    4. [gelöst] regex
    [gelöst] regex
    • crycode
      crycode Developer last edited by
      Versuchs mal damit: /id="aqiPm10"\s+class="aqi">(\d+)<\/div>/
      Zum Testen: https://regex101.com/r/a41Fp3/1 🙂
        mike1976 last edited by
        Geht leider nicht.
        Das ist der Quelltext der seite:
        <!DOCTYPE html>
        <html lang="en">
          <head>
            <meta charset="utf-8" />
            <meta name="viewport" content="width=device-width, initial-scale=1.0" />
            <title>AQI</title>
            <script src="aqi.js"></script>
            <link rel='stylesheet' href='style.css'>
          </head>
          <body>
            <div class="container">
              <h1>AQI</h1>
              <p class='time' id="time"></p>
              <div class='aqi-container' id="containerPm25">
                  <div class='aqi-label'>AQI (PM2.5)</div>
                  <div class='aqi' id="aqiPm25"></div>
                  <div class='pm-label' id="pm25"></div>
              </div>
              <div class='aqi-container' id="containerPm10">
                  <div class='aqi-label'>AQI (PM10)</div>
                  <div class='aqi' id="aqiPm10"></div>
                  <div class='pm-label' id="pm10"></div>
              </div>
            </div>
          </body>
          <script type="text/javascript">
            getData();
            setInterval(getData, 60000);
          </script>
        </html>
        H crycode 2 Replies Last reply Reply Quote 0
          hans_999 @mike1976 last edited by
          @mike1976 said in regex:
          Geht leider nicht.
          Das schaut aber auch nicht so aus wie im Screenshot oben!
          Wo ist denn jetzt der Wert
          id="aqiPm10" class="aqi">9</div>
          geblieben?
            mike1976 last edited by mike1976
            der wird zwischen >< hinterlegt von diesem code:
            #!/usr/bin/python
            # coding=utf-8
            # "DATASHEET": http://cl.ly/ekot
            # https://gist.github.com/kadamski/92653913a53baf9dd1a8
            from __future__ import print_function
            import serial, struct, sys, time, json
            DEBUG = 0
            CMD_MODE = 2
            CMD_QUERY_DATA = 4
            CMD_DEVICE_ID = 5
            CMD_SLEEP = 6
            CMD_FIRMWARE = 7
            CMD_WORKING_PERIOD = 8
            MODE_ACTIVE = 0
            MODE_QUERY = 1
            ser = serial.Serial()
            ser.port = "/dev/ttyUSB0"
            ser.baudrate = 9600
            ser.open()
            ser.flushInput()
            byte, data = 0, ""
            def dump(d, prefix=''):
                print(prefix + ' '.join(x.encode('hex') for x in d))
            def construct_command(cmd, data=[]):
                assert len(data) <= 12
                data += [0,]*(12-len(data))
                checksum = (sum(data)+cmd-2)%256
                ret = "\xaa\xb4" + chr(cmd)
                ret += ''.join(chr(x) for x in data)
                ret += "\xff\xff" + chr(checksum) + "\xab"
                if DEBUG:
                    dump(ret, '> ')
                return ret
            def process_data(d):
                r = struct.unpack('<HHxxBB', d[2:])
                pm25 = r[0]/10.0
                pm10 = r[1]/10.0
                checksum = sum(ord(v) for v in d[2:8])%256
                return [pm25, pm10]
                #print("PM 2.5: {} μg/m^3  PM 10: {} μg/m^3 CRC={}".format(pm25, pm10, "OK" if (checksum==r[2] and r[3]==0xab) else "NOK"))
            def process_version(d):
                r = struct.unpack('<BBBHBB', d[3:])
                print("Y: {}, M: {}, D: {}, ID: {}, CRC={}".format(r[0], r[1], r[2], hex(r[3]), "OK" if (checksum==r[4] and r[5]==0xab) else "NOK"))
            def read_response():
                byte = 0
                while byte != "\xaa":
                    byte = ser.read(size=1)
                d = ser.read(size=9)
                if DEBUG:
                    dump(d, '< ')
                return byte + d
            def cmd_set_mode(mode=MODE_QUERY):
                ser.write(construct_command(CMD_MODE, [0x1, mode]))
                read_response()
            def cmd_query_data():
                ser.write(construct_command(CMD_QUERY_DATA))
                d = read_response()
                values = []
                if d[1] == "\xc0":
                    values = process_data(d)
                return values
            def cmd_set_sleep(sleep=1):
                mode = 0 if sleep else 1
                ser.write(construct_command(CMD_SLEEP, [0x1, mode]))
                read_response()
            def cmd_set_working_period(period):
                ser.write(construct_command(CMD_WORKING_PERIOD, [0x1, period]))
                read_response()
            def cmd_firmware_ver():
                ser.write(construct_command(CMD_FIRMWARE))
                d = read_response()
                process_version(d)
            def cmd_set_id(id):
                id_h = (id>>8) % 256
                id_l = id % 256
                ser.write(construct_command(CMD_DEVICE_ID, [0]*10+[id_l, id_h]))
                read_response()
            if __name__ == "__main__":
                while True:
                    cmd_set_sleep(0)
                    cmd_set_mode(1);
                    for t in range(15):
                        values = cmd_query_data();
                        if values is not None:
                            print("PM2.5: ", values[0], ", PM10: ", values[1])
                            time.sleep(2)
                    # open stored data
                    with open('/var/www/html/aqi.json') as json_data:
                        data = json.load(json_data)
                    # check if length is more than 100 and delete first element
                    if len(data) > 100:
                        data.pop(0)
                    # append new values
                    data.append({'pm25': values[0], 'pm10': values[1], 'time': time.strftime("%d.%m.%Y %H:%M:%S")})
                    # save it
                    with open('/var/www/html/aqi.json', 'w') as outfile:
                        json.dump(data, outfile)
                    print("Going to sleep for 5min...")
                    cmd_set_mode(0);
                    cmd_set_sleep()
                    time.sleep(300)
            es geht um einen sds011 sensor, habe das script direkt am pi hinterlegt.
            sicherlich würde es leichter gehen wenn ich den wert bei node-red einlesen würde.
            Einlesen klappt ja eigentlich auch,
            Bin aber leider zu blöd das ich den Sensor in sleep modus bekomme.
            Deswegen eigentlich der umweg über die web seite.
            Ausser du kannst mir veraten wie ich den sleep modus aktiviere und deaktiviere über node red.
            Hier die Node-red variate, wie gesagt der sensor ist verbunden und liefert auch die benötigeten werte, doch leider
            bekomme ich den befehl nicht hin das er für eine zeit in sleep modus geht 😞
            oder hast du eine idee wie der befehl aussehen müsste?
            • crycode
              crycode Developer @mike1976 last edited by
              @mike1976
              Wie @hans_999 schon geschrieben hat sieht der HTML Code jetzt anders aus, als in deinem ersten Post.
              Wenn die Zahl dann an der entsprechenden Stelle steht solle dazu dann dieser RegEx passen:
              /<[^>]*id=['"]aqiPm10['"][^>]*>(\d+)<\/\w+>/
              Siehe auch https://regex101.com/r/a41Fp3/2
              Der findet eine Zahl innerhalb eines beliebigen Tags (in deinem Code das div) mit der ID aqiPm10, unabhängig davon, ob der Tag noch andere Attribute hat oder ob " oder ' für die Attribute verwendet wird.
              Dein Screenshot sieht nach dem den Parser-Adapter aus. Ich bin mir nicht sicher, aber kann sein, dass du da den RegEx ohne die / am Anfang und Ende eingeben musst.
              Bezüglich Node-red kann ich dir leider nicht weiterhelfen.
                mike1976 @crycode last edited by
                @crycode
                Okay auf https://regex101.com/r/a41Fp3/2 geht es,
                doch leider will der Adapter nicht.
                habe es mit
                und ohne
                getestet, immer das gleiche. noch eine idee?
                  Homoran Global Moderator Administrators @mike1976 last edited by Homoran
                  @mike1976 sagte in regex:
                  Dann brauchen wir den "echten" quellcode.
                  mit dem geposteten kann ich das nicht nachvollziehen
                  Beim Parser gibt es den ein oder anderen feinen Unterschied im Vergleich zu regex101
                  Wahrscheinlich liegt es nur am Format.
                  Ich habe mal den folgenden Wert (10.50) genommen:
                  <!DOCTYPE html>
                  <html lang="en">
                    <head>
                      <title>AQI</title>
                    </head>
                    <body>
                        <h1>AQI</h1>
                        </div>
                            <div class='aqi' id="aqiPm10">10.50</div>
                        </div>
                      </div>
                    </body>
                      getData();
                    </script>
                  </html>
                  Und mit dem regex <[^>]*id="aqiPm10">(\d+\.\d+)<\/div> ausgelesen
                  Auch die genauen Einstellungen im Adapter wären interessant
                    @Homoran
                    testpi.dyndns-at-home.com:56000
                    habe ich mal freigeschalten. kannst direkt auf die webseite
                    Quellcode:
                    aqi.py
                    einstellungen von adapter habe ich oben einen screen gemacht. gibt ja nicht viele punkte
                    crycode 1 Reply Last reply Reply Quote 0
                      und das ist die export file des adapters:
                      system.adapter.parser.0.json
                      • crycode
                        @mike1976
                        Das Problem an der Stelle ist, dass der eigentliche Wert gar nichtdirekt im HTML Code steht, sondern per JavaScript aus der Datei api.json geladen wird. Versuch mal als URL http://192.168.1.241/api.json und als RegEx den: {"pm10":\s+(\d+(\.\d+)?)[^}]*}]
                        Das sollte dann jeweils den letzten (aktuellsten) Wert auslesen, egal ob es nun z.B. 9 oder 9.5 ist.
                        Beispiel: https://regex101.com/r/a41Fp3/3
                        Alternativ könnte man sicherlich auch über den JavaScript Adapter direkt die JSON-Datei laden und daraus dann den gewünschten Wert extrahieren.
                          @crycode said in regex:
                          Leider nein der aufruf geht auch nicht 😞
                          wenn ich im den link so teste bzw. öffne bekomme ich nur 404 not found
                          okay muss einsehen das es für mich leider nicht möglich sein wird den wert in iobroker zu bekommen.
                          Danke an euch allen für euer rasches bemühen.
                          lg mike
                          • crycode
                            @mike1976 ups, mein Fehler... das sollte aqi.json heißen. Dann müsste er die Datei auch finden 😉
                              @crycode
                              okay damit liest der adapter jetzt die seite ein, aber er will mir einfach keinen wert geben.
                              Hast recht auf https://regex101.com/r/a41Fp3/3 geht es einwandfrei.
                              Habe jetzt alle varianten gesteset im adapter:
                              boolean
                              number(.)
                              number(,)
                              string
                              JSON
                              eigentlich müsste der type ja nummer(.) sein, aber nicht um die bohne das er mir einen wert gibt
                                update bekomme jetzt einen wert 🙂
                                habe bei den einstellungen noch Num 4 drinnen stehen
                                geändert auf 0 und siehe da es kommt was rein.
                                ich weis das kling jetzt sicherlich frech aber wie könnte ich jetzt immer die letzten werte von
                                pm25 und seperat pm10 haben.
                                im moment ist es ja immer der von pm10.
                                Man Tausend dank erstmal 🙂
                                  Denke habe es hinbekommen
                                  geändert auf
                                  "pm25":\s+(\d+(\.\d+)?)[^}]*}]
                                    Danke das auslesen der "µg/m³" geht nun einwandfrei.
                                    Ist es eigentlich möglich den "AQI (PM2.5)" und den "AQI (PM15)" auch auszulesen?
                                    in http://192.168.1.241/aqi.json wird der ja nicht augelistet.
                                    Das sind die Webseiten auf den das script aufbaut:
                                    $ wget -O /var/www/html/index.html https://raw.githubusercontent.com/zefanja/aqi/master/html/index.html
                                    $ wget -O /var/www/html/aqi.js https://raw.githubusercontent.com/zefanja/aqi/master/html/aqi.js
                                    $ wget -O /var/www/html/style.css https://raw.githubusercontent.com/zefanja/aqi/master/html/style.css
                                    • crycode
                                      crycode Developer @mike1976 last edited by crycode
                                      @mike1976 Das sieht doch schon mal gut aus 🙂
                                      Direkt auslesen kannst du die beiden Werte nicht, da die ja nicht so in den Daten enthalten sind.
                                      Du kannst die Berechnung aber in ioBroker über ein Script nachbilden und die Ergebnisse dann eigene Datenpunkte schreiben.
                                      Dann wäre aber wieder der oben schon mal erwähnte Weg direkt die JSON-Datei zu laden die schönere und zuverlässigere Variante.
                                      Das Script dazu sieht dann so aussehen:
                                      // URL von der die JSON-Daten geladen werden
                                      const url = 'http://192.168.1.241/aqi.json';
                                      // Datenpunkte (javascript.0.XX)
                                      const objPm10 = 'aqi.pm10';
                                      const objPm25 = 'aqi.pm25';
                                      const objAqiPm10 = 'aqi.aqiPm10';
                                      const objAqiPm25 = 'aqi.aqiPm25';
                                      // Objekete anlegen, falls nicht vorhanden
                                      createState(objPm10, { name: 'PM10', unit: 'µg/m³', type: 'number', role: 'value' });
                                      createState(objPm25, { name: 'PM2.5', unit: 'µg/m³', type: 'number', role: 'value' });
                                      createState(objAqiPm10, { name: 'AQI (PM10)', type: 'number', role: 'value' });
                                      createState(objAqiPm25, { name: 'AQI (PM2.5)', type: 'number', role: 'value' });
                                      // alle 5 Sekunden die Daten laden
                                      schedule('*/5 * * * * *', loadData);
                                       * Funktion zum Laden der Daten.
                                      function loadData () {
                                        request(url, (err, res, body) => {
                                          if (err) {
                                            log(err.toString(), 'error');
                                            return;
                                          const data = JSON.parse(body);
                                          const pm10 = data[data.length -1].pm10;
                                          const pm25 = data[data.length -1].pm25;
                                          const aqiPm10 = calcAQIpm10(pm10);
                                          const aqiPm25 = calcAQIpm25(pm25);
                                          // Log-Ausgabe zum Testen
                                          // log(`pm10: ${pm10}, pm25: ${pm25}, aqiPm10: ${aqiPm10}, aqiPm25: ${aqiPm25}`);
                                          setState(objPm10, pm10, true);
                                          setState(objPm25, pm25, true);
                                          setState(objAqiPm10, aqiPm10, true);
                                          setState(objAqiPm25, aqiPm25, true);
                                       * Berechnung von AQI PM 2.5.
                                       * Quelle: https://github.com/zefanja/aqi/blob/master/html/aqi.js#L55
                                      function calcAQIpm25(pm25) {
                                        let pm1 = 0;
                                        let pm2 = 12;
                                        let pm3 = 35.4;
                                        let pm4 = 55.4;
                                        let pm5 = 150.4;
                                        let pm6 = 250.4;
                                        let pm7 = 350.4;
                                        let pm8 = 500.4;
                                        let aqi1 = 0;
                                        let aqi2 = 50;
                                        let aqi3 = 100;
                                        let aqi4 = 150;
                                        let aqi5 = 200;
                                        let aqi6 = 300;
                                        let aqi7 = 400;
                                        let aqi8 = 500;
                                        let aqipm25 = 0;
                                        if (pm25 >= pm1 && pm25 <= pm2) {
                                          aqipm25 = ((aqi2 - aqi1) / (pm2 - pm1)) * (pm25 - pm1) + aqi1;
                                        } else if (pm25 >= pm2 && pm25 <= pm3) {
                                          aqipm25 = ((aqi3 - aqi2) / (pm3 - pm2)) * (pm25 - pm2) + aqi2;
                                        } else if (pm25 >= pm3 && pm25 <= pm4) {
                                          aqipm25 = ((aqi4 - aqi3) / (pm4 - pm3)) * (pm25 - pm3) + aqi3;
                                        } else if (pm25 >= pm4 && pm25 <= pm5) {
                                          aqipm25 = ((aqi5 - aqi4) / (pm5 - pm4)) * (pm25 - pm4) + aqi4;
                                        } else if (pm25 >= pm5 && pm25 <= pm6) {
                                          aqipm25 = ((aqi6 - aqi5) / (pm6 - pm5)) * (pm25 - pm5) + aqi5;
                                        } else if (pm25 >= pm6 && pm25 <= pm7) {
                                          aqipm25 = ((aqi7 - aqi6) / (pm7 - pm6)) * (pm25 - pm6) + aqi6;
                                        } else if (pm25 >= pm7 && pm25 <= pm8) {
                                          aqipm25 = ((aqi8 - aqi7) / (pm8 - pm7)) * (pm25 - pm7) + aqi7;
                                        return Math.round(aqipm25);
                                       * Berechnung von AQI PM 10.
                                       * Quelle: https://github.com/zefanja/aqi/blob/master/html/aqi.js#L94
                                      function calcAQIpm10(pm10) {
                                        let pm1 = 0;
                                        let pm2 = 54;
                                        let pm3 = 154;
                                        let pm4 = 254;
                                        let pm5 = 354;
                                        let pm6 = 424;
                                        let pm7 = 504;
                                        let pm8 = 604;
                                        let aqi1 = 0;
                                        let aqi2 = 50;
                                        let aqi3 = 100;
                                        let aqi4 = 150;
                                        let aqi5 = 200;
                                        let aqi6 = 300;
                                        let aqi7 = 400;
                                        let aqi8 = 500;
                                        let aqipm10 = 0;
                                        if (pm10 >= pm1 && pm10 <= pm2) {
                                          aqipm10 = ((aqi2 - aqi1) / (pm2 - pm1)) * (pm10 - pm1) + aqi1;
                                        } else if (pm10 >= pm2 && pm10 <= pm3) {
                                          aqipm10 = ((aqi3 - aqi2) / (pm3 - pm2)) * (pm10 - pm2) + aqi2;
                                        } else if (pm10 >= pm3 && pm10 <= pm4) {
                                          aqipm10 = ((aqi4 - aqi3) / (pm4 - pm3)) * (pm10 - pm3) + aqi3;
                                        } else if (pm10 >= pm4 && pm10 <= pm5) {
                                          aqipm10 = ((aqi5 - aqi4) / (pm5 - pm4)) * (pm10 - pm4) + aqi4;
                                        } else if (pm10 >= pm5 && pm10 <= pm6) {
                                          aqipm10 = ((aqi6 - aqi5) / (pm6 - pm5)) * (pm10 - pm5) + aqi5;
                                        } else if (pm10 >= pm6 && pm10 <= pm7) {
                                          aqipm10 = ((aqi7 - aqi6) / (pm7 - pm6)) * (pm10 - pm6) + aqi6;
                                        } else if (pm10 >= pm7 && pm10 <= pm8) {
                                          aqipm10 = ((aqi8 - aqi7) / (pm8 - pm7)) * (pm10 - pm7) + aqi7;
                                        return Math.round(aqipm10);
                                      Die beiden Funktionen calcAQIpm25 und calcAQIpm10 sind direkt aus der aqi.js übernommen. Ich habe dabei lediglich den Rückgabewert angepasst, sodass immer eine Zahl ohne Nachkommastellen zurückgegeben wird.
                                      Die Daten sind dann unter javascript.0.aqi.* verfügbar. 🙂
                                        @crycode
                                        Ähhh... Was soll ich sagen ausser 1000 mal Danke.
                                        Das funktioniert einwandfrei 😄 😄
                                        Hatte die hoffnung schon aufgegeben.
                                        Kommer leider aus der SPS welt und script mässig ein kompleter noob.
                                        Danke nochmal hast mir einen riesen schritt weitergeholfen, jetzt muss ich nur noch eine vernünftige Wochenzeitschaltuhr für die Vis finden.
                                        GLG Mike
                                        PS: Danke für deine Zeit und Hilfe
                                        communication
                                        1034
