    4. Neuer Adapter vCard
    Neuer Adapter vCard
      looxer01 last edited by
      also eingelesen wird das File nicht. Daher bekomme ich auch nicht die Erfolgsmeldung.
      Wenn ich einen ungültigen Pfad eingebe, dann bekomme ich sowas: error vcard.0 Error reading vcards: Error: ENOENT, open 'http://192.168.0.62/vCard Export.vcf'
      Wenn ich den Pfad direkt eingebe wie im Raspi gespeichert, dann bekomme ich diese Fehler:
      raspberrypi	2015-09-19 15:26:36	info	host.raspberrypi Restart adapter system.adapter.vcard.0 because enabled
      raspberrypi	2015-09-19 15:26:36	error	host.raspberrypi instance system.adapter.vcard.0 terminated with code 6 (uncaught exception)
      vcard.0	2015-09-19 15:26:36	error	TypeError: Cannot set property 'fullname' of undefined at EventEmitter.attributeMatched (/opt/iobroker/node_modules/iobroker.vcard/node_modules/vcard-json/lib/vcard-json.js:72:24) at EventEmit
      vcard.0	2015-09-19 15:26:36	error	uncaught exception: Cannot set property 'fullname' of undefined
      vcard.0	2015-09-19 15:26:36	info	vcard.0 starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.vcard
      raspberrypi	2015-09-19 15:26:35	info	host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (OK)
      raspberrypi	2015-09-19 15:26:33	info	host.raspberrypi instance system.adapter.vcard.0 started with pid 6407
      EDIT: gerade erst gesehen, dass es doch noch mehr Hinweise im LOG gibt:
      TypeError:	2015-09-19 16:10:24	error	at Object.oncomplete (fs.js:107:15)
      TypeError:	2015-09-19 16:10:24	error	at fs.js:266:14
      TypeError:	2015-09-19 16:10:24	error	at /opt/iobroker/node_modules/iobroker.vcard/node_modules/vcard-json/lib/vcard-json.js:61:26
      TypeError:	2015-09-19 16:10:24	error	at parseVcard (/opt/iobroker/node_modules/iobroker.vcard/node_modules/vcard-json/lib/vcard-json.js:23:5)
      TypeError:	2015-09-19 16:10:24	error	at Function._.each._.forEach (/opt/iobroker/node_modules/iobroker.vcard/node_modules/vcard-json/node_modules/underscore/underscore.js:153:9)
      TypeError:	2015-09-19 16:10:24	error	at /opt/iobroker/node_modules/iobroker.vcard/node_modules/vcard-json/lib/vcard-json.js:40:7
      TypeError:	2015-09-19 16:10:24	error	at Function._.each._.forEach (/opt/iobroker/node_modules/iobroker.vcard/node_modules/vcard-json/node_modules/underscore/underscore.js:158:9)
      TypeError:	2015-09-19 16:10:24	error	at /opt/iobroker/node_modules/iobroker.vcard/node_modules/vcard-json/lib/vcard-json.js:45:12
      TypeError:	2015-09-19 16:10:24	error	at EventEmitter.emit (events.js:106:17)
      TypeError:	2015-09-19 16:10:24	error	at EventEmitter.attributeMatched (/opt/iobroker/node_modules/iobroker.vcard/node_modules/vcard-json/lib/vcard-json.js:72:24)
      TypeError:	2015-09-19 16:10:24	error	Cannot set property 'fullname' of undefined
      uncaught	2015-09-19 16:10:24	error	exception: Cannot set property 'fullname' of undefined
      vcard-0	2015-09-19 16:10:24	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.vcard
      vcard-0	2015-09-19 16:10:24	debug	statesDB connected
      vcard-0	2015-09-19 16:10:24	debug	objectDB connected
      Non	2015-09-19 16:10:23	info	npm module. No package.json
      host-raspberrypi	2015-09-19 16:10:22	info	instance system.adapter.vcard.0 started with pid 6952
      host-raspberrypi	2015-09-19 16:09:51	info	Restart adapter system.adapter.vcard.0 because enabled
        hometm last edited by
        Hallo looxer01,
        die Probleme sollten behoben sein.
        Die aktuelle Version kannst du mit "npm install iobroker.vcard" installieren
        Tobias
          ….bin gerade unterwegs und ab 17.10. wieder zurück und werde dann sofort testen. ...und ab in die Sonne .... 🙂
            'Hi Tobias,
            super, jetzt funktioniert es technisch erstmal - meine vcards werden eingelesen.
            Wenn ich das richtig verstanden habe, dann müsste ich jetzt als input eine Reihe von Telefonnummern einlesen und erhalte als output die korrespondierenden Namen.
            Ich würde das gerne mit dem Fritzbox adapter kombinieren. Im Idealfall: wenn eine Rufnummer in vcard gespeichert ist, dann soll der name angezeigt werden, ansonsten die Nummer.
            Hast du das schon umgesetzt ? und wenn könntest du ggf das entsprechende Widget bzw script zur Verfügung stelen ?
            vG
            L…
              Hallo looxer01,
              hier die Lösung:
              Ich habe das Widget "basic-string (unescaped)" verwendet. Das Widget zeigt den Output "vcard.0.Outputs.ReplacedPhoneNumbers" an.
              Mit dem folgenden Skript kopiere ich den Output vom Fritzbox-Adapter zum vCard-Adapter.
              subscribe({
                  id: "fritzbox.0.history.allTableHTML"/*history of calls as HTML*/,
                  change: 'ne'
              },function(data){func(data)});
              function func(data)
                  var x=getState("fritzbox.0.history.allTableHTML").val;
                  setState("vcard.0.Inputs.ReplacePhoneNumbers"/*String source*/, x);
              Das ganze funktioniert so wie du vermutest. Wenn die Nummer bekannt ist, wird der Name im Widget angezeigt.
              In der nächsten Version (weiß noch nciht wann ich dazu komme) soll das ganze auch ohne das Skript funktionieren.
              Tobias
                Brati last edited by
                das funktioniert ja perfekt. Hab das Script auf "fritzbox.0.history.missedTableHTML" geändert. Kann man noch intergrieren, dass der Namens String immer gleich lang ist, z.B. 20 Zeichen einnimmt? Dann ist die Tabelle ordentlich formatiert. Jetzt sieht es ja so aus:
                ext. Rufnummer…......Eigenes Amt
                Max Mustermann.........blabla
                Muddi.........blabla
                Will Lustig.........blabla
                Zum Export der Vcard: Wer Google nutzt, kann die auch gut direkt dort aus den dortigen Kontakten exportieren. Ich hab sie dann aufs NAS gelegt und Verzeichnis gemountet.
                Brati
                  gute Idee mit der festen Spaltenbreite. Habe auch schon eine Idee, wie ich es in der nächsten Version machen werde
                  Tobias
                    super, 1000 Dank Tobias,
                    funktionierte auch bei mir auf Anhieb.
                    Dann freue ich mich schon auf deine nächste Version 🙂
                    Wäre es auch möglich das gleiche für die aktuellen eingehenden Anrufe zu tun ? ( fritzbox.0.calls.ringActualNumbers)
                    Da muesste ja der Adapter noch eine zusätzliche Variable haben und das Script muesste dann noch diese Nummer ersetzen.
                    vG
                    L…
                    • Bluefox
                      Bluefox last edited by
                      Um Select ID Dialog zu integrieren muss man folgendes in admin/index.html machen:
                      • Im head einfügen:
                      • Im body:
                      • Und dann Script:
                      ! var selectId; function initSelectId (cb) { if (selectId) return selectId; socket.emit('getObjects', function (err, res) { if (!err && res) { selectId = $('#dialog-select-member').selectId('init', { noMultiselect: true, objects: res, imgPath: '../../lib/css/fancytree/', filter: {type: 'state'}, name: 'vcard-select-state', texts: { select: _('Select'), cancel: _('Cancel'), all: _('All'), id: _('ID'), name: _('Name'), role: _('Role'), room: _('Room'), value: _('Value'), selectid: _('Select ID'), from: _('From'), lc: _('Last changed'), ts: _('Time stamp'), wait: _('Processing...'), ack: _('Acknowledged'), selectAll: _('Select all'), unselectAll: _('Deselect all'), invertSelection: _('Invert selection') }, columns: ['image', 'name', 'role', 'room', 'value'] }); cb && cb(selectId); } }); } !
                      Um Dialog zu zeigen:
                                  initSelectId(function (sid) {
                                    sid.selectId('show', currentId, function (newId) {
                                        console.log(newId);
                      Vielleicht braucht man noch die Übersetzungen:
                      "Select": {"en": "Select", "de": "Auswählen", "ru": "Выбрать"},
                      "Ok": {"en": "Ok", "de": "Ok", "ru": "Ok"},
                      "Cancel": {"en": "Cancel", "de": "Abbrechen", "ru": "Отмена"},
                      "All": {"en": "All", "de": "Alle", "ru": "все"},
                      "ID": {"en": "ID", "de": "ID", "ru": "ID"},
                      "name": {"en": "name", "de": "Name", "ru": "Имя"},
                      "Role": {"en": "Role", "de": "Rolle", "ru": "Роль"},
                      "Room": {"en": "Room", "de": "Raum", "ru": "Комната"},
                      "Value": {"en": "Value", "de": "Wert", "ru": "Значение"},
                      "Select ID": {"en": "Select ID", "de": "ID Auswählen", "ru": "Выбрать ID"},
                      "From": {"en": "From: ", "de": "Von", "ru": "От"},
                      "Last changed": {"en": "Last changed", "de": "Letzte Änderung", "ru": "Изменён"},
                      "Time stamp": {"en": "Time stamp", "de": "Zeitstempel", "ru": "Время"},
                      "Processing...": {"en": "Processing...", "de": "Bearbeite...", "ru": "Обработка..."},
                      "Acknowledged": {"en": "Acknowledged", "de": "Bestätigt", "ru": "Подтверждён"},
                      "Filter:": {"en": "Filter:", "de": "Filter:", "ru": "Фильтр:"},
                      "id": {"en": "ID", "de": "ID", "ru": "ID"},
                      "Select all": {"en": "Select all", "de": "Alle auswählen", "ru": "Выбрать все видимые"},
                      "Deselect all": {"en": "Deselect all", "de": "Auswahl aufheben", "ru": "Убрать выделение"},
                      "Invert selection": {"en": "Invert selection", "de": "Selektierung invertieren", "ru": "Инвертировать выделение"},
                        Vielen Dank Bluefox.
                        Ich habe versuche den Dialog zu implementieren.
                        1. Frage:
                        ` > var sid = initSelectId(function (sid) {
                        console.log(newId);
                        Was ist currentId? Ist dies der Einstiegspunkt im Objekt-Baum?
                        2. Frage:
                        Ich habe einen Html-Butten implementiert.
                        und
                         function select(ch) {
                                    sid.selectId('show', '', function (newId) {
                                    habe es auch mit "sid.selectId
                                    ('show', 'javascript.0', function (newId) {"
                                    probiert
                                        console.log(newId);
                                    var elem = document.getElementById("object"+ch);
                                    elem.value = sid;
                        Leider öffnet sich der Dialog nciht. Habe ich etwas übersehen?
                        Im Browser kommt keine Fehlermeldung. IoBroker ist upgedated
                        Tobias
                        • Bluefox
                          Habe pull request erstellt, wo es geht.
                            Vielen Dank- so funktioniert es
                              Neue Version V 0.0.3 bei npm/github verfügbar.
                              Neue Features:
                              • laden der vcard-Datei per http
                              • drei getrennte Kanäle (Ein-/Ausgänge) für die Ersetzung von Nummern in Namen
                              • Ersetzte Namen können mit html/css formatiert werden
                              • EIngänge können direkt auf Objekte verbunden werden (kein Skript mehr notwendig)
                              Tobias
                                Hi Tobias,
                                ich habe die neue Version per copy in die node modules gebracht.
                                • Adapter gestoppt
                                • Script deaktiviert (namen copy)
                                • copy
                                • Adapter gestartet
                                die Version 0.0.3 wird angezeigt in der Adapterübersicht.
                                Es gibt keine zusätzliche Konfig im Adapter.
                                Im Log wird angezeit, dass der Adapter startet und Vcards eingelesen hat.
                                Ich habe sonst nichts geändert. Anrufe werden allerdings jetzt nicht mehr angezeigt.
                                Habe ich etwas falsch gemacht, bzw etwas ausgelassen ?
                                vG Looxer
                                  @looxer01:
                                  Hi Tobias,
                                  • Adapter gestoppt
                                  • copy
                                  • Adapter gestartet
                                  vG Looxer `
                                  Versuche im iobroker-verzeichnis
                                  "iobroker upload vcard" auszuführen.
                                  In Zukunft kannst du einfach mit
                                  "npm update iobroker.vcard" updaten
                                  Tobias
                                  Gesendet von meinem VT10416-2 mit Tapatalk
                                    ich war zurück auf 0.0.2. und habe es jetzt über NPM versucht.
                                    da scheint noch was nicht zu stimmen
                                    raspberrypi	2015-10-31 12:19:29	info	host.raspberrypi Restart adapter system.adapter.vcard.0 because enabled
                                    raspberrypi	2015-10-31 12:19:29	error	host.raspberrypi instance system.adapter.vcard.0 terminated with code 8 (node.js: Cannot find module)
                                    raspberrypi	2015-10-31 12:19:28	info	host.raspberrypi instance system.adapter.vcard.0 started with pid 5528
                                    host-raspberrypi	2015-10-31 12:18:58	info	Restart adapter system.adapter.vcard.0 because enabled
                                    Edit: nach dem upload Befehl scheint es jetzt zu gehen. Die Kanäle lassen sich konfigurieren.
                                    Die Anrufe kommen zunächst mal in Input an…
                                      Hi Tobias,
                                      irgendwie komme ich nicht weiter.
                                      Konfig ist wie unten gezeigt. Wo finde ich jetzt die Output Kanäle ? Ich sehe immer noch den vorherigen Output und der wird nicht upgedated.
                                      edit: ignoriere den Postfix - copy fehler in kanal1
                                      es steht ja auch in der doku:
                                      > The output is written to Outputs.ReplacedPhoneNumbersChX
                                      und ich finde bei mir nur "ReplacedPhoneNumbers"
                                      Kann es sein, dass noch ein CreateState fehlt ?
                                        …nachdem ich jetzt die Instanz gelöscht habe und dann neu erstellt habe sehen die Datenpunkte erstmal gut aus.
                                        Ich teste jetzt weiter
                                        sehr schön 😄
                                        ich musste ein wenig mit den styles rumspielen, da die Breiten nicht passten (von 300px auf 90px reduziert)
                                        Jetzt sieht es guuut aus und auch der Fritx Callmonitor wird bei einem aktuellen Anruf mit Namen gezeigt..
                                        1000 Dank mal wieder an Tobias.
                                        vG Looxer
                                          Hmm,
                                          nachdem das alles so schon lief, habe ich auf V 0.0.3 geupdatet und bekomme jetzt immer im Log:
                                          ioBroker	2015-11-03 14:10:32	error	host.ioBroker instance system.adapter.vcard.0 terminated with code 8 (node.js: Cannot find module)
                                          ioBroker	2015-11-03 14:10:30	info	host.ioBroker instance system.adapter.vcard.0 started with pid 2508
                                          host-ioBroker	2015-11-03 14:10:00	info	Restart adapter system.adapter.vcard.0 because enabled
                                          host-ioBroker	2015-11-03 14:10:00	error	instance system.adapter.vcard.0 terminated with code 8 (node.js: Cannot find module)
                                          host-ioBroker	2015-11-03 14:09:56	info	instance system.adapter.vcard.0 started with pid 2507
                                          host-ioBroker	2015-11-03 14:09:56	info	object change system.adapter.vcard.0
                                          deinstallation und neuinstallation hat nicht geholfen. Jemand eine Idee?
                                            @hometm:
                                            "iobroker upload vcard" auszuführen `
                                            Ich hatte ebenfalls diesen fehler. Mit upload war es ok
                                            128
                                            26249
