das ich am Anfang sage welchen Sender ich hören möchte und sie das dann spielt.
                          Aber ich kann ja, wenn die Routine gestartet ist, einfach Alexa ansprechen und sie bitten einen anderen Sender zu spielen..... das geht ja auch.
                          War gar nicht sooo schwer!
                            @Uli977
                            Das wird dann aber echt bisschen komplizierter, weil Alexa dazwischen hängt und die eben nur auf den Namen der Routine reagiert. Hier müsste man die Spracherkennung irgendwie vorher umleiten, modifizieren und dann an Alexa schicken.
                            Geht bestimmt, nur hab ich da gerade kein Ansatz im Kopf.
                            • Uli977
                              @Jan1 Alles gut! Ich lasse es so.
                                @Uli977
                                Warte doch mal, nur weil mir nix dazu einfällt heißt das noch lange nicht, dass es zu kompliziert ist😉
                                Uli977 haselchen 2 Replies Last reply Reply Quote 0
                                • Uli977
                                  @Jan1 😊
                                  • haselchen
                                    haselchen Most Active @Jan1 last edited by
                                    @Jan1
                                    Könnte man den Summary Datenpunkt triggern?
                                    Mit den Blockly Textbausteinen?
                                    Darüber könnte man die Sender Filtern.
                                      @haselchen
                                      Geht bestimmt irgendwie. Problem ist eben, dass das Kommsndo von Alexa entgegen genommen wird und wenn die nichts mit anfangen kann, ist schon mal Schluss.
                                      Hier msste man mit dem IObroker Adapter für Sprachbefehle was vorschalten. Das wird aber wieder blöd, weil der ja nur auf "Alexa sage I O Broker bla bla" reagiert.
                                      • dslraser
                                        @Uli977
                                        wie heißt denn jetzt Deine eigentliche Routine ?
                                        Und wie soll der "Wunschbefehl" heißen ?
                                        • Uli977
                                          Uli977 @dslraser last edited by
                                          @dslraser
                                          Mein Routine heißt wie folgt: Alexa, schalte Radio ein
                                          Schöne wäre...
                                          Alexa, spiele Radio Neandertal im Wohnzimmer oder auf Rotel
                                          bzw.
                                          Alexa, spiele WDR2 auf Rotel
                                          • dslraser
                                            Bei mir geht der AVR ganz alleine an wenn die Bluetooth Verbindung hergestellt wird (Bluetooth ist im AVR integriert). Bei mir reicht das so...
                                            Sender könnte man beliebig erweitern.
                                             <block type="on_ext" id="MZX#q{Gs.k*hPSsJ9cKU" x="87" y="12">
                                               <value name="OID0">
                                                     <block type="logic_operation" id="Y)6]`Q9xcctJsNJ*n2Xk" inline="false">
                                                         <block type="logic_operation" id=":Mph^k)JrtbItY5v+-w#" inline="false">
                                                             <block type="logic_compare" id="Fy6yYtFUO7Y@^J,~(`wR">
        <block type="get_value" id="*?.PBWtjh,9}H1NG%6O9">
        <block type="text" id="|]`u@Mv~9eR).$#v+RDX">
        <field name="TEXT">spiele n. d. r. zwei im wohnzimmer</field>
                                                             <block type="logic_compare" id="Gv;QzXO,u*z39MJJ{1ir">
        <block type="get_value" id="RhXIZNAkv7%U*yXC)+SO">
        <block type="text" id="BST3m|13cQ/vS-08xQq.">
        <field name="TEXT">spiele n. d. r. zwei auf Rothell</field>
                                                         <block type="logic_operation" id="4,ey-=V$-9h74l}qsGEh" inline="false">
                                                             <block type="logic_compare" id=":fQ~X*n=JWP!Dqk?f7`h">
        <block type="get_value" id="q|N4[Pd:E%cgz_?4QtaM">
        <block type="text" id="le]p7]}?#t^`]{7qg=;=">
        <field name="TEXT">spiele w. d. r. zwei im wohnzimmer</field>
                                                             <block type="logic_compare" id="i)=,{~bT!8w7%Amp=**N">
        <block type="get_value" id="1CRKsakAOFQ59X0KxbC5">
        <block type="text" id="O|6g(Q.fGyP?CA.*|_rB">
        <field name="TEXT">spiele w. d. r. zwei auf Rothell</field>
                                            Bei Dir müßte man dann wahrscheinlich noch Deine Harmony activity dazwischen schalten. Das hier ist ganz ohne Routine. Also zum testen müßtest Du Deine Routine event. deaktivieren.
                                            • Uli977
                                              @dslraser ok.... mein AVR geht nicht an, da ich einen separaten Bluetooth Empfänger an einem der AV Eingänge angeschlossen habe.
                                              Ok... Implementierung nicht ganz verstanden, aber ich schaue mir das Skript mal an
                                              alexa harmony iobroker
                                              4077
