    4. Test Adapter tr-064-community v1.0.x
      crunchip Forum Testing Most Active @apollon77 last edited by crunchip
      @apollon77 der Adapter läuft seit rund 2 Wochen, aktuell mit
      • admin 3.6.12 seit 5Tagen
      • js-controller 2.0.39 seit Beginn der Version
      • node v10.17.0 erst seit gestern
      ich starte den adapter per cron jede Nacht um 0:01neu
      hat scheinbar irgendwie die Verbindung verloren
      heute das erste mal diese Fehlermeldungen bekommen
      tr-064-community.0	2019-11-09 00:01:15.285	info	(32254) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
      host.IoBroker	2019-11-09 00:01:12.960	info	instance system.adapter.tr-064-community.0 started with pid 32254
      host.IoBroker	2019-11-09 00:01:11.923	info	Restart adapter system.adapter.tr-064-community.0 because enabled
      host.IoBroker	2019-11-09 00:01:11.922	error	instance system.adapter.tr-064-community.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      tr-064-community.0	2019-11-09 00:01:06.880	error	(32219) ~
      tr-064-community.0	2019-11-09 00:01:06.880	error	(32219) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
      tr-064-community.0	2019-11-09 00:01:06.879	error	(32219) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064-community.0	2019-11-09 00:01:06.877	error	(32219) timeout - "timeout"
      tr-064-community.0	2019-11-09 00:01:03.748	info	(32219) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
      host.IoBroker	2019-11-09 00:01:01.688	info	instance system.adapter.tr-064-community.0 started with pid 32219
      host.IoBroker	2019-11-09 00:01:00.662	info	Restart adapter system.adapter.tr-064-community.0 because enabled
      host.IoBroker	2019-11-09 00:01:00.661	error	instance system.adapter.tr-064-community.0 terminated with code 156 (156)
      tr-064-community.0	2019-11-09 00:01:00.073	info	(18006) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      tr-064-community.0	2019-11-09 00:01:00.053	info	(18006) terminating
      tr-064-community.0	2019-11-09 00:01:00.024	info	(18006) Scheduled restart.
      desweiteren habe ich noch eine Frage zu entgangene Anrufe
      ist es möglich einen Anruf als entgangen zu listen,
      auch wenn sich der Ab schon eingeschaltet hat, aber noch bevor die Ansage zu ende ist, der Anrufer wieder auflegt.
      Da man so die Anrufe nicht mitbekommt, denn der Ab hat ja keine Nachricht zum anzeigen, da vorzeitig aufgelegt wurde und in der missed calllist taucht der Anruf nicht auf, da ja eigentlich der Ab den Anruf entgegen genommen hat.
      • Nashra
        Bei mir taucht nach Mitternacht im Minutentakt dies auf
        2019-11-09 00:00:00.628 - error: host.ioBroker-RasPi instance system.adapter.tr-064-community.0 terminated with code 156 (156)
        Um 01:00 Uhr wird der Adapter neu gestartet, danach ist Ruhe
        admin 3.6.12
        node.js v10.17.0
        npm 6.12.0
          apollon77 @Nashra last edited by
          @Nashra mehr log vllt?
          • Nashra
            Nashra Most Active Forum Testing @apollon77 last edited by
            @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
            Nein leider nicht, ist nur diese eine Zeile die im Minutentakt ausgeworfen wird
              Eine „ich stoppe“ Meldung ohne „ich starte“ ist eher unwahrscheinlich... zeig doch bitte einfach mal paar Minuten log
              • Nashra
                Muß mich entschuldigen war vorhin noch nicht ganz wach und habe nur auf die roten Einträge geachtet 😞
                Sorry...
                2019-11-09 00:00:00.023 - info: tr-064-community.0 (18005) Scheduled restart.
                2019-11-09 00:00:00.060 - info: tr-064-community.0 (18005) terminating
                2019-11-09 00:00:00.069 - info: tr-064-community.0 (18005) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2019-11-09 00:00:00.111 - info: javascript.0 (6498) script.js.Meine_Geräte.Lebensmittel-Tabelle: RSS-Feed https://www.lebensmittelwarnung.de/bvl-lmw-de/opensaga/feed/alle/nordrhein_westfalen.rss eingelesen
                2019-11-09 00:00:00.272 - info: javascript.0 (6498) script.js.Meine_Geräte.Unwetter: []
                2019-11-09 00:00:00.631 - info: host.ioBroker-RasPi Restart adapter system.adapter.tr-064-community.0 because enabled
                2019-11-09 00:00:01.726 - info: host.ioBroker-RasPi instance system.adapter.tr-064-community.0 started with pid 19115
                2019-11-09 00:00:04.821 - info: tr-064-community.0 (19115) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
                2019-11-09 00:00:24.531 - info: history.0 (3196) Delete old history "/opt/iobroker/iobroker-data/history/20191031/history.tankerkoenig.0.stations.cheapest.diesel.feed.json"
                2019-11-09 00:01:00.012 - info: tr-064-community.0 (19115) Scheduled restart.
                2019-11-09 00:01:00.061 - info: tr-064-community.0 (19115) terminating
                2019-11-09 00:01:00.064 - info: tr-064-community.0 (19115) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2019-11-09 00:01:00.662 - error: host.ioBroker-RasPi instance system.adapter.tr-064-community.0 terminated with code 156 (156)
                2019-11-09 00:01:00.663 - info: host.ioBroker-RasPi Restart adapter system.adapter.tr-064-community.0 because enabled
                2019-11-09 00:01:01.731 - info: host.ioBroker-RasPi instance system.adapter.tr-064-community.0 started with pid 20355
                2019-11-09 00:01:04.861 - info: tr-064-community.0 (20355) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
                2019-11-09 00:02:00.011 - info: tr-064-community.0 (20355) Scheduled restart.
                2019-11-09 00:02:00.062 - info: tr-064-community.0 (20355) terminating
                2019-11-09 00:02:00.067 - info: tr-064-community.0 (20355) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2019-11-09 00:02:00.622 - error: host.ioBroker-RasPi instance system.adapter.tr-064-community.0 terminated with code 156 (156)
                2019-11-09 00:02:00.623 - info: host.ioBroker-RasPi Restart adapter system.adapter.tr-064-community.0 because enabled
                2019-11-09 00:02:01.745 - info: host.ioBroker-RasPi instance system.adapter.tr-064-community.0 started with pid 21485
                2019-11-09 00:02:04.973 - info: tr-064-community.0 (21485) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
                2019-11-09 00:03:00.024 - info: tr-064-community.0 (21485) Scheduled restart.
                2019-11-09 00:03:00.082 - info: tr-064-community.0 (21485) terminating
                2019-11-09 00:03:00.089 - info: tr-064-community.0 (21485) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2019-11-09 00:03:00.652 - error: host.ioBroker-RasPi instance system.adapter.tr-064-community.0 terminated with code 156 (156)
                  @Nashra sagte in Test Adapter tr-064-community v1.0.x:
                  Scheduled restart.
                  Here you go ... du hast einen restart schedule eingetragen. Cron falsch?
                  • Nashra
                    Scheduled restart.
                    Hm, habe es so gemacht
                    liv-in-sky apollon77 2 Replies Last reply Reply Quote 0
                      liv-in-sky @Nashra last edited by liv-in-sky
                      @Nashra du solltes die minute konfigurien
                      ehr so:
                      "59 23 ***" für 23:59
                      ein stern an erster stelle bedeutet : minütlich
                      • Nashra
                        Nashra Most Active Forum Testing @liv-in-sky last edited by
                        @liv-in-sky sagte in Test Adapter tr-064-community v1.0.x:
                        ehr so:
                        Hm, hatte "Alle 23 Stunden" gewählt, habe es jetzt auf "3 0 * * *" geändert, also müßte es 00:03 sein
                          @Nashra yup -so sieht es besser aus
                            apollon77 @Nashra last edited by apollon77
                            @Nashra Das bedeutete In Stunde 23 und 0 jede Minute (wenn ichs jetzt richtig analysiere)
                            Nashra 1 Reply Last reply Reply Quote 1
                            • Nashra
                              Nashra Most Active Forum Testing @apollon77 last edited by Nashra
                              Ok, dann habe ich mich dadurch irritieren lassen. War der Meinung das es dann alle 23 Std. einmal gemacht wird.
                                @Nashra
                                • */23 ***
                                  alle 23 stunden - bei 24 stunden startest du dann irgendwann mitten im tag - weil ja täglich immer eine stunde früher der neustart kommt
                                • SBorg
                                  SBorg Forum Testing Most Active @liv-in-sky last edited by SBorg
                                  Da fallen immer viele darauf rein 🙂
                                  btw: * */23 * * * startet tatsächlich nur um 23 Uhr für jede Minute, also 23:00, 23:01,...23:59
                                  */10 (bspw. für Minuten) startet nicht tatsächlich im 10 Minuten-Takt, sondern im 10 Minuten-Raster. Starte ich also um xx:12 läuft der Job nicht um xx:12, xx:22, xx:32 ..., sondern tatsächlich im xx:10, xx:20, xx:30, .... Raster, also quasi immer vielfache vom Startwert. Möchte man dass, müsste man zB. 12,22,32,42,52 angeben oder 12-52,*/10
                                  Da es bei Stunden aber keine vielfache von 23 gibt, läuft er tatsächlich nur immer um 23 Uhr und nicht jeden Tag dann eine Stunde früher.
                                  ...und alles OT 😉
                                  liv-in-sky 1 Reply Last reply Reply Quote 1
                                    liv-in-sky @SBorg last edited by
                                    @SBorg danke - man lernt ja nie aus
                                      A Former User @apollon77 last edited by
                                      @apollon77 also hier läuft die 1.0.1 einwandfrei, hast du das Object 'reboot' als button geändert, oder ist das noch von meiner manuellen Umstellung so geblieben?
                                      läuft hier in 9 Instanzen:
                                        crunchip Forum Testing Most Active @Guest last edited by
                                        @ilovegym mal bisschen OT
                                        für was hat man 9 Instanzen😳
                                        wegen verschiedener Telefonnummern?
                                          A Former User @crunchip last edited by A Former User
                                          @crunchip 🙂
                                          ich hab AVM reich gemacht 🙂 muss n ganzes Haus mit 4 Etagen und Nebengebäude Garage etc versorgen..
                                          7590 - MainRouter am DSL 100
                                          7590 DG ( Dachgeschoss ) - Dect und Wlan
                                          7580 DG - Wlan
                                          7560 Keller - Dect und Wlan
                                          1750 EG rechts
                                          1750 EG links
                                          3000 OG
                                          3000 Keller
                                          7312 DG - war noch übrig und versorgt ne kleine Ecke.. 😉
                                          hab meist permanent um die 220-230 Geräte im Netzwerk, in Stosszeiten können das mal 320 werden..
                                          Dazu noch 7 Xiaomi Gateways, ca 115 Sensoren etc..
                                          Damit ich alle Fritzdevices in der richtigen Reihenfolge rebooten kann, ist mein Reboot Script schon wichtig 🙂
                                          Kommt zum Glück nur 1x im Monat vor, da kackt die 7590 mit "no memory" ab.. ;-))))
                                          crunchip apollon77 2 Replies Last reply Reply Quote 0
                                            @ilovegym na da fällt mir nix mehr ein😁
                                            immer schön, wenn man ein kleines schnuckeliges normales Einfamilienhaus hat, mir reicht da eine Fritz-Box und seit einiger Zeit nen Unifi AP
                                            community tr-064
                                            88
                                            727
                                            189090
