    4. Test Adapter hue v2.2.x
      Stormbringer @foxriver76 last edited by
      @foxriver76 Hier gehts ja richtig Rund 😜
      Wegen dem Test der 2.4.0 und den Dynamischen Szenen. Die funktionieren leider noch nicht.
      Im LOG kommt:
      hue.0	2019-11-07 20:22:43.161	warn	Used invalid characters: hue.0.Philips_hue.XFDani[9][1]sn:step changed to hue.0.Philips_hue.XFDani_9__1_sn:step
      hue.0	2019-11-07 20:22:43.153	warn	Used invalid characters: hue.0.Philips_hue.XFDani[9][1]sn:step.reachable changed to hue.0.Philips_hue.XFDani_9__1_sn:step.reachable
      hue.0	2019-11-07 20:22:43.149	warn	Used invalid characters: hue.0.Philips_hue.XFDani[9][1]sn:step.on changed to hue.0.Philips_hue.XFDani_9__1_sn:step.on
      hue.0	2019-11-07 20:22:43.144	warn	Used invalid characters: hue.0.Philips_hue.XFDani[9][1]sn:step.lastupdated changed to hue.0.Philips_hue.XFDani_9__1_sn:step.lastupdated
      hue.0	2019-11-07 20:22:43.139	warn	Used invalid characters: hue.0.Philips_hue.XFDani[9][1]sn:step.status changed to hue.0.Philips_hue.XFDani_9__1_sn:step.status
      hue.0	2019-11-07 20:22:43.136	warn	Used invalid characters: hue.0.Philips_hue.XFDani[9]sn:state changed to hue.0.Philips_hue.XFDani_9_sn:state
      hue.0	2019-11-07 20:22:43.130	warn	Used invalid characters: hue.0.Philips_hue.XFDani[9]sn:state.reachable changed to hue.0.Philips_hue.XFDani_9_sn:state.reachable
      hue.0	2019-11-07 20:22:43.127	warn	Used invalid characters: hue.0.Philips_hue.XFDani[9]sn:state.on changed to hue.0.Philips_hue.XFDani_9_sn:state.on
      hue.0	2019-11-07 20:22:43.123	warn	Used invalid characters: hue.0.Philips_hue.XFDani[9]sn:state.lastupdated changed to hue.0.Philips_hue.XFDani_9_sn:state.lastupdated
      hue.0	2019-11-07 20:22:43.119	warn	Used invalid characters: hue.0.Philips_hue.XFDani[9]sn:state.status changed to hue.0.Philips_hue.XFDani_9_sn:state.status
      hue.0	2019-11-07 20:22:43.071	warn	Used invalid characters: hue.0.Philips_hue.XFDani[6][1]sn:step changed to hue.0.Philips_hue.XFDani_6__1_sn:step
      hue.0	2019-11-07 20:22:43.066	warn	Used invalid characters: hue.0.Philips_hue.XFDani[6][1]sn:step.reachable changed to hue.0.Philips_hue.XFDani_6__1_sn:step.reachable
      hue.0	2019-11-07 20:22:43.060	warn	Used invalid characters: hue.0.Philips_hue.XFDani[6][1]sn:step.on changed to hue.0.Philips_hue.XFDani_6__1_sn:step.on
      hue.0	2019-11-07 20:22:43.055	warn	Used invalid characters: hue.0.Philips_hue.XFDani[6][1]sn:step.lastupdated changed to hue.0.Philips_hue.XFDani_6__1_sn:step.lastupdated
      hue.0	2019-11-07 20:22:43.050	warn	Used invalid characters: hue.0.Philips_hue.XFDani[6][1]sn:step.status changed to hue.0.Philips_hue.XFDani_6__1_sn:step.status
      hue.0	2019-11-07 20:22:43.046	warn	Used invalid characters: hue.0.Philips_hue.XFDani[6]sn:state changed to hue.0.Philips_hue.XFDani_6_sn:state
      hue.0	2019-11-07 20:22:43.042	warn	Used invalid characters: hue.0.Philips_hue.XFDani[6]sn:state.reachable changed to hue.0.Philips_hue.XFDani_6_sn:state.reachable
      hue.0	2019-11-07 20:22:43.039	warn	Used invalid characters: hue.0.Philips_hue.XFDani[6]sn:state.on changed to hue.0.Philips_hue.XFDani_6_sn:state.on
      hue.0	2019-11-07 20:22:43.035	warn	Used invalid characters: hue.0.Philips_hue.XFDani[6]sn:state.lastupdated changed to hue.0.Philips_hue.XFDani_6_sn:state.lastupdated
      hue.0	2019-11-07 20:22:43.033	warn	Used invalid characters: hue.0.Philips_hue.XFDani[6]sn:state.status changed to hue.0.Philips_hue.XFDani_6_sn:state.status
      schon beim Start vom Adapter und beim Triggern einer Dynamischen Szene dann auch wieder obwohl ich nicht mal diese XFDani (was immer das ist) anstoße. XFDani taucht aber in den Objekten auf.
      • foxriver76
        foxriver76 Developer @Stormbringer last edited by
        @Stormbringer ist das ne HueLabs Szene? Falls ja, sag mal welche, dann kann ich es anschauen.
          @foxriver76 Hab keine Ahnung was das sein soll, ist auch erst nach dem Adapter Update aufgetaucht.
          • foxriver76
            foxriver76 Developer @Stormbringer last edited by foxriver76
            @Stormbringer achso, sprich der Adapter funktioniert gar nicht?
            Schalt mal auf debug und sende mir den config JSON-String, muss nicht auf 2.4.0 sein.
              Stormbringer @foxriver76 last edited by Stormbringer
              @foxriver76 Nein Adapter funktioniert sonst einwandfrei, wie vorher. Nur beim Start bringt er den Fehler und wenn man eine dynamische Szene anklickt. Hat sonst keine Auswirkungen außer, dass die dynamischen Szenen nicht gehen. Wie komm ich denn an den Config Jason String?
                @foxriver76 Ich hab mir mal die Szenen mit ner All4Hue angeschaut. Kann es mit den Sonderzeichen in der Namensgebung zusammen hängen? Löschen trau ich sie mich aber irgendwie nicht, weil ich nicht weiß woher die kommen und im Normalfall heißt ja keine Szene so komisch... Nicht, dass die die Bridge irgendwie braucht...
                25b315ba-9d99-4de5-923d-6df946765a7e-D104230D-A3F2-47E1-A25F-D0A68179EB5D_1_105_c.jpeg
                • foxriver76
                  @Stormbringer ja liegt mit Sicherheit an den eckigen Klammern. Allerdings sollte ich das auf Adapterseite handhaben, wenn das in der Bridge so benannt werden darf.
                    @foxriver76 Ok, schreist halt wenn ich wieder was testen kann 😉 Falls es dir noch weiter hilft, inzwischen ballern die Fehlermeldungen durchgehend rein. Aber Adapter funktioniert nach wie vor so gut wie seit 2.0
                    • foxriver76
                      @Stormbringer Ich mache das morgen mal. Muss vermutlich nur die unerlaubten Chars ersetzten.
                        @foxriver76 Dankeschön 🙂
                        • foxriver76
                          @Stormbringer Aktualisiert auf Github. Upload nicht vergessen 😉
                            @foxriver76 Danke, erledigt. Gute Nachricht vorweg, die Fehlermeldungen sind weg 😉 Schlechte Nachricht die Lichter werden nur eingeschalten ohne Dynamik
                            Hier der LOG Auszug aber glaub der sagt nicht viel aus:
                            hue.0 2019-11-10 11:23:53.695 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:53.673 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:53.669 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:53.669 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:53.511 debug Poll all states
                            hue.0 2019-11-10 11:23:50.699 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:50.687 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:50.686 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:50.684 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:50.510 debug Poll all states
                            hue.0 2019-11-10 11:23:47.700 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:47.682 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:47.679 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:47.677 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:47.509 debug Poll all states
                            hue.0 2019-11-10 11:23:44.695 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:44.683 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:44.683 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:44.677 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:44.509 debug Poll all states
                            hue.0 2019-11-10 11:23:41.698 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:41.681 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:41.681 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:41.679 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:41.509 debug Poll all states
                            hue.0 2019-11-10 11:23:38.693 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:38.681 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:38.681 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:38.679 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:38.508 debug Poll all states
                            hue.0 2019-11-10 11:23:35.682 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:35.668 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:35.667 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:35.666 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:35.507 debug Poll all states
                            hue.0 2019-11-10 11:23:32.723 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:32.676 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:32.676 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:32.675 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:32.506 debug Poll all states
                            hue.0 2019-11-10 11:23:29.691 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:29.677 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:29.676 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:29.674 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:29.505 debug Poll all states
                            hue.0 2019-11-10 11:23:26.706 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:26.693 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:26.693 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:26.691 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:26.506 debug Poll all states
                            hue.0 2019-11-10 11:23:23.691 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:23.677 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:23.676 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:23.676 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:23.505 debug Poll all states
                            hue.0 2019-11-10 11:23:20.690 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:20.675 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:20.673 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:20.672 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:20.505 debug Poll all states
                            hue.0 2019-11-10 11:23:17.706 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:17.693 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:17.692 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:17.691 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:17.505 debug Poll all states
                            hue.0 2019-11-10 11:23:14.730 debug groups.get:0:945b5b55e61738ee1c25ff4cd9aecf09 result: {"_rawData":{"name":"Group 0","lights":["1","5","8","9","10","11","12","16","17","19","20","21","22","23","26","27","28","29","30","32","34","37",
                            hue.0 2019-11-10 11:23:14.716 debug groupQueue full. Throttling down...
                            hue.0 2019-11-10 11:23:14.713 debug polling group Philips_hue.All (0) with prio 5
                            hue.0 2019-11-10 11:23:14.712 debug getFullState:getFullState:ccc856ad56bbc1f50de0070dd3cb0267 result: {"lights":{"1":{"state":{"on":false,"bri":90,"hue":12828,"sat":52,"effect":"none","xy":[0.4578,0.412],"alert":"none","colormode":"xy"
                            hue.0 2019-11-10 11:23:14.505 debug Poll all states
                            hue.0 2019-11-10 11:23:12.595 info Started scene: Scene Scene myScene huelabs/meditati
                            • foxriver76
                              @Stormbringer ja musst herausfinden wie die Szene gestartet wird z. B. legt die Meditation Lights Szene einen Sensor an mit dem Namen Start and Stop. Dieser Sensor hat den DP Status. In allen bisher getesteten Fällen konnte ich die Szene steuern durch Status 0 == aus, Status 1 == an
                                @foxriver76 sagte in Test Adapter hue v2.2.x:
                                Start and Stop
                                Ah ok, und wo versteckt er sich bei dir? Wenn ich Start und Stop suche findet er z. B. nichts...
                                • foxriver76
                                  @Stormbringer
                                  Also, damit wir uns nicht falsch verstehen:
                                  1. Adapter Einstellungen angepasst
                                  2. Um bei unserem Beispiel zu bleiben -> Meditation Lights Hue Labs Szene
                                    Hier sieht man auch, dass dort Start and Stop steht -> so heißt dann auch der virtuelle Sensor
                                  3. Im Adapter den Sensor suchen und den Status mit 0/1 ansteuern. Ich habe hier die Namensspalte manuell geändert, damit ich es den Meditation Lights zuordnen kann.
                                    @foxriver76 Ne verstehen uns schon 😉 Wusste nur nicht woher das Start Stop kommt aber das ist jetzt geklärt. Anzeigen tut er leider bei mir noch immer nichts... Aber irgendwie spinnt bei mir jetzt der Broker voll. Adapter update oder Hue Adapter neu starten verursacht Neustart aller Instanzen... Sollt glaub ich erst mal die Baustelle klären g
                                    • foxriver76
                                      @Stormbringer Klingt nach js-controller 2 - Compact Modus?
                                        @foxriver76 hab noch den stable drauf, den meide ich noch g Oder brauch ich den für 2.4.0?
                                          @foxriver76 Ist es normal, dass der Hue Adapter 19 % CPU Last auf einem NUC verursacht?
                                          • foxriver76
                                            @Stormbringer Wenn das polling interval sehr niedrig ist und viele Geräte gesynched werden (Kann mir vorstellen, dass da jetzt einiges mehr ist durch diese virtuellen Sensoren bei dir) kann das schon sein, bei mir kann man jeweils Peaks (~15 % Auslastung auf einem Rock64) beobachten wenn gepollt wird
                                            79.9k
                                            hue hue adapter zigbee
                                            25
                                            208
                                            17723
