    4. Z-Wave Adapter
    Z-Wave Adapter
    • V
      versteckt last edited by
      Einen wunderschönen…,
      hab es grade bei mir angepasst. Der Adapter startet wie gewohnt, funktioniert also.
      LG Christian
      • Bluefox
        Bluefox last edited by
        Alles klar. Danke.
        Werde ich rein mergen und publischen .
          Der z-wave Adapter ist gerade beim update "verschwunden":
          root@odroid-wheezy:/opt/iobroker# iobroker upgrade zwave
          Adapter "zwave"          is not installed.
          Fehlermeldung und exit code 10 danach war er "weg"
          Löschen lässt er sich auch nicht mehr (ist wirklich weg (?))
          und bei versuch neu zu installieren mag er nicht mehr:
          ! root@odroid-wheezy:/opt/iobroker# npm install iobroker.zwave npm WARN package.json iobroker@ No description npm WARN package.json iobroker@ No repository field. npm WARN package.json iobroker@ No README data npm http GET https://registry.npmjs.org/iobroker.zwave npm http 304 https://registry.npmjs.org/iobroker.zwave npm http GET https://registry.npmjs.org/openzwave-shared npm http 304 https://registry.npmjs.org/openzwave-shared npm http GET https://registry.npmjs.org/nan npm http 304 https://registry.npmjs.org/nan ! > openzwave-shared@1.0.8 install /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared node-gyp rebuild ! make: Entering directory `/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build' CXX(target) Release/obj.target/openzwave_shared/src/openzwave.o In file included from ../src/openzwave.cc:18:0: ../src/openzwave.hpp:30:21: fatal error: Manager.h: No such file or directory compilation terminated. make: *** [Release/obj.target/openzwave_shared/src/openzwave.o] Error 1 make: Leaving directory `/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build' gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23) gyp ERR! stack at ChildProcess.EventEmitter.emit (events.js:98:17) gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:789:12) gyp ERR! System Linux 3.8.13.27 gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared gyp ERR! node -v v0.10.22 gyp ERR! node-gyp -v v0.11.0 gyp ERR! not ok npm WARN optional dep failed, continuing iobroker.zwave@0.2.1 !
          Rainer
          • V
            Ev. mein Fehler in der Doku, hast du openzwave Header und Libraries installiert?
            Gesendet von meinem iPhone mit Tapatalk
              @versteckt:
              Ev. mein Fehler in der Doku, hast du openzwave Header und Libraries installiert? `
              Natürlich nicht, dann hätte ich ja lesen müssen :oops:
              Order /opt ist ok dafür?
              EDIT:
              jetzt ließ es sich über putty installieren - in iobroker admin war jetzt die Version 0.2.0 - update auf 0.2.1 verfügbar.
              Das habe ich über den admin auf den neuesten Stand gebracht - dachte ich - danach immer noch v. 0.2.0 undupdate auf 0.2.1 verfügbar.
              Rainer
              • Bluefox
                @Homoran:
                Das habe ich über den admin auf den neuesten Stand gebracht - dachte ich - danach immer noch v. 0.2.0 undupdate auf 0.2.1 verfügbar. `
                Sollte gefixt sein.
                  Ja!
                  Stieg wiedermit code 10 aus - danach war aber die neue Version drin
                  Rainer
                    pierrecinema last edited by
                    hallo zusammen
                    erst mal danke für die tolle arbeit zwave einzubinden. leider versuche ich es seit einer woche . mein aeon stick gen5 wird erkannt. danach versuche ich ein gerät anulerne , das geht aber nicht. wie kriege ich den stick in den anlern modus. auf den bilder weiter vorne hat es beim adapter mehr als nur das gerät tab. bei mir sieht es so aus. was fehlt mir noch?
                      hallo
                      wirklich keiner eine idee, wie habt es ihr gemacht? ist überhaupt jemand noch in diesem forum?
                      gruss und danke
                      • Bluefox
                        Ich vermute, dass anlernen und so weiter passiert in openzwave Oberfläche. Das hier ist nur um die angelernte Geräte zu exportieren.
                          @Bluefox:
                          Ich vermute, dass anlernen und so weiter passiert in openzwave Oberfläche. Das hier ist nur um die angelernte Geräte zu exportieren. `
                          hallo bluefox
                          danke für deine Antwort. wie meinst in der openzwave oberfläche. ist das nicht die aus meinem screenshot? bei den bildern weiter vorne im thread sieht man in diesem menu mehr tabs als in meinem, ich habe das gefühlt mir fehlt etwas, aber was.
                          Gruss
                          • Bluefox
                            https://github.com/OpenZWave/open-zwave-control-panel
                            Jemand hat geschrieben, dass Adapterist gut, nur anlernen Funktion fehlt…
                            Wenn ich wüsste, wie man die Anlernen-Funktion aufrufen konnte, dann konnte ich dann Adapter erweitern.
                            Ich habe nur gefunden softReset und hardReset.
                            • Bluefox
                              Ich habe jetzt viel neuere Version von openzwave lib für node.js entdeckt:
                              https://github.com/OpenZWave/node-openzwave-shared
                              Vielleicht konnte husky-koglhof mal schauen.
                                @Bluefox:
                                Vielleicht konnte husky-koglhof mal schauen. `
                                kopier ich das ganze zip in meine ordner oder muss ich was kompilieren
                                  interessant wäre wenn man das integrieren könnte
                                    reiden last edited by
                                    Hallo
                                    Ich habe heute versucht ZWave zu installieren und leider bekomme ich folgende Fehler :evil:
                                    iobroker 2015-11-11 12:03:48 info exit 14
                                    iobroker 2015-11-11 12:03:48 error host.raspberrypi error: reading io-package.json SyntaxError: Unexpected string
                                    iobroker 2015-11-11 12:03:48 info host.raspberrypi install adapter zwave
                                    iobroker 2015-11-11 12:03:46 info add zwave
                                    host-raspberrypi 2015-11-11 12:03:32 warn warning: Following packages cannot be read: example
                                    Gruss
                                      ok, Fehler gefunden
                                      "desc": {
                                      "en": "ZWave support based on openzwave packet",
                                      "de": "ZWave Unterstützung dürch Openzwave Paket",
                                      "ru": "Поддержка ZWave основанная на Openzwave пакете"
                                      nach "}" war kein Komma
                                      Gruss
                                        Hallo zusammen
                                        Heute habe ich wieder ein bisschen mit Z-Wave „gespielt“.
                                        Ich habe den Aeotec Z-Stick Gen5 und Fibaro Motion Sensor. Alles mit ZWave Modul könnte ich installieren und zum laufen gebracht. Leider wenn ich die hm-rega und hm-rpc mit CCU2 verbinde und aktiviere, ist nach kurze Zeit meine CCU2 nicht mehr erreicht von ioBroker wie auch über Browser. Nach dem Start von CCU funktioniert CCU aber ioBroker meldet die ganze Zeit Timeout und hat keine Verbindung mit der CCU. Starte ich wieder ioBroker dann hängt sich wieder CCU auf.
                                        ioBroker ist auf RPI-2, alle Module ausser js-controller (ist 7.14) auf neustem Stand.
                                        Gruss
                                        • V
                                          Hallo, habe den zwave Adapter komplett überarbeitet und teste ihn derzeit intensiv.
                                          Ich werde wenn alles klappt, morgen zur Verfügung stellen.
                                          Sollte dann auch in occ und HomeKit funktionieren.
                                          Das Alarm Thema versuche ich noch ausgiebig, meine Katzen sind super Tester.
                                          Auch habe ich alles soweit vorbereitet, das die neue History funktioniert.
                                          • Bluefox
                                            Super, ich wollte schon selber da was anschauen, aber es gab immer wieder was wichtigeres (und gibt es immer noch) zu tun.
                                            Konnte es möglich sein aus ioBroker Anlernen-Modus starten?
                                            110
                                            28909
