    4. Test Adapter z-wave v1.6.x
      cburghardt @Stormbringer last edited by
      @Stormbringer said in Test Adapter z-wave v1.6.x:
      Looool echt? dachte nur FHEM und Openhab ned
      Hab mich verlesen, es gibt nur ein binding lol
        Stormbringer @cburghardt last edited by Stormbringer
        @cburghardt Hab jetzt mal Node als erstes geupdeted... NPM rebuild hab ich gemacht... Alle Adapter laufen nur Z Wave meckert:
        zwave.0 2019-11-09 23:30:40.106 error Error: The module '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/openzwave_shared.node' was compiled against a different Node.js version using NODE_MODULE_VERSI
        zwave.0 2019-11-09 23:30:40.106 error uncaught exception: The module '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/openzwave_shared.node' was compiled against a different Node.js version using NODE
        zwave.0 2019-11-09 23:30:39.692 debug received all objects
        zwave.0 2019-11-09 23:30:38.890 info starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.17.0
        zwave.0 2019-11-09 23:30:08.540 error uncaught exception: The module '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/openzwave_shared.node' was compiled against a different Node.js version using NODE
        zwave.0 2019-11-09 23:30:07.959 debug received all objects
        zwave.0 2019-11-09 23:30:06.962 info starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.17.0
        zwave.0 2019-11-09 23:37:01.456 error at Module.load (internal/modules/cjs/loader.js:653:32)
        zwave.0 2019-11-09 23:37:01.456 error at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        zwave.0 2019-11-09 23:37:01.456 error at Module._compile (internal/modules/cjs/loader.js:778:30)
        zwave.0 2019-11-09 23:37:01.456 error at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:27:19)
        zwave.0 2019-11-09 23:37:01.456 error at require (internal/modules/cjs/helpers.js:25:18)
        zwave.0 2019-11-09 23:37:01.456 error at Module.require (internal/modules/cjs/loader.js:692:17)
        zwave.0 2019-11-09 23:37:01.456 error at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        zwave.0 2019-11-09 23:37:01.456 error at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        zwave.0 2019-11-09 23:37:01.456 error at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
        zwave.0 2019-11-09 23:37:01.456 error the module (for instance, using npm rebuild or npm install).
        zwave.0 2019-11-09 23:37:01.456 error NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
        zwave.0 2019-11-09 23:37:01.456 error NODE_MODULE_VERSION 57. This version of Node.js requires
        zwave.0 2019-11-09 23:37:01.456 error was compiled against a different Node.js version using
        zwave.0 2019-11-09 23:37:01.456 error Error: The module '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/openzwave_shared.node'
        zwave.0 2019-11-09 23:37:01.455 error the module (for instance, using npm rebuild or npm install).
        zwave.0 2019-11-09 23:37:01.455 error NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
        zwave.0 2019-11-09 23:37:01.455 error NODE_MODULE_VERSION 57. This version of Node.js requires
        zwave.0 2019-11-09 23:37:01.455 error was compiled against a different Node.js version using
        zwave.0 2019-11-09 23:37:01.455 error uncaught exception: The module '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/openzwave_shared.node'
        Sagt das was mein Hauptproblem ist g?
          @cburghardt sagte in Test Adapter z-wave v1.6.x:
          Glaub bei denen heißt alles Binding loool Binding ist bei denen sowas wie bei uns Adapter.... Hab das beim Umstieg von den ganzen Kaufsystemen neben FHEM und Broker getestet. Nur irgendwie ist das da saukompliziert im Vergleich zum Broker.
            @Stormbringer die node version hat nichts mit openzwave zu tun und somit auch nichts mit dem Problem. Aber nun gut, zu dem Fehler:
            https://www.iobroker.net/#de/documentation/install/updatenode.md
            S 3 Replies Last reply Reply Quote 0
              Ah ok, was willst du mir mit dem Link sagen? Das ich reinstall-skript versuchen soll?
                @cburghardt Habs hinbekommen. Anscheinend hat das npm rebuild nicht funktioniert.
                cd /opt/iobroker
                sudo mv reinstall.sh reinstall.dos
                sudo tr -d '\r' < reinstall.dos > reinstall.sh
                sudo chmod +x reinstall.sh
                und dann npm rebuild hat geholfen. Stell jetzt auf debug.
                  Verstehs nicht, jetzt kennt er batterie und strom gemischt nicht. Heißt manche Strom gehen, manche Batterie gehen.... Bei einem Aeon Multisensor 6 (strombetrieben) kommt im LOG beim Aufwecken:
                  zwave.0 2019-11-10 03:05:17.192 info node ready nodeID: 58, nodeInfo: {"manufacturer":"AEON Labs","manufacturerid":"0x0086","product":"ZW100 MultiSensor 6","producttype":"0x0002","productid":"0x0064","type":"Routing Multilevel Sensor","n
                  zwave.0 2019-11-10 03:05:17.099 debug node58: timeout
                  Aber Datenpunkte legt er nur so an (nach Scan Complete):
                  Bildschirmfoto 2019-11-10 um 00.47.40.png .
                  Downgrade auf 1.6.0 zeigt er komischerweise auch nicht mehr an.
                  Ich schlaf mal ne Runde drüber, vielleicht hab ich ja Glück und dir fällt noch was ein. Wär spaßhalber möglich die 1.7.0 mit der ozw libaray von der 1.6.0 umzustellen?
                    timeout deutet eher auf ein Kommunikationsproblem hin. Kommt nach dem timeout noch was anderes?
                    Ich verstehe die Aussage nicht. Warum sollten Datenpunkte nach einem normalen Neustart angelegt werden?
                    Und der Screenshot hat nur Basisdaten.
                    Wie gesagt: die Version 1.6.0 hat einfach nur den master von openzwave verwendet. Aber der entwickelt sich natürlich laufend weiter.
                    Du kannst es natürlich versuchen und den Master-Stand runterladen (https://github.com/OpenZWave/open-zwave/archive/master.zip), kompilieren und installieren. Aber ob der Adapter damit läuft, kann ich nicht sagen.
                      @cburghardt ne da kam sonst nichts anderes. Aber nach ein paar unfreiwilligen Neustarts durch Test von einem anderen Adapter hat er sich jetzt eigentlich gut eingependelt. Ähnlich wie die 1.6.0, also Top Arbeit mal wieder. Fettes Danke ;o)
                      Das Einzige was er jetzt noch hat aber offiziell per LOG meldet ist, dass die Karte nicht mehr geht
                      zwave.0 2019-11-11 19:20:11.707 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                      zwave.0 2019-11-11 19:20:11.707 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                      zwave.0 2019-11-11 19:20:11.707 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                      zwave.0 2019-11-11 19:20:11.707 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                      zwave.0 2019-11-11 19:20:11.707 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                      zwave.0 2019-11-11 19:20:11.707 error at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                      zwave.0 2019-11-11 19:20:11.707 error at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                      zwave.0 2019-11-11 19:20:11.707 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                      zwave.0 2019-11-11 19:20:11.707 error at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3679:41)
                      zwave.0 2019-11-11 19:20:11.707 error at Object.message (/opt/iobroker/node_modules/iobroker.zwave/main.js:214:65)
                      zwave.0 2019-11-11 19:20:11.707 error TypeError: Cannot read property 'common' of undefined
                      zwave.0 2019-11-11 19:20:11.705 error message messagebox.system.adapter.zwave.0 [object Object] Cannot read property 'common' of undefined
                      Oder ist dir das als GitHub Issue lieber?
                      C 2 Replies Last reply Reply Quote 0
                        Ja das wäre super
                          chris299 last edited by
                          für mich sieht die 1.6.3 des Z-Wave Adapters auch sehr gut aus 👏 , abgesehen von
                          https://github.com/ioBroker/ioBroker.zwave/issues/96 😉
                          (MacOS Catalina, node10.17, npm 6.11.3, AEOTEC Gen5 Z-Wave USB-Stick)
                          Viele Grüße
                          Christoph
                          chris299 created this issue in ioBroker/ioBroker.zwave
                          open Installation Zwave-Adapter auf MacOS via Gui schlägt fehl #96
                            Gefixt in der GitHub Version (aktuell über GitHub zu beziehen, demnächst auch als 1.7.1)
                              @cburghardt Danke, hab die 1.7.1 jetzt drauf 😉
                                @cburghardt Die läuft im übrigen Bombe. Hast du auch nen Paypalaccount um die mal n Bier für die Top Arbeit zu spendieren 😉
                                Das einzige was suboptimal ist, wenn man Info aktualisiert löscht er alle Datenpunkte. Weiß war eine beabsichtigte Änderung aber warum? Wenn die DP gelöscht werden spinnt der JS Adapter kurz rum, weil ihm die abpumpte fehlen, Historywerte muss man wieder neu setzen und die Namensgebung 🙈
                                  @Stormbringer ich weiß, das ist unschön, aber nicht zu vermeiden, openzwave selber löscht alle Attribute und dann die node bei diesem refresh. In vorherigen Versionen war das nicht so, weil der refresh faktisch nicht funktioniert hat, war ein Bug bei openzwave 😉
                                  Aber das Info aktualisieren sollte nur in Ausnahmefällen nötig sein.
                                    smudu last edited by
                                    Was Z-Wave betrifft, bin ich mir nicht mehr sicher ob der Wechsel zu ioBroker die richtige Entscheidung war...
                                    Ich habe am Wochende das Upgrade von 1.7.0 auf 1.7.2 durchgeführt. Aber eigentlich ist es nur schlimmer geworden.
                                    Das beim Wechsel von 1.4.x auf 1.6.x alle relevanten DPs sich ändern muss man wohl so hinnehmen. Das sollte m.E. präsenter drauf hingewiesen werden.
                                    Dann heißt es auf Github "On first run, the Adapter needs "some" time, to calculate all..." Das stimmt so auch nicht ganz. Fast alle Batterie-betriebenen Geräte wachen per Default nur alle 24 Stunden auf. Ich habe alleine 12 Fensterkontakte, die sich aus ioBroker-Sicht bis zum WAKEUP "tot" stellen, also bis zu 24 Stunden kein Fenster offen melden.
                                    Mit dem Update auf 1.7.2 führt der Reboot des Raspi oder auch nur ein einfaches "Info aktualisieren" nun dazu, dass der Z-Wave Adapter wieder alle Nodes neu scannt.
                                    Ansonsten ist mir noch aufgefallen, dass die Datenpunkte unter Configuration der jeweiligen Nodes anscheinend die Defaults des Herstellers sind und nicht das was tatsächlich konfiguriert ist. Demnach müssten alle meine Kontakte u.a. die Temperatur in Fahrenheit ausgeben. Auch eine 6-fach Steckdose, die ja immer erreichbar ist, hat nach dem erneuten Scan meine Einstellungen in den Datenpunkten wieder vergessen/zeigt den Default an.
                                    Einige Geräte/Datenpunkte werden nicht korrekt übernommen(?). Z.B. ein Fibaro Walli Rolladenschalter:
                                    "states": {
                                          "0": "Roller blind",
                                          "1": "Venetian blind",
                                          "2": "roller blind with built-in driver",
                                          "3": "roller blind with built-in driver (impulse)"
                                    In der zugehörigen openzwave.xml:
                                    <Value genre="config" index="151" label="Operating mode" size="1" type="list" value="1">
                                          <Help>This parameter allows adjusting operation according to the connected device.</Help>
                                          <Item label="Roller blind" value="1"/>
                                          <Item label="Venetian blind" value="2"/>
                                          <Item label="roller blind with built-in driver" value="5"/>
                                          <Item label="roller blind with built-in driver (impulse)" value="6"/>
                                        </Value>
                                    Wenn der Z-Wave Adapter neu startet braucht er auch immer mehrere "Anläufe" bis sich berappelt (Nein, ich war nicht zu ungeduldig):
                                    2019-12-02 19:34:43.225  info: zwave.0 List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyAMA0"}]
                                    2019-12-02 19:34:57.909  info: zwave.0 Execute refreshNodeInfo for 15
                                    2019-12-02 19:34:58.179  info: zwave.0 node removed: 15
                                    2019-12-02 19:34:58.258  info: zwave.0 State created: zwave.0.NODE15.MANUFACTURER_SPECIFIC.Config_File_Revision = undefined, index = 1, comClass = 114, instance = 1
                                    2019-12-02 19:34:58.260  info: zwave.0 State created: zwave.0.NODE15.MANUFACTURER_SPECIFIC.Loaded_Config_Revision = undefined, index = 0, comClass = 114, instance = 1
                                    2019-12-02 19:34:58.262  info: zwave.0 State created: zwave.0.NODE15.CONFIGURATION.Power_delta = undefined, index = 0, comClass = 112, instance = 1
                                    2019-12-02 19:34:58.263  info: zwave.0 State created: zwave.0.NODE15.CONFIGURATION.No_communication_light = undefined, index = 1, comClass = 112, instance = 1
                                    2019-12-02 19:34:58.264  info: zwave.0 State created: zwave.0.NODE15.CONFIGURATION.Room_color = undefined, index = 2, comClass = 112, instance = 1
                                    2019-12-02 19:34:58.265  info: zwave.0 State created: zwave.0.NODE15.CONFIGURATION.Power_on_relay = undefined, index = 3, comClass = 112, instance = 1
                                    2019-12-02 19:34:58.266  info: zwave.0 State created: zwave.0.NODE15.CONFIGURATION.LED_on_network_error = undefined, index = 4, comClass = 112, instance = 1
                                    2019-12-02 19:34:58.305  info: zwave.0 State created: zwave.0.NODE15.VERSION.Library_Version = undefined, index = 0, comClass = 134, instance = 1
                                    2019-12-02 19:34:58.317  info: zwave.0 State created: zwave.0.NODE15.VERSION.Protocol_Version = undefined, index = 1, comClass = 134, instance = 1
                                    2019-12-02 19:34:58.366  error: Caught by controller[0]: terminate called after throwing an instance of 'OpenZWave::OZWException'
                                    2019-12-02 19:34:58.367  error: Caught by controller[0]:   what():  Manager.cpp:1514 - InvalidValueIDError (101) Msg: Invalid ValueID passed to GetValueLabel
                                    2019-12-02 19:34:58.367  warn: host.mdomu*** instance system.adapter.zwave.0 terminated due to SIGABRT
                                    2019-12-02 19:34:58.367  error: host.mdomu*** instance system.adapter.zwave.0 terminated with code null ()
                                    2019-12-02 19:34:58.367  info: host.mdomu*** Restart adapter system.adapter.zwave.0 because enabled
                                    2019-12-02 19:35:28.403  info: host.mdomu*** instance system.adapter.zwave.0 started with pid 14993
                                    2019-12-02 19:35:29.092  info: zwave.0 starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.17.0
                                    2019-12-02 19:35:33.609  info: zwave.0 scanning homeid=0xe58b19ca...
                                    2019-12-02 19:35:33.611  info: zwave.0 driver ready: homeid = e58b19ca
                                    2019-12-02 19:35:33.615  info: zwave.0 Update zwave.0.NODE1
                                    2019-12-02 19:35:33.626  info: zwave.0 Update zwave.0.NODE2
                                    2019-12-02 19:35:34.191  info: zwave.0 Update zwave.0.NODE30
                                    2019-12-02 19:35:34.216  info: zwave.0 Update zwave.0.NODE31
                                    2019-12-02 19:35:37.378  info: zwave.0 node ready nodeID: 1, nodeInfo: {"manufacturer":"Z-Wave.Me","manufacturerid":"0x0115","product":"ZME_UZB1 USB Stick","producttype":"0x0400","productid":"0x0001","type":"Static PC Controller","name":"","loc":""}
                                    2019-12-02 19:35:37.379  info: zwave.0 Update zwave.0.NODE1
                                    2019-12-02 19:35:37.533  info: zwave.0 State created: zwave.0.NODE15.SWITCH_ALL.Switch_All = undefined, index = 0, comClass = 39, instance = 1
                                    2019-12-02 19:35:51.664  info: zwave.0 State created: zwave.0.NODE15.MANUFACTURER_SPECIFIC.Latest_Available_Config_File_Revision = undefined, index = 2, comClass = 114, instance = 1
                                    2019-12-02 19:35:51.670  info: zwave.0 State created: zwave.0.NODE15.MANUFACTURER_SPECIFIC.Device_ID = undefined, index = 3, comClass = 114, instance = 1
                                    2019-12-02 19:35:51.672  info: zwave.0 State created: zwave.0.NODE15.MANUFACTURER_SPECIFIC.Serial_Number = undefined, index = 4, comClass = 114, instance = 1
                                    2019-12-02 19:36:03.510  info: zwave.0 State created: zwave.0.NODE15.VERSION.Library_Version = undefined, index = 0, comClass = 134, instance = 1
                                    2019-12-02 19:36:03.517  info: zwave.0 State created: zwave.0.NODE15.VERSION.Protocol_Version = undefined, index = 1, comClass = 134, instance = 1
                                    2019-12-02 19:36:03.560  error: Caught by controller[0]: terminate called after throwing an instance of 'OpenZWave::OZWException'
                                    2019-12-02 19:36:03.561  error: Caught by controller[0]:   what():  Manager.cpp:1514 - InvalidValueIDError (101) Msg: Invalid ValueID passed to GetValueLabel
                                    2019-12-02 19:36:03.561  warn: host.mdomu*** instance system.adapter.zwave.0 terminated due to SIGABRT
                                    2019-12-02 19:36:03.561  error: host.mdomu*** instance system.adapter.zwave.0 terminated with code null ()
                                    2019-12-02 19:36:03.562  info: host.mdomu*** Restart adapter system.adapter.zwave.0 because enabled
                                    2019-12-02 19:36:33.591  info: host.mdomu*** instance system.adapter.zwave.0 started with pid 16274
                                    2019-12-02 19:36:34.257  info: zwave.0 starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.17.0
                                    2019-12-02 19:36:36.414  info: zwave.0 scanning homeid=0xe58b19ca...
                                    2019-12-02 19:36:36.416  info: zwave.0 driver ready: homeid = e58b19ca
                                    2019-12-02 19:36:36.421  info: zwave.0 Update zwave.0.NODE1
                                    2019-12-02 19:36:36.433  info: zwave.0 Update zwave.0.NODE2
                                    2019-12-02 19:36:36.681  info: zwave.0 Update zwave.0.NODE30
                                    2019-12-02 19:36:37.159  info: zwave.0 Update zwave.0.NODE31
                                    2019-12-02 19:36:40.264  info: zwave.0 node ready nodeID: 1, nodeInfo: {"manufacturer":"Z-Wave.Me","manufacturerid":"0x0115","product":"ZME_UZB1 USB Stick","producttype":"0x0400","productid":"0x0001","type":"Static PC Controller","name":"","loc":""}
                                    2019-12-02 19:36:40.265  info: zwave.0 Update zwave.0.NODE1
                                    2019-12-02 19:37:05.662  info: zwave.0 State created: zwave.0.NODE15.VERSION.Protocol_Version = undefined, index = 1, comClass = 134, instance = 1
                                    2019-12-02 19:37:05.669  info: zwave.0 State created: zwave.0.NODE15.VERSION.Application_Version = undefined, index = 2, comClass = 134, instance = 1
                                    2019-12-02 19:37:05.671  info: zwave.0 State created: zwave.0.NODE15.INDICATOR.Indicator_1 = undefined, index = 0, comClass = 135, instance = 1
                                    2019-12-02 19:37:05.673  info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Protection = undefined, index = 0, comClass = 117, instance = 1
                                    2019-12-02 19:37:52.887  info: zwave.0 node ready nodeID: 3, nodeInfo: {"manufacturer":"Devolo home Control","manufacturerid":"0x0175","product":"Metering Plug MT02646","producttype":"0x0001","productid":"0x0011","type":"On/Off Power Switch","name":"","loc":""}
                                    2019-12-02 19:37:52.889  info: zwave.0 Update zwave.0.NODE3
                                    2019-12-02 19:37:52.957  info: zwave.0 node ready nodeID: 16, nodeInfo: {"manufacturer":"Popp & Co","manufacturerid":"0x0154","product":"Smoke Detector and Siren","producttype":"0x0100","productid":"0x0201","type":"Smoke Alarm Sensor","name":"","loc":""}
                                    2019-12-02 19:37:52.957  info: zwave.0 Update zwave.0.NODE16
                                    2019-12-02 19:37:53.057  info: zwave.0 node ready nodeID: 24, nodeInfo: {"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGS223 Double Relay","producttype":"0x0203","productid":"0x1000","type":"On/Off Power Switch","name":"","loc":""}
                                    2019-12-02 19:37:53.058  info: zwave.0 Update zwave.0.NODE24
                                    2019-12-02 19:37:53.153  info: zwave.0 node ready nodeID: 25, nodeInfo: {"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGS223 Double Relay","producttype":"0x0203","productid":"0x1000","type":"On/Off Power Switch","name":"","loc":""}
                                    2019-12-02 19:37:53.154  info: zwave.0 Update zwave.0.NODE25
                                    2019-12-02 19:37:53.226  info: zwave.0 node ready nodeID: 27, nodeInfo: {"manufacturer":"Popp & Co","manufacturerid":"0x0154","product":"Smoke Detector and Siren","producttype":"0x0100","productid":"0x0201","type":"Smoke Alarm Sensor","name":"","loc":""}
                                    2019-12-02 19:37:53.227  info: zwave.0 Update zwave.0.NODE27
                                    2019-12-02 19:37:53.297  info: zwave.0 node ready nodeID: 31, nodeInfo: {"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGWR111 Walli Roller Shutter","producttype":"0x1d01","productid":"0x1000","type":"Window Covering Endpoint Aware","name":"","loc":""}
                                    2019-12-02 19:37:53.297  info: zwave.0 Update zwave.0.NODE31
                                    2019-12-02 19:37:53.382  info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Instance_2:_Switch_2 = undefined, index = 0, comClass = 37, instance = 2
                                    2019-12-02 19:37:53.390  info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Instance_2:_Protection = undefined, index = 0, comClass = 117, instance = 2
                                    2019-12-02 19:37:53.392  info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Instance_3:_Switch_3 = undefined, index = 0, comClass = 37, instance = 3
                                    2019-12-02 19:37:53.393  info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Instance_3:_Protection = undefined, index = 0, comClass = 117, instance = 3
                                    2019-12-02 19:37:53.394  info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Instance_4:_Switch_4 = undefined, index = 0, comClass = 37, instance = 4
                                    2019-12-02 19:37:53.395  info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Instance_4:_Protection = undefined, index = 0, comClass = 117, instance = 4
                                    2019-12-02 19:37:53.396  info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Instance_5:_Switch_5 = undefined, index = 0, comClass = 37, instance = 5
                                    2019-12-02 19:37:53.397  info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Instance_5:_Protection = undefined, index = 0, comClass = 117, instance = 5
                                    Das OZW_log.txt wird bei jedem Neustart neu erstellt. Das er die manufacturer_specific.xml nicht nachladen und dort speichern kann, ist vermutlich auch nicht korrekt?:
                                    2019-12-02 19:36:35.271 Always, OpenZwave Version 1.6-953-g79663e1e-dirty Starting Up
                                    2019-12-02 19:36:35.282 Info, Loading Localization File /usr/local/etc/openzwave/Localization.xml
                                    2019-12-02 19:36:35.284 Info, Loaded /usr/local/etc/openzwave/Localization.xml With Revision 8
                                    2019-12-02 19:36:35.285 Always, Using Language Localization
                                    2019-12-02 19:36:35.287 Info, Loading NotificationCCTypes File /usr/local/etc/openzwave/NotificationCCTypes.xml
                                    2019-12-02 19:36:35.288 Info, Loaded /usr/local/etc/openzwave/NotificationCCTypes.xml With Revision 9
                                    2019-12-02 19:36:35.290 Info, Loading SensorMultiLevelCCTypes File /usr/local/etc/openzwave/SensorMultiLevelCCTypes.xml
                                    2019-12-02 19:36:35.290 Info, Loaded /usr/local/etc/openzwave/SensorMultiLevelCCTypes.xml With Revision 3
                                    2019-12-02 19:36:35.290 Info, Setting Up Provided Network Key for Secure Communications
                                    2019-12-02 19:36:35.307 Info, Manufacturer_Specific.xml file Revision is 56
                                    2019-12-02 19:36:35.676 Info, Product name collision: FGR223 Roller Shutter Controller 3 type 303 id 1000 manufacturerid 10f, collides with FGRM223 Roller Shutter Controller 3, type 303 id 1000 manufacturerid 10f
                                    2019-12-02 19:36:35.900 Info, Product name collision: ED2.0 Meter Adapter type 0 id 0 manufacturerid 128, collides with ED2.0 Meter Adapter, type 0 id 0 manufacturerid 128
                                    2019-12-02 19:36:35.900 Info, Product name collision: ED2.0 Display type 128 id 0 manufacturerid 128, collides with ED2.0 Display, type 128 id 0 manufacturerid 128
                                    2019-12-02 19:36:36.032 Info, Product name collision: ZW500D 500W In-Wall Preset Dimmer Switch type 102 id 201 manufacturerid 11a, collides with ZW500D 500W In-Wall Preset Dimmer Switch, type 102 id 201 manufacturerid 11a
                                    2019-12-02 19:36:36.032 Info, Product name collision: ZW15RM Plus 15A TR Smart Meter Duplex Receptacle type 111 id 105 manufacturerid 11a, collides with ZW15RM Plus 15A TR Smart Meter Duplex Receptacle, type 111 id 105 manufacturerid 11a
                                    2019-12-02 19:36:36.073 Info, Queuing Lookup on mfs.db.openzwave.com for Node 0
                                    2019-12-02 19:36:36.074 Info,   Opening controller /dev/ttyACM0
                                    2019-12-02 19:36:36.074 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
                                    2019-12-02 19:36:36.074 Info, Starting DNSThread
                                    2019-12-02 19:36:36.074 Info, mgr,     Added driver for controller /dev/ttyACM0
                                    2019-12-02 19:36:36.074 Info, Timer: thread starting
                                    2019-12-02 19:36:36.074 Detail, Timer: waiting with timeout -1 ms
                                    2019-12-02 19:36:36.074 Info, LookupTxT Checking mfs.db.openzwave.com
                                    2019-12-02 19:36:36.075 Info, Lookup for mfs.db.openzwave.com returned 59
                                    2019-12-02 19:36:36.077 Info, Serial port /dev/ttyACM0 opened (attempt 1)
                                    2019-12-02 19:36:36.077 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
                                    2019-12-02 19:36:36.077 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
                                    2019-12-02 19:36:36.077 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
                                    2019-12-02 19:36:36.077 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
                                    2019-12-02 19:36:36.077 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
                                    2019-12-02 19:36:36.077 Warning, Config Revision of ManufacturerSpecific Database is out of date
                                    2019-12-02 19:36:36.077 Info, Queuing download for http://download.db.openzwave.com/mfs.xml
                                    2019-12-02 19:36:36.085 Warning, File Removal failed: /usr/local/etc/openzwave/manufacturer_specific.xml
                                    2019-12-02 19:36:36.085 Warning, File Transfer Failed. Could not Rotate Existing File: /usr/local/etc/openzwave/manufacturer_specific.xml
                                    2019-12-02 19:36:36.085 Warning, Can't download ManufacturerSpecifix.xml Config file
                                    2019-12-02 19:36:36.085 Info, ManufacturerSpecificDB Initialized
                                    2019-12-02 19:36:36.085 Detail, Notification: User Alert - Manufacturer_specific.xml out of Date
                                    2019-12-02 19:36:36.085 Detail, Notification: A Config File Failed to download
                                    2019-12-02 19:36:36.085 Detail, Notification: ManufacturerSpecificDB Ready
                                    2019-12-02 19:36:36.086 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
                                    2019-12-02 19:36:36.086 Info, contrlr, Encrypted Flag is 0
                                    2019-12-02 19:36:36.088 Detail, contrlr,   Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x36, 0x2e, 0x30, 0x32, 0x00, 0x01, 0x92
                                    2019-12-02 19:36:36.088 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
                                    2019-12-02 19:36:36.088 Info, contrlr,     Static Controller library, version Z-Wave 6.02
                                    2019-12-02 19:36:36.088 Detail, contrlr,   Expected reply was received
                                    2019-12-02 19:36:36.088 Detail, contrlr,   Message transaction complete
                                    2019-12-02 19:36:36.321 Info, Node003, (50 - COMMAND_CLASS_METER) - Compatibility Flags:
                                    2019-12-02 19:36:36.321 Info, Node003, (50 - COMMAND_CLASS_METER) - State Flags:
                                    2019-12-02 19:36:36.321 Info, Node003, 	 CCVersion: 3
                                    2019-12-02 19:36:36.321 Info, Node003, 	 InNif: true
                                    2019-12-02 19:36:36.321 Info, Node003, 	 StaticRequests: 2
                                    2019-12-02 19:36:36.321 Warning, Localization::ReadXMLVIDHelp: Error in /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/../../ozwcache_0xe58b19ca.xml at line 436 - No Help Entry for CommandClass 50, ValueID: 0 (-1):  (null) (Lang: )
                                    2019-12-02 19:36:36.321 Warning, Localization::ReadXMLVIDHelp: Error in /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/../../ozwcache_0xe58b19ca.xml at line 439 - No Help Entry for CommandClass 50, ValueID: 2 (-1):  (null) (Lang: )
                                    2019-12-02 19:36:36.321 Warning, Localization::ReadXMLVIDHelp: Error in /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/../../ozwcache_0xe58b19ca.xml at line 442 - No Help Entry for CommandClass 50, ValueID: 4 (-1):  (null) (Lang: )
                                    2019-12-02 19:36:36.321 Warning, Localization::ReadXMLVIDHelp: Error in /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/../../ozwcache_0xe58b19ca.xml at line 445 - No Help Entry for CommandClass 50, ValueID: 5 (-1):  (null) (Lang: )
                                    2019-12-02 19:36:36.321 Warning, Localization::ReadXMLVIDHelp: Error in /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/../../ozwcache_0xe58b19ca.xml at line 448 - No Help Entry for CommandClass 50, ValueID: 6 (-1):  (null) (Lang: )
                                    2019-12-02 19:36:36.321 Warning, Localization::ReadXMLVIDHelp: Error in /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/../../ozwcache_0xe58b19ca.xml at line 451 - No Help Entry for CommandClass 50, ValueID: 256 (-1):  (null) (Lang: )
                                    2019-12-02 19:36:36.321 Warning, Localization::ReadXMLVIDHelp: Error in /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Release/../../ozwcache_0xe58b19ca.xml at line 454 - No Help Entry for CommandClass 50, ValueID: 257 (-1):  (null) (Lang: )
                                    2019-12-02 19:36:36.321 Info, Node003, (90 - COMMAND_CLASS_DEVICE_RESET_LOCALLY) - Compatibility Flags:
                                    2019-12-02 19:36:36.321 Info, Node003, (90 - COMMAND_CLASS_DEVICE_RESET_LOCALLY) - State Flags:
                                    2019-12-02 19:36:36.321 Info, Node003, 	 StaticRequests: 4
                                    2019-12-02 19:36:36.326 Info, Node008, 	 CCVersion: 4
                                    2019-12-02 19:36:36.326 Info, Node008, 	 InNif: true
                                    2019-12-02 19:36:36.326 Info, Node008, 	 StaticRequests: 0
                                    2019-12-02 19:36:36.326 Warning, Value size is invalid (0). Only 1, 2 & 4 supported for node 8, class 0x71, instance 1, index 6
                                    2019-12-02 19:36:36.326 Info, Node008, (114 - COMMAND_CLASS_MANUFACTURER_SPECIFIC) - Compatibility Flags:
                                    2019-12-02 19:36:36.326 Info, Node008, (114 - COMMAND_CLASS_MANUFACTURER_SPECIFIC) - State Flags:
                                    2019-12-02 19:36:36.326 Info, Node008, 	 CCVersion: 2
                                    C S 2 Replies Last reply Reply Quote 0
                                      cburghardt @smudu last edited by
                                      @smudu said in Test Adapter z-wave v1.6.x:
                                      Das kann ich bei meinen Geräten nicht bestätigen. Melden die Geräte laut dem ozw log denn diesen Status?
                                      Das neue Scannen ist bei jedem Start des Adapters der Fall, so wie bei allen mir bekannten z-wave Implementierungen. Info aktualisieren macht das aber nur beim node.
                                      Vermutlich nicht vergessen (das Gerät speichert es selber), aber dann stimmt die Anzeige nicht. Da wäre ein bug report gut.
                                      "states": {
                                          </Value>
                                      Vermutlich ein bug. Auch da wäre ein GitHub issue sinnvoll.
                                      Das habe ich schon mal gesehen. Da ist ein falscher Wert in der openzwave config gespeichert. Was da normal hilft ist ein refresh dieses Node.
                                      Naja, wenn es bei dir in /usr/local gespeichert ist und der Adapter dort keinen Schreibzugriff hat? Ob man den download will oder nicht, ist aber eine persönliche Entscheidung, die Auslieferungsversion geht ja.
                                        Stormbringer @smudu last edited by
                                        @smudu Darf ich fragen worauf die Z Wave vorher laufen hast lassen? War eigentlich auch immer am übleren, dass outzusourcen. Aber die aktuelle Beta läuft jetzt seit langem echt mal gut.
                                          ich hab auch mehrfach umgestellt .. ja es ist nervig das die Objectnamen sich geändert haben (vor allem wenn man Grafen erstellt mit den Datenpunkten)
                                          aber da können wir nix machen.. die Daten kommen so vom OZW.. ansonsten läft das Ding wie lange nicht mehr..
                                          bin froh dass sich das einer angenommen hat..
                                          danke @cburghardt
                                            @Stormbringer
                                            Das einfache zu erst: Ich komme von fhem
                                            @cburghardt
                                            Das mit dem Githib Issues kann ich machen.
                                            Das mit dem Speichern der XML unter /usr/local... habe ich mir nicht ausgesucht und wäre mir ohne Fehlersuche auch nicht aufgefallen.
                                            Vielleicht habe ich mich mißverständlich ausgedrückt. Das Scannen ist natürlich normal. Nur das ioBroker(openzave) bis zum nächsten WAKEUP einer Node keine Status Änderungen meldet, erwarte ich nur unter folgenden Bedingungen:
                                            • Neuinstallation Adapter/Instanz
                                            • Major Update wie von 1.4.x nach 1.6.x
                                            Ich habe heute nochmals versucht das, mehr oder weniger erfolgreich, zu reproduzieren
                                            • Neustart der Z-Wave Instanz > Ok
                                            • Kompletter Neustart Raspi > Ok
                                            • Info Aktualisieren bei Node 24 (Fibaro Doppelschalter) > Ok, die Instanz bleibt dabei grün/wird nicht neu gestartet!
                                              Laut Log werden auch nur die Datenpunkte für diese Node aktualisiert.
                                            • Info Aktualisieren bei Node 15 (Greenwave 6-fach Steckdose) > Fehler
                                              Die Zwave Instanz startet drei mal neu und macht dabei ein Update aller Nodes. Warum aber neben Node 15 nur nochmals für Node 24 alle Datenpunkte aktualisiert werden erschließt sich mir nicht.
                                              Bei einer 6-fach Steckdose mit Messung kommt einiges an Datenpunkten zusammen, vielleicht ein Timeout Problem?
                                            Was mir wichtig ist, dass die Fensterkontakte jetzt trotz der Neustarts immer noch ihren Status korrekt melden. Damit kann ich leben.
                                            Für das OZW log muss ich mir noch was einfallen lassen. Es gibt kein logrotate und es wird bei jedem Neustart der Instanz neu erstellt 😞
                                            Falls das ioBroker Log irgendwie hilft (Info Aktualisieren bei Node 15):
                                            2019-12-04 09:41:15.589 - info: zwave.0 List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyAMA0"}]
                                            2019-12-04 09:42:11.097 - info: zwave.0 Execute refreshNodeInfo for 15
                                            2019-12-04 09:42:11.405 - info: zwave.0 node removed: 15
                                            2019-12-04 09:42:11.582 - error: Caught by controller[0]: terminate called after throwing an instance of 'OpenZWave::OZWException'
                                            2019-12-04 09:42:11.583 - error: Caught by controller[0]: what(): Manager.cpp:1514 - InvalidValueIDError (101) Msg: Invalid ValueID passed to GetValueLabel
                                            2019-12-04 09:42:11.583 - warn: host.mdomus.*** instance system.adapter.zwave.0 terminated due to SIGABRT
                                            2019-12-04 09:42:11.583 - error: host.mdomus.*** instance system.adapter.zwave.0 terminated with code null ()
                                            2019-12-04 09:42:11.583 - info: host.mdomus.*** Restart adapter system.adapter.zwave.0 because enabled
                                            2019-12-04 09:42:41.608 - info: host.mdomus.*** instance system.adapter.zwave.0 started with pid 23326
                                            2019-12-04 09:42:42.289 - info: zwave.0 starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.17.0
                                            2019-12-04 09:42:44.380 - info: zwave.0 scanning homeid=0xe58b19ca...
                                            2019-12-04 09:42:44.381 - info: zwave.0 driver ready: homeid = e58b19ca
                                            2019-12-04 09:42:44.385 - info: zwave.0 Update zwave.0.NODE1
                                            2019-12-04 09:42:44.397 - info: zwave.0 Update zwave.0.NODE2
                                            2019-12-04 09:42:44.429 - info: zwave.0 Update zwave.0.NODE3
                                            2019-12-04 09:42:44.454 - info: zwave.0 Update zwave.0.NODE8
                                            2019-12-04 09:42:44.469 - info: zwave.0 Update zwave.0.NODE9
                                            2019-12-04 09:42:44.482 - info: zwave.0 Update zwave.0.NODE10
                                            2019-12-04 09:42:44.495 - info: zwave.0 Update zwave.0.NODE16
                                            2019-12-04 09:42:44.787 - info: zwave.0 Update zwave.0.NODE17
                                            2019-12-04 09:42:44.799 - info: zwave.0 Update zwave.0.NODE18
                                            2019-12-04 09:42:44.814 - info: zwave.0 Update zwave.0.NODE19
                                            2019-12-04 09:42:44.837 - info: zwave.0 Update zwave.0.NODE20
                                            2019-12-04 09:42:44.892 - info: zwave.0 Update zwave.0.NODE21
                                            2019-12-04 09:42:44.913 - info: zwave.0 Update zwave.0.NODE22
                                            2019-12-04 09:42:44.927 - info: zwave.0 Update zwave.0.NODE23
                                            2019-12-04 09:42:44.944 - info: zwave.0 Channel created: zwave.0.NODE24.SWITCH_ALL = Disabled, index = 0, comClass = 39, instance = 1
                                            2019-12-04 09:42:44.945 - info: zwave.0 State created: zwave.0.NODE24.SWITCH_ALL.Switch_All = undefined, index = 0, comClass = 39, instance = 1
                                            2019-12-04 09:42:44.949 - info: zwave.0 State created: zwave.0.NODE24.CENTRAL_SCENE.Scene_Reset_Timeout = undefined, index = 257, comClass = 91, instance = 1
                                            2019-12-04 09:42:44.953 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = State saved at power failure, all outputs are set to previous state upon power restore, index = 9, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.954 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Saving_state_before_power_failure = undefined, index = 9, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.954 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = Standard operation, index = 10, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.955 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.First_channel_-_operating_mode = undefined, index = 10, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.955 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = Cancel mode and set target state, index = 11, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.956 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.First_channel_-_reaction_to_switch_for_delay/auto_ON/OFF_modes = undefined, index = 11, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.956 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 50, index = 12, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.957 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.First_channel_-_time_parameter_for_delay/auto_ON/OFF_modes = undefined, index = 12, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.957 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 5, index = 13, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.957 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.First_channel_-_pulse_time_for_flashing_mode = undefined, index = 13, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.958 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = Standard operation, index = 15, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.958 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Second_channel_-_operating_mode = undefined, index = 15, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.959 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = Cancel mode and set target state, index = 16, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.959 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Second_channel_-_reaction_to_switch_for_delay/auto_ON/OFF_modes = undefined, index = 16, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.959 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 50, index = 17, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.960 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Second_channel_-_time_parameter_for_delay/auto_ON/OFF_modes = undefined, index = 17, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.960 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 5, index = 18, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.960 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Second_channel_-_pulse_time_for_flashing_mode = undefined, index = 18, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.961 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = Toggle switch (device changes status when switch changes status), index = 20, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.961 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Switch_type = undefined, index = 20, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.962 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = Disabled, index = 21, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.962 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Flashing_mode_report = undefined, index = 21, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.963 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 15, index = 27, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.963 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Associations_in_Z-Wave_network_security_mode = undefined, index = 27, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.964 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 0, index = 28, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.964 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.S1_switch_-_scenes_sent = undefined, index = 28, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.965 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 0, index = 29, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.965 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.S2_switch_-_scenes_sent = undefined, index = 29, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.966 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 0, index = 30, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.966 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.S1_associations_sent_to_2nd_and_3rd_association_groups = undefined, index = 30, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.966 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 255, index = 31, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.967 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.S1_Switch_ON_value_sent_to_2nd_and_3rd_association_groups = undefined, index = 31, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.967 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 0, index = 32, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.967 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.S1_Switch_OFF_value_sent_to_2nd_and_3rd_association_groups = undefined, index = 32, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.968 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 99, index = 33, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.968 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.S1_Switch_Double_Click_value_sent_to_2nd_and_3rd_association_groups = undefined, index = 33, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.969 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 0, index = 35, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.969 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.S2_associations_sent_to_4th_and_5th_association_groups = undefined, index = 35, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.970 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 255, index = 36, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.970 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.S2_Switch_ON_value_sent_to_4th_and_5th_association_groups = undefined, index = 36, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.971 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 0, index = 37, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.972 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.S2_Switch_OFF_value_sent_to_4th_and_5th_association_groups = undefined, index = 37, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.973 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 99, index = 38, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.973 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.S2_Switch_Double_Click_value_sent_to_4th_and_5th_association_groups = undefined, index = 38, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.974 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = Flash, index = 40, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.974 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Reaction_to_General_Alarm = undefined, index = 40, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.975 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = Turn OFF, index = 41, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.976 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Reaction_to_Flood_Alarm = undefined, index = 41, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.977 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = Flash, index = 42, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.977 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Reaction_to_CO/CO2/Smoke_Alarm = undefined, index = 42, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.978 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = Turn On, index = 43, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.979 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Reaction_to_Heat_Alarm = undefined, index = 43, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.980 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 600, index = 44, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.981 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Flashing_alarm_duration = undefined, index = 44, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.982 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 20, index = 50, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.982 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.First_channel_-_power_reports = undefined, index = 50, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.983 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 10, index = 51, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.983 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.First_channel_-_minimal_time_between_power_reports = undefined, index = 51, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.984 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 100, index = 53, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.985 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.First_channel_-_energy_reports = undefined, index = 53, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.985 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 20, index = 54, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.986 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Second_Channel_-_power_reports = undefined, index = 54, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.987 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 10, index = 55, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.987 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Second_channel_-_minimal_time_between_power_reports = undefined, index = 55, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.988 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 100, index = 57, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.988 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Second_channel_-_energy_reports = undefined, index = 57, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.989 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 3600, index = 58, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.989 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Periodic_power_reports = undefined, index = 58, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.990 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = 3600, index = 59, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.991 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Periodic_energy_reports = undefined, index = 59, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.991 - info: zwave.0 Channel created: zwave.0.NODE24.CONFIGURATION = function inactive, index = 60, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.992 - info: zwave.0 State created: zwave.0.NODE24.CONFIGURATION.Measuring_energy_consumed_by_the_device_itself = undefined, index = 60, comClass = 112, instance = 1
                                            2019-12-04 09:42:44.994 - info: zwave.0 State created: zwave.0.NODE24.MANUFACTURER_SPECIFIC.Loaded_Config_Revision = undefined, index = 0, comClass = 114, instance = 1
                                            2019-12-04 09:42:44.994 - info: zwave.0 State created: zwave.0.NODE24.MANUFACTURER_SPECIFIC.Config_File_Revision = undefined, index = 1, comClass = 114, instance = 1
                                            2019-12-04 09:42:44.995 - info: zwave.0 State created: zwave.0.NODE24.MANUFACTURER_SPECIFIC.Latest_Available_Config_File_Revision = undefined, index = 2, comClass = 114, instance = 1
                                            2019-12-04 09:42:44.996 - info: zwave.0 State created: zwave.0.NODE24.MANUFACTURER_SPECIFIC.Device_ID = undefined, index = 3, comClass = 114, instance = 1
                                            2019-12-04 09:42:45.001 - info: zwave.0 State created: zwave.0.NODE24.POWERLEVEL.Set_Powerlevel = undefined, index = 2, comClass = 115, instance = 1
                                            2019-12-04 09:42:45.005 - info: zwave.0 State created: zwave.0.NODE24.POWERLEVEL.Test_Node = undefined, index = 3, comClass = 115, instance = 1
                                            2019-12-04 09:42:45.006 - info: zwave.0 State created: zwave.0.NODE24.POWERLEVEL.Test_Powerlevel = undefined, index = 4, comClass = 115, instance = 1
                                            2019-12-04 09:42:45.007 - info: zwave.0 State created: zwave.0.NODE24.POWERLEVEL.Frame_Count = undefined, index = 5, comClass = 115, instance = 1
                                            2019-12-04 09:42:45.008 - info: zwave.0 State created: zwave.0.NODE24.POWERLEVEL.Test = undefined, index = 6, comClass = 115, instance = 1
                                            2019-12-04 09:42:45.009 - info: zwave.0 State created: zwave.0.NODE24.POWERLEVEL.Report = undefined, index = 7, comClass = 115, instance = 1
                                            2019-12-04 09:42:45.010 - info: zwave.0 State created: zwave.0.NODE24.POWERLEVEL.Test_Status = undefined, index = 8, comClass = 115, instance = 1
                                            2019-12-04 09:42:45.017 - info: zwave.0 State created: zwave.0.NODE24.POWERLEVEL.Acked_Frames = undefined, index = 9, comClass = 115, instance = 1
                                            2019-12-04 09:42:45.019 - info: zwave.0 Channel created: zwave.0.NODE24.SECURITY = false, index = 0, comClass = 152, instance = 1
                                            2019-12-04 09:42:45.019 - info: zwave.0 State created: zwave.0.NODE24.SECURITY.Secured = undefined, index = 0, comClass = 152, instance = 1
                                            2019-12-04 09:42:45.020 - info: zwave.0 Update zwave.0.NODE25
                                            2019-12-04 09:42:45.046 - info: zwave.0 Update zwave.0.NODE26
                                            2019-12-04 09:42:45.067 - info: zwave.0 Update zwave.0.NODE27
                                            2019-12-04 09:42:45.075 - info: zwave.0 Update zwave.0.NODE28
                                            2019-12-04 09:42:45.088 - info: zwave.0 Update zwave.0.NODE29
                                            2019-12-04 09:42:45.097 - info: zwave.0 Update zwave.0.NODE30
                                            2019-12-04 09:42:45.116 - info: zwave.0 Update zwave.0.NODE31
                                            2019-12-04 09:42:48.274 - info: zwave.0 node ready nodeID: 1, nodeInfo: {"manufacturer":"Z-Wave.Me","manufacturerid":"0x0115","product":"ZME_UZB1 USB Stick","producttype":"0x0400","productid":"0x0001","type":"Static PC Controller","name":"","loc":""}
                                            2019-12-04 09:42:48.275 - info: zwave.0 Update zwave.0.NODE1
                                            2019-12-04 09:42:48.377 - info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Switch_1 = undefined, index = 0, comClass = 37, instance = 1
                                            2019-12-04 09:42:48.379 - info: zwave.0 State created: zwave.0.NODE15.SWITCH_ALL.Switch_All = undefined, index = 0, comClass = 39, instance = 1
                                            2019-12-04 09:43:01.638 - info: zwave.0 State created: zwave.0.NODE15.MANUFACTURER_SPECIFIC.Loaded_Config_Revision = undefined, index = 0, comClass = 114, instance = 1
                                            2019-12-04 09:43:01.643 - info: zwave.0 State created: zwave.0.NODE15.MANUFACTURER_SPECIFIC.Config_File_Revision = undefined, index = 1, comClass = 114, instance = 1
                                            2019-12-04 09:43:01.644 - info: zwave.0 State created: zwave.0.NODE15.MANUFACTURER_SPECIFIC.Latest_Available_Config_File_Revision = undefined, index = 2, comClass = 114, instance = 1
                                            2019-12-04 09:43:01.649 - info: zwave.0 State created: zwave.0.NODE15.MANUFACTURER_SPECIFIC.Device_ID = undefined, index = 3, comClass = 114, instance = 1
                                            2019-12-04 09:43:01.650 - info: zwave.0 State created: zwave.0.NODE15.MANUFACTURER_SPECIFIC.Serial_Number = undefined, index = 4, comClass = 114, instance = 1
                                            2019-12-04 09:43:01.788 - info: zwave.0 State created: zwave.0.NODE15.CONFIGURATION.Power_delta = undefined, index = 0, comClass = 112, instance = 1
                                            2019-12-04 09:43:01.790 - info: zwave.0 State created: zwave.0.NODE15.CONFIGURATION.No_communication_light = undefined, index = 1, comClass = 112, instance = 1
                                            2019-12-04 09:43:01.791 - info: zwave.0 State created: zwave.0.NODE15.CONFIGURATION.Room_color = undefined, index = 2, comClass = 112, instance = 1
                                            2019-12-04 09:43:01.794 - info: zwave.0 State created: zwave.0.NODE15.CONFIGURATION.Power_on_relay = undefined, index = 3, comClass = 112, instance = 1
                                            2019-12-04 09:43:01.794 - info: zwave.0 State created: zwave.0.NODE15.CONFIGURATION.LED_on_network_error = undefined, index = 4, comClass = 112, instance = 1
                                            2019-12-04 09:43:13.472 - info: zwave.0 State created: zwave.0.NODE15.VERSION.Library_Version = undefined, index = 0, comClass = 134, instance = 1
                                            2019-12-04 09:43:13.476 - info: zwave.0 State created: zwave.0.NODE15.VERSION.Protocol_Version = undefined, index = 1, comClass = 134, instance = 1
                                            2019-12-04 09:43:13.527 - error: Caught by controller[0]: terminate called after throwing an instance of 'OpenZWave::OZWException'
                                            2019-12-04 09:43:13.527 - error: Caught by controller[0]: what(): Manager.cpp:1514 - InvalidValueIDError (101) Msg: Invalid ValueID passed to GetValueLabel
                                            2019-12-04 09:43:13.528 - warn: host.mdomus.*** instance system.adapter.zwave.0 terminated due to SIGABRT
                                            2019-12-04 09:43:13.528 - error: host.mdomus.*** instance system.adapter.zwave.0 terminated with code null ()
                                            2019-12-04 09:43:13.528 - info: host.mdomus.*** Restart adapter system.adapter.zwave.0 because enabled
                                            2019-12-04 09:43:43.555 - info: host.mdomus.*** instance system.adapter.zwave.0 started with pid 24638
                                            2019-12-04 09:43:44.235 - info: zwave.0 starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.17.0
                                            2019-12-04 09:43:46.307 - info: zwave.0 scanning homeid=0xe58b19ca...
                                            2019-12-04 09:43:46.310 - info: zwave.0 driver ready: homeid = e58b19ca
                                            2019-12-04 09:43:46.313 - info: zwave.0 Update zwave.0.NODE1
                                            2019-12-04 09:43:46.324 - info: zwave.0 Update zwave.0.NODE2
                                            2019-12-04 09:43:46.361 - info: zwave.0 Update zwave.0.NODE3
                                            2019-12-04 09:43:46.387 - info: zwave.0 Update zwave.0.NODE8
                                            2019-12-04 09:43:46.411 - info: zwave.0 Update zwave.0.NODE9
                                            2019-12-04 09:43:46.424 - info: zwave.0 Update zwave.0.NODE10
                                            2019-12-04 09:43:46.443 - info: zwave.0 Update zwave.0.NODE16
                                            2019-12-04 09:43:46.648 - info: zwave.0 Update zwave.0.NODE17
                                            2019-12-04 09:43:46.669 - info: zwave.0 Update zwave.0.NODE18
                                            2019-12-04 09:43:46.686 - info: zwave.0 Update zwave.0.NODE19
                                            2019-12-04 09:43:46.699 - info: zwave.0 Update zwave.0.NODE20
                                            2019-12-04 09:43:46.725 - info: zwave.0 Update zwave.0.NODE21
                                            2019-12-04 09:43:46.738 - info: zwave.0 Update zwave.0.NODE22
                                            2019-12-04 09:43:46.748 - info: zwave.0 Update zwave.0.NODE23
                                            2019-12-04 09:43:46.783 - info: zwave.0 Update zwave.0.NODE25
                                            2019-12-04 09:43:46.813 - info: zwave.0 Update zwave.0.NODE26
                                            2019-12-04 09:43:46.826 - info: zwave.0 Update zwave.0.NODE27
                                            2019-12-04 09:43:46.834 - info: zwave.0 Update zwave.0.NODE28
                                            2019-12-04 09:43:46.847 - info: zwave.0 Update zwave.0.NODE29
                                            2019-12-04 09:43:46.855 - info: zwave.0 Update zwave.0.NODE30
                                            2019-12-04 09:43:46.868 - info: zwave.0 Update zwave.0.NODE31
                                            2019-12-04 09:43:50.089 - info: zwave.0 node ready nodeID: 1, nodeInfo: {"manufacturer":"Z-Wave.Me","manufacturerid":"0x0115","product":"ZME_UZB1 USB Stick","producttype":"0x0400","productid":"0x0001","type":"Static PC Controller","name":"","loc":""}
                                            2019-12-04 09:43:50.090 - info: zwave.0 Update zwave.0.NODE1
                                            2019-12-04 09:44:15.723 - info: zwave.0 State created: zwave.0.NODE15.VERSION.Protocol_Version = undefined, index = 1, comClass = 134, instance = 1
                                            2019-12-04 09:44:15.773 - error: Caught by controller[0]: terminate called after throwing an instance of 'OpenZWave::OZWException'
                                            2019-12-04 09:44:15.774 - error: Caught by controller[0]: what(): Manager.cpp:1733 - InvalidValueIDError (101) Msg: Invalid ValueID passed to IsValueReadOnly
                                            2019-12-04 09:44:15.774 - warn: host.mdomus.*** instance system.adapter.zwave.0 terminated due to SIGABRT
                                            2019-12-04 09:44:15.774 - error: host.mdomus.*** instance system.adapter.zwave.0 terminated with code null ()
                                            2019-12-04 09:44:15.774 - info: host.mdomus.*** Restart adapter system.adapter.zwave.0 because enabled
                                            2019-12-04 09:44:45.798 - info: host.mdomus.*** instance system.adapter.zwave.0 started with pid 25817
                                            2019-12-04 09:44:46.545 - info: zwave.0 starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.17.0
                                            2019-12-04 09:44:48.802 - info: zwave.0 scanning homeid=0xe58b19ca...
                                            2019-12-04 09:44:48.803 - info: zwave.0 driver ready: homeid = e58b19ca
                                            2019-12-04 09:44:48.807 - info: zwave.0 Update zwave.0.NODE1
                                            2019-12-04 09:44:48.819 - info: zwave.0 Update zwave.0.NODE2
                                            2019-12-04 09:44:48.861 - info: zwave.0 Update zwave.0.NODE3
                                            2019-12-04 09:44:48.888 - info: zwave.0 Update zwave.0.NODE8
                                            2019-12-04 09:44:48.903 - info: zwave.0 Update zwave.0.NODE9
                                            2019-12-04 09:44:48.917 - info: zwave.0 Update zwave.0.NODE10
                                            2019-12-04 09:44:48.933 - info: zwave.0 Update zwave.0.NODE16
                                            2019-12-04 09:44:48.941 - info: zwave.0 Update zwave.0.NODE17
                                            2019-12-04 09:44:48.952 - info: zwave.0 Update zwave.0.NODE18
                                            2019-12-04 09:44:49.222 - info: zwave.0 Update zwave.0.NODE19
                                            2019-12-04 09:44:49.235 - info: zwave.0 Update zwave.0.NODE20
                                            2019-12-04 09:44:49.249 - info: zwave.0 Update zwave.0.NODE21
                                            2019-12-04 09:44:49.266 - info: zwave.0 Update zwave.0.NODE22
                                            2019-12-04 09:44:49.303 - info: zwave.0 Update zwave.0.NODE23
                                            2019-12-04 09:44:49.377 - info: zwave.0 Update zwave.0.NODE25
                                            2019-12-04 09:44:49.407 - info: zwave.0 Update zwave.0.NODE26
                                            2019-12-04 09:44:49.418 - info: zwave.0 Update zwave.0.NODE27
                                            2019-12-04 09:44:49.427 - info: zwave.0 Update zwave.0.NODE28
                                            2019-12-04 09:44:49.442 - info: zwave.0 Update zwave.0.NODE29
                                            2019-12-04 09:44:49.451 - info: zwave.0 Update zwave.0.NODE30
                                            2019-12-04 09:44:49.466 - info: zwave.0 Update zwave.0.NODE31
                                            2019-12-04 09:44:52.483 - info: zwave.0 node ready nodeID: 1, nodeInfo: {"manufacturer":"Z-Wave.Me","manufacturerid":"0x0115","product":"ZME_UZB1 USB Stick","producttype":"0x0400","productid":"0x0001","type":"Static PC Controller","name":"","loc":""}
                                            2019-12-04 09:44:52.484 - info: zwave.0 Update zwave.0.NODE1
                                            2019-12-04 09:45:27.431 - info: zwave.0 State created: zwave.0.NODE15.VERSION.Application_Version = undefined, index = 2, comClass = 134, instance = 1
                                            2019-12-04 09:46:14.939 - info: zwave.0 node ready nodeID: 3, nodeInfo: {"manufacturer":"Devolo home Control","manufacturerid":"0x0175","product":"Metering Plug MT02646","producttype":"0x0001","productid":"0x0011","type":"On/Off Power Switch","name":"","loc":""}
                                            2019-12-04 09:46:14.941 - info: zwave.0 Update zwave.0.NODE3
                                            2019-12-04 09:46:15.044 - info: zwave.0 node ready nodeID: 16, nodeInfo: {"manufacturer":"Popp & Co","manufacturerid":"0x0154","product":"Smoke Detector and Siren","producttype":"0x0100","productid":"0x0201","type":"Smoke Alarm Sensor","name":"","loc":""}
                                            2019-12-04 09:46:15.045 - info: zwave.0 Update zwave.0.NODE16
                                            2019-12-04 09:46:15.138 - info: zwave.0 node ready nodeID: 24, nodeInfo: {"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGS223 Double Relay","producttype":"0x0203","productid":"0x1000","type":"On/Off Power Switch","name":"","loc":""}
                                            2019-12-04 09:46:15.232 - info: zwave.0 node ready nodeID: 25, nodeInfo: {"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGS223 Double Relay","producttype":"0x0203","productid":"0x1000","type":"On/Off Power Switch","name":"","loc":""}
                                            2019-12-04 09:46:15.233 - info: zwave.0 Update zwave.0.NODE25
                                            2019-12-04 09:46:15.317 - info: zwave.0 node ready nodeID: 27, nodeInfo: {"manufacturer":"Popp & Co","manufacturerid":"0x0154","product":"Smoke Detector and Siren","producttype":"0x0100","productid":"0x0201","type":"Smoke Alarm Sensor","name":"","loc":""}
                                            2019-12-04 09:46:15.317 - info: zwave.0 Update zwave.0.NODE27
                                            2019-12-04 09:46:15.413 - info: zwave.0 node ready nodeID: 31, nodeInfo: {"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGWR111 Walli Roller Shutter","producttype":"0x1d01","productid":"0x1000","type":"Window Covering Endpoint Aware","name":"","loc":""}
                                            2019-12-04 09:46:15.413 - info: zwave.0 Update zwave.0.NODE31
                                            2019-12-04 09:46:15.496 - info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Instance_2:_Switch_2 = undefined, index = 0, comClass = 37, instance = 2
                                            2019-12-04 09:46:15.500 - info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Instance_2:_Protection = undefined, index = 0, comClass = 117, instance = 2
                                            2019-12-04 09:46:15.502 - info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Instance_3:_Switch_3 = undefined, index = 0, comClass = 37, instance = 3
                                            2019-12-04 09:46:15.504 - info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Instance_3:_Protection = undefined, index = 0, comClass = 117, instance = 3
                                            2019-12-04 09:46:15.505 - info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Instance_4:_Switch_4 = undefined, index = 0, comClass = 37, instance = 4
                                            2019-12-04 09:46:15.506 - info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Instance_4:_Protection = undefined, index = 0, comClass = 117, instance = 4
                                            2019-12-04 09:46:15.506 - info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Instance_5:_Switch_5 = undefined, index = 0, comClass = 37, instance = 5
                                            2019-12-04 09:46:15.507 - info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Instance_5:_Protection = undefined, index = 0, comClass = 117, instance = 5
                                            2019-12-04 09:46:15.508 - info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Instance_6:_Switch_6 = undefined, index = 0, comClass = 37, instance = 6
                                            2019-12-04 09:46:15.508 - info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Instance_6:_Protection = undefined, index = 0, comClass = 117, instance = 6
                                            2019-12-04 09:46:15.559 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_1:_Electric_-_kWh_1 = undefined, index = 0, comClass = 50, instance = 1
                                            2019-12-04 09:46:15.562 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_1:_Electric_-_W_1 = undefined, index = 2, comClass = 50, instance = 1
                                            2019-12-04 09:46:15.563 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_1:_Exporting_1 = undefined, index = 256, comClass = 50, instance = 1
                                            2019-12-04 09:46:15.564 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_1:_Reset = undefined, index = 257, comClass = 50, instance = 1
                                            2019-12-04 09:46:15.589 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_2:_Electric_-_kWh_2 = undefined, index = 0, comClass = 50, instance = 2
                                            2019-12-04 09:46:15.591 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_2:_Electric_-_W_2 = undefined, index = 2, comClass = 50, instance = 2
                                            2019-12-04 09:46:15.592 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_2:_Exporting_2 = undefined, index = 256, comClass = 50, instance = 2
                                            2019-12-04 09:46:15.593 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_2:_Reset = undefined, index = 257, comClass = 50, instance = 2
                                            2019-12-04 09:46:15.625 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_3:_Electric_-_kWh_3 = undefined, index = 0, comClass = 50, instance = 3
                                            2019-12-04 09:46:15.629 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_3:_Electric_-_W_3 = undefined, index = 2, comClass = 50, instance = 3
                                            2019-12-04 09:46:15.631 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_3:_Exporting_3 = undefined, index = 256, comClass = 50, instance = 3
                                            2019-12-04 09:46:15.631 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_3:_Reset = undefined, index = 257, comClass = 50, instance = 3
                                            2019-12-04 09:46:15.665 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_4:_Electric_-_kWh_4 = undefined, index = 0, comClass = 50, instance = 4
                                            2019-12-04 09:46:15.668 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_4:_Electric_-_W_4 = undefined, index = 2, comClass = 50, instance = 4
                                            2019-12-04 09:46:15.671 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_4:_Exporting_4 = undefined, index = 256, comClass = 50, instance = 4
                                            2019-12-04 09:46:15.672 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_4:_Reset = undefined, index = 257, comClass = 50, instance = 4
                                            2019-12-04 09:46:15.709 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_5:_Electric_-_kWh_5 = undefined, index = 0, comClass = 50, instance = 5
                                            2019-12-04 09:46:15.711 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_5:_Electric_-_W_5 = undefined, index = 2, comClass = 50, instance = 5
                                            2019-12-04 09:46:15.712 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_5:_Exporting_5 = undefined, index = 256, comClass = 50, instance = 5
                                            2019-12-04 09:46:15.713 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_5:_Reset = undefined, index = 257, comClass = 50, instance = 5
                                            2019-12-04 09:46:15.750 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_6:_Electric_-_kWh_6 = undefined, index = 0, comClass = 50, instance = 6
                                            2019-12-04 09:46:15.752 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_6:_Electric_-_W_6 = undefined, index = 2, comClass = 50, instance = 6
                                            2019-12-04 09:46:15.753 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_6:_Exporting_6 = undefined, index = 256, comClass = 50, instance = 6
                                            2019-12-04 09:46:15.754 - info: zwave.0 State created: zwave.0.NODE15.METER.Instance_6:_Reset = undefined, index = 257, comClass = 50, instance = 6
                                            2019-12-04 09:46:16.113 - info: zwave.0 State created: zwave.0.NODE15.PROTECTION.Instance_1:_Protection = undefined, index = 0, comClass = 117, instance = 1
                                            2019-12-04 09:46:16.356 - info: zwave.0 State created: zwave.0.NODE15.SWITCH_BINARY.Instance_1:_Switch_1 = undefined, index = 0, comClass = 37, instance = 1
                                            2019-12-04 09:46:17.203 - info: zwave.0 node ready nodeID: 15, nodeInfo: {"manufacturer":"GreenWave Reality Inc","manufacturerid":"0x0099","product":"PowerNode 6 port","producttype":"0x0003","productid":"0x0004","type":"Binary Power Switch","name":"","loc":""}
                                            2019-12-04 09:46:17.218 - info: zwave.0 Scan completed
                                            arteck C 2 Replies Last reply Reply Quote 0
                                            tester z-wave
                                            10
                                            101
                                            8468
