    5. Hue Lampe Blinken lassen
    • dslraser
      dslraser Forum Testing Most Active @Daniel Schwarz last edited by dslraser
      @Daniel-Schwarz
      dann exportiere doch mal ein aktuelles "richtiges" Blockly...
      Daniel Schwarz 2 Replies Last reply Reply Quote 0
      • Daniel Schwarz
        Daniel Schwarz @dslraser last edited by Daniel Schwarz
        @dslraser
          <block type="comment" id="MT|OG_uE2Vv|b(gV]g!-" x="-2487" y="-1262">
            <field name="COMMENT">Waschmaschine Tamara</field>
              <block type="on" id="E]v/{:S!EN}:`-n!KG8t">
                <field name="OID">hs100.0.192_168_1_64.power</field>
                  <block type="controls_if" id="6^wpDO[uw!J:X}YAGLc2">
                      <block type="logic_operation" id="tUg/fnG6gl=C,e5r@2;=">
                        <field name="OP">AND</field>
                          <block type="logic_compare" id="~acQv-uHMamsd]CyqSAt">
                            <field name="OP">GTE</field>
                              <block type="get_value" id="*QG)__VUq{)wR/%,lD_u">
                              <block type="math_number" id="nHDh5{|=ujj,/s4R,wi%">
                                <field name="NUM">1.9</field>
                          <block type="logic_compare" id="M6)24zQSu9Q-rcyqE74-">
                            <field name="OP">EQ</field>
                              <block type="get_value" id="4ourwMoM?M,Q8p`2vS:5">
                                <field name="OID">hs100.0.Waschmashine_Tamara_läuft</field>
                              <block type="logic_boolean" id="a_o2/Yq3q(:@7_rniS3A">
                      <block type="update" id="Tw6Rx`ft}FX%p^c]3jr!">
                          <block type="logic_boolean" id="ch7k(!?noDm6pdeEwQxQ">
                          <block type="control" id="e)PS_6qK6]4JA1L[zXF(">
                            <mutation delay_input="true"></mutation>
                            <field name="OID">alexa2.0.Echo-Devices.G090LV03639302FK.Commands.speak</field>
                            <field name="DELAY_MS">120</field>
                              <block type="text" id="[U_XerX2c3PkA)L87$[P">
                                <field name="TEXT">Guten Tag meine lieben, die Waschmaschine wurde gestartet</field>
                    <value name="IF1">
                      <block type="logic_operation" id="={^U$UE)w[X.op!T$8*N">
                          <block type="logic_compare" id="h0l|45d(w-#07qv*AI9c">
                            <field name="OP">LT</field>
                              <block type="get_value" id="#9rMD6VG56|qPND]J]C9">
                              <block type="math_number" id="UII=:BzN$82(llmLr?:d">
                                <field name="NUM">1.8</field>
                          <block type="logic_compare" id="Cp#uT-JNnXlRY#p#)K?7">
                              <block type="get_value" id="U*IPrN:P7LrA;I:np=k:">
                              <block type="logic_boolean" id="w]-x^hHtJd54^I7]KQl|">
                    <statement name="DO1">
                      <block type="update" id="Hn79Id=H[-32#@PbW+Qh">
                          <block type="logic_boolean" id="AsLvsc6Ky*qe5m`^2cQ]">
                          <block type="control" id="2CEP7kKDa@k1do^oB(%X">
                            <field name="DELAY_MS">20</field>
                              <block type="text_join" id="=C{XRK$K(5v~dtj#7f0C">
                                <mutation items="4"></mutation>
                                <value name="ADD0">
                                  <block type="text" id="#j41KA3g[~o7Fteb^:zr">
                                    <field name="TEXT">Halli, Hallo, ich bin es, die Waschmaschine, ich bin sowas von fertig! ;-)</field>
                                <value name="ADD1">
                                  <block type="text" id="nounxTUR@-UvTVNF_^o#">
                                    <field name="TEXT">Zu deiner Information, du hast heute</field>
                                <value name="ADD2">
                                  <block type="get_value" id=")DTM^xKQ~wKY!*cSUK_F">
                                    <field name="OID">hs100.0.192_168_1_64.totalNow</field>
                                <value name="ADD3">
                                  <block type="text" id="W$G2it*A)Sp/};v+K]ow">
                                    <field name="TEXT">KWh, beim Waschen verbraucht.</field>
          <block type="comment" id="eI,c=[yFos]R~mWJ`H/z" x="-1213" y="-1237">
            <field name="COMMENT">Waschmaschine Sibylle</field>
              <block type="on" id="Ma,cer@O39_MHUXE9b6{">
                <field name="OID">hs100.0.192_168_1_63.power</field>
                  <block type="controls_if" id="U1uqg)1c{UYg%K;c5A6v">
                      <block type="logic_operation" id="}A|D9zK[RvsatF3t207-">
                          <block type="logic_compare" id="ZKHiHIV;rYPRn(a,^chX">
                              <block type="get_value" id=":kY_+I6B]29G!!Mz2-]#">
                              <block type="math_number" id="|k;F$jK|W.bs[D,wUC}5">
                                <field name="NUM">1.6</field>
                          <block type="logic_compare" id="NBEs$P3%HC]-%|OoLAN_">
                              <block type="get_value" id="IPZ@V}3xfJADI7YqktH">
                                <field name="OID">hs100.0.Waschmaschine_Sibylle_läuft</field>
                              <block type="logic_boolean" id="EidA92E?flHTK8Q+I4">
                      <block type="update" id="0?=A65jlQdW|w,[];@">
                          <block type="logic_boolean" id="/a!HgmdF.^EB2xq7y;S1">
                          <block type="control" id="EfmaiW1eoFma/%;tx/uN">
                            <field name="OID">alexa2.1.Echo-Devices.G090U509910604SS.Commands.speak</field>
                            <field name="DELAY_MS">200</field>
                              <block type="text" id="7~NfsWx!4$Axj+5yW;5">
                    <value name="IF1">
                      <block type="logic_operation" id="hr-gsMEPM%q-NFnrii^a">
                          <block type="logic_compare" id="yjfRIE_PDs%FEPtMWf#l">
                              <block type="get_value" id="kN%Iy1mht+ua8v#+IKy*">
                              <block type="math_number" id="jMA/e%Pyb9J8Y{wRFl*N">
                                <field name="NUM">1.3</field>
                          <block type="logic_compare" id="{j@yrT3dQzuUj|7N(1.O">
                              <block type="get_value" id="UCSz[z*556|oVd-!eh%V">
                              <block type="logic_boolean" id="?m,?02hXT0%B%PIy~?h:">
                      <block type="update" id="d@I:Qh,1V#fRsSbcl6gg">
                          <block type="logic_boolean" id="=VFU/ydj[Fm~(%88LVMX">
                          <block type="control" id="GwM0IrbMj(VE?$_04hV9">
                              <block type="text_join" id="3?*H|JGs27V@6~~~8F)-">
                                <value name="ADD0">
                                  <block type="text" id="EK,Z#@PTAApgQq:}.ub$">
                                <value name="ADD1">
                                  <block type="text" id="o|olcNOtO7Bki7,Dkm6H">
                                <value name="ADD2">
                                  <block type="get_value" id="[lI(`pb]l:,mcIceod$v">
                                <value name="ADD3">
                                  <block type="text" id="Ot+b^8x;4V@0IgYOeK/d">
        Das ist ein Funktionierendes. nur halt eben ohne blinken ?
        • Daniel Schwarz
          @dslraser
          Ich frage mich wie DU es realisieren würdest, also nicht nur die lampen blinken, sondern den kompletten datensatz... etc.
          iich würde echt behaupten, das es einen Konflikt in dem ganzen gibt.
          • dslraser
            @Daniel-Schwarz
            schaue ich mir später mal an
            Daniel Schwarz 1 Reply Last reply Reply Quote 0
            • Daniel Schwarz
              @dslraser okay alles klar, und vielen dank nochmals für deine hilfe etc.
              tut mir auch echt leid, dass es alles so kompliziert wird bzw ist.
              EDIT:
              Das ist der Part wo ich mit angefangen habe..
              FORUM LINK
              • dslraser
                @Daniel-Schwarz
                probiere mal so, testen kann ich es ja nicht, da ich Deine Geräte nicht habe.
                fünf Beiträge runter.....
                • Daniel Schwarz
                  @dslraser
                  gibt es einen grund weshalb bei einem block timeout dabei ist und beim anderen nicht ?
                  • dslraser
                    @Daniel-Schwarz sagte in Hue Lampe Blinken lassen:
                    Es gibt übrigens schon so einige Waschmaschinenscripte hier im Forum. Manche Waschmaschinen machen auch längere Pausen während des Waschganges und melden dann fertig, weil der Verbrauch zu niedrig war....usw.usw.usw. Die Scripte, die ich hier schon gesehen habe, berücksichtigen auch so etwas. Einfach mal die Suche bemühen.
                    • dslraser
                      moment---
                      • Daniel Schwarz
                        @dslraser
                        Ja danke, das hatte ich vorher schon gemacht, aber die waren iwie alle nicht so wirklicch wie ich es wollte...
                        EDIT:
                        Der Alarm button ist aber jetzt ohne funktion oder ?
                        da gerade keine maschine mehr läuft.
                        • dslraser
                          @Daniel-Schwarz
                           <variables>
                             <variable type="" id="xL{FzofqhyJnPQq`w`6A">Wohnzimmer_vorherige_Farbe</variable>
                             <variable type="" id="S|;`41z#2)fy^=rNAo~q">Licht_war_aus</variable>
                             <variable type="" id="Kc{,!;GakGUAz,3b2Fmi">Wunschfarbe</variable>
                             <variable type="undefined" id="Alarm">Alarm</variable>
                             <variable type="" id="#-mXz|12s@TMb{7:o;u`">Alarmfarbe</variable>
                             <variable type="undefined" id="vorher">vorher</variable>
                           </variables>
                           <block type="comment" id="I6dC10r:h!zx%yxI6$-C" x="13" y="1438">
                                       <block type="logic_operation" id="}A|D9zK[RvsatF3t207-" inline="false">
                                     <value name="IF1">
                                       <block type="logic_operation" id="hr-gsMEPM%q-NFnrii^a" inline="false">
                                           <block type="controls_if" id=",VT_(}-]A9;)0R(vSU]b">
                                               <block type="logic_operation" id="z=E|D(bH-sMAk36(LLoS" inline="false">
                                                   <block type="logic_compare" id="c5G,b,Shw]HQ?lw,Bg7a">
                                                       <block type="get_value" id="k%N/@JIfr`Zw(_XHXfbL">
                                                       <block type="logic_boolean" id="P@eVRqlr24$(}/OSJfO?">
                                                   <block type="logic_compare" id="f3n4C7WFRM+kZLKub[Vr">
                                                       <block type="get_value" id="wkj(TG+71zYi^KoXMn7u">
                                                         <field name="OID">hue.0.Wohnzimmer.on</field>
                                                       <block type="logic_boolean" id="VGngcb_qiQ40#^(:6BAE">
                                               <block type="variables_set" id="!gVq(9GOHu}!7:/$%dH(">
                                                 <field name="VAR" id="xL{FzofqhyJnPQq`w`6A" variabletype="">Wohnzimmer_vorherige_Farbe</field>
                                                   <block type="text_join" id="ubTVdLS$;!d.M`e:xVl~">
                                                     <mutation items="13"></mutation>
                                                     <value name="ADD0">
                                                       <block type="text" id="j=i8G+L{#L}24{xa{hG5">
                                                         <field name="TEXT">{"on":</field>
                                                     <value name="ADD1">
                                                       <block type="get_value" id="vzLd^92gIs,1^3d=G]=a">
                                                     <value name="ADD2">
                                                       <block type="text" id="!~F-*j%?1RNBag?`n:R=">
                                                         <field name="TEXT">,"level":</field>
                                                     <value name="ADD3">
                                                       <block type="get_value" id="Bg_P[|O+,Mu00BYv,g{;">
                                                         <field name="OID">hue.0.Wohnzimmer.level</field>
                                                     <value name="ADD4">
                                                       <block type="text" id="?,aj$+AM9OqDcY=ee?;,">
                                                         <field name="TEXT">,"hue":</field>
                                                     <value name="ADD5">
                                                       <block type="get_value" id="/r9qP/YM[I/S564$R@=;">
                                                         <field name="OID">hue.0.Wohnzimmer.hue</field>
                                                     <value name="ADD6">
                                                       <block type="text" id="_;F=(a5[)uRsLHy@Hn/H">
                                                         <field name="TEXT">,"b":</field>
                                                     <value name="ADD7">
                                                       <block type="get_value" id="lZ,#.V9eKtZ7kq,nQ!(V">
                                                         <field name="OID">hue.0.Wohnzimmer.b</field>
                                                     <value name="ADD8">
                                                       <block type="text" id="0dk;OC2*=2DNQ+Z/P|ah">
                                                         <field name="TEXT">,"g":</field>
                                                     <value name="ADD9">
                                                       <block type="get_value" id="25VAjGL3EfK%UG*{QvC4">
                                                         <field name="OID">hue.0.Wohnzimmer.g</field>
                                                     <value name="ADD10">
                                                       <block type="text" id="uK@M{CN[e|ZCbI^n1huo">
                                                         <field name="TEXT">,"r":</field>
                                                     <value name="ADD11">
                                                       <block type="get_value" id="CahP{k1``=L!pBlxFVa_">
                                                         <field name="OID">hue.0.Wohnzimmer.r</field>
                                                     <value name="ADD12">
                                                       <block type="text" id="3t#WOjP5^1^gG,}ev0.5">
                                                         <field name="TEXT">,"alert":"none","transitiontime":100}</field>
                                             <value name="IF1">
                                               <block type="logic_operation" id="j8`X7P7ftm/gF~EfsiDG" inline="false">
                                                   <block type="logic_compare" id="L0JhREFF`j9!rE5Nv$)i">
                                                       <block type="get_value" id="i*TEOWmP#Y@O=MKH(oM,">
                                                       <block type="logic_boolean" id="G]tQU(3kQeXYC(lcG3JG">
                                                   <block type="logic_compare" id="iZ8O3#v6aum^VV2*lbCE">
                                                       <block type="get_value" id="R4Uwu2xy,%qj=K%7?P!%">
                                                       <block type="logic_boolean" id="50lP69)k7B[]Rk/9QQXx">
                                               <block type="variables_set" id="tJoznpM~~gpGKq34/4p4">
                                                 <field name="VAR" id="S|;`41z#2)fy^=rNAo~q" variabletype="">Licht_war_aus</field>
                                                   <block type="logic_boolean" id="9(egRKvQ6Og:9}X9vqe[">
                                                   <block type="variables_set" id="$]v];32jRO^r|FSZ@.A5">
                                                     <field name="VAR" id="Kc{,!;GakGUAz,3b2Fmi" variabletype="">Wunschfarbe</field>
                                                       <block type="text" id="4`@%7@YzY2tQ_3rWu3Mq">
                                                         <field name="TEXT">{"on":true,"level":100,"hue":26,"b":8,"g":138,"r":254,"alert":"none","transitiontime":100}</field>
                                                       <block type="timeouts_settimeout" id="[w0aUWyvjzp=-t9`)PNW">
                                                         <field name="NAME">Alarm</field>
                                                         <field name="DELAY">100</field>
                                                         <field name="UNIT">ms</field>
                                                           <block type="variables_set" id="RLN*#zZ3qy9yYHO`0/g^">
                                                             <field name="VAR" id="#-mXz|12s@TMb{7:o;u`" variabletype="">Alarmfarbe</field>
                                                               <block type="text" id="4x#.$y:DTRa:HHhdn_c]">
        <field name="TEXT">{"level":100, "hue":0,"alert":"lselect", "transitiontime":0}</field>
                                                               <block type="control" id="itzibgpZWAu(DBWms?jg">
        <field name="OID">hue.0.Wohnzimmer.command</field>
        <block type="variables_get" id="wuNXQStvBk*;W{8k2L4Y">
                                                           <block type="timeouts_settimeout" id="-8pz2t/Vcu1_p25SIXB]">
                                                             <field name="NAME">vorher</field>
                                                             <field name="DELAY">15</field>
                                                               <block type="controls_if" id="GIak!-2;;-0,.0eEN@1E">
        <block type="logic_compare" id="{1GrBE@GyW!b_?2vJZlO">
        <block type="variables_get" id="ZCIWnTB*gH%^zYA[xZE,">
        <block type="logic_boolean" id="(E]3,vuEW|]mqQ5i,K-Z">
        <block type="control" id="DP@=NkP}mRlad9fvV_uS">
        <block type="variables_get" id="l82L(3J,zRC$!GFJj*g*">
        <statement name="ELSE">
        <block type="control" id="YEni4AhjTr^SC7ilRz}n">
        <block type="variables_get" id=",J;X#!07T[Ryi]-=S$u]">
        <block type="control" id="{q*`mUco|1E;Vj2}Nm$8">
        <block type="text" id="{X/sr6W2Qh2HhcpY]yF{">
        <field name="TEXT">{"on":false,"transitiontime":100}</field>
        <block type="variables_set" id="}]4UV1{QQ:@0dNDw?r_-">
        <block type="logic_boolean" id="zX^|qC#13:NlHPnFok{D">
                                                     <value name="ADD0">
                                                     <value name="ADD1">
                                                     <value name="ADD2">
                                                     <value name="ADD3">
                           <variables>
                           </variables>
                           <block type="comment" id="MT|OG_uE2Vv|b(gV]g!-" x="13" y="13">
                                       <block type="logic_operation" id="tUg/fnG6gl=C,e5r@2;=" inline="false">
                                     <value name="IF1">
                                       <block type="logic_operation" id="={^U$UE)w[X.op!T$8*N" inline="false">
                                           <block type="controls_if" id="x7EaBGDENGkS0TK$B(w%">
                                               <block type="logic_operation" id="LW?[?l=}r.1ML6e^o*,3" inline="false">
                                                   <block type="logic_compare" id="9Ea.9@n4DIBz7tWsc6o*">
                                                       <block type="get_value" id="5}T=ct9l_@9tTUYZ::_w">
                                                       <block type="logic_boolean" id="f]/Qoa#8bQ(q*Pje|!nl">
                                                   <block type="logic_compare" id="30g!.(l0Yz5tvvKT9zzb">
                                                       <block type="get_value" id="wb-!ZwL$5tlE[u#]q7U:">
                                                       <block type="logic_boolean" id="%%$B?OA0N]qeoVVRKc(V">
                                               <block type="variables_set" id="vFGzS*?e-L}yh=0?jQ$u">
                                                   <block type="text_join" id="6T#,e*QX)JI}=$[}@@F4">
                                                     <value name="ADD0">
                                                       <block type="text" id="BLAPc(kX=qJDT5@b^B,i">
                                                     <value name="ADD1">
                                                       <block type="get_value" id="zf_4g.5VYBb*TM:80NpY">
                                                     <value name="ADD2">
                                                       <block type="text" id="*(kgm^2[yijPGj1JLSh%">
                                                     <value name="ADD3">
                                                       <block type="get_value" id="-=SLN~~ws!mz+u6O^rwP">
                                                     <value name="ADD4">
                                                       <block type="text" id="p^_FJZ$u2Q+kd3m^J?v5">
                                                     <value name="ADD5">
                                                       <block type="get_value" id="p/lV)o`b5s#-k;6*j9;^">
                                                     <value name="ADD6">
                                                       <block type="text" id=":wM^jaL+TpCBosd39zm_">
                                                     <value name="ADD7">
                                                       <block type="get_value" id="#CgM4;GS)VGck+!?{(XD">
                                                     <value name="ADD8">
                                                       <block type="text" id="[jD.nSA{1|7w;x[wkOa!">
                                                     <value name="ADD9">
                                                       <block type="get_value" id="W?7eP{m%W~[vUBaRH2Y!">
                                                       <block type="text" id="I#~*w5O1nYlindL01c2l">
                                                       <block type="get_value" id="SE{4.Z9{i2u4W/XMASk-">
                                                       <block type="text" id="!@2BF{`%TzO(.p=cM}5p">
                                             <value name="IF1">
                                               <block type="logic_operation" id="-V?QlS$ER+Fe(ZHZC~%o" inline="false">
                                                   <block type="logic_compare" id="QN;Whhb!wyUdG|0*MyW~">
                                                       <block type="get_value" id="D{js@!jhP_L7Z_p`F}i7">
                                                       <block type="logic_boolean" id="d%,fy8}x#]dAgOStYmcl">
                                                   <block type="logic_compare" id="9p}B2%XhPb.K%zA7Nn++">
                                                       <block type="get_value" id="@$qJs*-*ll^P~u*@ZxOO">
                                                       <block type="logic_boolean" id="?tOk4~D(sfU*H,x/b/Ur">
                                               <block type="variables_set" id="1{#BvcF-KWA0gzdT]tV4">
                                                   <block type="logic_boolean" id=")9NmF]!UU%20UG$X|4#9">
                                                   <block type="variables_set" id="k*Vmi0*!8U,dBa=_YE!O">
                                                       <block type="text" id="[#3;`R6-8_xy7A6Mj-=}">
                                               <block type="timeouts_settimeout" id="t5z9IGhAM2U||A=l?oE+">
                                                   <block type="variables_set" id="eV2nz=S+o0Qh#knfX(VX">
                                                       <block type="text" id="6=Nsu~FIZ]GOWy9RW!a~">
                                                       <block type="control" id="Lr:]7?$$Digass0*HoR[">
                                                           <block type="variables_get" id="=]YL~Rr~V00O,oe*2!)R">
                                                   <block type="timeouts_settimeout" id="Ft#CxWl=aL97Eq/1At(.">
                                                       <block type="controls_if" id="S]ZcTCCaff{|N8s3lG,b">
                                                           <block type="logic_compare" id="uw*LFp.7s+wAcB}w_9;u">
                                                               <block type="variables_get" id="bJ7WHnuwLBnUP7xEp}K8">
                                                               <block type="logic_boolean" id="m`;umRIZO%.tdGH$8;.)">
                                                           <block type="control" id="H-EBF0vG#rLz{@[/;^V0">
                                                               <block type="variables_get" id="~8~Jn?G+5I5`YE`8w#Qr">
                                                           <block type="control" id="lit.[J:;U2L[@{-{bf`(">
                                                               <block type="variables_get" id="AhY{UEx!(:@VRu]a`x2j">
                                                               <block type="control" id="@v0.X3AAGc*U8Udhqu[M">
        <block type="text" id="K~17t7:-PAkJ4{{TZMY}">
                                                           <block type="variables_set" id="3c;Mfm,.pYC$g%7{P}ez">
                                                               <block type="logic_boolean" id="hQ1J)7f.t$79)ORQc9#g">
                                                           <block type="text_join" id="=C{XRK$K(5v~dtj#7f0C" inline="false">
                                                             <value name="ADD0">
                                                             <value name="ADD1">
                                                             <value name="ADD2">
                                                             <value name="ADD3">
                          Ich habe mal zwei getrennte Blocklys draus gemacht. (auch wegen den Variablen und Timeouts)
                          Der war ja nur zum testen ob das blinken überhaupt funktioniert. Den brauchst Du in dem Waschmaschienenscript ja nicht.
                          • Daniel Schwarz
                            @dslraser
                            Okay, habe sie jetzt auch getrennt gesetzt.
                            Okay, habe verstanden, das heisst aber auch das ich es so jetzt nicht testen kann, da keine WM läuft. auch nicht wenn ich den DP auf true setze.
                            Aber dann schauen wir einfach mal.
                            BBTown dslraser 2 Replies Last reply Reply Quote 0
                            • BBTown
                              BBTown @Daniel Schwarz last edited by
                              @Daniel-Schwarz kannst Du nicht einfach eine Lampe an die Steckdose hängen?
                              • dslraser
                                @Daniel-Schwarz
                                übrigens, hier ist ein Waschmaschinen Blockly was ich meinte
                                https://forum.iobroker.net/post/9569
                                • Daniel Schwarz
                                  Daniel Schwarz @BBTown last edited by
                                  @BBTown
                                  Und dann mache ich was damit ?
                                  Wie genau stellst du dir das vor ?
                                  • BBTown
                                    BBTown @Daniel Schwarz last edited by BBTown
                                    @Daniel-Schwarz zur Simulation von Last/(Strom)Verbrauch?!
                                    Daniel Schwarz 1 Reply Last reply Reply Quote 1
                                    • Daniel Schwarz
                                      @BBTown
                                      Achsoooo, hahaha okay, das macht sinn.
                                      • Daniel Schwarz
                                        @dslraser
                                        Ja das hatte ich glaube auch gesehen gehabt, aber frag mich jetzt mal noch was damit war...
                                        • Daniel Schwarz
                                          @dslraser
                                          hmm jetzt mit lampe dran, ändert der mir nicht mehr den wert auf true... trotz 5 watt verbrauch
                                          und somit passiert gar nichts
                                          • dslraser
                                            @Daniel-Schwarz
                                            Ich habe jetzt nochmal eine Weile "rumprobiert". Bei mir habe ich als Trigger mal eine normale Schaltsteckdose genommen. Ich habe noch mal einiges verändert. Bei mir hat es so funktioniert, auch wenn die Lampe vorher weiß war. Alarmfarbe ist rot eingestellt. Ich habe dann mal versucht alles auf Dein Blockly zu übertragen. Probier mal bitte dieses Blockly. Ist aber erstmal nur eine Maschine. Wenn es bei Dir funktioniert, kannst Du das ja leicht kopieren.
                                             <variables>
                                               <variable type="undefined" id="Alarm_Lampe_war_aus">Alarm_Lampe_war_aus</variable>
                                               <variable type="undefined" id="Alarm_Lampe_war_an">Alarm_Lampe_war_an</variable>
                                             </variables>
                                             <block type="comment" id="I6dC10r:h!zx%yxI6$-C" x="12" y="-38">
                                                     <block type="variables_set" id="ULJqVA?$K6.qMKQmbpRF">
                                                         <block type="text" id="{4CLW]o@hF(XGimYxu!C">
                                                           <field name="TEXT">{"level":100, "r":100,"alert":"lselect", "transitiontime":0}</field>
        <block type="control" id="EfmaiW1eoFma/%;tx/uN" inline="false" collapsed="true">
                                                           <value name="IF1">
        <block type="control" id="GwM0IrbMj(VE?$_04hV9" inline="false" collapsed="true">
        <value name="ADD0">
        <value name="ADD1">
        <value name="ADD2">
        <value name="ADD3">
        <block type="controls_if" id="x7EaBGDENGkS0TK$B(w%" collapsed="true">
        <block type="logic_operation" id="PAjio?x9XqtLn+sM$^~q" inline="false">
        <block type="logic_compare" id="IW.`[*:u==j[DNQ[OK`v">
        <block type="get_value" id=")6u:-]J@!i|}|j(E]B5E">
        <block type="logic_boolean" id="~hEVoG5CyoN+sv{{BB;K">
        <block type="logic_compare" id="3Eh6Ruq3H3S?}EpnQAlM">
        <block type="get_value" id="wwa*TbF/?8e-9#irr@*7">
        <block type="logic_boolean" id="VVv5Ot[TY?N(F]t(Z%|e">
        <block type="variables_set" id="b9urUe=Yr_=iU%5)h|ck" collapsed="true">
        <block type="text_join" id="`L[zcsiZx)1,O|jJ7lj.">
        <value name="ADD0">
        <block type="text" id="Hj|8{9!c.`mrJpCpt(m*">
        <value name="ADD1">
        <block type="get_value" id="M$p9OXLjw:*)^]gC:-i6">
        <value name="ADD2">
        <block type="text" id="%,HS[U!kGOs6N|2dhTm+">
        <value name="ADD3">
        <block type="get_value" id="k]p#2VxJ=OGEQ3^=U*)=">
        <value name="ADD4">
        <block type="text" id="RyhIk(X^q;q`N|qWECJ7">
        <value name="ADD5">
        <block type="get_value" id="rO,4OhiK)-Q-{ghDa(sS">
        <value name="ADD6">
        <block type="text" id=".F;_~LVo_OM$O|(wv@!+">
        <value name="ADD7">
        <block type="get_value" id=":U7N4aga!ZwD6l3_]c[9">
        <value name="ADD8">
        <block type="text" id="3@5q{w56qn#/(O}ad.{s">
        <value name="ADD9">
        <block type="get_value" id="q.[-(gAE~r-E!-cmf_9B">
        <block type="text" id="04W{15E)S8LMHA;zT,E0">
        <block type="get_value" id="d@^/0!PhczCl{FM2gvvH">
        <block type="text" id="Jon021N2wE7[ak6cXIi{">
        <block type="control" id="=H;{e=)jtRyl?L;+esN5">
        <block type="variables_get" id="$B*S6d:hz(=OE7:WBL94">
        <block type="timeouts_settimeout" id="S28bVy@ODVoyUu`ye5|6">
        <field name="NAME">Alarm_Lampe_war_an</field>
        <block type="control" id="{XMp]}%uGE8`a_m@BCO:">
        <block type="variables_get" id="+:@vtVc}$kWuz95#miMy">
        <value name="IF1">
        <block type="logic_operation" id="`bIKUuu5gGPq.kc/0[B{" inline="false">
        <block type="logic_compare" id="g,dV!V]g!02H*i3LW8`x">
        <block type="get_value" id="^$-@@~n5ehaQsz*5:U-g">
        <block type="logic_boolean" id="WKM`Bx)0{M;V5EpO8JG.">
        <block type="logic_compare" id="Bd]E6m(;Lf,YE=@HLhQ[">
        <block type="get_value" id="6qX?KVvAZE;Aj/REs.qf">
        <block type="logic_boolean" id="ba9_5y;6I0@ydx-ef0eW">
        <block type="control" id="((?FlJ;;5hSWq3BOmXJo">
        <block type="variables_get" id="WC?J1+1dz;49!JWv_3n.">
        <block type="timeouts_settimeout" id="791GG7L%DRqAIc*g|Nnc">
        <field name="NAME">Alarm_Lampe_war_aus</field>
        <block type="control" id="Lfyri[#!.2{$vTM(rSZj">
        <block type="variables_get" id="{NgNb?Ub]toZlPfO}zn+">
        <block type="control" id="j2}?Ujr8Svat_5G5N[-b">
        <block type="text" id="x_IAyAfmce@2;$RjkMNZ">
                                                     <block type="on_ext" id="Dh1}]g.*Y*2#PG/$}Psa" collapsed="true">
                                                       <value name="OID0">
                                                         <shadow type="field_oid" id="a8BEpy1,Ciq)TQS#2oN0">
                                                           <field name="oid">hue.0.Wohnzimmer.on</field>
                                                         <block type="controls_if" id="xz9Ub9K6w.t})FIQLm9P" collapsed="true">
                                                             <block type="logic_compare" id="OA[*$L0[YIdLwK5`3Tq*">
        <block type="get_value" id="Stp10`qq66fCh@rMKw=_">
        <block type="logic_boolean" id=".#=1[HB/E{XyH4Mr~j#T">
                                                             <block type="variables_set" id="YP)!R%ZP*B{%*%0No3^{" collapsed="true">
        <block type="text_join" id="u]q(L56`9=n/~*Oo}I|J">
        <value name="ADD0">
        <block type="text" id=";!f5?_5d4d7[nJiVl4=j">
        <value name="ADD1">
        <block type="get_value" id="|uSHbIn%=YCYQQ,{201:">
        <value name="ADD2">
        <block type="text" id="/cC_ginyj^d4A*BU):?}">
        <value name="ADD3">
        <block type="get_value" id="aC,7],iC=DfbOxlSxnf5">
        <value name="ADD4">
        <block type="text" id="kD$;bezgb}R}*jt4Z8#)">
        <value name="ADD5">
        <block type="get_value" id="(yc21Iu4{DLTk(S8+Rii">
        <value name="ADD6">
        <block type="text" id="{s4PtLN{l{FF(piL!Du=">
        <value name="ADD7">
        <block type="get_value" id="D`YT|*rvxxaC)*Q:{0^-">
        <value name="ADD8">
        <block type="text" id="uR?yhpbjUfq^h;?!~USm">
        <value name="ADD9">
        <block type="get_value" id="u`VR1]tsjAWUISn@|qs{">
        <block type="text" id="ObA%_^^v|%W$ha8e?qx7">
        <block type="get_value" id="%ZI29W$U+R/m,?ULDU!H">
        <block type="text" id="-?SSZuhw/PW(:(`/JASx">
                                            blockly
                                            13
                                            105
                                            15368
