    4. Test Adapter SourceAnalytix v0.2.x
      crunchip Forum Testing Most Active @watcherkb last edited by crunchip
      @watcherkb leider nur als Bild, vom Handy aus
      Und pro Std
        watcherkb @crunchip last edited by watcherkb
        @crunchip auf die Schnelle fällt mir auf das dort keine "role" angegeben ist bei mir: habs mal auf Value gestellt.
            "role": "value",
        bekomme auch beim Neustart des Adapters folgenden error: Sorry unite type qm not supported yet
        shuttercontrol.0	2019-10-29 16:56:41.772	debug	system.adapter.admin.0: logging false
        sourceanalytix.0	2019-10-29 16:55:06.294	debug	Object array : ["admin.0.Datenpunkte.Energie.Gaszähler.aktuell"]
        sourceanalytix.0	2019-10-29 16:55:06.294	error	Sorry unite type qm not supported yet
        sourceanalytix.0	2019-10-29 16:55:06.294	debug	Custom object tree : {"enabled":true,"alias":"Gasverbrauch","state_type":"gas","state_unit":"m3","costs":true,"consumption":true,"meter_values":true,"start_day":6238,"start_week":6238,"start_month":6
        sourceanalytix.0	2019-10-29 16:55:06.294	debug	Content custom of object : {"enabled":true,"alias":"Gasverbrauch","state_type":"gas","state_unit":"m3","costs":true,"consumption":true,"meter_values":true,"start_day":6238,"start_week":6238,"start_mo
        sourceanalytix.0	2019-10-29 16:55:06.294	debug	instanze name : sourceanalytix.0
        sourceanalytix.0	2019-10-29 16:55:06.293	info	Activate SourceAnalytix for : admin.0.Datenpunkte.Energie.Gaszähler.aktuell
        sourceanalytix.0	2019-10-29 16:55:06.291	debug	Result doc : {"rows":[{"id":"sonoff.0.Sonoff_25.POWER","value":{"influxdb.0":{"enabled":true,"changesOnly":true,"debounce":0,"maxLength":10,"retention":0,"changesRelogInterval":0,"changesMinDelta":0,
        sourceanalytix.0	2019-10-29 16:55:06.264	info	Initializing all enabled states for SourceAnalytix
        sourceanalytix.0	2019-10-29 16:55:06.264	info	Adapter SourceAnalytix startet :-)
        sourceanalytix.0	2019-10-29 16:55:06.251	info	starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v10.16.3
        sourceanalytix.0	2019-10-29 16:55:06.246	debug	statesDB connected
        sourceanalytix.0	2019-10-29 16:55:06.238	debug	objectDB connected
        host.IOBroker_Produktiv	2019-10-29 16:55:06.084	info	instance system.adapter.sourceanalytix.0 started with pid 4789
        host.IOBroker_Produktiv	2019-10-29 16:55:03.589	info	instance system.adapter.sourceanalytix.0 terminated with code 156 ()
        sourceanalytix.0	2019-10-29 16:55:03.582	info	Adapter SourceAnalytix stopped !
        sourceanalytix.0	2019-10-29 16:55:03.578	info	Adapter SourceAnalytix stopped !
        host.IOBroker_Produktiv	2019-10-29 16:55:03.578	info	stopInstance system.adapter.sourceanalytix.0 killing pid 15335
        host.IOBroker_Produktiv	2019-10-29 16:55:03.578	info	object change system.adapter.sourceanalytix.0
          @watcherkb dein unit ist da qm3, sollte m3 sein
            @crunchip sagte in Test Adapter SourceAnalytix v0.2.x:
            du hast mich auf den richtigen Pfad gelenkt. Es waren wohl 2 Fehler drin: das q zu viel und das hochgestellte 3 also ³...
            danke dir, jetzt hat sich was an den Werten getan 🙂
            • Elektroniker86
              Elektroniker86 @crunchip last edited by
              was meinst du damit?
              Hab bei mir Gas/Wasser (m3) mit eingebunden, läuft und zählt.
              durch watcherkb bin ich auf die Lösung gekommen bei wir wird der Wert auch in m³ mit der hochgestellten 3 geliefert.
              Ich ändere das ab dann sollte es auch funktionieren.
              • Dutchman
                Dutchman Developer Most Active Administrators @Elektroniker86 last edited by
                @Elektroniker86 sagte in Test Adapter SourceAnalytix v0.2.x:
                crap, macht mir bitte ein issue auf GitHub die hoch 3 kan ich einbauen kein problem.
                Hatte damals nur m3 gemacht ... ups 😕
                  darkbrain85 @Dutchman last edited by
                  @Dutchman sagte in Test Adapter SourceAnalytix v0.2.x:
                  gerade dabei Discovergy adapter wieder vernünftig zum laufen zu bringen, danach ist SA dran 🙂
                  diesen Monat wird sich was tun
                  Mhhhhh.... war wohl nix... 😄
                  Hast du einen Zeitplan wann das wirklich kommt? Im Prinzip warte ich schon seit Anfang des Jahres sehnsüchtig darauf...
                  • Dutchman
                    Dutchman Developer Most Active Administrators @darkbrain85 last edited by
                    @darkbrain85 sagte in Test Adapter SourceAnalytix v0.2.x:
                    bon schon dran, arbeite gerade an multicast API und diesem hier die m3 werte gehen in dev anderen Sachen werden ich abarbeiten.
                    Muss leider auch code bissl umstrukturieren was es bissl komplizierter macht.
                    • hg6806
                      hg6806 Most Active last edited by
                      Noch 'ne kurze Frage.
                      Habe durch meine Solarthermie einen Parser-Wert "Leistung-aufaddiert".
                      Problem ist, dass nach dem Wert 999 keine 1000 sondern wieder 0. 😞
                      Ich bekomme das leider nur so aus dem Gerät heraus.
                      Habe das erst nach Tagen jetzt entdeckt, bzw. rausgefunden.
                      Ich würde jetzt erstmal die Adapter anhalten, Parser Offset 1000 machen und alle Werte in Objects Sourceanalytix ändern. Oder geht das in die Hose?
                      Könnte man das irgendwie vorher speichern für ein "undo"?
                      • Dutchman
                        Dutchman Developer Most Active Administrators @hg6806 last edited by
                        @hg6806 sagte in Test Adapter SourceAnalytix v0.2.x:
                        ich habe nicht direkt eine Lösung fuer dich, kan nur melden das dies in der nächsten version behoben sein wird.
                        Darin adoptieren ich das kumulative zählen, mit anderen Worten : SourceAnalytix mach den zaehelrstand und der wen der an auf 0 sprint zaehl er einfach weiter anstatt auch nach 0 zu gehen.
                        Dies wird konfigurabel sein den nicht jeder möchte das.
                        • hg6806
                          Habe es mal händisch versucht die Daten zu ändern, das endet immer in einem Chaos.
                          Ich hatte glücklicherweise die states.json gesichert und später drübergebügelt, danach hatte ich wenigstens wieder die alten Werte.
                          Tja, dann mal warten auf die heiß-ersehnte nächste Version!.
                          • JB_Sullivan
                            JB_Sullivan last edited by JB_Sullivan
                            Kann mir jemand sagen, woher diese Fehlermeldungen im LOG rühren könnten?
                            Tagellang habe ich gar keine Fehlermeldungen und dann sporadisch wird mir das LOG mit "sourceanalytix.0 2019-11-16 09:20:42.320 error Error in case handling of cost type identificaton : undefined" voll gespamt
                            Hat jemand eine Idee dazu?
                            sourceanalytix.0	2019-11-16 09:20:42.320	debug	State object custom content: {"start_day":1.869,"start_week":0.003,"start_month":"0.977","start_quarter":"0.977"}
                            sourceanalytix.0	2019-11-16 09:20:42.320	debug	State object content: {"_id":"sonoff.0.Waschmaschine.ENERGY_Today","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Waschmaschine ENERGY Today
                            sourceanalytix.0	2019-11-16 09:20:42.320	debug	Calc obj root sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Today
                            sourceanalytix.0	2019-11-16 09:20:42.320	debug	Write calculations for : sonoff.0.Waschmaschine.ENERGY_Today
                            sourceanalytix.0	2019-11-16 09:20:42.320	debug	Instance name : sourceanalytix.0
                            sourceanalytix.0	2019-11-16 09:47:58.448	error	Error in case handling of cost type identificaton : undefined
                            sourceanalytix.0	2019-11-16 09:47:58.448	debug	State object custom content: {"start_day":1.869,"start_week":0.003,"start_month":"0.977","start_quarter":"0.977"}
                            sourceanalytix.0	2019-11-16 09:47:58.448	debug	State object content: {"_id":"sonoff.0.Waschmaschine.ENERGY_Today","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Waschmaschine ENERGY Today
                            sourceanalytix.0	2019-11-16 09:47:58.448	debug	State object custom content: {"start_day":1.42,"start_week":0.727,"start_month":"1.326","start_quarter":"1.326"}
                            sourceanalytix.0	2019-11-16 09:47:58.433	debug	State object content: {"_id":"sonoff.0.Waschmaschine.ENERGY_Yesterday","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Waschmaschine ENERGY Y
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Calc obj root sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Today
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Write calculations for : sonoff.0.Waschmaschine.ENERGY_Today
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Instance name : sourceanalytix.0
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Calc obj root sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Yesterday
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Write calculations for : sonoff.0.Waschmaschine.ENERGY_Yesterday
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Meter Calculation executed
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	calculated cost year : 68.97
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	calculated cost quarter : 8.91
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	calculated cost month : 2.86
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	calculated cost week : 1.48
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	calculated cost day : 0.01
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	example state string : sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Total.cost.01_current_day
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	delivery type .consumption.
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	cost type .cost.
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	objroot sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Total
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	year consumed 238.646
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	quarter consumed 30.84699999999998
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	month consumed 9.890999999999991
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	week consumed 5.109999999999985
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	day consumed 0.03999999999999204
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	calculated reading day : 238.646
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	calculated reading quarter : 30.847
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	calculated reading month : 9.891
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	calculated reading week : 5.110
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	calculated reading day : 0.040
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Start consumption calculations
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Delivery state set to : .consumption.
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	year start : 0
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	quarter start 207.799
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	month start 228.755
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	week start : 233.536
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	day start : 238.606
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	reading_start : 0
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Handle meter history : false
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Handle consumption calculations : true
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Cost unit : 0.289
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Cost basic : 6
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Calculation Factor : 0.289
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Handle cost calculations : true
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Meter calculated reading : 238.646
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Meter current reading : 238.646
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	State value output of unit factore calculation : 238.646
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Test unit : kwh
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	State value input for unit factore calculation : 238.646
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Object array input for unit factore calculation : {"_id":"sonoff.0.Waschmaschine.ENERGY_Total","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	Case result : Electricity consumption
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	State object custom content: {"enabled":true,"alias":"","state_type":"kWh_consumption","costs":true,"consumption":true,"meter_values":false,"start_meassure":5864,"start_day":238.606,"start_week":233.5
                            sourceanalytix.0	2019-11-16 09:47:58.417	debug	State object content: {"_id":"sonoff.0.Waschmaschine.ENERGY_Total","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Waschmaschine ENERGY Total
                            sourceanalytix.0	2019-11-16 09:47:58.399	debug	Calc obj root sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Total
                            sourceanalytix.0	2019-11-16 09:47:58.399	debug	Write calculations for : sonoff.0.Waschmaschine.ENERGY_Total
                            sourceanalytix.0	2019-11-16 09:47:58.399	debug	Instance name : sourceanalytix.0
                            tankerkoenig.0	2019-11-16 09:47:56.732	info	Reading data from tankerkoenig ...
                            sourceanalytix.0	2019-11-16 09:47:52.350	error	Error in case handling of cost type identificaton : undefined
                            sourceanalytix.0	2019-11-16 09:47:52.350	debug	State object custom content: {"start_day":1.869,"start_week":0.003,"start_month":"0.977","start_quarter":"0.977"}
                            sourceanalytix.0	2019-11-16 09:47:52.350	debug	State object content: {"_id":"sonoff.0.Waschmaschine.ENERGY_Today","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Waschmaschine ENERGY Today
                            sourceanalytix.0	2019-11-16 09:47:52.350	debug	State object custom content: {"start_day":1.42,"start_week":0.727,"start_month":"1.326","start_quarter":"1.326"}
                            sourceanalytix.0	2019-11-16 09:47:52.350	debug	State object content: {"_id":"sonoff.0.Waschmaschine.ENERGY_Yesterday","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Waschmaschine ENERGY Y
                            sourceanalytix.0	2019-11-16 09:47:52.350	debug	Calc obj root sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Today
                            sourceanalytix.0	2019-11-16 09:47:52.350	debug	Write calculations for : sonoff.0.Waschmaschine.ENERGY_Today
                            sourceanalytix.0	2019-11-16 09:47:52.350	debug	Instance name : sourceanalytix.0
                            sourceanalytix.0	2019-11-16 09:47:52.350	debug	Calc obj root sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Yesterday
                            sourceanalytix.0	2019-11-16 09:47:52.350	debug	Write calculations for : sonoff.0.Waschmaschine.ENERGY_Yesterday
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Meter Calculation executed
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	calculated cost year : 68.97
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	calculated cost quarter : 8.91
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	calculated cost month : 2.86
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	calculated cost week : 1.48
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	calculated cost day : 0.01
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	example state string : sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Total.cost.01_current_day
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	delivery type .consumption.
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	cost type .cost.
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	objroot sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Total
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	year consumed 238.646
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	quarter consumed 30.84699999999998
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	month consumed 9.890999999999991
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	week consumed 5.109999999999985
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	day consumed 0.03999999999999204
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	calculated reading day : 238.646
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	calculated reading quarter : 30.847
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	calculated reading month : 9.891
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	calculated reading week : 5.110
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	calculated reading day : 0.040
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Start consumption calculations
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Delivery state set to : .consumption.
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	year start : 0
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	quarter start 207.799
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	month start 228.755
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	week start : 233.536
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	day start : 238.606
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	reading_start : 0
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Handle meter history : false
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Handle consumption calculations : true
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Cost unit : 0.289
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Cost basic : 6
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Calculation Factor : 0.289
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Handle cost calculations : true
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Meter calculated reading : 238.646
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Meter current reading : 238.646
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	State value output of unit factore calculation : 238.646
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Test unit : kwh
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	State value input for unit factore calculation : 238.646
                            sourceanalytix.0	2019-11-16 09:47:52.334	debug	Object array input for unit factore calculation : {"_id":"sonoff.0.Waschmaschine.ENERGY_Total","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":
                            sourceanalytix.0	2019-11-16 09:47:52.318	debug	Case result : Electricity consumption
                            sourceanalytix.0	2019-11-16 09:47:52.318	debug	State object custom content: {"enabled":true,"alias":"","state_type":"kWh_consumption","costs":true,"consumption":true,"meter_values":false,"start_meassure":5864,"start_day":238.606,"start_week":233.5
                            sourceanalytix.0	2019-11-16 09:47:52.318	debug	State object content: {"_id":"sonoff.0.Waschmaschine.ENERGY_Total","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Waschmaschine ENERGY Total
                            sourceanalytix.0	2019-11-16 09:47:52.318	debug	Calc obj root sourceanalytix.0.sonoff__0__Waschmaschine__ENERGY_Total
                            sourceanalytix.0	2019-11-16 09:47:52.318	debug	Write calculations for : sonoff.0.Waschmaschine.ENERGY_Total
                            sourceanalytix.0	2019-11-16 09:47:52.318	debug	Instance name : sourceanalytix.0
                            sourceanalytix.0	2019-11-16 09:47:46.353	error	Error in case handling of cost type identificaton : undefined
                            • Dutchman
                              Dutchman Developer Most Active Administrators @JB_Sullivan last edited by
                              @JB_Sullivan sagte in Test Adapter SourceAnalytix v0.2.x:
                              hi, was hast du hier auswaehlt ?
                              • JB_Sullivan
                                JB_Sullivan @Dutchman last edited by
                                @Dutchman
                                • Dutchman
                                  @Dutchman
                                  gehe mal bitte bei diesen state auf dem schraubschlussel, dan unter raw und copy/paste mal den hinhält hier rein bitte
                                  • JB_Sullivan
                                      "_id": "sonoff.0.Waschmaschine.ENERGY_Total",
                                      "common": {
                                        "type": "number",
                                        "role": "value.power.consumption",
                                        "read": true,
                                        "write": false,
                                        "unit": "kWh",
                                        "name": "Waschmaschine ENERGY  Total",
                                        "custom": {
                                          "sourceanalytix.0": {
                                            "enabled": true,
                                            "alias": "",
                                            "state_type": "kWh_consumption",
                                            "costs": true,
                                            "consumption": true,
                                            "meter_values": false,
                                            "start_meassure": 5864,
                                            "start_day": 239.476,
                                            "start_week": 233.536,
                                            "start_month": 228.755,
                                            "start_quarter": 207.799,
                                            "start_year": 0,
                                            "state_unit": "kWh"
                                      "native": {},
                                      "type": "state",
                                      "from": "system.adapter.sourceanalytix.0",
                                      "ts": 1573945200016,
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636,
                                        "owner": "system.user.admin",
                                      "user": "system.user.admin"
                                    • Dutchman
                                      kWh_consumption
                                      das ist der Datenpunkt von total, im error log ist der today.
                                      btw: du solltest auch den energy total auswerten und nicht today da dieser jeden tag auf 0 springt
                                      • JB_Sullivan
                                        Sorry verklickt - der ist ja auch gleich darunter 😉
                                          "_id": "sonoff.0.Waschmaschine.ENERGY_Today",
                                          "common": {
                                            "type": "number",
                                            "read": true,
                                            "write": false,
                                            "unit": "kWh",
                                            "name": "Waschmaschine ENERGY  Today",
                                            "custom": {
                                                "start_day": 0.87,
                                                "start_week": 0.003,
                                                "start_month": "0.977",
                                                "start_quarter": "0.977"
                                          "native": {},
                                          "type": "state",
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636,
                                        Today ist auch gar nicht aktiviert
                                        Today hole ich mir direkt aus dem Sonoff POW
                                        • Dutchman
                                          wen today nicht aktiviert ist warum kommt er dan im log ? 😉
                                          • JB_Sullivan
                                            Ähhmmmm - möglicherweise ist das ein Wink mit dem Zaunpfahl?!?!? Aber ich verstehe den gerade nicht 😞
                                            adapter test
                                            103
                                            958
                                            288197
