Adapter: ebus
sudo telnet 192.168.178.84 8888
GET /data HTTP/1.0 // und 2x Enter eingegeben da kommt ein "ERR: command not found"
Na das sieht doch mal nicht so schlecht aus.. nur dass im Telnet auf Port 8888 natürlich ganz andere Komandos gelten.
Gib mal ein ? ein
Dann kommt bei mir:
usage:
read|r Read value(s): read [-f] [-m SECONDS] [-s QQ] [-d ZZ] [-c CIRCUIT] [-p PRIO] [-v|-V] [-n|-N] [-i VALUE[;VALUE]] NAME [FIELD[.N]]
Read by new defintion: read [-f] [-m SECONDS] [-s QQ] [-d ZZ] [-v|-V] [-n|-N] [-i VALUE[;VALUE]] -def DEFINITION
Read hex message: read [-f] [-m SECONDS] [-s QQ] [-c CIRCUIT] -h ZZPBSBNN[DD]*
write|w Write value(s): write [-s QQ] [-d ZZ] -c CIRCUIT NAME [VALUE[;VALUE]]
Write by new def.: write [-s QQ] [-d ZZ] -def DEFINITION [VALUE[;VALUE]]
Write hex message: write [-s QQ] [-c CIRCUIT] -h ZZPBSBNN[DD]*
auth|a Authenticate user: auth USER SECRET
hex Send hex data: hex [-s QQ] ZZPBSBNN[DD]*
find|f Find message(s): find [-v|-V] [-r] [-w] [-p] [-a] [-d] [-h] [-i ID] [-f] [-F COL[,COL]] [-e] [-c CIRCUIT] [-l LEVEL] [NAME]
listen|l Listen for updates: listen [stop]
state|s Report bus state
info|i Report information about the daemon, the configuration, and seen devices.
grab|g Grab messages: grab [stop]
Report the messages: grab result [all]
define Define new message: define [-r] DEFINITION
decode|d Decode field(s): decode [-v|-V] [-n|-N] DEFINITION DD[DD]
encode|e Encode field(s): encode DEFINITION VALUE[;VALUE]*
scan Scan slaves: scan [full|ZZ]
Report scan result: scan result
log Set log area level: log [AREA[,AREA]* LEVEL]
raw Toggle logging of messages or each byte.
dump Toggle binary dump of received bytes
reload Reload CSV config files
quit|q Close connection
help|? Print help help [COMMAND], COMMMAND ?Dann z.B. "find" oder "info" ... dann sieht Du schon mal was es gibt, und welche Werte es gibt...
Hallo
also ich habe jetzt mal
sudo telnet 192.168.178.84 8888 und dann Enter
? und dann Enter eingeben
und anschließend find eingeben.
Das war das Ergebnis
denke das ist ganz ok oder?
Ich muss dazu sagen, das meine Wärmepumpe nur am Strom angeschlosse ist, also noch nicht an der Heizung angeschlossen. Heizungsbauer hat noch keine Zeit gehabt, aber ich wollte den Ebus schon mal testen
Jetzt werden im IO Broker auch schon mehr Werte angezeigt.
Die Warmwassersolltemperatur habe ich auf 46°C eingestellt, wie kann ich die jetzt aus dem IO Broker raus verstellen?
Muss ich da was in die "cmd" Zeile eingeben ? Nur was?
Vielen Dank für die Hilfe
Hinten an Deinem Objekt ist ein Stift. Da drauf gehen und das Objekt auf Schreiben stellen. Könnte klappen.
ne .. klappt sicher nicht !
man muss das richtige write kommando in den cmd Datenpunkt schreiben..
mit Telnet anmelden, find..
dann die Treffer mit hwc (hotwaterCircuit) ansehen...
mit read -c hwc namedesobject kann man im telnet die werte auslesen...
und mit write - c hwc namedesobject Wert ... kann man die werte setzen (wenn es keine readonly sind)
wenn das dann im telnet klappt, und mit read verifiziert werden kann, dann muss dieses Kommando in den Cmd-Datenpunkt des ebus-Adapters... Der holt das zyklisch ab und schreibt es ...
Klappt nicht, stimmt. Es erschließt sich mir nur nicht, warum in den Einstellungen
"target telnet Port zum Schreiben von Daten" konfiguriert wird. -
weil der inhalt des Datenpunktes cmd "schreibend" an den ebus-daemon geht !
Habe so weit alles eingerichtet viel Werte auch raus gefunden. Leider hat die 620/3 keinen einzigen Wert als schreibend zugelassen. Kann noch nicht mal den WW Speicher in der Temperatur ändern.
kann es sein das man den Adapter bei einem Multihost System nicht auf einen Slave legen kann? Bekomme ich dann nicht zum laufen auf dem Host ohne Probleme.
@markus397 sollte eigentlich kein Problem sein, bei mir läuft ebus auf einem slave.. Hast du ein log von dem Problem?
ne wurde scheinbar gar nicht mehr gestartet. Im Log taucht nur auf das er beendet wurde, wenn man auf Neustarten klickt oder so. Aber danach passiert nix weiter. Habe es auch mit Neustarten versucht. Stand auch auf Debug.
@markus397 zeig doch bitte trotzdem mal das log...
Habe es gerade noch mal auf den Slave geschoben.
Wenn ich den Schedule manuell noch mal änder kommt wieder stop und die warn Meldung
host.raspberrypi 2019-11-16 21:40:54.630 warn stopInstance system.adapter.ebus.0 not scheduled host.raspberrypi 2019-11-16 21:40:54.630 info stopInstance system.adapter.ebus.0 host.raspberrypi 2019-11-16 21:40:54.629 info object change system.adapter.ebus.0 host.nanopct4 2019-11-16 21:40:54.610 info object change system.adapter.ebus.0 host.raspberrypi 2019-11-16 21:40:49.941 info object change system.adapter.ebus.0 host.nanopct4 2019-11-16 21:40:49.920 info stopInstance canceled schedule system.adapter.ebus.0 host.nanopct4 2019-11-16 21:40:49.920 info stopInstance system.adapter.ebus.0 host.nanopct4 2019-11-16 21:40:49.919 info object change system.adapter.ebus.0 -
@markus397 welche js-controller Version nutzt du? Läuft auf dem Raspi noch ein andere Adapter?
Ja da läuft aktuell der BLE Adapter der aber auch schon auf dem Host lief und JS ist Installiert: 1.5.14
Der ist auch grün? Bei mir kommt die o.g. Warnung, wenn ich den adapter stoppe und dann die "Zeitplanung" verändere...
Natürlich ist der grün^^. Wie gesagt sobald ich den stoppe oder neustarte usw. kommt das im log. Sonst kommt nix. Kein Fehler o.ä.
Ich habe mir die Ebus Platine für erden GPIO Steckplatz des Raspberry im FHEM Forum besorgt. Leider sind meine Linux Kenntnisse sehr rudimentär, deshalb die Frage ob mir ein User sein SD-Karten Image für meine Hardwarekonfiguration zur Verfügung stellen könnte. Vielen Dank im Voraus
Grüße und einen guten Rutsch ins neue Jahr -
@Knallochse wäre diese Frage nicht vielleicht eher was für das FHEM-Forum, wenn du dort die Platine her hast?
Er braucht ja schon für Iobroker das ganze, aber ein image kann ihn wohl keiner geben, aber als kleiner trost ich bin auch nicht fit in Linux und habe das hin bekommen. Wenn er uns erzählt was er für Hardware hat und wo was läuft bzw. laufen soll kann man ihn aber bestimmt ans Ziel bringen. Habe die gleiche Platine hier auch auf einen Raspi 3B+ am laufen.
Natürlich möchte ich die Daten im IoBroker verarbeiten und da wird mir das Fhem-Forum nicht weiter helfen. Ich habe nicht mal FHEM am laufen.
Mein IoBroker läuft als Docker auf einer Synology DS. Ich möchte den Ebus als „Bridge“ der Daten, wobei der R3+ keine weiteren Aufgaben übernehmen soll. Also nur Linux + Ebus Software.
