    4. Test js-controller v2.0.x (GitHub)
      apollon77 @SBorg last edited by
      @SBorg dann stell mal zurück. Silly macht log halt voll.
      • SBorg
        SBorg Forum Testing Most Active @apollon77 last edited by
        @apollon77 Keine Ahnung ob Zufall, aber wieder auf "Info" zurück und schon:
        ical.0	        2019-11-10 23:00:24.701	warn	(28785) no connection to objects DB
        dwd.0	        2019-11-10 23:00:24.675	warn	(28686) no connection to objects DB
        luftdaten.0	2019-11-10 23:00:24.642	warn	(28427) no connection to objects DB
        Wenn es aber eh keine Auswirkung hat, Wayne... 😁
          @SBorg hattest du so ein silly log mal gepostet? Bzw was ist bei debug?
          • SBorg
            @apollon77 nein, weil es im silly/debug-Modus problemlos läuft:
            2019-11-10 20:33:13.435 - info: host.Ubuntu instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
            2019-11-10 20:35:00.105 - info: host.Ubuntu instance system.adapter.luftdaten.0 started with pid 28937
            2019-11-10 20:35:03.705 - debug: luftdaten.0 (28937) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2019-11-10 20:35:05.065 - debug: luftdaten.0 (28937) Objects connected to redis: 127.0.0.1:9001
            2019-11-10 20:35:05.094 - debug: luftdaten.0 (28937) objectDB connected
            2019-11-10 20:35:05.099 - debug: luftdaten.0 (28937) Redis States: Use Redis connection: 127.0.0.1:9000
            2019-11-10 20:35:05.123 - debug: luftdaten.0 (28937) statesDB connected
            2019-11-10 20:35:05.182 - debug: luftdaten.0 (28937) States connected to redis: 127.0.0.1:9000
            2019-11-10 20:35:06.135 - info: luftdaten.0 (28937) starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v8.16.2
            2019-11-10 20:35:06.232 - debug: luftdaten.0 (28937) sensor type: remote, sensor identifier: XXX, sensor name: XXX
            2019-11-10 20:35:06.243 - debug: luftdaten.0 (28937) remote request started
            2019-11-10 20:35:06.424 - silly: luftdaten.0 (28937) States redis pmessage system.adapter.luftdaten.0.logLevel/system.adapter.luftdaten.0.logLevel:{"val":"silly","ack":true,"ts":1573414506361,"q":0,"from":"system.adapter.luftdaten.0","lc":1573400109996}
            2019-11-10 20:35:07.298 - debug: luftdaten.0 (28937) remote request done
            2019-11-10 20:35:07.299 - debug: luftdaten.0 (28937) received data (200): [{"sensor":{"id": --- langer JSON-String mit Daten --- ":null,"timestamp":"2019-11-10 19:29:54"}]
            2019-11-10 20:35:16.294 - debug: luftdaten.0 (28937) cleaned everything up...
            2019-11-10 20:35:16.413 - info: luftdaten.0 (28937) Terminated (NO_ERROR): Without reason
            2019-11-10 20:35:16.934 - info: host.Ubuntu instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
            2019-11-10 20:40:00.056 - info: host.Ubuntu instance system.adapter.luftdaten.0 started with pid 6119
            2019-11-10 20:40:04.292 - info: host.Ubuntu instance system.adapter.dwd.0 started with pid 6347
            2019-11-10 20:40:04.435 - debug: luftdaten.0 (6119) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2019-11-10 20:40:05.878 - debug: luftdaten.0 (6119) Objects connected to redis: 127.0.0.1:9001
            2019-11-10 20:40:05.922 - debug: luftdaten.0 (6119) objectDB connected
            2019-11-10 20:40:05.931 - debug: luftdaten.0 (6119) Redis States: Use Redis connection: 127.0.0.1:9000
              @SBorg Zeig mal bitte aus der /opt/iobroker/iobroker-data/iobroker.json den "objects" Abschnitt. Da ist ein Feld "connectTimeout" ... was steht da bei Dir?
              • SBorg
                @apollon77 Zwei Sekunden:
                 "objects": {
                    "type": "file",
                    "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
                    "host": "127.0.0.1",
                    "port": 9001,
                    "user": "",
                    "pass": "",
                    "noFileCache": false,
                    "connectTimeout": 2000,
                    "options": {
                      "auth_pass": null,
                      "retry_max_delay": 5000
                  @SBorg Ok, was auch default ist. Da wir beim Objects init jetzt einiges mehr tun reicht die Zeit vllt manchmal nicht, ich erhöhe das dann in der nächsten Version mal
                    Hallo liebe tester!!
                    Ich habe heute nochmal ein bissl Stopping mit Disconnects und sowas getestet und da war noch ein Bug drin. Weil wir dennoch gern morgen in Stable wollen brauche ich Dringe Eure Hilfe (nochmal).
                    Bitte 2.0.44 vom GitHub testen. Ich packe die nach positiven Feedback von Euch nachher noch ins Latest.
                    Gern auch wieder master/Slave Fälle testen ... alsoSlaves wenn master weg und so ... das wäre extrem super!!
                    • BBTown
                      BBTown @apollon77 last edited by BBTown
                      @apollon77 die v2.0.44 bekomme ich leider nicht (system is up to date)
                        A Former User @BBTown last edited by A Former User
                        @BBTown sagte in Test js-controller v2.0.x (GitHub):
                        @apollon77 die v2.0.44 bekomm eich leider nicht (system is up to date)
                        musst du mit npm install ioBroker/ioBroker.js-controller direkt von git ziehen. (erst in iobroker-verzeichnis..)
                          apollon77 last edited by apollon77
                          Und nochmal ich ... Wer die 2.0.44 VOR 19:19 installiert hat bitte nochmal ... da war noch ein Bug 😞
                          Aber jetzt schaut es bnei mir ok aus
                          BBTown dslraser ? 3 Replies Last reply Reply Quote 0
                          • BBTown
                            @apollon77
                            bei mir sieht alles unauffällig aus .... aber eben auch ein einfaches System (kein slave, file/file)
                            • dslraser
                              dslraser Forum Testing Most Active @apollon77 last edited by dslraser
                              @apollon77
                              Edit.....jetzt ging es doch weiter....
                                A Former User @apollon77 last edited by
                                @apollon77 hier alles ohne Probleme - habe nachdem alles auf der 44 war, nochmal die Clienthosts rebootet, um zu sehen, was der iobroker macht, aber er wartet und die clients haben sich sehr schnell connected.
                                Andersrum auch getestet, die clients warten schön bis der Masterhost wieder da ist.
                                  perfekt Danke!
                                  • SBorg
                                    Bis jetzt sieht es top aus, nicht mal beim hochfahren einen "objects-DB"-Fehler 👍 😎
                                    • dslraser
                                      dslraser Forum Testing Most Active @BBTown last edited by
                                      @apollon77
                                      Dito.
                                        Perfekt dann kommt es auf npm sobald die Kids im Bett sind. 😉
                                          SO, HIER IST ERST MAL SCHLUSS ....
                                          --> https://forum.iobroker.net/topic/26759/js-controller-2-jetzt-für-alle-im-stable
                                          mega Dank an alle Mitwirkenden !! War eine Super Zusammenarbeit.
                                          Ich lasse mal noch 1-2 Tage den Thread offen falls Fixes nötig sind ...
                                            An alle fleissigen Tester der 2.0 "damals" ... jetzt kommt die 2.2 und Eure hilfe wäre wieder super ... ---> https://forum.iobroker.net/topic/28139/beta-test-js-controller-2-2-x-github
                                            js-controller
                                            48
                                            1047
                                            268747
