    5. {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    SOLVED {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    • Uli977
      Uli977 @Jan1 last edited by
      @Jan1 Alles gut! Ich lasse es so.
      • dslraser
        dslraser Forum Testing Most Active @Uli977 last edited by dslraser
        @Uli977
        oder so...
         <variables>
           <variable type="" id="@!_^k9^zFWondd-=a;yB">erstes_wort</variable>
           <variable type="" id="OGOEqOh/EzI.f(,K^lb.">letztes_wort</variable>
         </variables>
         <block type="on_ext" id="MZX#q{Gs.k*hPSsJ9cKU" x="63" y="137">
           <value name="OID0">
             <shadow type="field_oid" id="Iv~|tQUnQir?Y:KkU?E4">
               <field name="oid">alexa2.0.History.summary</field>
             <block type="variables_set" id="7;U{Id?fayG4D/9zacn:">
               <field name="VAR" id="@!_^k9^zFWondd-=a;yB" variabletype="">erstes_wort</field>
                 <block type="text_indexOf" id="vu;@JqZ82JhLJ[stQiSM">
                   <field name="END">FIRST</field>
                     <block type="on_source" id="_J|$!h@a#CsIiO`({ebU">
                   <value name="FIND">
                     <shadow type="text" id="u]tclL!.B1zr1L+;EiRO">
                       <field name="TEXT">abc</field>
                     <block type="text" id="tH+g7qq:p]jw.fWaQfDz">
                       <field name="TEXT">spiele</field>
                 <block type="variables_set" id="!^uRN)9I3JiLr9d4~}SJ">
                   <field name="VAR" id="OGOEqOh/EzI.f(,K^lb." variabletype="">letztes_wort</field>
                     <block type="text_indexOf" id="JbIL2yFac?i*^Q2WTg|F">
                         <block type="on_source" id="Gvg2D-bOcwq5upLm76TR">
                       <value name="FIND">
                         <block type="text" id="1]2I2PG:.3LKq!TKaRwq">
                           <field name="TEXT">wohnzimmer</field>
                     <block type="controls_if" id="DLE4zW;!}2)dWCZraCs5">
                         <block type="logic_operation" id="Jv+_Dj1(/:vNV]F7Sp)~">
                           <field name="OP">AND</field>
                             <block type="variables_get" id=":8Sky#sE)OaVL^`ki?YC">
                             <block type="variables_get" id="p9:-dL%0+Dw!sElR15w+">
                         <block type="control" id="3X*:XR4h7~R|Ed|,n/tM">
                           <mutation delay_input="true"></mutation>
                           <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Bluetooth.00:05:CD:FE:7C:8D.connected</field>
                           <field name="DELAY_MS">3</field>
                             <block type="logic_boolean" id="P)c3)R|X@.HJ6|ot;~h^">
             <block type="on_ext" id="Np`X%6sixOMQ%rLG8}f?">
               <value name="OID0">
                 <shadow type="field_oid" id="P`oxf1xXZWdEzcp(9-`c">
                 <block type="controls_if" id="E^f1*Vai{bZA9HIGp:O]">
                     <block type="logic_operation" id="iU-Wq*:zwi)OFmha.0V=" inline="false">
                       <field name="OP">OR</field>
                         <block type="logic_compare" id="Ihx7uP01OIWXc`vDn]Qe">
                           <field name="OP">EQ</field>
                             <block type="get_value" id="Rt(YmF?$i-Fs@BdrAB{]">
                               <field name="OID">alexa2.0.History.summary</field>
                             <block type="text" id="S-8g!7ijnQNnn4vYw6zg">
                               <field name="TEXT">radio im wohnzimmer aus</field>
                         <block type="logic_compare" id="Vi!)G6^WE!mI2?xNUE^/">
                             <block type="get_value" id="+#rHESJ]RmF5nD9G(O27">
                             <block type="text" id="CrCbgaq,bZ6jhZ?/p{N]">
                               <field name="TEXT">mach die kiste aus</field>
                     <block type="control" id="G44K%t.cT$qWm]`g6$cu">
                       <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Player.controlPause</field>
                         <block type="logic_boolean" id="}C3ITXps53|IjKF4JG{y">
                         <block type="control" id="R=S~-``,W5]`$8y?!]5o">
                             <block type="logic_boolean" id="E=KTWyM*gPzKTjaFWC([">
                             <block type="control" id="n4J5Xbe.hFjRwd9-Y_g7">
                               <field name="OID">denon.0.zoneMain.powerZone</field>
                                 <block type="logic_boolean" id="{_lrr!ml1h(=)$e{^F]2">
        Alexa, spiele Radio NDR2 . läßt den ECHO selbst den Sender abspielen.
        Alexa, spiele Radio NDR2 im Wohnzimmer schaltet die Aktion.
        Sollte so gehen
        Uli977 1 Reply Last reply Reply Quote 0
          Jan1 @Uli977 last edited by
          @Uli977
          Warte doch mal, nur weil mir nix dazu einfällt heißt das noch lange nicht, dass es zu kompliziert ist😉
          Uli977 haselchen 2 Replies Last reply Reply Quote 0
          • Uli977
            @Jan1 😊
            • haselchen
              haselchen Most Active @Jan1 last edited by
              @Jan1
              Könnte man den Summary Datenpunkt triggern?
              Mit den Blockly Textbausteinen?
              Darüber könnte man die Sender Filtern.
                Jan1 @haselchen last edited by
                @haselchen
                Geht bestimmt irgendwie. Problem ist eben, dass das Kommsndo von Alexa entgegen genommen wird und wenn die nichts mit anfangen kann, ist schon mal Schluss.
                Hier msste man mit dem IObroker Adapter für Sprachbefehle was vorschalten. Das wird aber wieder blöd, weil der ja nur auf "Alexa sage I O Broker bla bla" reagiert.
                • dslraser
                  @Uli977
                  wie heißt denn jetzt Deine eigentliche Routine ?
                  Und wie soll der "Wunschbefehl" heißen ?
                  • Uli977
                    Uli977 @dslraser last edited by
                    @dslraser
                    Mein Routine heißt wie folgt: Alexa, schalte Radio ein
                    Schöne wäre...
                    Alexa, spiele Radio Neandertal im Wohnzimmer oder auf Rotel
                    bzw.
                    Alexa, spiele WDR2 auf Rotel
                    • dslraser
                      @Uli977 sagte in Alexa, spiele WDR2 im Wohnzimmer:
                      Bei mir geht der AVR ganz alleine an wenn die Bluetooth Verbindung hergestellt wird (Bluetooth ist im AVR integriert). Bei mir reicht das so...
                      Sender könnte man beliebig erweitern.
                       <block type="on_ext" id="MZX#q{Gs.k*hPSsJ9cKU" x="87" y="12">
                         <value name="OID0">
                               <block type="logic_operation" id="Y)6]`Q9xcctJsNJ*n2Xk" inline="false">
                                   <block type="logic_operation" id=":Mph^k)JrtbItY5v+-w#" inline="false">
                                       <block type="logic_compare" id="Fy6yYtFUO7Y@^J,~(`wR">
                                           <block type="get_value" id="*?.PBWtjh,9}H1NG%6O9">
                                           <block type="text" id="|]`u@Mv~9eR).$#v+RDX">
                                             <field name="TEXT">spiele n. d. r. zwei im wohnzimmer</field>
                                       <block type="logic_compare" id="Gv;QzXO,u*z39MJJ{1ir">
                                           <block type="get_value" id="RhXIZNAkv7%U*yXC)+SO">
                                           <block type="text" id="BST3m|13cQ/vS-08xQq.">
                                             <field name="TEXT">spiele n. d. r. zwei auf Rothell</field>
                                   <block type="logic_operation" id="4,ey-=V$-9h74l}qsGEh" inline="false">
                                       <block type="logic_compare" id=":fQ~X*n=JWP!Dqk?f7`h">
                                           <block type="get_value" id="q|N4[Pd:E%cgz_?4QtaM">
                                           <block type="text" id="le]p7]}?#t^`]{7qg=;=">
                                             <field name="TEXT">spiele w. d. r. zwei im wohnzimmer</field>
                                       <block type="logic_compare" id="i)=,{~bT!8w7%Amp=**N">
                                           <block type="get_value" id="1CRKsakAOFQ59X0KxbC5">
                                           <block type="text" id="O|6g(Q.fGyP?CA.*|_rB">
                                             <field name="TEXT">spiele w. d. r. zwei auf Rothell</field>
                      Bei Dir müßte man dann wahrscheinlich noch Deine Harmony activity dazwischen schalten. Das hier ist ganz ohne Routine. Also zum testen müßtest Du Deine Routine event. deaktivieren.
                      • Uli977
                        @dslraser ok.... mein AVR geht nicht an, da ich einen separaten Bluetooth Empfänger an einem der AV Eingänge angeschlossen habe.
                        Ok... Implementierung nicht ganz verstanden, aber ich schaue mir das Skript mal an
                        • dslraser
                          @Uli977
                          bei Dir dann so ungefähr
                          • Uli977
                            @dslraser ok, das habe ich.... und dann?
                            • dslraser
                              @Uli977
                              also Rotel versteht Alexa bei mir sehr schlecht, da steht immer wieder was anderes in der History. Wohnzimmer klappt immer.
                              • dslraser
                                Jetzt sagst Du Alexa, spiele NDR2 im Wohnzimmer
                                • dslraser
                                  @Uli977
                                  in Deiner Harmony Aktion muss eine 1 stehen zum einschalten
                                  • Uli977
                                    @dslraser Danke für den Tipp, hatte ich übersehen mit der 1
                                    Ich muss also die Routine jetzt auch anpassen?
                                    • dslraser
                                      Das ist ganz ohne eine Routine oder Button. Die kannst Du mal deaktivieren und mal das andere Script von vorhin ausschalten.
                                      Uli977 2 Replies Last reply Reply Quote 0
                                      • Uli977
                                        @dslraser Tatsächlich es geht...... da staunt der Laie und der Fachmann wundert sich 🙂
                                        • Uli977
                                          @dslraser Und wenn ich das ganze wieder ausschalten will?
                                          • dslraser
                                            @Uli977
                                            dann nur Deine BT Verbindung trennen mit false und den Player auf pause und Deine Harmony auf 0.
                                            Dafür kannst Du ja die Routine von vorhin nehmen.
                                            Wenn Du noch mehr Sender einbauen willst, dann sagst Du erstmal Deinen Sprachbefehl und schaust in der History was sie verstanden hat. Diesen Text kannst Du dann nehmen und Dein Blockly erweitern.
                                            Hier mal mit vier Sendern (ohne Harmony bei mir)
                                            • Uli977
                                              @dslraser Das Ausschalten, dann aber wieder mit einer Routine?
                                              alexa harmony iobroker
                                              4077
