    4. [Vorstellung] Meine zweite Visualisierung
    • Uli977
      Uli977 @Kuddel last edited by
      @Kuddel kannst du mir dein Scipt uptime mal schicken?
        Kuddel @Uli977 last edited by
        @Uli977 mittlerwiele habe ich für jedes Gerät ein einzelnes Skript. Es wurde zu unübersichtlich ^^
        Hier das Skript für den ioBroker (Blockly Export):
        <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="S},%B!W7FjU|w+;Bi3u/" x="-662" y="-336">
         <field name="SCHEDULE">*/1 * * * *</field>
           <block type="variables_set" id="c;vRX]+MD3w~Fa4u0_oA">
             <field name="VAR" id="xR[!J/DBv`U}Y:9[0lI`" variabletype="">raw</field>
               <block type="get_value" id="#=Ud:?8|Bc0R?oq(}{Vz">
                 <field name="OID">rpi2.0.uptime.uptime</field>
               <block type="variables_set" id=":+s25++7%;E1ZPSp_bNH">
                 <field name="VAR" id="t?tbMWd@B^!Lwtws97h(" variabletype="">tage</field>
                   <block type="math_round" id="V_n,Z?87Yzo#1@Gk)B_|">
                     <field name="OP">ROUNDDOWN</field>
                     <value name="NUM">
                       <shadow type="math_number" id="w)m[6-o#SFO|})aX;^Sn">
                         <field name="NUM">3.1</field>
                       <block type="math_arithmetic" id="#vPh0eWHzHbmc0{P(xGl">
                         <field name="OP">DIVIDE</field>
                           <shadow type="math_number" id="bahI:FVxEi%`f[PVR#?r">
                             <field name="NUM">1</field>
                           <block type="get_value" id="[]}_AgMQs2tS-b3SOG6:">
                           <shadow type="math_number" id="cBfkqtHp/(na=hF*Xs;{">
                             <field name="NUM">86400</field>
                   <block type="variables_set" id="xf#[c;spkxV;?_=;2t4]">
                     <field name="VAR" id="@Xe/hH@K?lg~ckA0s$1v" variabletype="">zw</field>
                       <block type="math_arithmetic" id="g85j0([NmkejbN]_LFQ;">
                           <shadow type="math_number" id="}H73ztKqU,dkWZ,F,i*R">
                           <block type="variables_get" id="-VqLq_~+I^S2}L3!#xzI">
                           <shadow type="math_number" id="P5_|Dw(]!C*d/0LDlJX[">
                           <block type="math_arithmetic" id="8KQWiO_0+1E7KPBL`BnK">
                               <shadow type="math_number" id=",I@|[8va{Mw(V#ASt9{M">
                               <block type="variables_get" id="HYJ?9+`q-3)^O0iZJD-[">
                               <shadow type="math_number" id="@(,y`FuDg+P*5o[794U6">
                       <block type="variables_set" id="eAJhBVv3}N8LUFKRAWGZ">
                         <field name="VAR" id="sFV`GY=PcXe}ZLrky{bK" variabletype="">std</field>
                           <block type="math_round" id="/RbEc%QP!6/M9EimZe]N">
                             <value name="NUM">
                                 <field name="NUM">0</field>
                               <block type="math_arithmetic" id="BFHl3E~ysn|,xUa5Vb8#">
                                   <block type="variables_get" id="7=o8aPA{`ENu)Ede_%B@">
                                   <shadow type="math_number" id="6k]Nz4u+nuL.OON8Z+?j">
                                     <field name="NUM">3600</field>
                           <block type="variables_set" id=".+IdB1+tIgC(cXj^#9gr">
                             <field name="VAR" id="ThAY6m1`ng2#i#jP3dUp" variabletype="">zw2</field>
                               <block type="math_arithmetic" id="Tb1}ci*dwi]?N(+VZS0*">
                                   <block type="variables_get" id="pl@KE2~vpoFkF~SSzk%%">
                                   <block type="math_arithmetic" id="pIkaJRUH0EN9i5BFh|Ou">
                                       <block type="variables_get" id="^B.o=TuQbG!2~GNM/e-d">
                                       <shadow type="math_number" id="jHJ,OA,V7xyG1^Be^jW.">
                               <block type="variables_set" id="6GHul#I2g`ZkYC1e~C{1">
                                 <field name="VAR" id="pf9`Yy1b?]wA]a6U/B*@" variabletype="">min</field>
                                   <block type="math_round" id="I%[WOX~v6)8yc}K1_|nS">
                                     <value name="NUM">
                                       <block type="math_arithmetic" id="kqIicz=;J=5v)|+`2Vs)">
                                           <block type="variables_get" id="/E]PwFOERrG;mY.@U?fN">
                                           <shadow type="math_number" id=":5Jjoq2?fnn.3?nX.qu5">
                                             <field name="NUM">60</field>
                                   <block type="comment" id="}62au5%|-uoD0^;/S~ro">
                                     <field name="COMMENT">0 bei Std hinzufügen</field>
                                       <block type="controls_if" id="?TXM*.u^oR?=mu!C7#Gu">
                                           <block type="logic_compare" id="[p}YkaS];xdRMD*ap48G">
                                             <field name="OP">LT</field>
                                               <block type="variables_get" id="J{uV_w/y/+ZCV.l3D|i:">
                                               <block type="math_number" id="gI1:JylA#77yV(JkpK-B">
                                                 <field name="NUM">10</field>
                                           <block type="variables_set" id="ys[j:Xn^gP:?Hv[zAW6#">
                                               <block type="text_join" id="d.!cr#8mc8)?UUgV:OX7">
                                                 <value name="ADD0">
                                                   <block type="text" id="OJ@x,#Ao.]qv/F1*WGrw">
                                                     <field name="TEXT">0</field>
                                                 <value name="ADD1">
                                                   <block type="variables_get" id="zZIf^PD**]GNm8rfZgWV">
                                           <block type="comment" id="}Dx+SO@qP}PgQPnCiPe~">
                                             <field name="COMMENT">0 bei Min hinzufügen</field>
                                               <block type="controls_if" id="w9ZUSJJysyrxjo%O}*AF">
                                                   <block type="logic_compare" id="wJ}HmbQ.3A%3lP*+{9:B">
                                                       <block type="variables_get" id="S(W}:D+!I,z}N@-!qlLJ">
                                                       <block type="math_number" id="Pbic4r3a3N.-[@ukd.l3">
                                                   <block type="variables_set" id="%^^k8,?cY?eR!Zo]qZIX">
                                                       <block type="text_join" id="emQn)QW2nx4diB92R^vk">
                                                         <value name="ADD0">
                                                           <block type="text" id="USkT*`Qj|%3NxDYYt}Bu">
                                                         <value name="ADD1">
                                                           <block type="variables_get" id="6p0+r[)u0Krqi;d4:,ZD">
                                                   <block type="controls_if" id="v@B2k(R?[gCoK1a~I9`F">
                                                       <block type="logic_compare" id="1dfxjx[N`Epx2~*6W~7;">
                                                         <field name="OP">EQ</field>
                                                           <block type="variables_get" id="l^{OAh,GFMX(@#9-warp">
                                                           <block type="math_number" id="!V0n5d2Z-i!(iBk895]x">
                                                       <block type="update" id="}dygd@NM}^+sSCG`^@Xn">
                                                         <field name="OID">javascript.0.uptime.iobroker</field>
                                                           <block type="text_join" id="]#nx!b5z}YAPXTsmNLQ|">
                                                             <mutation items="6"></mutation>
                                                             <value name="ADD0">
                                                               <block type="variables_get" id="+aVEIO9S5O-.3_#gOO/x">
                                                             <value name="ADD1">
                                                               <block type="text" id="]erCl}B}Ea`ac^[!:!*)">
        <field name="TEXT"> Tag, </field>
                                                             <value name="ADD2">
                                                               <block type="variables_get" id="a%[T3/e/(_l9BPIVM(-)">
                                                             <value name="ADD3">
                                                               <block type="text" id="qF9D;Tv`WFo,)3,+[|Ve">
        <field name="TEXT"> Std, </field>
                                                             <value name="ADD4">
                                                               <block type="variables_get" id="j`B:8.qUHr*`vdar-A}K">
                                                             <value name="ADD5">
                                                               <block type="text" id="bV2z[/bBEhy_BqMy.UHC">
        <field name="TEXT"> Min</field>
                                                     <statement name="ELSE">
                                                       <block type="update" id="(g+SDiV]@I6UoHl8jE.i">
                                                           <block type="text_join" id="|gSv+WZHIMcsYv;iY}y5">
                                                             <value name="ADD0">
                                                               <block type="variables_get" id=";lH~jePSwnZZ`B9Uf9#8">
                                                             <value name="ADD1">
                                                               <block type="text" id="_N5MntuQ3.OAGrQ,UEnV">
        <field name="TEXT"> Tage, </field>
                                                             <value name="ADD2">
                                                               <block type="variables_get" id=".4sH_?4VFhqf^8u!M7F9">
                                                             <value name="ADD3">
                                                               <block type="text" id="V0sqG%|UzZe:%=_GTSO%">
                                                             <value name="ADD4">
                                                               <block type="variables_get" id="~~tdGbeXHF,RXc4-gV[i">
                                                             <value name="ADD5">
                                                               <block type="text" id="1oy#IR@#^HupeI(++C48">
        Uli977 2 Replies Last reply Reply Quote 0
        • Uli977
          @Kuddel Danke! Probiere ich mal aus.
          • Uli977
            Uli977 @Kuddel last edited by Uli977
            @Kuddel Komisch, laut Meldung wird der rpi2 erfolgreich installiert, aber ich finde ihn nicht in den Instanzen... hä?
              crunchip Forum Testing Most Active @Uli977 last edited by
              @Uli977
              • wenn du von git installierst, musst du die Instanz manuell hinzufügen.
              • für was brauchst du diesen Adapter denn? Läuft dein System auf einen PI?
              • Uptime findest du doch unter system.host.ioBroker
              Uli977 1 Reply Last reply Reply Quote 0
              • Uli977
                Uli977 @crunchip last edited by
                @crunchip
                Ich nutze einen RockPi 4B.
                Wahrscheinlich hast du recht, für diesen einen Fall kann ich system.host.ioBroker nehmen.
                • N
                  nautilusweb @Kuddel last edited by
                  hier mal ein Screenshot von dem Tooltip.
                  Mir fehlen halt ein paar Zeiten und ich verstehe nicht wo die herkommen sollen....
                    mario.blass last edited by
                    ich finde es nicht witzig, dass du das hier veröffentlichst 😟
                    Ich dachte, dass ich mit meiner Visu fertig bin, aber wenn ich das hier sehe, kann ich nur sagen HUT ab !!!
                    Na ja, man wird halt nie fertig.
                    Respekt.
                      Kuddel @nautilusweb last edited by
                      @nautilusweb den Tooltip kannst du ignorieren.
                      Poste mal bitte einen Screenhsot von den Fehlenzeiten mit den Namen.
                      was du noch machen kannnst, alle Blockly Blöcke einmal manuell starten.
                      Dazu einfach alles aus den Triggern rauslösen und abspeichern. Dann das Skript einmal starten.
                      Dann sollten alle Objekte gefüllt sein
                        Kuddel @mario.blass last edited by
                        @mario-blass du kannst dich entspannen, ich bin auch noch lange nicht fertig ^^
                        iwas bastel ich doch noch immer dazu....
                        • Pat1968
                          Pat1968 @marco-mh last edited by
                          Hallo
                          Kann einer von euch mal die bilder zur verfügung stellen für die Müllabfuhr?
                          Ob als Sack oder Tonne. Vielen Dank 😉
                          Röstkartoffel 1 Reply Last reply Reply Quote 0
                          • opossum
                            opossum last edited by opossum
                            hier die Icons für Mülltonnen.
                            Muell.zip
                            Die Grafiken habe ich hier aus dem Forum.
                            Pat1968 1 Reply Last reply Reply Quote 0
                            • Röstkartoffel
                              Röstkartoffel @Pat1968 last edited by
                              @Pat1968
                              oder hier:
                              Muell_Icons.zip
                              Das sieht dann so aus (Abfuhrtag ist mit roter Mülltonne):
                              hier das komplette Widget:
                              Muell.txt
                              • Pat1968
                                Pat1968 @opossum last edited by
                                @Kuddel
                                • Pat1968
                                  Pat1968 @Röstkartoffel last edited by
                                  @Röstkartoffel
                                  Hast du Die in der Grünen Tonne?
                                  • Röstkartoffel
                                    @Pat1968
                                    Leider nicht.
                                    Die rote habe ich mir auch selbst gemacht, das könnte ich vielleicht auch noch mal in Grün machen. Wenn gewünscht.
                                    • Pat1968
                                      @Röstkartoffel
                                      Sind die icons in photoshop erstellt worden?
                                      • Röstkartoffel
                                        @Pat1968
                                        Nein. Photoshop kann ich mir nicht leisten 😧
                                        Das Ursprüngliche in weiß stammen aus dem Adapter "icons-material-png" und heißt "ic_delete_white_48dp.png" . Das Rote habe ich selber eingefärbt.
                                        • Pat1968
                                          @Röstkartoffel
                                          Müll PNG.rar
                                          Hab die Gruene mit eingefügt.
                                          Wenn jemand dies braucht 😉
                                          • N
                                            nautilusweb @Kuddel last edited by nautilusweb
                                            @Kuddel welche scripte brauche ich denn alles?
                                            Ich habe alle aus deiner zip importiert, aberes sind nicht alle gestartet.
                                            Vielleicht fehlt mir da ein script, folgende habe ich zusätzlich importiert:
                                            -Fortschritt Tag
                                            -Fortschritt Nacht
                                            -Tages und Nachtzeiten
                                            Hier der Screenshot
                                            template vis
                                            148
                                            1324
                                            490890
