    4. Test Adapter Plex v0.8.x
      el_malto @P-A-L-A-D-I-N last edited by el_malto
      @P-A-L-A-D-I-N
      Hier nochmal mein angepasstes Skript.
      Blocky Export:
       <variables>
         <variable type="undefined" id="timeout">timeout</variable>
         <variable type="undefined" id="timeout3">timeout3</variable>
         <variable type="" id="@BD~_DP+=5?}Dp#DE%+E">Nachricht</variable>
         <variable type="undefined" id="timeout2">timeout2</variable>
       </variables>
       <block type="on" id="2-.V;oBuu~$=TzO-gqzV" x="113" y="-1463">
         <field name="OID">enigma2.0.Alexa_Command.Standby</field>
           <block type="controls_if" id="oFZR]6IIw{V|R]5oZ$tW">
               <block type="logic_compare" id="7|-Hsx}=EoONEF@_!-C=">
                 <field name="OP">EQ</field>
                   <block type="get_value" id="Nx9g(Tq4MauvQx1qUYE_">
                   <block type="logic_boolean" id="*~?Y*Sw~s25:ug,GN`c_">
               <block type="request" id="=/rX{N``)yc.?s,koYw}">
                 <mutation with_statement="false"></mutation>
                 <field name="WITH_STATEMENT">FALSE</field>
                 <field name="LOG"></field>
                 <value name="URL">
                   <shadow type="text" id="x;qgw5IT,O1^$~r*xAU!">
                     <field name="TEXT">http://192.168.0.20:8585/?key=H</field>
           <block type="on" id=",.g;MwZItD:cQUAgjzv9">
             <field name="OID">plex.0.events.event</field>
               <block type="comment" id="IY419_D/WKg=/%rW-*+i">
                 <field name="COMMENT">Steuerung</field>
                   <block type="controls_if" id="%WlMB^%b?PSR)?^Q/eei">
                       <block type="logic_operation" id="0sxHI2;gU!wxPLbQP!2j" inline="false">
                         <field name="OP">AND</field>
                           <block type="logic_operation" id="cD`~66),sk$O;1OzYh2N" inline="false">
                               <block type="logic_operation" id=")YY).U:lR,BrQ#Xmdt8h" inline="false">
                                 <field name="OP">OR</field>
                                   <block type="logic_compare" id="QxDBobk2p$!b-f17~Mdu">
                                       <block type="get_value" id="4fqui}(FUPWvMs^jJ4H.">
                                       <block type="text" id="9Vlh?C$,pqM}9r-WDW+?">
                                         <field name="TEXT">play</field>
                                   <block type="logic_compare" id="8H0ji[QbLGfj{HhL;hlL">
                                       <block type="get_value" id="=ItM%g#q2|,LF8QGy%oe">
                                       <block type="text" id="VSbd5isKZC0wtZZm:BvC">
                                         <field name="TEXT">resume</field>
                               <block type="logic_compare" id="]ohQk?0^V))x;6;wdhN{">
                                   <block type="get_value" id="NSpyn9DA(w,!~q#LI`QL">
                                     <field name="OID">plex.0.events.account</field>
                                   <block type="text" id="zJLf-Ii;ktcwFGe.2?c9">
                                     <field name="TEXT">el_malto</field>
                           <block type="logic_compare" id="pox7L}25!*`4p.9|_/7t">
                               <block type="get_value" id="!HJzbs`C)[O.Gn=.oHuM">
                                 <field name="OID">plex.0.events.player</field>
                               <block type="text" id="]:|j05DS)E^AKK9^?l=3">
                                 <field name="TEXT">Server</field>
                       <block type="comment" id="=/K)3IB%?,X5%pN-/UzA">
                         <field name="COMMENT">Steuerung TV</field>
                           <block type="controls_if" id="s|y]jY8u7]-M|`n=@IQw">
                               <block type="logic_compare" id="Tk{g_:jpnbiLYKI[12^w">
                                 <field name="OP">NEQ</field>
                                   <block type="get_value" id="RKAril99yyNS9pZ~eo;z">
                                     <field name="OID">scene.0.TV</field>
                                   <block type="logic_boolean" id="uZd7O(Sz[Y8AltwUn6A!">
                               <block type="control" id="hrmhFcb)V[%{i2M0o;X*">
                                   <block type="logic_boolean" id="^?D|ozmpLkr_H_A7z=1v">
                                   <block type="control" id=":/2=E/z3}?AsQY.jD[z0">
                                     <mutation delay_input="true"></mutation>
                                     <field name="OID">javascript.0.scriptEnabled.common.HDMI_2_SZ</field>
                                     <field name="DELAY_MS">9000</field>
                                     <field name="UNIT">ms</field>
                                       <block type="logic_boolean" id="_^sqRBl7JGlnE374ISHg">
                             <statement name="ELSE">
                               <block type="control" id="2VR}.^_u_Vz2,u1$4S~?">
                                   <block type="logic_boolean" id="DHDk7WJvnZ0~pgRK2cjn">
                               <block type="comment" id="}VMsK)HLppCv4l-:%PQ~">
                                 <field name="COMMENT">Steuerung Beleuchtung</field>
                                   <block type="controls_if" id="6^WXQBlei?q$.6Vw||xE">
                                       <block type="logic_operation" id=",E*GBpU-B_?1-9xJP*MZ" inline="false">
                                           <block type="logic_compare" id="P28?W_6b64y:Gt3t3`H3">
                                               <block type="get_value" id="ba.Pp9He5fyxeU1SF)DS">
                                                 <field name="OID">zigbee.0.14b457fffe43566d.state</field>
                                               <block type="logic_boolean" id="/s5~M05K_80(#]B9`KFv">
                                           <block type="logic_compare" id="$U?E7saWE^!R$a+BUp@x">
                                             <field name="OP">GTE</field>
                                               <block type="get_value" id="^,CpUBHt59=}c9VjVo:K">
                                                 <field name="OID">zigbee.0.14b457fffe43566d.brightness</field>
                                               <block type="math_number" id=":sxPB+nU`~r?;t.3/8IN">
                                                 <field name="NUM">50</field>
                                       <block type="control" id="DsUoDt:ouh$|N$tFh3u=">
                                         <field name="OID">zigbee.0.14b457fffe43566d.transition_time</field>
                                           <block type="math_number" id="Yjv5T``mB_w.+ml#8P/N">
                                             <field name="NUM">5</field>
                                           <block type="control" id=":/r?/[r-0J}SZ%PMT*Ki">
                                             <field name="DELAY_MS">1000</field>
                                               <block type="math_number" id=")`7paaJXKnVVv,mF+*ao">
                                                 <field name="NUM">1</field>
                                               <block type="control" id="a!n@6My+x{(_Wo^ZZ/B+">
                                                 <field name="DELAY_MS">6000</field>
                                                   <block type="math_number" id="Bj^VP-x*nghG1U{ZpNG4">
                                                     <field name="NUM">0</field>
                                                   <block type="control" id="TyQR1*dhu84Vs9e5P=L;">
                                                     <field name="DELAY_MS">7000</field>
                                                       <block type="math_number" id="yqSkv;(QE(~N42vtzFDL">
                                     <value name="IF1">
                                       <block type="logic_operation" id="7!6A@xyB7zy1W3yV8=pK" inline="false">
                                           <block type="logic_compare" id="HGi+y+_w-=magM!x^:i(">
                                               <block type="get_value" id="UWXPWv})KEKP-Vs%1Z^}">
                                               <block type="logic_boolean" id="a68J~LJls.HAa5SJ1S^V">
                                           <block type="logic_compare" id="6^RB1gt2XXfaRaCB?E.w">
                                             <field name="OP">LT</field>
                                               <block type="get_value" id="a]$xr(8(SywZr/ZWI,3B">
                                               <block type="math_number" id="[5UT0l@#vVF8.6|Xq;}G">
                                     <statement name="DO1">
                                       <block type="control" id="V1ShsdPnT?t4.43*CM+h">
                                           <block type="math_number" id="0P0FTup$-xVx7:xY8~n$">
                                             <field name="NUM">2.5</field>
                                           <block type="control" id="JQ97}Y;VryR[)w2}|9W8">
                                               <block type="math_number" id="oo$1y@/`Mk?qu`E1dPXB">
                                               <block type="control" id="pp])2hnv*`^Di?oPf?x*">
                                                 <field name="DELAY_MS">3500</field>
                                                   <block type="math_number" id="K.t;gvo:~2cc#~%SB(,(">
                                                   <block type="control" id="z_H|cm20R{sT3S](ODp.">
                                                     <field name="DELAY_MS">4500</field>
                                                       <block type="math_number" id="3SKeufL9p[@_.M,3?vU@">
                       <block type="comment" id="8Vc`+uKUyY42-Lm#f{,C">
                         <field name="COMMENT">Benachrichtigungen</field>
                           <block type="controls_if" id="x$2GP5yLpmx3s72e!N~{">
                               <block type="logic_operation" id="nD!8%mm~[KP#fB1-jJze" inline="false">
                                   <block type="logic_compare" id=")BV-^8y6}m!w5cIw_eEC">
                                       <block type="get_value" id="EQaUq.Pdyr,mPVf@NO)j">
                                       <block type="text" id="TK=jnu:c9mLu*anx`zt2">
                                   <block type="logic_compare" id="d[yu4{pgw*$Dp/4DFqDv">
                                       <block type="get_value" id="2qJZ1p?bm#=eu8?)bgD#">
                                       <block type="text" id="6n]}h]3,(e{Uy,.qL_R:">
                               <block type="timeouts_settimeout" id="O~v9bovR{_0tMGH`UM$=">
                                 <field name="DELAY">1000</field>
                                   <block type="exec" id="RyC)5(c-kzB;Lb,DR*2(">
                                     <value name="COMMAND">
                                       <shadow type="text" id="9UA@3:)o+n=0$R/0C=bd">
                                         <field name="TEXT"></field>
                                       <block type="text_join" id="I9Ka|u)Y:2Ew)S|cgOx8">
                                         <value name="ADD0">
                                           <block type="text" id="%H)yF_B*FE8#3p}$?JUs">
                                             <field name="TEXT">wget -q -N -O /opt/iobroker/plex.jpg "</field>
                                         <value name="ADD1">
                                           <block type="get_value" id="B.$a}Fex@zQ`Ar}(:bKA">
                                             <field name="OID">plex.0.events.caption</field>
                                         <value name="ADD2">
                                           <block type="text" id="kl1Fq+bj]P*=O~e5.5;v">
                                             <field name="TEXT">"</field>
                                       <block type="variables_set" id=";`?Dl%F^FkUV%}R.QBQS">
                                         <field name="VAR" id="@BD~_DP+=5?}Dp#DE%+E" variabletype="">Nachricht</field>
                                           <block type="get_value" id=";Lzo=+RtjK7]c#tGrRA^">
                                             <field name="OID">plex.0.events.message</field>
                                           <block type="timeouts_settimeout" id="s5850+qHwVn_5_+hxOzg">
                                             <field name="DELAY">2000</field>
                                               <block type="procedures_callcustomnoreturn" id="InrX]IWdIj7#?2~p5.[d">
                                                 <mutation name="Nachricht"></mutation>
                             <value name="IF1">
                               <block type="logic_operation" id="kQ}jJEJs-gi42!z`~`Jt" inline="false">
                                   <block type="logic_compare" id="/lfj.n|i)2N^[vCQtZ4C">
                                       <block type="get_value" id=".0@(i(9qCu~i%[nv8%H,">
                                       <block type="text" id="UnMDTuyy)F[qqKJB.9@2">
                                         <field name="TEXT">stop</field>
                                   <block type="logic_compare" id="yxx_?5uM;Re6Pv4=h#yw">
                                       <block type="get_value" id="89l?#)tqmJ@8f#%D$Cv;">
                                       <block type="text" id="l6_W/%n9*!19C.sKo@DO">
                                         <field name="TEXT">pause</field>
                               <block type="timeouts_settimeout" id="A4%X8!9K!_b0nrtD`@G7">
                                 <field name="NAME">timeout3</field>
                                   <block type="telegram" id="@Lwd;F$u~A?fA)l^-x6k">
                                     <value name="MESSAGE">
                                       <shadow type="text" id="|p[lvg3Zky~a2JHsQGl2">
                                       <block type="get_value" id="=Z$hkfqW+}S9Qf6dZ!Z?">
       <block type="procedures_defcustomnoreturn" id="d(]AIJuEMpk/U2O4G|W/" x="863" y="88">
         <mutation statements="false"></mutation>
         <field name="NAME">Nachricht</field>
         <field name="SCRIPT">c2VuZFRvKCJ0ZWxlZ3JhbSIsICJzZW5kIiwge3RleHQ6ICcvb3B0L2lvYnJva2VyL3BsZXguanBnJywgY2FwdGlvbjogW05hY2hyaWNodF0uam9pbignJyl9KTs=</field>
      Generell steuere ich den Player "Server" mit der App auf meinem iPhone oder iPad. Wenn ich damit dann einen Film auf dem Player "Server" starte, überprüft das Skript unter den "Steuerung" Kommentar welcher Player gerade was abspielt. Wenn es der Player "Server" ist, wird der TV an bzw auf den richtigen Eingang geschaltet. Je nach Zustand wird alles richtig eingestellt. Genau das gleiche mit der Beleuchtung.
      Da ich meinen TV über meinen Enigma Receiver mit HDMI CEC steuere, überprüft das erste "falls Objekt" wenn mein Receiver ausgeschaltet wird. Wenn das der Fall ist, wird zu meinem HTPC (192.168.0.20) wo der Plex Player "Server" drauf läuft über "GetAdmin" die "H" Taste gesendet. Diese beendet die Wiedergabe und geht auf dem "Home" Screen vom Player Pleyer. So kann ich dann einfach mit der Fernbedinung vom Receiver den Receiver und TV ausschalten und dann wird die Wiedergabe auf dem Player auch beendet.
      Unter den "Benachrichtigung" Kommentar lasse ich mir die erstellten Benachrichtigungen und das Thumb vom Film oder Serie per Telegram schicken. Unter "Benachrichtigung" die Nachricht und unter "Untertitel" lasse ich mir den Pfad zum Thumb erstellen.
      Benachrichtigungen im Adapter:
      Und in Telegram sieht das dann so aus:
      P 1 Reply Last reply Reply Quote 2
        P-A-L-A-D-I-N @el_malto last edited by
        @el_malto Vielen Dank für das angepaßte Script und die Erläuterungen, die das Ganze für mich jetzt auch deutlich greifbarer machen! 🙂
        Ich finde die Idee mit dem Trigger (Player X spielt etwas ab) richtig gut! Ich werde das bei mir zwar ziemlich stark abändern müssen (habe u.a. keinen Enigma-Receiver am Haupt-TV, dafür aber, zusätzlich zum TV, noch einen Receiver, der auf den richtigen Kanal eingestellt werden muß usw.), aber ich denke mal, daß ich das mithilfe Deiner Vorlage irgendwie schaffen sollte.
        Muß mir auch mal Gedanken machen, wie ich es hin bekomme, daß ich hier zwei Szenarien automatisieren kann, ohne daß sie sich in die Quere kommen: Einmal das Abspielen mit dezentem Ton (z.B. Wiedergabe einer Plex-Aufnahme oder einer Serie) und dann noch ein richtiger Filmabend mit 5.1-Ton, wenn es mal etwas lauter werden darf. Wäre die Logik dahinter nur über den Inhalt steuerbar (Serie oder Film), wäre die Umsetzung vielleicht noch recht simpel. Aber da wir, wegen der Kinder, teilweise eben auch die Filme nur mit dezentem Ton anschauen, dürfte das etwas schwieriger werden - vielleicht noch mit zusätzlichen "intelligenten" Wenn-dann-Schleifen (Uhrzeit, Status der Kinderzimmerbeleuchtung u.ä.), die erfüllt sein müssen, damit das "große Kino" aufgefahren wird. 😉
          el_malto last edited by el_malto
          @Zefau
          Bei mir werden die "History" Seite irgendwie nicht richtig dargestellt.
          Müsste es nicht so wie bei dir in Post
          #1
          aussehen?
          sigi234 Zefau 2 Replies Last reply Reply Quote 0
            sigi234 Forum Testing Most Active @el_malto last edited by
            @el_malto
            Bei mir auch.
            • Zefau
              Zefau @sigi234 last edited by
              @sigi234 sagte in Test Adapter Plex v0.8.x:
              Hallo, bekomme immer das V 0.8.3 :
              Die Meldung kommt bei jedem Adapter-Start, sofern du den Wert in den Adapter-Einstellungen nicht selbst nach oben anpasst. Oder kommt die Meldung bei dir häufiger?
                sigi234 Forum Testing Most Active @Zefau last edited by
                @Zefau sagte in Test Adapter Plex v0.8.x:
                Ok, danke habe auf 10 Sekunden gestellt.
                • Zefau
                  @sigi234 wieso hast du ein so starkes Polling eingestellt? Welche Informationen brauchst du so aktuell?
                  • Zefau
                    Zefau @el_malto last edited by
                    @el_malto die Icons sollten mit v0.8.4 nun wieder funktionieren. Ich hab in der Version auch ein Feld für das Thumbnail eingefügt, dass die URL automatisch zusammensetzt (dann brauchst du es nicht mit caption basteln). Das Thumbnail wird auch im Web Interface angezeigt.
                    E Zefau 2 Replies Last reply Reply Quote 1
                      Was ist normal?
                      Denke wenn ich eine Vis erstelle möchte ich die Daten 1:1 haben.
                        el_malto @Zefau last edited by
                        Geil, vielen Dank!
                        • Zefau
                          Zefau @Zefau last edited by
                          @liv-in-sky @Headhunter70 die v0.8.4 unterstützt nun Remote Player control. Glaube ihr hattet danach gefragt, oder habe ich das falsch in Erinnerung?
                          Um das umzusetzen müsst ihr plex im Cloud / IOT Adapter freischalten (unter Services und IFTTT).
                          Die URL lautet dann wie folgt https://service.iobroker.in/v1/iotService?service=custom_plex&key=1cx5a1d0-XXXX-XXXX-XXXX-0ba10fe76408&user=zefau%40mailbox.org&data=<Player>_<Command>
                          Für <Player> dann den Channel vom Player direkt unter _playing nehmen, also z. B. livingroom-052D8D3F-2AA78B71E95A sowie <Command> den Befehl, also z. B. play.
                          Sprich: https://service.iobroker.in/v1/iotService?service=custom_plex&key=1cx5a1d0-XXXX-XXXX-XXXX-0ba10fe76408&user=zefau%40mailbox.org&data=livingroom-052D8D3F-2AA78B71E95A_play
                          • Zefau
                            Events (also das Abspielen auf Endgeräten) wird direkt und unabhängig der Refresh-Rate geschickt.
                            Bei allen anderen Inhalten ist die Frage, wie oft du die auf dem Plex Server änderst. Also die Server-Infos, Playlists, die Libraries, etc.
                            Ich hab bei mir aktuell 3600 eingetragen (1h).
                              Ich jetzt auch. 😀
                                sigi234 Forum Testing Most Active @Zefau last edited by sigi234
                                @Zefau
                                Irgendwo habe ich einen Fehler drinnen.
                                Gibt es eine Möglichkeit die Benachrichtigungen zu exportieren/sichern
                                ERLEDIGT musste erst was abspielen.
                                  el_malto @sigi234 last edited by
                                  @Zefau
                                  Was meinst du genau mit exportieren?
                                  Die Benachrichtigungen werden doch unter "events" in den Datenpunkten geschrieben.
                                  Nachricht -> message
                                  Untertitel -> caption
                                  thumb -> thumb
                                    Bei mir finde ich im Cloud Adapter irgendwie nichts. Benutze die free Cloud.
                                      @el_malto sagte in Test Adapter Plex v0.8.x:
                                      @Zefau
                                      thumb -> thumb
                                      Das ich alle bearbeiteten und angelegten Benachrichtigungen bei einer Neuinstallation wieder zurückspielen kann.
                                      Import und Export als json
                                        @Zefau
                                        Hallo, wie bekomme ich eigentlich die Album Bilder in Vis angezeigt? Und ev. in den Benachrichtigungen?
                                        E Zefau 2 Replies Last reply Reply Quote 0
                                          el_malto @sigi234 last edited by el_malto
                                          Dafür kannst du super die %Platzhalter% benutzen. @Zefau hat das ja extra in den Adapter Einstellungen hinzugefügt. Einfach den richtigen Datenpunkt mit %Platzhalter% unten "thumb" und dann taucht der Link zum thumb unter "events" im Datenpunkt "thumb" auf. Den kannst ja dann in der VIS verlinken.
                                          • Zefau
                                            Bei Whitelist für Services plex eintragen. Dann den Link darunter benutzen.
                                            plex
                                            14
                                            312
                                            38481
