    5. {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    SOLVED {gelöst} Alexa, spiele WDR2 im Wohnzimmer
    • dslraser
      dslraser Forum Testing Most Active @Uli977 last edited by
      @Uli977
      bei Dir dann so ungefähr
      Uli977 1 Reply Last reply Reply Quote 0
      • dslraser
        dslraser Forum Testing Most Active @Uli977 last edited by dslraser
        @Uli977
        oder so...
         <variables>
           <variable type="" id="@!_^k9^zFWondd-=a;yB">erstes_wort</variable>
           <variable type="" id="OGOEqOh/EzI.f(,K^lb.">letztes_wort</variable>
         </variables>
         <block type="on_ext" id="MZX#q{Gs.k*hPSsJ9cKU" x="63" y="137">
           <value name="OID0">
             <shadow type="field_oid" id="Iv~|tQUnQir?Y:KkU?E4">
               <field name="oid">alexa2.0.History.summary</field>
             <block type="variables_set" id="7;U{Id?fayG4D/9zacn:">
               <field name="VAR" id="@!_^k9^zFWondd-=a;yB" variabletype="">erstes_wort</field>
                 <block type="text_indexOf" id="vu;@JqZ82JhLJ[stQiSM">
                   <field name="END">FIRST</field>
                     <block type="on_source" id="_J|$!h@a#CsIiO`({ebU">
                   <value name="FIND">
                     <shadow type="text" id="u]tclL!.B1zr1L+;EiRO">
                       <field name="TEXT">abc</field>
                     <block type="text" id="tH+g7qq:p]jw.fWaQfDz">
                       <field name="TEXT">spiele</field>
                 <block type="variables_set" id="!^uRN)9I3JiLr9d4~}SJ">
                   <field name="VAR" id="OGOEqOh/EzI.f(,K^lb." variabletype="">letztes_wort</field>
                     <block type="text_indexOf" id="JbIL2yFac?i*^Q2WTg|F">
                         <block type="on_source" id="Gvg2D-bOcwq5upLm76TR">
                       <value name="FIND">
                         <block type="text" id="1]2I2PG:.3LKq!TKaRwq">
                           <field name="TEXT">wohnzimmer</field>
                     <block type="controls_if" id="DLE4zW;!}2)dWCZraCs5">
                         <block type="logic_operation" id="Jv+_Dj1(/:vNV]F7Sp)~">
                           <field name="OP">AND</field>
                             <block type="variables_get" id=":8Sky#sE)OaVL^`ki?YC">
                             <block type="variables_get" id="p9:-dL%0+Dw!sElR15w+">
                         <block type="control" id="3X*:XR4h7~R|Ed|,n/tM">
                           <mutation delay_input="true"></mutation>
                           <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Bluetooth.00:05:CD:FE:7C:8D.connected</field>
                           <field name="DELAY_MS">3</field>
                             <block type="logic_boolean" id="P)c3)R|X@.HJ6|ot;~h^">
             <block type="on_ext" id="Np`X%6sixOMQ%rLG8}f?">
               <value name="OID0">
                 <shadow type="field_oid" id="P`oxf1xXZWdEzcp(9-`c">
                 <block type="controls_if" id="E^f1*Vai{bZA9HIGp:O]">
                     <block type="logic_operation" id="iU-Wq*:zwi)OFmha.0V=" inline="false">
                       <field name="OP">OR</field>
                         <block type="logic_compare" id="Ihx7uP01OIWXc`vDn]Qe">
                           <field name="OP">EQ</field>
                             <block type="get_value" id="Rt(YmF?$i-Fs@BdrAB{]">
                               <field name="OID">alexa2.0.History.summary</field>
                             <block type="text" id="S-8g!7ijnQNnn4vYw6zg">
                               <field name="TEXT">radio im wohnzimmer aus</field>
                         <block type="logic_compare" id="Vi!)G6^WE!mI2?xNUE^/">
                             <block type="get_value" id="+#rHESJ]RmF5nD9G(O27">
                             <block type="text" id="CrCbgaq,bZ6jhZ?/p{N]">
                               <field name="TEXT">mach die kiste aus</field>
                     <block type="control" id="G44K%t.cT$qWm]`g6$cu">
                       <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Player.controlPause</field>
                         <block type="logic_boolean" id="}C3ITXps53|IjKF4JG{y">
                         <block type="control" id="R=S~-``,W5]`$8y?!]5o">
                             <block type="logic_boolean" id="E=KTWyM*gPzKTjaFWC([">
                             <block type="control" id="n4J5Xbe.hFjRwd9-Y_g7">
                               <field name="OID">denon.0.zoneMain.powerZone</field>
                                 <block type="logic_boolean" id="{_lrr!ml1h(=)$e{^F]2">
        Alexa, spiele Radio NDR2 . läßt den ECHO selbst den Sender abspielen.
        Alexa, spiele Radio NDR2 im Wohnzimmer schaltet die Aktion.
        Sollte so gehen
        • Uli977
          Uli977 @dslraser last edited by
          @dslraser ok, das habe ich.... und dann?
          • dslraser
            @Uli977
            also Rotel versteht Alexa bei mir sehr schlecht, da steht immer wieder was anderes in der History. Wohnzimmer klappt immer.
            • dslraser
              @Uli977 sagte in Alexa, spiele WDR2 im Wohnzimmer:
              Jetzt sagst Du Alexa, spiele NDR2 im Wohnzimmer
              • dslraser
                @Uli977
                in Deiner Harmony Aktion muss eine 1 stehen zum einschalten
                • Uli977
                  @dslraser Danke für den Tipp, hatte ich übersehen mit der 1
                  Ich muss also die Routine jetzt auch anpassen?
                  • dslraser
                    Das ist ganz ohne eine Routine oder Button. Die kannst Du mal deaktivieren und mal das andere Script von vorhin ausschalten.
                    Uli977 2 Replies Last reply Reply Quote 0
                    • Uli977
                      @dslraser Tatsächlich es geht...... da staunt der Laie und der Fachmann wundert sich 🙂
                      • Uli977
                        @dslraser Und wenn ich das ganze wieder ausschalten will?
                        • dslraser
                          @Uli977
                          dann nur Deine BT Verbindung trennen mit false und den Player auf pause und Deine Harmony auf 0.
                          Dafür kannst Du ja die Routine von vorhin nehmen.
                          Wenn Du noch mehr Sender einbauen willst, dann sagst Du erstmal Deinen Sprachbefehl und schaust in der History was sie verstanden hat. Diesen Text kannst Du dann nehmen und Dein Blockly erweitern.
                          Hier mal mit vier Sendern (ohne Harmony bei mir)
                          • Uli977
                            @dslraser Das Ausschalten, dann aber wieder mit einer Routine?
                            • dslraser
                              Steht doch oben......
                              • Uli977
                                @dslraser Sorry, im Eifer des Gefechts überlesen......
                                • Uli977
                                  @dslraser Sehr sehr geil! Genau so wollte ich es... DANKE dir!
                                  Was ist den radio fritz... ein guter Sender? Kenne ich gar nicht
                                  • dslraser
                                    Radio Fritz ist ein Berliner Sender
                                    Ausschalten geht auch über diesen Weg. Auch ohne Routine und Button.
                                    Hier nochmal das gesamte Blockly. (ohne Harmony)
                                     <block type="on_ext" id="MZX#q{Gs.k*hPSsJ9cKU" x="87" y="12">
                                       <value name="OID0">
                                             <block type="logic_operation" id="Y)6]`Q9xcctJsNJ*n2Xk" inline="false">
                                                 <block type="logic_operation" id=":Mph^k)JrtbItY5v+-w#" inline="false">
                                                     <block type="logic_compare" id="Fy6yYtFUO7Y@^J,~(`wR">
                                                         <block type="get_value" id="*?.PBWtjh,9}H1NG%6O9">
                                                         <block type="text" id="|]`u@Mv~9eR).$#v+RDX">
                                                           <field name="TEXT">spiele n. d. r. zwei im wohnzimmer</field>
                                                     <block type="logic_compare" id="Gv;QzXO,u*z39MJJ{1ir">
                                                         <block type="get_value" id="RhXIZNAkv7%U*yXC)+SO">
                                                         <block type="text" id="BST3m|13cQ/vS-08xQq.">
                                                           <field name="TEXT">spiele radio s. a. w. im Wohnzimmer</field>
                                                 <block type="logic_operation" id="4,ey-=V$-9h74l}qsGEh" inline="false">
                                                     <block type="logic_compare" id=":fQ~X*n=JWP!Dqk?f7`h">
                                                         <block type="get_value" id="q|N4[Pd:E%cgz_?4QtaM">
                                                         <block type="text" id="le]p7]}?#t^`]{7qg=;=">
                                                           <field name="TEXT">spiele w. d. r. zwei im wohnzimmer</field>
                                                     <block type="logic_compare" id="i)=,{~bT!8w7%Amp=**N">
                                                         <block type="get_value" id="1CRKsakAOFQ59X0KxbC5">
                                                         <block type="text" id="O|6g(Q.fGyP?CA.*|_rB">
                                                           <field name="TEXT">spiele radio fritz im wohnzimmer</field>
                                           <value name="OID0">
                                    Edit: ich muß noch zusätzlich meinen AVR ausschalten, weil der sonst an bleibt 😊
                                    • Uli977
                                      @dslraser Was soll ich sagen.... PERFEKT! Danke!
                                      • dslraser
                                        @Uli977
                                        Prima, dann stelle den Thread auf [gelöst]. (ganz oben im ersten Beitrag Deinen Titel bearbeiten)
                                        • dslraser
                                          @Uli977
                                          eine Sache fällt mir doch noch ein. Man könnte auch nur auf das erste Wort in der History triggern, wenn das immer z.B. mit spiele anfängt, dann könnte man immer diese Aktion auslösen, also Deine Harmony Aktion schalten und Blauzahn aktivieren. Der Sender wird ja dann von Alexa sowieso abgespielt. So kannst Du jeden Sender sagen ohne das er im Blockly angegeben werden muß. Sobald spiele als erstes gesagt wird startet die Aktion. Vielleicht willst Du es ja so....
                                          Alexa, spiele NDR2
                                          Alexa, spiele WDR2
                                             <value name="OID0">
                                                   <block type="logic_compare" id="WUs0(F=vk*xOB;q%]gG)">
                                                       <block type="text_getSubstring" id="f5KoGv$%Zm!NLY7z%f({">
                                                         <mutation at1="false" at2="true"></mutation>
                                                         <field name="WHERE1">FIRST</field>
                                                         <field name="WHERE2">FROM_START</field>
                                                         <value name="STRING">
                                                           <block type="on_source" id="c#LY4#OLipUP+z=,xL_^">
                                                         <value name="AT2">
                                                           <block type="math_number" id="FD_s|Lv~2+q4y}K5ESo1">
                                                             <field name="NUM">6</field>
                                                       <block type="text" id="`(k{j)n2p/qpW).EF~z+">
                                                 <value name="OID0">
                                          • Uli977
                                            @dslraser ich teste das!
                                            • Uli977
                                              Uli977 @dslraser last edited by Uli977
                                              @dslraser Perfekt! Was soll ich sagen.... Dankeschön! Erneut!
                                              alexa harmony iobroker
                                              4077
